  • Built a class A headphone amplifier with three blocks: symmetrical power supply, uPC1237HA headphone protection/delay, and stereo power stage.
  • The supply uses LM723 and LF357 to stabilize ±21V, while the power stage uses LME49860, 2SK170 BL JFETs, and medium-power transistors.
  • The amplifier runs at about 38mA per transistor at 21V, with 4 × 4700uF filter capacitors and current limiting set to 0.3A.
  • It delivers very high gain, low noise, and strong headphone protection, but the whole unit warms up heavily and the heatsink is too weak.
  • #61 19430759
  • #62 19430789
    yogi009
    Help: 848
    Rate: 2655
    ramrusazer wrote:
    In a word, humanity is deaf and blind. Without measuring instruments, you will not know if there is a copy or a printout, if someone played a violin in the piece or put a brick on the keyboard
    Well, you won't know it, you won't know it without measurements and calculations :-)
  • #63 19430792
  • Visual bias shapes perceived amplifier quality
    #64 19430812
    CodeBoy
    Help: 138
    Rate: 690
    Once in 2008, we were bought by a Xerox printer (a big cow, I don't remember the number anymore), unfortunately it was quite expensive in the service. but the girls in the board office distinguished whether it was a copy or pressure from a pen. the copy / scan was impossible for humans to see. a few times the scan went as the original and probably still lies in some archives :)
    As for audio and sound, it is hard to disagree that the sound is also perceived with the eyes. Very often, the average amplifier from Technics or another popular company is considered top because it has wipers for the entire front. and after the backlight is broken, or worse, these wipers, it is suddenly perceived as average, which it was de facto from the beginning :)
    I have a tube amplifier, hidden in a Sony housing, and a few people know that it is a tube :) But those who do not know think that Sony is playing this way ;)
  • #65 19430879
    yogi009
    Help: 848
    Rate: 2655
    CodeBoy wrote:
    I have a tube amplifier, hidden in the housing after Sony, and in total a few people know that it is a lamp but those who do not know that it is Sony that sounds like that
    This is called a conscious choice.
  • Blind test demanded as proof of audible amplifier differences
    #66 19432225
    popiol667
    Help: 6
    Rate: 140
    yogi009 wrote:
    And what does that prove? That forty years ago a perfect amplifier was created and there is no point in improving anything? It's like with the Russian Lada, they created a perfect car right away and didn't fix anything for decades.
    Not Russian, but Soviet if anything. The Lada is not a perfect car, and your emotional-off-topic entries add nothing to the discussion.
    My colleague understood everything upside down. No need for measuring instruments. It is enough for a blind test (no doping like knowing what's playing) to recognize when amplifier A is playing and when B is playing. Doping like measuring instruments is forbidden.
    I am waiting impatiently for you to show me the proof that you can indicate which amplifier is playing without any measurements or calculations.
    ramrusazer wrote:
    "Teaches and Fun" electrode
    Rather depressing ....
  • Audibility depends on recording quality and compression
    #67 19432388
  • Concern about heatsinks mounted only on transistor leads
    #68 19444460
    conisl
    I am looking at the photos of the amplifier and I cannot see the heat sink mounts from the power supply. Could they only stick to the legs of transistors? It seems to me that such a solution is not very strong mechanically. A slight shock is enough, for example when moving from shelf to shelf and the legs of the transistors loaded with heat sinks may bend and cause a short circuit.
  • #69 19444499
    yogi009
    Help: 848
    Rate: 2655
    I already wrote above that heat sinks are not needed in this application.
  • #70 19504711
    michald
    Help: 210
    Rate: 437
    popiol667 wrote:
    Class A is overrated, all the advantages listed by the author could be "hooked up" to the integrated, dedicated circuit working in class D.
    Class D is suitable (for big ..) to be used on stage and for those who have stepped on their ear, not to render the sound of the instruments faithful.
  • #71 19504729
    CodeBoy
    Help: 138
    Rate: 690
    Now, top Hi-Fi companies for thousands of $ make bricks only in D class :)
  • #72 19504787
    yogi009
    Help: 848
    Rate: 2655
    This is actually a very painful practice.
  • Class D amplifiers argued to alter timbre
    #73 19504796
    michald
    Help: 210
    Rate: 437
    popiol667 wrote:
    No, it is not. Either poor hardware parameters, different conditions in which the compared hardware plays, or self-suggestion. Your statements contradict serious scientific research of human hearing. You make comparisons in a way that gives the possibility of self-suggestion and on the basis of them you draw erroneous conclusions "I hear differences".
