How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
Ganjor86 730846 1593
Can I turn a cheap DVB-T USB tuner into an SDR receiver, and how can I make it receive shortwave too?
Yes: with an RTL2832U-based DVB-T dongle you can use it as an SDR receiver after replacing the stock DVB-T drivers with the prepared Zadig/libusb drivers and running SDR software like SDR Sharp or HDSDR [#11182116] In normal mode these tuners work roughly from 24 MHz up to about 1700 MHz, so VHF/UHF services, airband, CB, ADS-B, etc. are fine [#13168529] [#12073526] For shortwave below that range, do not connect the antenna straight to the RTL chip; direct sampling is possible but is considered risky and can damage the RTL28xx [#12073526] The safer and better-performing solution in the thread is an upconverter on the antenna input, e.g. based on TA7358/LA1185/LA1186, which users report can extend reception down to roughly 100 kHz–40 MHz [#13135481]
  • #181 13512432
    Lonek
    Level 19  
    Help: 13
    Rate: 13
    Ok ...... that's what I did, but I didn't give Install Driver anymore and I downloaded these drv from somewhere
  • #182 13515702
    oster7
    Rate: 17
    I have such a question on the top screen in SDR - max. the visible range is ~~ 2.4 MHz. Whether and how to extend it to e.g. 10 MHz or more?
  • #183 13518367
    radiosystem
    BW = 3.2 MHz is the maximum for this receiver.
  • #184 13529738
    phonemen
    lysy1980 everything is nice, beautiful, I think I bought a tuna from you a few days ago, but here the problem from another shelf, namely sdr, is ok, but blazehdtv, mediacenter and other crap do not search for programs for me. The headset is installed correctly, not the ones from Zadig only from Realtek and there is no signal in the dark. Antenna installation OK antenna AT 12 elements and 7m of cable. A normal tv tuner works perfectly while usb-stic lipa :(
    For the sdr program, I use the drivers from zadig and the sdr works correctly, but there is no sensational sensitivity, but that's not the point where I'm tired of dvb-t.
  • #185 13529815
    sb8gapi
    Rate: 36
    In order for DVB-T programs to work on the tuner, as already mentioned, the original drivers for the tuner are needed. It does not work on modified drivers. After installing the original drivers, it is possible to pick up even in VLC (this way you can check the correctness of the installed drivers), without the need to install a dedicated program to operate the tuner.
    The answer was already on the forum:
    https://www.elektroda.pl/rtvforum/topic2353101-150.html#13319726
  • #186 13529901
    phonemen
    sb8gapi Do you read what I wrote? not those from zadig only from Realtek and there is darkness no signal
  • #187 13529921
    oster7
    Rate: 17
    Check maybe on another USB port [not what you have SDR] install as DVB-T
  • #188 13529952
    sb8gapi
    Rate: 36
    I've been reading and my hands are dropping. Just moving the tuner to another slot will not help if you do not uninstall the Lib-USB (Universal Serial Bus devices) -> Bulk-In Interface device drivers.
    How many times can you write the same that DVB-T works after the correct installation of the original drivers. The REALTEK 2832U Device appears under Sound, video and game controllers in the control panel of Device Manager.
    In the attachment screen of the screen with correctly installed driver and receipt in VLC program.
  • #189 13530002
    phonemen
    sb8gapi and ass beaten old man, unfortunately I UNINSTALLED the headset and installed the original ones, even on the fresh win7 system, only the ORIGINAL headsets. I have the same as you on the screen and VLC is silent, Miedacenter too and blaze too :( . The tuner cannot be damaged because the 2m amateur radios are played on the sdr and Gli ....... e, turn and 70 cm, which you would not wish for, so it's OK. However, DVB-T is not chula :( on the original driver. Unless you have some magic :) How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
  • #190 13530026
    sb8gapi
    Rate: 36
    Phonemen, you can write what tuner do you have? Do you have like mine in the control panel?
    Did you uninstall the driver from Device Manager?
    I am sending drivers from my tuner in the attachment, they may work.
    If everything is OK with the antenna, then in the VLC field, in the Transponder / multiplex frequency field, you enter the frequency of one of the multiplexes in your area in kHz (I have one of them at 650MHz, so I entered 650,000 kHz).
    http://telewizja-cyfrowa.com/nadajniki/
    I saw your screen. It looks ok.
    Phonemen and you have the option to check the tuner if it is receiving DVB-T on another computer?
    REALTEK 2832UDrivers
    • REALTEK_2832U_Drivers.zip (5.37 MB) You must be logged in to download this attachment.
