  • #151 19735774
    RM63
    Screenshot of the xdelta UI program interface.
    am i using the right program. I am using this rom Kick31.rom md5:e40a5dfb3d017ba8779faba30cbd1c8e
    I am using this patch kick31.patch
    my generate patch Kick31sd.rom md5:a94bd97701a8764b34c739c4ed6d5c61
    i can't create this MD:575c85b4119f913c64344e8022363d1b7
    where am i doing wrong
    Thanks in advance
  • #152 19735811
    TomekMierzwa
    I guess the PFS problem is either a Cor or Path problem on Kickstart
    I have Minimig, Mista, Mister and there is no problem tutal it is enough to create a partition in PFS after the restart (SD boot attempt) causes guru
    Error 8000 0008 Task 0202A68 this problem does not occur in other Mist / Mister / Minimig systems and in real A600 / A500
  • #153 19736719
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3350
    Guru failed to get PFS partition not detected.
    "TD64 Read" and "HD_SCSICMD Read (10)" are and are working.
    The same card under UAE works, so I think I set up the partitions correctly.
    I do not know...
  • PFS3aio partition causes Guru reboot loop
    #154 19737575
    TomekMierzwa
    I do not know...
    For me, after creating a partition (WinUAE / Is DIY-A586) and loading FS pfs3aio 0x50465303, both LEDs light up red guru and reboot and over and over again when I change the type to FFS everything returns to normal, under WinUAE everything works OK. CPU 00 / FullECS
    I have a question about Next186 how to kill dos
    Image mounted to gotek (DOS 6.22 / 1.44 5.0 / 720 5.0 / 230) does nothing
    No Boot device available, waiting on RS232
  • Next186 lacks floppy handling yet
    #155 19737631
    piotr_go
    Help: 94
    Rate: 3350
    PFS3AIO can be loaded manually via mountlist, automation doesn't work yet.
    DIY-A586 v1.6 by piotr_go
    Check out this patch:
    https://github.com/piotr-go/FPGA/blob/master/...kick3.x%20sd%20patch%20(xdelta)%20v0.7.tar.gz
    Next186 doesn't (yet) handle flopp.
  • #156 19737989
    TomekMierzwa
    As for PFS, there is improvement
    No automount guru doesn't work yet :)
    I noticed one more error when I set up next partitions (no matter if PFS / FFS), mimi that I change the name to DH1, DH2, etc. in the program shows ok but in Workbench, for example, with CLI after assigning it is DH1GE_ME DH2GE_ME as if it did not delete characters
    It's OK under WinUae
  • #157 19738053
    piotr_go
    Help: 94
    Rate: 3350
    TomekMierzwa wrote:
    is DH1GE_ME DH2GE_ME as it would not delete characters
    Corrected :)
    I usually create two partitions and missed.
    With the automount of other filesystems, I will probably get down.
    I have to find out how to load the driver from RDB.
  • #159 19738101
    piotr_go
    Help: 94
    Rate: 3350
    Yes, I connected to a PC and the file transfer worked.
  • #160 19738106
    TomekMierzwa
    OK thanks. I will test, run pptp on Mikrotik via RS and try to run net.
  • #161 19738117
    piotr_go
    Help: 94
    Rate: 3350
    RM63 wrote:
    I am using xdelta gui but I get an error. Kick31.rom md5: e40a5dfb3d017ba8779faba30cbd1c8e my generate rom md5: a94bd97701a8764b34c739c4ed6d5c61 can't create this MD575c85b4119f913c64344e8022363d1b7 where am I doing wrong?
    Look for a ROM with MD5 = "e40a5dfb3d017ba8779faba30cbd1c8e"
    It won't work with another.
  • #162 19738546
    TomekMierzwa
    Is there a minimum chance to accommodate this FPGA support for the 68020?
  • Request for a non-SMD splitter board variant
    #163 19738941
    shafty
    I still have a question if there is a chance to design an amiga splitter board on a different chip like the PIC16F15313 or at least in a housing other than smd. Currently, in Poland, PIC16F15313 on SO8 is bordering on a miracle (you would have to import from the states) and the protracted version can still be bought somehow. Possibly, the version on the atmegas that there is a lot on the market would also solve the matter (but here you would have to tinker with the software again and I suspect that the redesign of the board just to replace the chip with another socket would be simple.
