SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 506040 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • #871 19543590
    stev-an
    Level 19  
    Rate: 56
    @ cygan32 Welcome! Have you tried switching jumpers? I, in turn, would try down to 3 kW. If you look there, see what the setting is for 3 kW. Best regards.
  • #872 19543889
    cygan32
    And you could put a photo of the jumpers when you had them set to 3.3, I have urgent duties for now, but within 2 weeks I will take a photo of mine and try to change it
  • #873 19590457
    igorelectronics
    Rate: 19
    Does anyone have archived 2.2 firmware for the single-phase Sofara 1-3K TL G3?
    If so, I would ask for sharing.
  • #874 19590473
    m2tk
    Can anyone confirm whether the new SOFAR 12 KTLX - G3 series is actively or passively cooled?
    According to the documentation it is "Natural" which would suggest no fan, in Features it is "Natural cooling, no fans, low noise".
    In my case, the wall begins to hum when the production load is higher, the noise is like a fan.
    If it has do 8.8 and 11 KTLX G3 also have?
  • #875 19590496
    Janusz_kk
    Help: 224
    Rate: 1466
    It is the chokes that are buzzing.
  • #876 19590529
    m2tk
    They are so buzzing that it can be heard in the next room?
    The specification is 40dB, which is quite quiet.
  • #877 19590905
    Janusz_kk
    Help: 224
    Rate: 1466
    But these inverters are hermetic and have no fans, so apart from chokes there is nothing to hum. You don't have a contactor in the switchboard somewhere?
  • #878 19591327
    m2tk
    Are we both talking about this new series with a circular display (12 KTLX - G3)?
    If there was a fan, it would be somewhere inside the case.
    The sound is definitely coming out of the inverter.
    You can hear it for a moment during the start-up, when there is the 'Check' phase - some relays are clicking and it is heard as if the fan started for 1-2 seconds.
    My observations show that the hum starts with the production of approx. 3kW, and at 6/7 its volume / frequency increases. On the other hand, when it starts, it can be heard even with low (
  • #879 19591534
    DEFENCE
    Rate: 46
    If there was a fan there would have to be air exchange openings. Otherwise the fan wouldn't make sense.
  • #880 19598857
    berek20
    Rate: 15
    I wonder if after changing the power on the jumpers, in the event of a failure, there will be a trace in the inverter, e.g. on the card
  • #881 19599188
    marwi123
    The entire production is stored on the memory card
  • #882 19603625
    marinowo
    I have had a 4.4KTL-X solar sofar for several days. Installation founded by a company that has been on the market for many years.
    Question about the inverter ... the inverter is already connected to the router used for several days, all data is visible on the phone, I mean mainly the hourly production on a given day. Charts are OK. The internet connection is interrupted ... e.g. due to a failure at the internet provider. No internet for 3 days, then the internet comes back, should the inverter not send all overdue data to the server after recovering the link so that everything is visible on the phone? In my case, it sent only the total amount of energy produced on a given day, while the detailed hourly production with the graph is not visible. Have these details been lost yet? It seemed to me that all data, including detailed data, should be saved in the device's memory for at least a few days. I am asking for info, how is it with others?
  • #883 19603635
    iborkim
    Rate: 33
    That's how it works. You may find more detailed information on your memory card.
  • #884 19614634
    Kejsiq
    Hello gentlemen, I had version 2.01 and there was a problem with production jerking during the day, I updated to version 2.2 provided in the links earlier, but after the update I only have mandarin bushes, I cannot change the language because the inverter asks for the password 0715,0001 they do not go further I read the whole thread and no advice helps.
    I can not download any higher version from the page that is given a few posts below (it simply transfers to the manufacturer's website), would someone be polite and send any version with Polish / English?
  • #885 19614819
    jarczydło
    Rate: 19
    Post # 853 language PL is 100%
  • #886 19614834
    Kejsiq
    I am not saying that it is not there, but the inverter asks for a password after entering 01-10 (language change) and does not accept 0001, 0715. That's why I have a problem with the language.