  • #191 13530089
    Jezzman
    Help: 25
    Rate: 103
    @phonemen What antenna do you use to listen on SDR ??? Some self-made or factory ??
  • #192 13530101
    phonemen
    sb8gapi You are as big as my little Son would say :) I recommend this reading to all those who struggle with tunkami for a few days and a friend of bald1980 should add the reins of the above post to his colleague sb8gapi by sending an email. I successfully removed the bulk and installed these drivere and "bulka tv nice" :) GREETINGS and have a nice egg.
    Ps. The controls are not equal :)
    Jezzman I use scrap metal :) that is, an open dipole on the balcony 1p and a yagi AT 12 is an ordinary tv directional antenna, as if walking in the 400-800 mhz band, but it is enough, but I will create something on the roof, i.e. some omnidirectional only a matter of kasiorki :) to the 10th hoho :)
  • #193 13530119
    sb8gapi
    Rate: 36
    I am glad that we have succeeded. Maybe the drivers will still be useful to someone.
    At the beginning, I fought with various drivers for the LV5TDLX, because the tuner program did not search for programs after the drivers from the disc, but this is a different story and the topic is described in detail on the electrode.
    I recommend that you uninstall the drivers in the Control Panel in Device Manager, which will avoid many problems with installing DVB-T and SDR drivers.
    best regards
  • #194 13530137
    Jezzman
    Help: 25
    Rate: 103
    @phonemen Do you have a lot of this wire ?? :D I gave some 2m of wire for the window and I do not collect too much from the 2m and 70cm band; / And I live on the ground floor, the antenna on the roof is not for me because the building is a monument and they do not allow ... Personally, I use Not only TV and everything works as if someone wanted it, I can put the original drivers for DVB-T :D
  • #195 13530171
    phonemen
    Jezzman Thanks for the controls, but we've all got it working here :) a few posts higher, as for the antenna, it is half a wave, but it is enough for me locally, i.e. 1 m radiator and 1 m counterweight
    for yourself you have to look for yourself in another section, surely the SP and SQ guys will help, or as I have been playing it for over a dozen years, I recommend a nice ABC knig. likes :)
    Greetings and run away with Mały on the bike and thank SB8GAPI for help
  • #196 13531097
    lysy1980
    Help: 209
    Rate: 324
    Well, I was away for Christmas and so much has happened here. As for the controls, the tuners on Allegro, I attach those that I got from the "Chinese" Win7 x64, Vista and XP work OK for me, so I did not look for a hole in the whole and sent those that worked for me. Exactly the same drivers you included sb8gapi , I myself added a few pages ago in one of my posts.
    https://www.elektroda.pl/rtvforum/topic2353101-30.html#12105174
    I also improved the package with drivers on Allegro.
  • #198 13533244
    phonemen
    lysy1980 It's nice that everything is straightened as far as the controls are concerned :) but I have one more problem now, rather hardware on my part. Namely, I have a problem with Lapek, it's just don't laugh please :P Dell Latitude D610 on board has a Pentium M 1.87 GHz and 1 Gb Ramu slingshot, with memory is cool, but the proc gets in Du.e as in the attached screen and cuts the sound on listening and sometimes some correspondence is in she did not fully understand and here the question passes whether to throw the paw into scrap? what I would not like, of course, I cannot afford a new one and it is not going to expand it very much, are there any support programs or some other program checked for listening except hdsdr because this thing is deaf for me. I am asking for some advice and greetings, rubber ears :)
    • How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? scren_cpu.jpg (144.59 KB) You must be logged in to download this attachment.
  • #199 13533562
    sb8gapi
    Rate: 36
    No wonder it cuts the sound as there is CPU load at 100%.
    I suggest lowering the Sample Rate in Configure to 2048 MSPS or less even to 1024 MSPS.
    Alternatively, download an older version of SDR Sharp from the forum:
    https://www.elektroda.pl/rtvforum/download.php?id=565446 (version 1173)
    or the Stable 1.0 version from the Aurora website
    http://sdrsharp.com/downloads/sdr-stable.zip (has a lower CPU load than the latest version).
    For HD SDR, you need ExtIO_RTL.dll (ExtIO_RTL2832.dll). One of them should be copied to the HDSDR folder.
    The latest version of HD SDR and ExtIO_RTL.dll and ExtIO_RTL2832.dll from February 4, 2014 in the attachment.
    • ExtIO_RTL2832.zip (116.37 KB) You must be logged in to download this attachment.
    • ExtIO_RTL.zip (109.04 KB) You must be logged in to download this attachment.
