[BL602] How to flash Magic Home over WiFi without soldering
alwas 22932 104
  • #61 21507933
    Help: 450
    Rate: 920
    >>21507396
    as in your pin assignments in the config page aren't saving?
  • #62 21585608
    kellerto
    >>21418610 Any luck with 33_227_20231220_ZG-BL?
  • #63 21585743
    Help: 450
    Rate: 920
    we could do with a backup of a 33_227_20231220_ZG-BL device firmware for the collection and to test mhflasher
  • Original firmware dumped and version identified
    #64 21585983
    kellerto
    >>21585743 thank you for help. I was able to read (dump) the original Flash firmware. I was also able to run AT+LVER\r with packetsender app in order to find the version: 33_227_20231220_ZG-BL\r
    I'm trying to flash MagicHome RGB controller without success. Tried by soldering approach accepts which seems to work but no AP appears (even after 5 power cycles) also firmeware installation via OTA by using AT+UPURL and powershell http listener on Port.1111
    Here the original flash bin
    • flashBackup2.bin (2 MB) You must be logged in to download this attachment.
    • flash.bin (2 MB) You must be logged in to download this attachment.
  • #65 21586017
    Rate: 12954
    AP may not work if you power device from USB to UART converter. You need a good 3.3V power supply that can provide enough current.
    You can just watch UART log output via UART to see if it crashes.
  • #66 21586037
    kellerto
    Unfortunately problem exists even when I power up via regular DC 5….28V input socket (I used 12VDC)
  • #67 21586041
    Rate: 12954
    Ok, so what is the debug log output?
  • App-only flashing preserves RF calibration and MAC address
    #69 21586062
    Rate: 12954
    Why would you want it to be full size? We only overwrite main application, there is no need to overwrite full flash. I will say even more - we need to do this that way, otherwise we would:
    - overwrite RF partition and lose calibration (get worse WiFi quality, known problem on Beken)
    - overwrite MAC address and get MAC collisions (on some platforms)
    - overwrite Tuya GPIO Config (which we can extract on Beken and use to configure device)
    - overwrite your OBK config (only if you reflash)
    So, we obviously provide only app section, not full flash, just like Tasmota does.
  • #70 21586076
    kellerto
    Makes sense, thank you for clearing this thought.
  • Check whether BOOT pin was disconnected
    #71 21586087
    Rate: 12954
    If you think that you may misconfigured your device and want to "refresh" it, then the recommended method is to rewrite full 2MB factory flash (assuming you have taken it), and then flash our firmware again.
    Still, I'm saying that just for other readers, because in your case I am not sure if that's the problem... maybe something else is incorrect, let us know when you manage to take the debug log.
    Btw, did you make sure to disconnect BOOT pin before trying?
  • #72 21586110
    kellerto
    …was thinking the same. First instal the original backup, which I pulled at the beginning. Then instal the newest OpenBL602.bin
    Which is exactly what I did at the beginning of this journey. :-)
    And get us the debug log. Hope debug log is possible with bouffalolab flasher.
  • #73 21586120
    Rate: 12954
    Any UART client can set debug log as long as you set valid baud rate
  • Backup works and BL602 boots successfully
    #74 21586157
    Help: 450
    Rate: 920
    for the record your backup does work and here is the debug log from that. 2000000 baud
    mhflasher OTA method fails, as you know. this is log for when pushing 'flash' button in mhflasher app
  • #75 21586228
    Rate: 12954
    @divadiow can you try with older OBK binary? The one before we introduced size check with @insmod ?
  • #76 21586235
    insmod
    Help: 168
    Rate: 455
    Size check only matters when OTA is performed from OBK, not to it.
    Offtopic: did xr809 ota ever work? I get rtos scheduler shutting down when erasing, and if erase is skipped - when writing first payload. In that case it is either scheduler or hard fault.
    Curiously, if flash debugging is enabled it goes a little further, but will still hang or crash.