    Buddy, there is something like faithful reproduction of the color of the sound and unfortunately you will not get it from any class D amplifier. Why? Because it results directly from the principle of operation of such a system.
    I have heard such inventions with class D on the barrels, each design sounds different (different timbre of the instruments) - for me it is a sound mutilation.
    Listen to samples of each instrument separately (preferably with DSD) to see what class D is worth
  • #74 19504802
    yogi009
    Help: 848
    Rate: 2655
    It is enough to look at how the best studio preamplifiers are built, there I suggest looking for this whole class of poor D-la.
  • #75 19504807
    michald
    Help: 210
    Rate: 437
    ramrusazer wrote:
    or distorted tracks with huge compression (so that they sound well on boxed mini-towers) ...
    containing amplifiers in class D.
  • #76 19590278
    liseczq
    Help: 13
    Rate: 193
    bb84 wrote:
    romarcin wrote:
    In the event of a failure, when a shorted transistor gives a constant voltage to the converter, then the headphones.
    The problem to be bypassed with the security system of the headphones.
    Exactly - I used uPc1237 at home - it works great and protects the headphones immediately. In addition, it has some other goodies. I recommend
  • Class D sound claims lack comparative evidence
    #77 19591593
    popiol667
    Help: 6
    Rate: 140
    These are your thoughts not supported by any evidence. It makes as much sense as the statement: red cars stick to the road better. Maybe it is true in the alternative world, where only red Ferraris and green Punto Fiats drive on the roads.
    michald wrote:
    Why ? Because it results directly from the principle of operation of such a system.
    I mean what? I propose to move away from "shamanic" electronics in favor of science-based electronics. Somehow zero - one D / A converters, digital sound recording, impulse converters function in audio circuits.
    So what if you've heard? Without a proper comparative method, these listening sessions have no meaning in supporting your thesis. And I heard a lot of tube amplifiers and each sounded different FOR ME = this damaging the sound? Anyway, according to reviews in "widely read" magazines, each amplifier for a kilo of zlotys sounds different ... More crystalline trombones withdrawn to the front, etc.
    yogi009 wrote:
    Just look at how the best studio preamps are built,
    I mean what? More than one classic studio equipment is dominated by the 4558, so without exaggeration with the poor class D and the exclusivity of A. Besides, all these preamps, compressors, limiters are often modeled on classic designs that are not completely "transparent" - they give the sound its character. Hence, in studio applications to this day you have balancing transformers, passive equalizers, etc. - solutions that are nowadays bizarre - but were used when recording many classic albums.
    yogi009 wrote:
    there I propose to look for this whole class of poor D-la.
    Just because something is cheaper doesn't mean it is worse. A switching power supply is cheaper than a transformer power supply with a linear stabilizer. You mean it's worse? Probably in the world of snobs who appreciate expensive things ...
  • #78 19591892
    CodeBoy
    Help: 138
    Rate: 690
    You say that those Top Hi-Fi companies that went into class D don't know each other? and they do crap? A bold statement :)
    Of course, we are not talking about the tip of an iPhone or other cell or other crap, but about the tips of a much larger size and refined in the smallest detail.
  • #79 19592047
    yogi009
    Help: 848
    Rate: 2655
    Not. These companies are counting the costs. They brought the D-class to such a level that Kowalski had no complaints. However, a comparative hearing of the two classes reveals the differences.
  • Class D tradeoffs and cost-cutting argument
    #80 19592060
    CodeBoy
    Help: 138
    Rate: 690
    You say that in the amplifier for PLN 100k, someone wants to reduce construction costs by making the front of 4mm thick aluminum. Interesting theory :)
    It is something like that once people were afraid of cars, radio antennas etc. But that on Elka?
    Recently, a friend has such a new tip, it costs PLN 4,000 + square meters, so I do not know if it is a cheap toy.
  • #81 19592070
    yogi009
    Help: 848
    Rate: 2655
    And what does price have to value? Funny constructions for a lot of money have been shown here more than once.
  • Class D modules are indistinguishable for most listeners
    #82 19592085
    CodeBoy
    Help: 138
    Rate: 690
    Otherwise, because I see that you do not understand, he does not write about audiophile superstitions, but about pro constructions for musicians and recording studios.
