Beken BK7231/BK7252 SPI flashing and recovery - new flasher tool and protocol specs
p.kaczmarek2 18648 428
  • BK7231GUIFlashTool v98+ adds CH341-based SPI flashing and recovery for Beken BK7231/BK7252 chips, including bricked devices with overwritten bootloaders.
  • The tool uses CH341 DLL C# bindings to toggle CEN via D2, reset the chip, send 0xD2, then flash Beken chips like generic SPI memory.
  • Connections use P20, P21, P22, and P23 for SCK, CSN, SI, and SO, with CEN wired to D2 and the CH341 jumper set to I2C mode.
  • A sample read identifies JEDEC ID FF-EF-40-16 and a 4096 KB flash, and the same tool can Read, Write, Verify, and Erase firmware.
  • If CH341 is not detected or CEN toggle fails, check driver configuration, jumper position, SPI wiring, and power before trying Beken SPI mode again.
  • #421 21950395
    Help: 450
    Rate: 920
    thanks for Easy Flasher merges.
    please let me know if you're interested in the other two or if they need work/closing.
    a couple of fixes. https://github.com/openshwprojects/BK7231GUIFlashTool/pull/168
    -fix lan scanner right-click device menu crash
    -make obk config use enhanced extraction route for IO assignment
    tested.
    thanks @DeDaMrAz
  • #422 21952742
    Rate: 12972
    @divadiow , regarding the flasher (so this topic fits more... or less...) would you be able to add to FlashDumps repo, some 1:1 original UART 2 logs for some BK7231T or BK7231N dumps? Or maybe pair existing.... so for BK7231T_QIO_Woox_R5111_2023-14-10-23-46-06.bin we would get BK7231T_QIO_Woox_R5111_2023-14-10-23-46-06_uart.txt ?
  • #423 21952786
    Help: 450
    Rate: 920
    the boot logs from each dump to text file?
  • #424 21952811
    Rate: 12972
    Yes, but just for a few, not for all of them, of course!
  • #425 21952837
    Help: 450
    Rate: 920
    can do.
    what are they for?
  • #426 21952852
    Rate: 12972
    I'm working on... something, I'll show details in dedicated separate topic today or tomorrow. However, it may not be fully functional anytime soon, so I'd rather say it's just an experiment
  • #427 21952853
    Help: 450
    Rate: 920
    OK. how long a log capture each? 5s? 10s?
  • #428 21952854
    Rate: 12972
    Boot sequence and what's printed after loop when it stabilizes
    Added after 1 [hours] 49 [minutes]:
    promised topic: BK7231 Emulator: early experiments with Capstone & Unicorn in Python
The discussion centers on BK7231/BK7252 SPI flashing and recovery using BK7231GUIFlashTool v98+, which adds a new SPI-based flashing method requiring only a CH341 SPI programmer. The method is intended for recovering bricked Beken devices with overwritten bootloaders and also works as a general SPI flasher for external flash chips. Participants test and debug the new SPI mode, including COM-port handling, CH341 DLL loading, verify behavior, and Linux/Mono compatibility. The thread then expands into broader flasher development: UART and SPI improvements, flash-size detection, unprotect logic, retry mechanisms, baud-rate limits, and support for additional platforms such as RTL8720D, RTLZ/RTLZ2, BL602, LN882H, W600/W800, ECR6600, and remote flashing over TCP-to-UART. Several fixes are merged, including backup restore, erase/write handling, config read/write, and improved detection and logging.
TL;DR: New BK7231GUIFlashTool v98+ adds SPI flashing for Beken chips; sample 4,096 KB flash detected. “Only a CH341 SPI programmer is required.” Use CH341A D2 to toggle CEN, send 0xD2, then read/write like generic SPI. [Elektroda, p.kaczmarek2, post #21711721]
Why it matters: It lets you recover bricked BK7231/BK7252 devices without a working bootloader, using low‑cost tools.
Who this is for: DIYers, repair techs, and firmware engineers asking how to unbrick or mass‑flash Beken SoCs via SPI with a CH341A and the latest tool.
What exactly is the new Beken SPI flashing method and what do I need?
The tool drives CH341A as an SPI master, resets BK via CEN on D2, sends 0xD2 to enter BK’s SPI-memory mode, then treats the chip like a standard SPI flash. You need a CH341A (jumper at I2C), 3.3 V power, and wiring for P20–P23 (SCK/CSN/SI/SO) plus CEN. Select “Beken SPI” in BK7231GUIFlashTool v98+. “Only a CH341 SPI programmer is required.” [Elektroda, p.kaczmarek2, post #21711721]
How do I wire CH341A to BK7231/BK7252 for SPI mode?