  • BLDevCube can build working flash from blank chip
    #77 21586245
    Help: 450
    Rate: 920
    previous chats about it here https://www.elektroda.com/rtvforum/topic4055254.html#21131093
    Added after 10 [minutes]:
    I have burnt user's backup and then flashed 1.18.100 as per:
    4mb board. OpenBL AP broadcasts as expected. Not sure what that proves though because even with an entirely blank flash (erase whole chip- read back 4mb from 0x0 - all FF) BLDevCube seems to add/erase/carve all the needed bits up to make working flash
    eg
  • XR809 OTA never worked; asks how to build OTA file
    #78 21586308
    Rate: 12954
    insmod wrote:
    did xr809 ota ever work?.
    XR809 OTA never worked for me. XR809 was the first IoT device I flashed (except ESP), then I flashed BK and backported XR809 support to OpenBK (that was the first non-BK platform supported).
    I remember I was doing some debugging with printfs in XR809 OTA SDK code but failed to find anything, however, I know I was using the same binary I use for UART, which was most likely incorrect.
    https://github.com/openshwprojects/OpenXR809/commit/3c964113f1be89f749e4619483590bf5e2842a6a
    Recently we've looked into those XR872 cameras with @divadiow and I seemed to see more OTA code there, maybe OTA file generation.
    @insmod how far have you managed with that, do you know how to build flash OTA file for XR?
  • OTA likely reuses the UART binary and disables XIP
    #79 21586374
    insmod
    Help: 168
    Rate: 455
    >>21586308
    From what i understood in the SDK code, the same binary that is used for UART is used for OTA.
    And it probably works like two partition scheme on ESP.
    I did some debugging, and it stops RTOS scheduler and disables XIP on flash opening. That is probably the problem, and i'm don't know how to solve it. And i'm not sure if it would affect LFS and EF.
    Currently i separated pins for all XRs, added easyflash, LFS, and started using heap_4, not heap_stdlib.
    Coded pwm, but it's not working yet. Also coded ADC, but can't test it for now.
    Decided against updating freertos and lwip, binary size is already too much.
    Will see if i manage to successfully enable compression, like tuya uses by default.
  • #80 21586388
    kellerto
  • #81 21586431
    Rate: 12954
    Nice, which XR do you have, @insmod ? The first thing I would try to do for Xr809/XR806 is enabling the UART flashing method without pulling two pins down... it seems that XR872 has this possible via AT command (UPGRADE). Maybe we could also strip other AT commands to get more space.
  • XR806 UART pin combinations and flash size limit
    #82 21586469
    insmod
    Help: 168
    Rate: 455
    >>21586431
    I have XR809 and testing everything there.
    I also have XR872 doorbell with 4MB flash. But there are almost no pins wired out. Tried to find UART port, but no luck.
    Got PWM and ADC working.
    Binary size is already past 1024K limit, had to change it to 1056K. Currently at 1044 kb.
    UART for XR809 is easy, there is one pin combination for UART0, and one for UART1.
    But for XR806, one for UART0, 3 for UART1 and 3 for UART2.
  • #84 21586480
    insmod
    Help: 168
    Rate: 455
    >>21586478
    Didn't try it. Bot on W600 gcc-8 increased size by 3kb.
    I will later try to use gcc-10.3
  • Firmware flash changes Wi-Fi config and AP behavior
    #85 21586571
    kellerto
    >>21586157
    I can confirm, original backup worked. It also opens an AP soon power supply is applied.
    [17:49:11.452] -
    sysTick:90127
    7C3E82C16F17
    10.10.123.3
    fh:62544
    st1:21 st2:0 st3:0
    life:%100
    repT:0s
    pwr:0
    wanT:0 lanT:0
    ping:0 (0) 9999
    rssi:-9999 (0) 9999
    Test2: Installed OpenBL602_1.18.123.bin by using Single Download option
    UART Log after disconnected boot resistor connecting to 12V source. No UART Logging received
    [17:56:47.813] - serial type is general
    [17:56:50.190] - Open COM5 Success
    Test3: Installed OpenBL602_1.18.123.bin by using Firmware options
    Note: As you mentioned this kind of installation messes with chip and wifi config. Just did it to compare with Test 1 and 2.
    and please note, the IP Address listed in logfile is not mine and not related with my network. not sure where this setting is coming from. looks like build in into one of the other 3 firmware options (files) ?