    The region is set to Germany (by default, it was after the update) after the SN number 4 digits China
  • #887 19615686
    radar1967
    I had the same problem as my colleague Kejsiq, after updating the software Chinese language, the letter C in the serial number. On the PL website, I learned that it is an inverter for the Chinese market and it has no warranty in Poland and the European Union and should not be sold in Poland, but it has a regional lock that starts when you try to change the language or update the software, of course the PL service will not help. The seller from whom I bought the inverter informed me that of course I have a 5-year warranty with him, but he will not help anything for a regional blockade. You need a one-time code with four digits or 10,000 combinations that will only work for one day. So I decided to try to find this code and I did it, it took me 7 days, about 1.5 hours a day, I started with 0000 .... etc. My code is 4142 works only on May 25, 2021, you can try it. For the sake of simplicity, I will add that my serial number has two digits four, maybe it's a hint in the search. I would like to add that I have already changed the software twice and each time after the update the Chinese language, the date changed to 05/25/2021 the code and the language is Polish.
  • #888 19615705
    Kejsiq
    Just tell me if the upgrade to a higher version also ends in a fiasco and mandarin madness?
    Tomorrow, when the sun rises, I will change the date and A yours and use this code?
  • #889 19615729
    radar1967
    Every software change up or down is a Chinese bush for me.
  • #890 19615898
    studniarz
    Help: 23
    Rate: 179
    radar1967 wrote:
    On the PL website, I learned that it is an inverter for the Chinese market and it has no warranty in Poland and the European Union and should not be sold in Poland, .......
    radar1967 wrote:
    The seller from whom I bought the inverter informed me that of course I have a 5-year warranty with him, but .......
    By the way, I am curious how the certificates for these "versions for the Chinese market" really relate to the European reality .... :)
    Regards.
  • #891 19616061
    radar1967
    In my opinion, the certificates refer to individual groups of inverters, there are no serial numbers of inverters in them. I would like to add that I know a bit about electronics and I supervise two identical Sofar 5.5KTL-X inverters, one for China and one for Europe, I assure you that both are identical inside, the difference is the price of PLN 1000 in favor of the Chinese, so it is rather about the profits of European distributors.
  • #892 19616300
    Michalux
    Rate: 15
    If anyone was interested, I was able to match the Sofar's K-TLX data through the LSW-3 logger (WiFi S / N 17xxxxxx module).
    Python script polls LSW-3 and receives data issued by modbus, also all data sent to PVMonitor is available locally :D
  • #893 19616466
    zygzak
    Rate: 12
    I understand that to read data you need to be in the inverter network, this AP_xxxx?
  • #894 19616956
    Michalux
    Rate: 15
    Not necessarily in AP _..., but you have to be on the same IP network.
    So e.g. in the same WiFi network to which the WLS-3 module is connected.
  • #895 19619756
    slonina
    Rate: 8
    I will also provide a link to the repository for those interested:
    https://github.com/MichaluxPL/Sofar_LSW3
    Thanks for sharing, this app does a great job with the LSW-3 Series 17 datalogger. Only the "inverter_sn" configuration is not very intuitive, because it is not about the inverter number but the LSW-3 datalogger number.
    Previously, I read the curl production from the datalogger's web interface in a primitive way, now there is access to everything including string and phase voltages / currents and even reactive power, so you can easily send more data to PVmonitor. Is there a description of the names of individual variables used in the PVmonitor service somewhere on the forum (F1, F2 etc.)?
  • #896 19619773
    scorpion26
    Anyone have 3-5 KW inverter for sale?
  • #898 19620062
    Michalux
    Rate: 15
    True :)
    I will add the relevant info to the description of config.cfg :)
    A version that allows data export in Prometheus format should be available soon ;)
  • #899 19621049
    Kejsiq
    Returning to my topic and blocked in Chinese, the main manufacturer has easily provided the code to change the language, my number is 5100
  • #900 19621171
    radar1967
    You can further describe the topic of how you got the code from the manufacturer, I understand that you wrote to China, to what address. I suspect many people would benefit from this information.
✨ Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