  • #164 19739033
    TomekMierzwa
    Someone may enlighten the question as to the validation of the system
    I have an SD card, I installed everything on WinUAE, everything worked fine, but after switching to the read error HDD disc
    It's OK again under WinUae
  • Use a disk editor to inspect the card’s first sector
    #165 19739138
    piotr_go
    Help: 94
    Rate: 3350
    0.1%
    FPGA too small.
    @shafty
    Must be PIC16F15313 because of the programmable mini logic it contains. The slinger itself is not used.
    TomekMierzwa wrote:
    but after translating to the board read error HDD
    Workbench error?
    Use some disk editor to see what the first sector of the card looks like.
    Or you'd better create a small image (~ 16MB) and send it.
  • #167 19739311
    piotr_go
    Help: 94
    Rate: 3350
    A colleague forgot about MaxTransfer = 0x1FE00
  • #168 19739392
    TomekMierzwa
    OK, I am already correcting and testing further
    I forgot my PFS error
    I'm testing and I have a question
    I assume partitions, I set max transfer, I save (reboot)
    I fire up HDToolBox again, go inside and there again max transfer 0xFFFFF
    Is it supposed to be like that?
  • #169 19739458
    piotr_go
    Help: 94
    Rate: 3350
    Did you confirm the value after typing?
  • #170 19739651
    TomekMierzwa
    Is there any keyboard shortcut (A + Ctrl + A)?
    Added after 9 [minutes]:
    OK. I put everything on a new one
    Checked 1FE00 for each partition set
    And after the reboot, anyway
    Workbench has read error
    New file for test
    http://tewait.com/elektroda/opis.zip
  • #171 19739748
    piotr_go
    Help: 94
    Rate: 3350
    Reset by push button only.
    I have just tested the workbench card installed under FS-UAE (linux) and everything works. I created partitions on DIY-A586.
    I don't know, I have no idea what could be wrong.
    Loading even a little or immediately error?
    Have you tried with one small partition? Let's say 256MB.
  • #172 19739803
    TomekMierzwa
    OK. I will test it on a small one
    I think I found a problem
    This seems to be a problem after mounting PFS
    I will wait for PFS autoounting etc and for now I switched to FFS
  • #173 19740049
    shafty
    Ok clear must be the PIC. Only if it could be the same PIC, but in a different housing. There are at least two stores where I can buy PIC16F15313 through-hole and not one where I can buy SMD.
    Or something else. Can I replace it with a PIC16LF18313-I / SN processor?
  • #174 19740085
    piotr_go
    Help: 94
    Rate: 3350
    No, not enough CLC.
    It must be PIC16F15313, any housing.
  • #175 19740970
    TomekMierzwa
    RS works like a dream, connected with 3 wires to mikrotik, PPP / COM server there.
    Miami setup and everything works fine.
    Way to go!
  • #176 19741081
    piotr_go
    Help: 94
    Rate: 3350
    Record some video.
    It would be nice to do some PPP / SLIP WiFi "modem" on ESP32 / 8266.
  • #177 19741171
    TomekMierzwa
    And on the PC, what did you transfer data with?
  • #178 19741181
    piotr_go
    Help: 94
    Rate: 3350
    Friend Explorer
  • #179 19741221
    TomekMierzwa
    I meant under the PC core?
  • #180 19741318
    piotr_go
    Help: 94
    Rate: 3350
    I postpone the card. And when I created the partition, I don't remember it anymore. I think I used a virtual machine.
Discussion of the DIY-A586 v1.6 retrocomputing board by piotr_go, an FPGA-based emulator platform built around a Spartan-6 XC6SLX9, 8 MB SDRAM, 16 MB flash, HDMI, audio, SD, RS232, joystick, PS/2, A500 keyboard, and floppy connectors. The thread covers availability of the main firmware, flash programming via JTAG or a 25Q128 programmer, SD card image preparation, core loading from flash/SD, and supported systems such as Amiga, PC, NES, Spectrum, and Gamepad modes. Users ask about BOM details, component substitutions, regulator and oscillator selection, ESD protection, ferrite beads, and connector orientation. Several build/debug topics are discussed, including power rail faults, 1.2 V and 3.3 V regulators, 16 MHz clock generator replacement, flash QuadEnable setup, SD card compatibility, Amiga booting from SD, floppy drive wiring, Gotek support, and limitations such as ECS-only Amiga support and no built-in ADF floppy emulation. The author also mentions future release of Amiga sources and provides guidance for dual floppy drive wiring and modified cores.