    [19:49:31.413] - Starting bl602 now....
    Booting BL602 Chip...
    [19:49:31.413] -  ██║██╔██║ █████╔╝
    RISC-V Core Feature:RV32-ACFIMX
    Build Version: release_bl_iot_sdk_1.6.39-238-gf5ba0a7ee
    Build Date: Jun 21 2025
    Build Time: 05:56:26
    blog init set power on level 2, 2, 2.
    [IRQ] Clearing and Disable all the pending IRQ...
    [         0][INFO: hal_boot2.c: 282] [HAL] [BOOT2] Active Partition[0] consumed 596 Bytes
    [         0][INFO: hal_boot2.c:  82] ======= PtTable_Config @0x4200f250=======
    [         0][INFO: hal_boot2.c:  83] magicCode 0x54504642; version 0x0000; entryCnt 7; age 0; crc32 0x12DF9A26
    [         0][INFO: hal_boot2.c:  89] idx  type device activeIndex     name   Address[0]  Address[1]  Length[0]   Length[1]   age
    [         0][INFO: hal_boot2.c:  91] [00]  00     0         0            FW  0x00010000  0x000e8000  0x000d8000  0x00088000  0
    [         0][INFO: hal_boot2.c:  91] [01]  02     0         0           mfg  0x00170000  0x00000000  0x00032000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [02]  03     0         0         media  0x001a2000  0x00000000  0x00047000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [03]  04     0         0           PSM  0x001e9000  0x00000000  0x00008000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [04]  05     0         0           KEY  0x001f1000  0x00000000  0x00002000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [05]  06     0         0          DATA  0x001f3000  0x00000000  0x00005000  0x00000000  0
    [         0][INFO: hal_boot2.c:  91] [06]  07     0         0       factory  0x001f8000  0x00000000  0x00007000  0x00000000  0
    [         0][INFO: bl_flash.c: 391] ======= FlashCfg magiccode @0x42049c18=======
    [         0][INFO: bl_flash.c: 392] mid       0x5E
    [         0][INFO: bl_flash.c: 393] clkDelay    0x1
    [         0][INFO: bl_flash.c: 394] clkInvert    0x1
    [         0][INFO: bl_flash.c: 395] sector size   4KBytes
    [         0][INFO: bl_flash.c: 396] page size   256Bytes
    [         0][INFO: bl_flash.c: 397] ---------------------------------------------------------------
    [         0][INFO: hal_board.c:1249] [MAIN] [BOARD] [FLASH] addr from partition is 001f8000, ret is 0
    [         0][INFO: hal_board.c:1257] [MAIN] [BOARD] [XIP] addr from partition is 231e7000, ret is 0
    [         0][INFO: hal_board.c: 208] MAC address mode length 3
    [         0][INFO: hal_board.c: 212] MAC address mode is MBF
    Read slot:0
    [         0][INFO: hal_board.c: 187] Set MAC addrress 7C:3E:82:C1:6F:17
    [         0][INFO: hal_board.c: 955] country_code : 86
    [         0][INFO: hal_board.c: 342] xtal_mode is MF
    Read slot:0
    [         0][INFO: hal_board.c: 374] get xtal from M ready 31 31 1 60 60
    [         0][INFO: hal_board.c: 846] pwr_table_11b :20 20 20 18
    [         0][INFO: hal_board.c: 860] pwr_table_11g :18 18 18 18 18 18 14 14
    [         0][INFO: hal_board.c: 878] pwr_table_11n :18 18 18 18 18 16 14 14
    No written slot found
    [         0][BUF: hal_board.c: 606]   0   0   0   0   0   0   0   0   0   0   0   0   0   0
    [         0][INFO: hal_board.c: 902] set pwr_table_ble = 13 in dts
    [         0][INFO: hal_board.c: 687] ap_ssid string[0] = bl_test_005, ap_ssid_len = 11
    [19:49:31.429] -     0][INFO: hal_board.c: 698] ap_psk string[0] = 12345678, ap_psk_len = 8
    [         0][INFO: hal_board.c: 707] ap_channel
    [19:49:31.429] - = 11
    [         0][INFO: hal_board.c: 635] [STA] ap_ssid string[0] = yourssid, ap_ssid_len = 8
    [         0][INFO: hal_board.c: 646] [STA] ap_psk string[0] = yourapssword, ap_psk_len = 12
    [         0][INFO: hal_board.c: 654] auto_connect_enable = 0
    [         0][INFO: hal_board.c: 749] Troom_os = -1, lentmp = 4
    [         0][INFO: hal_board.c: 758] linear_or_follow = 1, lentmp = 4
    [         0][INFO: hal_board.c: 767] Tchannels:2412,2427,2442,2457,2472,
    [         0][INFO: hal_board.c: 781] Tchannel_os:180,168,163,160,157,
    [         0][INFO: hal_board.c: 795] Tchannel_os_low:199,186,170,165,160,
    [         0][INFO: hal_board.c: 808] en_tcal = 0, lentmp = 4
    [OS] Starting aos_loop_proc task...