    • HDSDR_install_1_.exe (1.67 MB) You must be logged in to download this attachment.
  • #200 13533819
    BOOM i ZONK
    Help: 21
    Rate: 73
    The Sample Rate is one thing, the other is the FFT Display tab to reduce the Resolution to some 8192 or how it will take 16384. The version does not matter, I had and the old and the new there was no difference, although I would be inclined to the newer one. The load is influenced by the type of modulation currently used. WFM is more demanding than NFM.
  • #201 13533978
    phonemen
    the same version, or rather the newest one, is best for all of them. I reduced it to 1024 MSPS and it is a bit better, but it tears a little, which will give Resolution, unfortunately, it did not do anything :( I'm running out of ideas.
  • #202 13534085
    sb8gapi
    Rate: 36
    You can also disable unnecessary processes in the Task (process) manager.
    How does HD SDR work?
  • #203 13534097
    phonemen
    sb8gapi hdsdr sucks, the processes are broken, but I cut a few more things with the test method and I downloaded the graphs with these sliders and it's better, it only cuts a bit :) I'm just listening to a repeater at 145,675 some 35km away from my qth. maybe I will improve something else, I hope :)
  • #204 13534402
    sb8gapi
    Rate: 36
    Still, disabling the audio filter should help. Audio -> Filter Audio.
  • #205 13534518
    BOOM i ZONK
    Help: 21
    Rate: 73
    Try my config and reduce the size of the window to a minimum like mine.
    • SDRSharp_config_athlon1700_.zip (1.62 KB) You must be logged in to download this attachment.
  • #206 13548455
    lysy1980
    Help: 209
    Rate: 324
    Yesterday I had a moment of slack and I made a converter for the TA7358 and played a little with the KF reception and I will say that it even gives "this" advice, although compared to the TS-850S equipment, it is not fancy, but for a few zlotys you can have fun.
    I do not currently have a dedicated HF antenna and I used the SIRIO GP3-E because I have one on the roof and the reception today was not bad.
    I use SDR RADIO PRO v2.2 connected with HAM Radio DeLuxe which in version 5.xx was free. SDR Radio and HRD work together fully and you can tune the tuner using HRD to the desired frequency, as well as change the filter width, AGC speed and many other functions.
    By the way, I decoded BPSK using the Digital Master which is part of HRD.
    In the screenshots, cooperation between SDR CONSOLE and SDR SERVER via LAN. The receiver is currently on the first floor, and I was sitting on the ground floor.
    How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz? How to use RTL-SDR on a cheap USB DVB-T tuner for HF and 64–1700 MHz?
    SYNOP
    Watermark on the drops due to the people who fuck my work and paste not their materials for auctions in Alledrogo
  • #207 13548624
    Jezzman
    Help: 25
    Rate: 103
    What antenna did my colleague use to receive HF ?? A colleague would put in a schematic of this converter here, I would like to make it myself, but I can't find a schematic :(
    Best regards.
  • #208 13548673
    lysy1980
    Help: 209
    Rate: 324
    Diagram and description in the attachment. This document can be found on Google.
    The antenna is like I wrote in the previous post. SIRIO GP 3-E, it is a VHF antenna, currently I do not have any HF antennas.
    SIRIO GP 3-E
    • TA7358_-_hf-to-vhf-upconverter.pdf (203.57 KB) You must be logged in to download this attachment.
  • #209 13561553
    hadron-collider
    I'm starting to play with SDR. A very interesting case :P
    Can someone explain the differences between: "quadrature sampling" and "direct sampling" (I and Q branch) from the technical point of view?
  • #210 13583266
    mkpl
    Level 37  
    Help: 306
    Rate: 863
    I have this tuner and a question from a different barrel. I did not find any information in this thread so I prefer to ask here.
    How does the reception "quality" compare to the bandwidth you set? Does it affect the sensitivity, noise or only the load on the computer and the available bandwidth?
    Do you also have strong FM stations around 26 - 40MHz? I even pick them up in stereo and with RDS. The antenna is a piece of cable, but it is annoying to receive harmonics from some other signals.
