  • DIY-A586 v1.9 is a revised FPGA board built around a Spartan6 XC6SLX9, with hardware changes accumulated over several years.
  • It removes joystick multiplexing, supports two floppy drives without extra circuits, and adds an 18.432MHz generator plus USB-C pull-downs.
  • The board uses 32MB 16bit SDRAM, 16MB flash, and stores up to 30 FPGA configurations in flash.
  • Mikan core runs with 8MB CHIP and 23.5MB FAST, and the 8MB DMA CHIP unexpectedly worked.
  • Diagram, Gerberas, and commercial-use restrictions are included in the appendix.
  • #361 21956253
    sillycon
    >>21956086 That could well be the case; I’d need to check again, perhaps with a few games. To what extent is it possible to manually select the clock frequency whilst the system is running, or to predefine the speed during core construction?
  • #362 21956893
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3353
    Not really during construction – it takes up quite a lot of space in the FPGA, and in that case the synthesis can sometimes go wrong when the parameters are changed.
    I haven’t tried it whilst it’s running.
Discussion of the DIY-A586 v1.9 FPGA-based Amiga-compatible board by piotr_go, built around a Spartan-6 XC6SLX9 with 32 MB SDRAM, 16 MB flash, HDMI, analog audio, SD, RS232, joystick, PS/2, floppy and A500 keyboard interfaces. The thread covers core architecture (own core with TG68 CPU), compatibility, FPGA resource usage, synthesis constraints, and comparisons with Minimig/MiSTer. A large part of the discussion focuses on assembly and bring-up: flash programming, ROM loading, SD card formatting, Kickstart patches, floppy-drive conversion, Gotek compatibility, SDRAM timing, oscillator choice, and soldering order. Later posts report fixes and updates for Amiga core, SD support, PS/2 reset, floppy reading, audio, and bitplane handling, plus questions about parts sourcing, connector footprints, and possible future ports or expansions such as AGA, C64, Spectrum, and alternative FPGA platforms.
