SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 506025 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • #811 19475708
    pawelstr147
    I have a question about the maximum power of the Sofar KTL-X 8.8 inverter generator. Some offers show 9,600W and others 11,000W. Are there two different models of inverters?
  • #812 19475811
    3301
    Help: 224
    Rate: 868
    In many cases, especially as a south-facing installation, 9600 is too much, but actually in one of the cards they give 11 kW. There is one inverter and there are several cards.
  • #813 19475983
    toolpusher
    Help: 35
    Rate: 210
    Do you think that when you connect 12kWp or 13kWp, something will happen? These are indicative data. It's important to keep an eye on the tensions and currents on the strings.
    The inverters from 8.8 to 11 are the same inverters, but the output power programmed by the manufacturer is different, which, by the way, can be easily changed by hardware.
  • #814 19476228
    pawelstr147
    If indicative, no problem, the inverter has one MPPT 11A input, so you can easily give more than 9600W. I thought so too, but wanted to be sure.
  • #815 19478070
    SilverX
    Rate: 9
    Rather, you change the settings in the software with jumpers ... In fact, you had less efficiency when you connected one string in parallel to two MPPTs?
  • #816 19479193
    toolpusher
    Help: 35
    Rate: 210
    I did not make such measurements because they are difficult to do and the difference is probably less than 1%
  • #817 19480137
    jareksz
    Rate: 15
    Hello, I am asking for advice, I am waiting for the replacement of the Sofar solar 11 ktl-x inverter for 26 days by the service for a new one and still do not know when the new inverters will be
    the installer offered me to replace the inverter with Foxess T10, agree to this replacement or still wait for the Sofar inverter?
  • #818 19480153
    prose
    Level 36  
    Help: 173
    Rate: 850
    And from scratch the papers in ZE.
  • #819 19480248
    toolpusher
    Help: 35
    Rate: 210
    Additionally, when you got the "My Electricity" subsidy, you cannot change the inverter for 3 years.
  • #820 19480375
    jareksz
    Rate: 15
    I haven't submitted papers for "My Electricity" yet because the inverter has died 35 days after it was installed.
  • #821 19480415
    toolpusher
    Help: 35
    Rate: 210
    SOFARSOLAR Poland carries out warranty claims in accordance with the procedure
    1) 14 days from the date of the complete warranty claim
    If the inverter does not work and does not process electricity, SOFARSOLAR Poland
    undertakes to consider the complaint within 14 working days from the date
    receipt of a complete notification. When it is necessary to replace the inverter with a new one
    it will take place no later than within 14 working days from the positive consideration of the application.
    If it is necessary to replace spare parts with new ones, a service visit will take place
    not later than within 14 days from the date of positive consideration of the application.
    I think you are entitled to some compensation. Another thing is how to enforce it.
  • #822 19480437
    grzes601
    Rate: 8
    The FOXESS T10 is a completely different world. Full MPPT power, not low power as in SOFAR.
    With the FOX inverter you will achieve more power when your MPPT are looking in different directions.
    You have the documents for FOX in the link;
    https://sklep.sunprofi.pl/foxess/290-fox-t10.html
    After tasting FOX, I will never take SOFAR again
    If you want to get to know sofarsolar poland, go to google and see the great sofara service (fries are missing)
  • #823 19480443
    jareksz
    Rate: 15
    They do not have inverters and they do not know when they will have them, Sofarsolar Poland does not compensate for exceeding the 14-day deadline (replacement was decided 26 days ago). My panels are for decoration.
  • #824 19480454
    toolpusher
    Help: 35
    Rate: 210
    I think that you could do something with a lawyer, only who wants to kick for a few zlotys. The fact that the Sofar company gives nothing does not matter. You are losing real money after these 14 days.
  • #825 19480476
    grzes601
    Rate: 8
    FOX parameters are in the given catalog card
    • T-Series-PL_HQ_12_.pdf (246.32 KB) You must be logged in to download this attachment.
  • #826 19480483
    toolpusher
    Help: 35
    Rate: 210
    Go to him and give him a presentation. As for me, you are an ordinary beater because you have already run into Sofara once. Similar to my colleague on D.
  • #827 19480501
    grzes601
    Rate: 8
    I will not defend a company that treats customers like cannon fodder for no reason.
    I work on 10000TL-Sx, 11KTL-X, T15 and I have a comparison practically online.
    Go to the sofara service in Warsaw, watch the dead bodies on the walls with the ladies and talk about technical matters. Then write what it was like on the trip.
  • #828 19480697
    prose
    Level 36  
    Help: 173
    Rate: 850
    For me, the sofar works at full power on each MPPT, I do not know what you mean by poor power? The poor is the Foxss measure.
  • #829 19480707
    grzes601
    Rate: 8
    What I mean is that in the 11KTL-X the maximum power of one MPPT is only 6200W
  • #830 19480737
    Cytro12
    Help: 47
    Rate: 303
    This Foxess is aggressively entering the market, someone knows how it works, at what temperatures, efficiency, what software, etc. because you know these technical data, they are all great on paper.
  • #831 19480742
    3301
    Help: 224
    Rate: 868
    There are also cards from 8800 as well as those where there are no restrictions on individual mpp.
  • #832 19480765
    prose
    Level 36  
    Help: 173
    Rate: 850
    But what's the problem you connect the two inputs in parallel and you have 12400W.
  • #833 19485841
    ja_pizgam
    Can anybody give me some software between v2.50 and 2.90 for KTL-X 5.5? I tried to update to version 2.90 but it crashed with the ARM file and grounded my inverter.
  • #834 19485855
    3301
    Help: 224
    Rate: 868
    Another example that not everyone will work with the high version, for what purpose do you want 290? what will change? 220 is the most stable and it solves the problem with the power and I can give up this one.
  • #835 19485888
    ja_pizgam
    The version with the inverter is 2.50, I had a problem with the inverter turning off with a sudden jump in the voltage of the panels (as the sun was coming out from behind the clouds, even on a cloudy day) and I contacted the installer and confirmed that the problem occurs on this version and sent a newer version I tried to update only today and there was a problem, and the installer has turned off the phone on the weekend, so I'm looking for help here so as not to lose 2 days of production.
  • #836 19485898
    3301
    Help: 224
    Rate: 868
    If it was as you wrote "the problem with the inverter turning off with a sudden jump in voltage of the panels", what errors appeared? and what would they be related to? with the voltage from the modules or with the current?
    Maybe you have too many modules in the string or these modules have an I mpp greater than 11A.
    If you do not want to lose, load 220, then you will re-upload what you want and maybe it will not lock, I can withdraw.
  • #837 19485901
    prose
    Level 36  
    Help: 173
    Rate: 850
    Maybe exactly what problem do you have, what do you mean?
  • #838 19485932
    ja_pizgam
    The problem is currently blocked inverter because the ARM file from version 2.90 has not updated at all (DSP1 and 2 are in version 2.90 already), I do not know what exactly was the problem because after reporting to the company what was installed, the first question was whether I have version 2.50 because it already had a dozen or so reports from this version, I had one, so he sent me a newer firmware, due to lack of time, I wanted to update today, but there was a problem and I cannot contact the company (phone is turned off), so probably only on Monday I will call them and I don't want to waste 2 days production, so I want to go back to a lower version, or at least to this 2.50, and if it can even be this version 2.20, so be it.
  • #840 19486012
    ja_pizgam
    I only see version 2.90 here, but the problem is the same on ARM crashes error, I tried 4x intermittently, so I guess my inverter hardware version (1.00) doesn't support this version.
✨ Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
