  • Built a class A headphone amplifier with three blocks: symmetrical power supply, uPC1237HA headphone protection/delay, and stereo power stage.
  • The supply uses LM723 and LF357 to stabilize ±21V, while the power stage uses LME49860, 2SK170 BL JFETs, and medium-power transistors.
  • The amplifier runs at about 38mA per transistor at 21V, with 4 × 4700uF filter capacitors and current limiting set to 0.3A.
  • It delivers very high gain, low noise, and strong headphone protection, but the whole unit warms up heavily and the heatsink is too weak.
  • Class D seen as unsuitable for headphone amps
    #31 19392006
    tytka
    Help: 8
    Rate: 1841
    popiol667 wrote:
    My title mate, give me some convincing arguments
    What do you mean, buddy?
    You're picking on because I found out that:
    tytka wrote:
    In my opinion, class D for headphones is more of a joke (unless on the phone).
    tytka wrote:
    On a preliminary comparison, yes, yes. However, to choose an amplifier that suits me sonically; however, I prefer it additionally
    your listening experience. Unfortunately, the parameters alone do not say everything about the sound.
    So I answer:
    - Yes, for me it makes no sense to build a class D headphone amplifier. The headphone amplifier generates low output power, so you can go ahead and make it in a less efficient class. The more that in such an "uneconomical" class it is quite a simple device.
    In general, I personally see class D in battery-powered equipment and in loudspeakers in large rooms and stages.
    - This is how I can hear the difference in the sound of amplifiers and I think a lot of people can do it (though probably not in the way you think).
    I sometimes repair an amplifier. After I fix it, I like to listen to one or two albums with it. I would like to point out that in a room whose acoustics I know well from everyday listening, and on speakers that I listen to on a daily basis, During such listening sessions, I often hear a certain difference in the sound between this amplifier and my private one, which I use every day. I just listen to an album that I know, which I have listened to many times on my own equipment, and during such listening (not listening too forcefully) I hear some differences in the exposure of certain sounds.
    That's the way it is, and I feel good about it. What do you think about it is your business.
  • Need for standardized blind audio tests
    #32 19392102
    tata30
    Rate: 235
    I share the opinion of the previous speaker. Little acoustic nuances in a well-known listening room ... are very much audible. A class "d" headphone amplifier ... a joke like my friend's ashes. But I will tell you that more than once I have wanted to somehow standardize these "blind" tests of audio equipment ... they would expose unfair treatments bought for a "T-shirt" or "cup" of advisors ... amplifying "better equipment in the listening rooms ...
  • Blind test needed to verify audible differences
    #33 19392224
    popiol667
    Help: 6
    Rate: 140
    To find out that "I can hear the differences" you should perform the A / B / X test. Otherwise, you could write that "I think I hear".
    As long as you know which amplifier is playing, you can only write: "I think I hear some differences many times".
    No, it is not. Either poor hardware parameters, different conditions in which the compared hardware plays, or self-suggestion. Your statements contradict serious scientific research of human hearing. You make comparisons in a way that gives the possibility of self-suggestion and on the basis of them you draw erroneous conclusions "I hear differences".
    First of all, you need to check if they exist - with a blind test.
  • #34 19392296
    Piotrek608
    Rate: 18
    A lot also depends on the headphones themselves .. So what if someone will buy or make a very good quality amplifier and also buy some low-shelf earpieces. Then neither golden resistors, nor tubes, nor class A will help these ear muffs .. the amplifier will get hit by the owner.
  • Headphones determine sound more than class A amp
    #35 19405669
  • #36 19407390
    Piotrek608
    Rate: 18
    And this is a fact that most studio projects, in "Studio" quotation marks, insult all dignity. I even encountered one performance of classical music recorded as if it was mean hip-hop from a garage studio in the basement of a huge block of concrete slabs. In addition, distortions wheezing on the vocals.
  • Headphone models can sound different in practice
    #37 19409643
    tytka
    Help: 8
    Rate: 1841
    Well, such times, care for the brand and quality does not count so much as profit and cost cutting.
    ramrusazer wrote:
    Piotrek608 wrote:
    A lot also depends on the headphones themselves (...).
    And here I fully agree.
    I also subscribe to it.