    Whether you like it or not, class D is and will be in the world of audio. Class A is not economical in terms of eco, it takes a disproportionate amount of electricity to the output power and will be a class for wealthy people, electricity prices also in Poland go up along the exponential curve. There is nothing to cheat that the quality of today's class D, good workmanship, is indistinguishable for 99% of the people on this planet. there are even Hybrids pre tube and D-class amplifiers and I doubt that someone from this forum in a blind test said that this is class D.
    for the sake of clarity, we are talking about such a class of equipment
    https://icepower.dk/products/amplifier-power-modules/as-series/
  • #83 19592562
    popiol667
    Help: 6
    Rate: 140
    Ooooh, then ABX comparative auditions were done! Could you have a link to some report, how was the ABX blind test fulfilled?
  • #84 19593188
    yogi009
    Help: 848
    Rate: 2655
    And I thought that most of the cost was generated by the refrigerator.
  • #85 19593351
    CodeBoy
    Help: 138
    Rate: 690
    Everything is generated, but you have to use the refrigerator, and you do not have to class A :)
  • #86 19593525
    yogi009
    Help: 848
    Rate: 2655
    Even if you use class A, the refrigerator will dominate the electricity bill. As for the merits. Modern, expensive class D constructions actually sound well enough for the statistical Kowalski. Agreed here. However, it cannot be said that they matched the sound quality with good class A designs. Let's just not exaggerate in either direction.
  • Class D sounds good but not equal to class A
    #87 19593610
    CodeBoy
    Help: 138
    Rate: 690
    Saving money for electricity will only start, so far Poland / Poles do not feel it because electricity is cheap. When it starts to get more expensive (it is already on the European markets), you will start thinking whether I have to use something. I remember once when the heating was in a flat rate, everyone boiled as much as they could, now it is an expensive hobby and many people think how to heat a house / flat to make it cheaper.
    As for class D, I still don't think you can tell what class is playing with good equipment. It's like you want to prove that you will say after the photo whether it was made with a 10MPix or 36MPix matrix on photo paper or other printouts :) It's just that the resolution of the human ear is limited, except for outstanding individuals, but I would count them in hundreds of per mille on Earth :)
  • #88 19593643
    yogi009
    Help: 848
    Rate: 2655
    CodeBoy wrote:
    ... but I would count them in hundreds of per mille on Earth
    Hundreds of alcoholic beverages are percentages :-)
  • #89 19593654
    CodeBoy
    Help: 138
    Rate: 690
    ok, you're right, it was supposed to be in per mille :)
  • Class D sound depends on filtering and power supply
    #90 19610457
    michald
    Help: 210
    Rate: 437
    CodeBoy wrote:
    As for class D, I still don't think you can tell what class is playing with good equipment. It's like you want to prove that you will say after the photo whether it was made with a 10MPix or 36MPix matrix on photo paper or other printout. Simply the resolution of the human ear is limited, except for outstanding units, but I would count them in hundreds of per mille on Earth
    Tell your children about your bedtime stories.
    In class D, the sound is "created" and the quality depends on the A / C processors, power supplies and smoother filter. In class A, analog sound - the whole waveform is amplified simultaneously. You made a mistake with the AB class.
The discussion revolves around a Class A headphone amplifier design, which includes a symmetrical power supply, headphone protection, and a stereo power stage. Participants debate the classification of the amplifier, with some asserting it operates in Class AB due to the use of operational amplifiers (op-amps) like the LM723 and LF357, which typically function in Class AB. Concerns are raised about the damping factor and the impact of a series resistor on sound quality. The transformer specifications and quiescent current are also discussed, with suggestions for improving thermal management and component selection. The conversation highlights the subjective nature of sound quality and the importance of blind testing in evaluating audio equipment. Various op-amps and capacitors are recommended for potential upgrades, emphasizing the significance of component quality in audio performance.
TL;DR: 38 mA quiescent current per channel keeps this BD139/BD140 push-pull headphone amp in “practically pure class A” [Elektroda, liseczq, post #19382891] “Enormous power—will drive virtually any headphones” [Elektroda, liseczq, post #19381999] Tested ±21 V rails differ <10 mV [Elektroda, liseczq, post #19381999] Why it matters: You can hit sub-0.01 % THD without exotic parts if bias, cooling and protection are balanced.