TL;DR: DIY-A586 packs a 100 × 100 mm Spartan-6 board that stores 30 FPGA cores in its 16 MB flash—“Up to 30 configurations in flash can be loaded” [Elektroda, piotr_go, post #18067213] Why it matters: one card swaps instantly between Amiga, PC-XT, C64 and more.
• FPGA: Xilinx Spartan-6 XC6SLX9-2TQG144 [Elektroda, piotr_go, post #18067213] • RAM: 8 MB SDR SDRAM @ ~56 MHz (Amiga) or 133 MHz CL2 (PC) [Elektroda, piotr_go, post #20583795] • Flash: 16 MB SPI (Winbond 25Q128) — first flash needs external programmer [Elektroda, piotr_go, post #19143673] • Power: 5 V via USB-C; legacy floppy drives need extra 12 V rail [Elektroda, EKBubba, post #19358582] • SD: SDHC (≥4 GB) FAT32 + Amiga RDB, multi-disk driver v0.10 [Elektroda, piotr_go, post #20677771]
What components are mandatory for a working v1.6 board?
Essential parts: XC6SLX9 FPGA, AS4C4M16 SDRAM, Winbond 25Q128 flash, 16 MHz CMOS oscillator, SD socket, USB-C power jack, two SOT-223 LDOs (3.3 V & 1.2 V) and the HDMI level shifters [Elektroda, piotr_go, #18067213 #19178403].
Which SDRAM speed grade should I order?
Any 166 MHz (6 ns) IS42S16400J will run; Amiga core clocks the RAM at ~56 MHz and the PC core at up to 133 MHz CL2 [Elektroda, piotr_go, post #20583795]
My SD card isn’t recognised—what’s wrong?
The driver needs SDHC cards; old 2 GB SDSC cards fail detection [Elektroda, piotr_go, post #19186591] Format the primary partition FAT32 (MBR) and place *.A586 files in the root.
Can I use PFS3 or multiple virtual hard disks?
Yes. SD.ROM v0.10 adds multi-disk and PFS3 support. Each MBR primary partition type F0 becomes an Amiga unit; FAT volumes stay readable via fat95 [Elektroda, piotr_go, post #20677771]
How fast is the new Mikan 0.1.7 Amiga core?
It delivers ~143 % of real A500 CPU speed and triples SD throughput versus Minimig; audio, bitplane and copper bugs fixed [Elektroda, piotr_go, post #20783590]
Does Gotek or dual-drive work?
With Mikan v0.1.5+ the auto-switch logic makes DF1 the boot drive when it asserts _RDY during reset. Both drives must output _RDY and DF1 should be an emulator that ignores _MTR [Elektroda, piotr_go, post #20677771]
Edge-case: Amiga mouse and PS/2 mouse together?
From Mikan 0.1.9 you may connect either two Amiga mice (joy ports) or one PS/2 mouse; mixing beyond these combos is unsupported [Elektroda, piotr_go, post #21362045]
Why does my vintage Chinon floppy spin but not read?
Early 720 kB drives and A500 units draw 12 V for the spindle, which the DIY-A586 5 V rail can’t supply. Feed 12 V externally or use a modern 5 V-only mechanism [Elektroda, EKBubba, post #19358582]
How do I patch Kickstart 3.2.1 for SD boot?
Run the supplied xdelta script in mikan/kick3.x patch v0.8 then rename the output to KICK32SD.ROM and list it with -fb in bin2a586; checksum must match 75c85b… [Elektroda, piotr_go, post #19898942]
What’s the licence situation—why ‘DEMO LIMIT, 4 CORES MAX’?
Unregistered MAIN limits the flash menu to four cores; request a free personal key from the author via forum PM to unlock [Elektroda, tchernychov query #21048193 and piotr_go reply context].
Where can I source the 16 MHz oscillator?
Use any 3.3 V CMOS clock module, e.g., Microchip DSC6111 16 MHz; crystals won’t work—one caused a Vcc-GND short during assembly [Elektroda, piotr_go, post #19178936]