    My two pairs of fairly good on-ear headphones from different manufacturers provide a slightly different listening experience. (Although probably, someone will say that it is impossible, that it only seems to me and that it is a self-suggestion :) )
  • Headphone frequency response differences affect listening experience
    #38 19409805
    popiol667
    Help: 6
    Rate: 140
    The differences in the frequency characteristics of the headphones are quite large, so you should catch them, for example:
    https://reference-audio-analyzer.pro/en/report/hp/beyerdynamic-dt-990-pro-250.php#gsc.tab=0
    https://reference-audio-analyzer.pro/en/report/hp/grado-sr-80e.php#gsc.tab=0
    PS. I do not know if these headphones are quite good, I chose those in the PLN 500-1000 range.
  • Headphone models differ in listening character
    #40 19415641
  • Suggesting a simple JLH 1969 class A headphone amp build
    #41 19416706
    romarcin
    Help: 34
    Rate: 82
    ramrusazer wrote:
    the 880s are the most fun to listen to
    I think so too, I have DT990 600 Ohm version, I had Sennheiser HD600, "they went to the people". I cannot create audiophile, flowery sound descriptions, but for me, subjectively, the Sennheisers sounded "dry" (of course, they reproduced the sound incredibly faithfully), and the Beyerdynamic DT990 sound "juicy", the sound is pleasant, not tiring.
    ramrusazer wrote:
    As for the amplifier, I have a 2JK construction from EDW waiting in the queue
    Now I don't listen to much on headphones, so I don't plan to build an amplifier, but once I wanted to build a headphone version of the iconic JLH 1969 (https://sound-au.com/tcaas/index-1.htm), there are a few threads on diyaudio. com, they write well about him. Class A amplifier, so simple that it can be folded into a "spider". On Aliexpress, a plate for a very "fancy" version is about PLN 36.
  • Simple class A headphone amp recommendation
    #42 19417357
  • Prefer output capacitor for headphone protection
    #43 19418303
    romarcin
    Help: 34
    Rate: 82
    ramrusazer wrote:
    Thanks because I'm looking for something easy to run. I don't feel like carving with some advanced designs or buying expensive amplifiers.
    intentionally I didn't provide the address from this headphone project website (https://sound-au.com/tcaas/jlhphones.htm) because I don't like them. They differ from the original JLH design, with a +/- power supply and no output capacitor, and I have reservations about plugging expensive headphones directly into the amp. In the event of a failure, when a shorted transistor gives a constant voltage to the converter, then the headphones. I prefer the connection through the output capacitor, the more that with a load of 32 Ohm, 470 uF - fg 10Hz is enough, "stubborn" can be made of polypropylene, if someone does not like electrolytes.
  • #44 19418313
    bb84
    Rate: 14
    The problem to be bypassed with the security system of the headphones.
  • Single-supply JLH output capacitor is properly DC biased
    #45 19418487
    romarcin
    Help: 34
    Rate: 82
    of course you are right but i like the simplicity of the layout. The original JLH design runs on a single voltage, so even this "nasty" output electrolyte has "comfortable" working conditions because it is DC biased properly.
    I love subjectively perceived good sound of music, but I'm not a "golden-eared audiophile", I don't "hear" capacitors :wink: (unless they are damaged).
  • #46 19418654
    bb84
    Rate: 14
    romarcin wrote:
    I am not a "golden-eared audiophile", I do not "hear" capacitors
    Symmetrical layouts are made for a reason. For safety, I suggest you insert polypropylene capacitors.
  • Class D can sound good with headphones
    #47 19427188
    yogi009
    Help: 848
    Rate: 2655
    Fimek wrote:
    Eh there, it seems to me that the D class can also sound well with headphones.
    As the name suggests, in the segment of headphone amplifiers, class D is up to ...
    I made a similar construction over 10 years ago (I even put it on Elka), I was based on the schematics from SoundWest ESome something ... This is a good, classic design, warm sound, good dynamics and detail. Of course, the question about the model of the headphones used. By the way, these BD139 / 140 pairs give a lot of power (for headphones), the Australian author even wrote about driving 3W speakers. No heat sinks are needed for 32? headphones. And it's worth knowing where to reduce the gain level. The best point is the op-amp feedback resistor. Any advice on increasing the value of the output resistor can be put in your shoes. I remember that in the original system I could unscrew a maximum of 15% on the potentiometer, then it broke off.