The discussion centers on using inexpensive DVB-T USB tuners, particularly those based on the RTL2832U chipset combined with various tuner modules like the R820T and E4000, as software-defined radio (SDR) receivers. These devices, originally intended for digital TV reception, can be repurposed for wideband SDR reception from approximately 25 MHz up to 1.7 GHz, covering amateur radio bands, FM broadcast, airband, ADS-B, and more. Modifications such as direct antenna connection to the RTL2832U chip pins enable reception of lower frequency bands (below 30 MHz), including shortwave, though precautions against electrostatic discharge and signal surges are necessary. Upconverter circuits based on chips like LA1186, LA1185, and TA7358AP are commonly used to extend reception down to HF and VLF bands by frequency shifting signals into the tuner's range. Various software solutions including SDR# (SDR Sharp), HDSDR, and dump1090 are recommended for Windows and Linux platforms, with driver installation often requiring tools like Zadig to replace default DVB-T drivers with RTL-SDR compatible ones. Users report challenges with driver installation, device recognition, and antenna selection, especially for frequencies outside the FM broadcast band. Amplifiers such as the FP6L and antennas like Discone or long wire are suggested to improve reception quality. Mobile and embedded platforms like Raspberry Pi and Android devices with USB OTG support are explored for portable SDR setups. The community shares detailed schematics, installation guides, and troubleshooting tips, emphasizing the cost-effectiveness and versatility of RTL-SDR dongles for radio experimentation and monitoring.
TL;DR: A US$13 RTL-SDR dongle with an R820T tuner covers 24-1762 MHz “Band 24-1762 MHz (no holes)” [Elektroda, zabex, post #12073526] and can be pushed to ≈100 kHz with a 50 MHz up-converter [Elektroda, sb8gapi, post #13074101]
Why it matters: One stick lets hobbyists scan HF, VHF, UHF and ADS-B without big radios.
• R820T native span: 24–1762 MHz [Elektroda, zabex, post #12073526] • Direct-Sampling mod: ≈0.1–28 MHz [Elektroda, methyl, post #13657048] • Typical dongle cost: US$13–15 incl. whip [Elektroda, Ganjor86, post #12076142] • PC spec: USB 2.0 + ≥1.2 GHz CPU [Elektroda, Serwis1, post #13206155] • TA7358 up-converter parts ≈ PLN 15 [Elektroda, sb8gapi, post #13074101]
What frequencies can an un-modified RTL-SDR with R820T cover?
About 24 MHz to 1.76 GHz without gaps [Elektroda, zabex, post #12073526] That spans airband, AIS, ACARS, ADS-B, VHF FM, UHF trunked, LTE and more.
How do I install drivers on Windows XP?
  1. Plug dongle, let Windows load Realtek driver.
  2. Run Zadig v2.1 XP, Menu → Options → List All Devices, choose "Bulk-In Interface 0".
  3. Click Install WINUSB driver. After 5 s SDR# sees “RTL-SDR/USB”. [Elektroda, lysy1980, post #13511327]
I get no DVB-T after installing SDR drivers—normal?
Yes. WINUSB replaces Realtek’s TV driver. Switch USB port or reinstall OEM driver when you need DVB-T reception [Elektroda, lysy1980, post #13511327]
What’s the simplest way to receive 0–30 MHz?
Add a 50 MHz HF up-converter using TA7358 or LA1185. It mixes HF to 50–80 MHz, cost under PLN 15 and sensitivity beats direct sampling [Elektroda, sb8gapi, #13074101; Elektroda, zabex, #12073526].
Can overheating freeze the dongle?
Yes. R820T can reach >60 °C and USB disconnects appear. Resoldering the USB plug and adding small heatsinks stopped lock-ups [Elektroda, mkpl, post #13635115]
Which antenna works best for wideband scans?
An outdoor TV log-periodic or discone on 50 Ω feed covers 50–1300 MHz. For HF add Mini-Whip or 20 m long-wire plus the up-converter [Elektroda, methyl, post #13657048]
Edge case: why does FM broadcast appear at 30 MHz?
Strong local FM images alias into 26–40 MHz when the front-end overloads. Use 88–108 MHz notch or reduce RF gain [Elektroda, mkpl, post #13583266]
Can I scan automatically like a hardware scanner?
Yes. Install the ‘Frequency Manager Scanner’ plug-in for SDR#; it hops user lists at 20 channels /s and logs activity [SDRSharpPlugins].
Is spectrum-analysis possible?
RTL-SDR plus ‘RTL-Power’ or ‘Spektrum’ sweeps 24 MHz–1.7 GHz, 2 MHz steps, ~30 dB dynamic range—handy for EMC checks [majek, 2013].
How do I add HF direct sampling without removing the tuner?
On R820T boards, wire a 1:10 transformer to RTL pins 4-5, select “Direct Sampling Q” in SDR#. This keeps VHF/UHF intact [Elektroda, BOOM i ZONK, post #13914702]