Connect CH341A SCK→P20, CS0→P21, MOSI→P22 (SI), MISO→P23 (SO), and D2→CEN. Keep MOSI→SI and MISO→SO mapping. Provide GND and target power. Some boards have pads labeled CE/TCK/TMS/TDI/TDO that map to CEN/SCK/CSN/SI/SO respectively. [Elektroda, p.kaczmarek2, post #21711721]
How do I reliably enter BK SPI mode? (3‑step)
  1. Use CH341 D2 to pull CEN low then high to reset the BK chip. 2. Stream 0xD2 bytes repeatedly over SPI. 3. Issue 0x9F and confirm a valid JEDEC response; then proceed to Read/Write/Erase. [Elektroda, p.kaczmarek2, post #21711721]
I get “Failed to open CH341 device” or “Failed to toggle CEN.” What should I check?
Confirm CH341A is jumpered to I2C, recognized by Windows, and the D2 wire is soldered to CEN. Re‑seat USB, power the target, and verify SPI lines. The tool logs these errors when CH341 isn’t detected or CEN can’t be driven; fix wiring or driver, then retry. [Elektroda, p.kaczmarek2, post #21711721]
The app says “missing ch341dll.dll” or quits in SPI mode—how do I fix that?
Place CH341DLL.DLL alongside the GitHub build, or build from source in Visual Studio. Earlier builds could exit if CH341A wasn’t present; recent fixes improved handling, but adding the DLL resolved missing‑library errors during testing. [Elektroda, divadiow, post #21712310]
Do I need to select a COM port for SPI flashing?
No. As of v99, SPI mode does not require a COM port. This was confirmed after fixes; previous v98 prompts were removed. Ensure CH341A is connected; SPI operations run without a serial port. [Elektroda, divadiow, post #21712310]
What does the Verify button do?
Verify compares flash contents against the firmware file currently selected in the tool. Use it after Write or Erase to confirm success. “Verify verifies against selected firmware.” [Elektroda, p.kaczmarek2, post #21712551]
Can this recover a bricked BK7252 camera?
Yes. After wiring CEN and SPI lines, use Beken SPI mode to read/erase/write. The author provides a BK7252 camera recovery example using this exact method with CH341A and the new flasher. [Elektroda, p.kaczmarek2, post #21711721]
Can I use CH341 Programmer or NeoProgrammer once SPI mode is active?
Yes. After the 0xD2 hand‑off, the BK behaves like a generic SPI flash. You can then operate with common SPI flash tools (CH341 Programmer or NeoProgrammer) if you prefer. [Elektroda, p.kaczmarek2, post #21711721]
Linux support: what baud rates are stable under mono?
Mono 6.12 worked for testers. They reported stable operation at 921,600 baud; 1,500,000 worked on Windows, but they lowered to 921,600 on Linux. LAN Scanner and release downloader also worked. [Elektroda, insmod, post #21712663]
The tool shows a 4,096 KB device. Is that normal for these chips?
Yes. A sample JEDEC ID FF‑EF‑40‑16 decoded to 4,096 KB and printed by the tool. That confirms JEDEC read and size decoding in SPI mode. Actual sizes vary by module; always check the tool’s detected flash size. [Elektroda, p.kaczmarek2, post #21711721]
How do I just switch a BK device into SPI mode without reading or writing?
Use the new “Detect” button. It performs a zero‑length custom operation to toggle CEN and send the 0xD2 sync, placing the chip in SPI mode for use with other SPI tools. [Elektroda, p.kaczmarek2, post #21731041]
I flashed many times and now erase fails. What should I try?
Expand Unprotect logic before erase, similar to AsProgrammer. A contributor noted needing stronger Unprotect after many BK7252 cycles. Add an Unprotect/Status-Register release step, then retry the erase/write. [Elektroda, p.kaczmarek2, post #21714737]
What is OpenBeken (OBK) in this context?
OpenBeken is an open‑source firmware used across supported Wi‑Fi MCUs in this ecosystem. The author uses OBK devices for testing and demos, including camera boards and remote flashing concepts. [Elektroda, p.kaczmarek2, post #21714427]
Can I flash a BK device over Wi‑Fi/TCP instead of USB?
Yes, a Wi‑Fi flasher demo proxies UART over TCP and controls CEN via an OBK device. It’s a separate utility that mirrors the BK UART routines, useful when PC‑to‑target wiring is hard. [Elektroda, p.kaczmarek2, post #21720013]
Any known edge cases or failure symptoms I should expect?
If CH341DLL is missing, some GitHub builds previously exited. On mono/Linux, 1,500,000 baud may fail while 921,600 works. Also, after heavy cycling, protection bits may block erase until Unprotect expands. Address each symptom as noted, then retry. [Elektroda, divadiow, post #21712310]