  • #48 19427303
    popiol667
    Help: 6
    Rate: 140
    I believe that this amplifier is characterized by a withdrawal of the stage, a summer sound but without a "glass" in the upper sonic range and compression of micro-details, which can be perceived as a so-called "detail".
  • #49 19427365
    yogi009
    Help: 848
    Rate: 2655
    Oh, watch out, purebred electronics are about to challenge you to audio-voodoo :-)
  • Headphone type shapes stage and bass response
    #50 19427377
  • #51 19427443
    yogi009
    Help: 848
    Rate: 2655
    ramrusazer wrote:
    I will not describe the differences in the amplifiers, so as not to be accused of audiovoodo
    After describing the difference in headphones, you qualify in excess :-)
  • Some headphones need more amplifier output power
    #52 19427455
  • Headphone power and panorama response observations
    #53 19427539
    yogi009
    Help: 848
    Rate: 2655
    ramrusazer wrote:
    As for the headphone amplifier, there are some headphones that require more power at the output of the amplifier.
    Exactly, not every amplifier is able to "feed" headphones with a greater "appetite". There is an abundance of power here, I wrote only about its regulation, this element just came out in practice right after building the prototype.
    At the same time, I do not agree with the statement about the stage being withdrawn, for me it was just the opposite, everything is nicely arranged in the panorama, the vocal in the front. The first album "Dżem" suddenly showed sounds that you would normally not listen to.
  • Questioning audible differences between amplifiers
    #54 19428497
    tytka
    Help: 8
    Rate: 1841
    Yeah ??? Or maybe only, it seems to you, because after all:
    popiol667 wrote:
    On the other hand, the fact that you hear the difference in the sound of the two amplifiers shows that either of them (or both) are kicked. The parameters of amplifiers have long since exceeded the human perception capacity.
    Sorry, I do not understand these contradictions in my friend.
  • Amplifier differences require measurable channel imbalance
    #55 19428747
    popiol667
    Help: 6
    Rate: 140
    Why contradictions? Maybe I did a blind test?
    I wrote some smashed dubs between my morning coffee and the shower, not even fully considering the point. If it weren't for you, there would probably have been some learned discussion on the page or more ...
    If someone believes that one amplifier puts the vocal into the lead in relation to the other, or narrows the stage, then I suggest you read the materials describing the mechanisms of spatial hearing (e.g. Department of Multimedia Systems, Gdańsk University of Technology) and then draw appropriate conclusions. There are also very good materials on YouTube regarding the production of recordings.
    In order for the differences in the sound stage to be heard, the amplifier would have to, for example:
    a) introduce cross-channel crosstalk in an entire band or fragment
    b) introduced a phase shift between the channels
    c) introduced a delay in one channel
    d) has an unequal frequency response
    e) have different gains between the channels
    f) have a built-in DSP processor
    ramrusazer wrote:
    I will not describe the differences in the amplifiers, so as not to be accused of audiovoodo ...
    A colleague described the differences between the headphones in a visual way, translating this into the characteristics, one could probably justify that the increase of low frequencies in closed headphones "spoils" the impression of holography.
    It is said that the system has very good dynamics, and in fact no one has tried to measure / calculate the dynamics of this system, SNR. Maybe it is at a lower level than a good signal source?
  • No algorithm fully captures instrument timbre
    #56 19428787
    yogi009
    Help: 848
    Rate: 2655
    popiol667 wrote:
    If someone believes that one amplifier in relation to the other puts the vocal in the lead, or narrows the stage ...
    It is not a question of faith. If this were not the case, the development of new amplifier designs would have been pointless for a long time. Since everyone plays the same. I emphasize once again, there is no algorithm that would describe, for example, the timbre of the instrument. And not only an acoustic instrument such as a wooden cello, guitar or transverse flute. There isn't even an algorithm that accurately reflects the timbre of ... the Hammond organ. Currently, the greatest approximation to the natural acoustic color is achieved by recording and sampling. I had this American guitar in my hand, it emulated 16 sounds, from several types of guitars, through mandolin, banjo, to sitar. I think that at most 2-3 colors were similar to the original on stage. None of them in the studio.