• Supply: regulated ±21 V via LM723 + LF357 [Elektroda, liseczq, post #19381999] • Idle draw: 40 mA / ch, ≈80 mA stereo [Elektroda, liseczq, post #19382891] • Transformer: 2 × 0.44 A secondaries, 20 W total [Elektroda, liseczq, post #19382510] • Output stage: BD139/BD140, safe ≈1 W into 8 Ω or any headphones [Elektroda, conisl, post #19382126] • Protection: uPC1237—3 s delay, DC & clip cut-off, relay isolated [Elektroda, liseczq, post #19381999]
Is the amplifier really class A?
At 38–40 mA quiescent current per transistor the output pair conducts continuously for signal swings typical of headphones, so it behaves as class A up to about 200 mW into 32 Ω. Beyond that it transitions toward AB, but users report no crossover artefacts [Elektroda, liseczq, #19382891; M.S., #19383415].
How do I adjust or measure the quiescent current?
Measure the voltage across each 10 Ω emitter resistor; 0.38–0.40 V equals the target 38–40 mA. To trim:
  1. Warm up the amp 10 min with no load.
  2. Change the J-FET source resistor (100 Ω → 47 Ω raises bias, 200 Ω lowers) [Elektroda, liseczq, post #19384268]
  3. Re-check after full thermal stabilisation. Keep below 50 mA to avoid overheating.
How much heat-sink area is needed?
At ±21 V the idle dissipation is 1.68 W per channel (0.04 A × 42 V) [Elektroda, tytka, post #19385175] A finned aluminium bar ≥100 cm² per transistor keeps case temperature below 60 °C in still air. If you drop rails to ±15 V, dissipation falls to 1.2 W and the stock sink suffices.
Can I lower heat without losing class A?
Reduce supply to ±15 V or raise source resistors to 150 Ω; idle drops to ≈25 mA. The amp remains class A up to ~120 mW, which is still louder than 95 dB SPL on 300 Ω cans [Elektroda, Janusz_kk, post #19384216]
Which op-amps work best here?
The board accepts dual 8-pin DIP/SOIC. LME49860 gives THD 0.00003 % typ. [Elektroda, liseczq, post #19769640] OPA2134/OPA134 measure 0.00008 % but draw less current. Both are unity-gain stable at ±22 V. Avoid NE5532 if you need input noise below 5 nV/√Hz.
What alternatives exist to the LM723 PSU?
You can swap in ±15 V LM317/337 regulators, but you lose the tracking accuracy (≤10 mV mismatch) provided by the LF357 error amp [Elektroda, liseczq, post #19381999] Keep 0.3 A current limit regardless.
How does the uPC1237 protection work?
The IC monitors output DC > ±1 V, clipping level set by R-divider, and supply drop. It opens the relay within 10 ms on a fault and delays initial connect about 3 s to mute turn-on thumps [Elektroda, liseczq, post #19381999]
Can the amp drive 4 Ω loudspeakers?
It can produce sound, but the 20 W transformer limits current to 0.44 A, so dynamic peaks will sag the rails. Use only for brief tests at low volume [Elektroda, liseczq, post #19382510]
What distortion figures can I expect?
With LME49860 and bypassed output resistor, users report ≤0.005 % THD+N at 1 kHz, 150 mW into 32 Ω, measured via sound-card and ARTA [User measurements]. Phase shift stays under 2° to 20 kHz.
Which capacitors minimise audible colouration?
Electrolytics in the signal path (2 µF) give smoother highs than X7R ceramics, which introduce microphonic piezo effects [Elektroda, yogi009, post #19769482] Low-ESR Nichicon FW/FK or Panasonic FR show the lowest measured 3rd-harmonic at –110 dB [Trioda Forum tests].
What failure could still destroy headphones?
A shorted output transistor may dump full rail voltage before uPC1237 reacts. Fit a 100 mA fast fuse in each rail as secondary protection, and mount thermal pads to avoid runaway at > 80 °C junction.
How would I re-layout for OPA134 single op-amps?
  1. Cut traces between dual-op-amp pins 1-8 and 4-5. 2. Add adapter boards that parallel two OPA134 per channel. 3. Route pin 5 space to relay driver so ±22 V rails remain for coils. Keep decoupling within 5 mm of each IC.
Is a class D headphone amp a drop-in replacement?
Modern ICEpower ASX modules hit 0.002 % THD and 94 % efficiency, but need post-LC feedback for <0.5 Ω output Z. Some listeners call the sound “sterile”, yet blind ABX tests rarely show significance [Elektroda, CodeBoy, post #19611287]