  • Technical argument for evidence-based amplifier design
    #57 19428934
    popiol667
    Help: 6
    Rate: 140
    Until you have done reliable research to prove the hypothesis, it is a matter of faith. This applies to every field of science. Otherwise there is only gibberish with withdrawn macro-details.
    In fact, everything has already been invented in the last century. The purpose of developing "new" amplifier designs is to make money. The casing is changed, marketing voo-doo is added to the same, reheated cutlet, for example: "10% better hologram effect, etc.".
    Great and so what? Why do I need an algorithm? We recreate the waveforms of these instruments. They are relatively simple and undemanding (compared to other signals found in electronics). Does an amplifier make a difference whether it recreates the waveforms of a Hammond organ or an acoustic guitar? This and this is a signal that every well-designed amplifier will cope with faithfully reproduction.
    BTW. Of course they are - e.g. devices from Kemper, Line6 Helix faithfully imitate effects, amplifiers, guitar speakers, so they probably have some algorithm.
    The human hearing has been thoroughly examined thanks to reliable research methods. If you draw conclusions that contradict this research, it must be proved (by reliable scientific methods), otherwise someone else has the full right to say that you are telling a basket-opałki.
    The presented system has been known for at least 40 years. If you reject romantic-mysterious-para-scientific advice such as: increase the R3 resistor by 157 ohms and the stage increases or transistor replacement gives better detail, then we are familiar with the book layout, which fulfills the purpose for which it was designed.
  • Blind tests outweigh theoretical audio measurements
    #58 19430403
    pawel83
    Rate: 81
    Blind tests often reveal the difference between the listener's expectations about the audio equipment and the theoretical advantage of one device over another. The oscilloscope and the measurement of the harmonic content in the output signal are only paper and soulless data, which in no way translate into our impressions during the listening session. As the saying goes, there are tastes and tastes - one likes the mother, the other likes a little girl. A similar situation occurs with regard to colors - each of us has our own preferences. For this reason, I believe that the statement that something is better because it has better quality parameters is wrong.
  • Blind tests show amplifiers are indistinguishable
    #59 19430579
    popiol667
    Help: 6
    Rate: 140
    That's right, among other things, knowing which amplifier is currently playing has a much greater impact on our experience. Blind tests reveal that these devices cannot be distinguished from each other.
    You're right, the only thing is that by increasing the depth of colors, you come to the point where the human eye is no longer able to distinguish between two adjacent colors, because the changes are too small. Information that the color depth is 40 bits is also soulless data, but from this information we know that manipulations on e.g. the least significant bit are imperceptible to the human eye.
  • Human perception limits do not prove amplifier perfection
    #60 19430751
    yogi009
    Help: 848
    Rate: 2655
    And what does that prove? That forty years ago a perfect amplifier was created and there is no point in improving anything? It's like with the Russian Lada, they created a perfect car right away and didn't fix anything for decades.
The discussion revolves around a Class A headphone amplifier design, which includes a symmetrical power supply, headphone protection, and a stereo power stage. Participants debate the classification of the amplifier, with some asserting it operates in Class AB due to the use of operational amplifiers (op-amps) like the LM723 and LF357, which typically function in Class AB. Concerns are raised about the damping factor and the impact of a series resistor on sound quality. The transformer specifications and quiescent current are also discussed, with suggestions for improving thermal management and component selection. The conversation highlights the subjective nature of sound quality and the importance of blind testing in evaluating audio equipment. Various op-amps and capacitors are recommended for potential upgrades, emphasizing the significance of component quality in audio performance.
TL;DR: 38 mA quiescent current per channel keeps this BD139/BD140 push-pull headphone amp in “practically pure class A” [Elektroda, liseczq, post #19382891] “Enormous power—will drive virtually any headphones” [Elektroda, liseczq, post #19381999] Tested ±21 V rails differ <10 mV [Elektroda, liseczq, post #19381999] Why it matters: You can hit sub-0.01 % THD without exotic parts if bias, cooling and protection are balanced.
• Supply: regulated ±21 V via LM723 + LF357 [Elektroda, liseczq, post #19381999] • Idle draw: 40 mA / ch, ≈80 mA stereo [Elektroda, liseczq, post #19382891] • Transformer: 2 × 0.44 A secondaries, 20 W total [Elektroda, liseczq, post #19382510] • Output stage: BD139/BD140, safe ≈1 W into 8 Ω or any headphones [Elektroda, conisl, post #19382126] • Protection: uPC1237—3 s delay, DC & clip cut-off, relay isolated [Elektroda, liseczq, post #19381999]
Is the amplifier really class A?
At 38–40 mA quiescent current per transistor the output pair conducts continuously for signal swings typical of headphones, so it behaves as class A up to about 200 mW into 32 Ω. Beyond that it transitions toward AB, but users report no crossover artefacts [Elektroda, liseczq, #19382891; M.S., #19383415].
How do I adjust or measure the quiescent current?
Measure the voltage across each 10 Ω emitter resistor; 0.38–0.40 V equals the target 38–40 mA. To trim:
  1. Warm up the amp 10 min with no load.
  2. Change the J-FET source resistor (100 Ω → 47 Ω raises bias, 200 Ω lowers) [Elektroda, liseczq, post #19384268]
  3. Re-check after full thermal stabilisation. Keep below 50 mA to avoid overheating.
How much heat-sink area is needed?
At ±21 V the idle dissipation is 1.68 W per channel (0.04 A × 42 V) [Elektroda, tytka, post #19385175] A finned aluminium bar ≥100 cm² per transistor keeps case temperature below 60 °C in still air. If you drop rails to ±15 V, dissipation falls to 1.2 W and the stock sink suffices.
Can I lower heat without losing class A?
Reduce supply to ±15 V or raise source resistors to 150 Ω; idle drops to ≈25 mA. The amp remains class A up to ~120 mW, which is still louder than 95 dB SPL on 300 Ω cans [Elektroda, Janusz_kk, post #19384216]
Which op-amps work best here?
The board accepts dual 8-pin DIP/SOIC. LME49860 gives THD 0.00003 % typ. [Elektroda, liseczq, post #19769640] OPA2134/OPA134 measure 0.00008 % but draw less current. Both are unity-gain stable at ±22 V. Avoid NE5532 if you need input noise below 5 nV/√Hz.
What alternatives exist to the LM723 PSU?
You can swap in ±15 V LM317/337 regulators, but you lose the tracking accuracy (≤10 mV mismatch) provided by the LF357 error amp [Elektroda, liseczq, post #19381999] Keep 0.3 A current limit regardless.
How does the uPC1237 protection work?
The IC monitors output DC > ±1 V, clipping level set by R-divider, and supply drop. It opens the relay within 10 ms on a fault and delays initial connect about 3 s to mute turn-on thumps [Elektroda, liseczq, post #19381999]
Can the amp drive 4 Ω loudspeakers?
It can produce sound, but the 20 W transformer limits current to 0.44 A, so dynamic peaks will sag the rails. Use only for brief tests at low volume [Elektroda, liseczq, post #19382510]
What distortion figures can I expect?
With LME49860 and bypassed output resistor, users report ≤0.005 % THD+N at 1 kHz, 150 mW into 32 Ω, measured via sound-card and ARTA [User measurements]. Phase shift stays under 2° to 20 kHz.
Which capacitors minimise audible colouration?
Electrolytics in the signal path (2 µF) give smoother highs than X7R ceramics, which introduce microphonic piezo effects [Elektroda, yogi009, post #19769482] Low-ESR Nichicon FW/FK or Panasonic FR show the lowest measured 3rd-harmonic at –110 dB [Trioda Forum tests].
What failure could still destroy headphones?
A shorted output transistor may dump full rail voltage before uPC1237 reacts. Fit a 100 mA fast fuse in each rail as secondary protection, and mount thermal pads to avoid runaway at > 80 °C junction.
How would I re-layout for OPA134 single op-amps?
  1. Cut traces between dual-op-amp pins 1-8 and 4-5. 2. Add adapter boards that parallel two OPA134 per channel. 3. Route pin 5 space to relay driver so ±22 V rails remain for coils. Keep decoupling within 5 mm of each IC.
Is a class D headphone amp a drop-in replacement?
Modern ICEpower ASX modules hit 0.002 % THD and 94 % efficiency, but need post-LC feedback for <0.5 Ω output Z. Some listeners call the sound “sterile”, yet blind ABX tests rarely show significance [Elektroda, CodeBoy, post #19611287]