    [OS] Starting OS Scheduler...
    [MTD] >>>>>> Hanlde info Dump >>>>>>
    name PSM
    id 0
    offset 0x001e9000(2002944)
    size 0x00008000(32Kbytes)
    xip_addr 0x231d8000
    [MTD] <<<<<< Hanlde info End <<<<<<
    [EF] Found Valid PSM partition, XIP Addr 231d8000, flash addr 001e9000, size 32768
    ENV AREA SIZE 32768, SECTOR NUM 8
    *default_env_size = 0x00000001
    ENV start address is 0x00000000, size is 32768 bytes.
    [19:49:31.476] - EasyFlash V4.0.99 is initialize success.
    You can get the latest version on https://github.com/armink/EasyFlash .
    name media
    id 0
    offset 0x001a200
    [19:49:31.476] - 0(1712128)
    size 0x00047000(284Kbytes)
    xip_addr 0x23191000
    [        38][ERROR : bl_romfs.c: 158] romfs magic is NOT correct
    [        39][INFO  : hosal_adc.c: 459] offset = 2132
    [        39][INFO  : hosal_adc.c: 233] ADC freq: 284Hz. div:6
    [OS] Starting proc_mian_entry task...
    [OS] Starting TCP/IP Stack...
    -------------------->>>>>>>> LWIP tcp_port 58301
    name PSM
    id 0
    xip_addr 0x231d8000
    Start Wi-Fi fw @95ms
    [19:49:31.554] - 1th channel,lo_vco_freq_cw=154
    2th channel,lo_vco_freq_cw=153
    3th channel,lo_vco_freq_cw=152
    4th channel,lo_vco_freq_cw=151
    5th channel,lo_vco_freq_cw=149
    6th channel,lo_vco_freq_cw=148
    7th channel,lo_vco
    [19:49:31.554] - _freq_cw=147
    8th channel,lo_vco_freq_cw=145
    9th channel,lo_vco_freq_cw=144
    10th channel,lo_vco_freq_cw=143
    11th channel,lo_vco_freq_cw=141
    12th channel,lo_vco_freq_cw=140
    13th channel,lo_vco_freq_cw=139
    14th channel,lo_vco_freq_cw=138
    15th channel,lo_vco_freq_cw=136
    16th channel,lo_vco_freq_cw=135
    17th channel,lo_vco_freq_cw=134
    18th channel,lo_vco_freq_cw=133
    19th channel,lo_vco_freq_cw=132
    20th channel,lo_vco_freq_cw=130
    21th channel,lo_vco_freq_cw=129
    0th channel,vco_idac_cw=7
    1th channel,vco_idac_cw=6
    2th channel,vco_idac_cw=6
    3th channel,vco_idac_cw=6
    4th channel,vco_idac_cw=6
    5th channel,vco_idac_cw=6
    6th channel,vco_idac_cw=6
    7th channel,vco_idac_cw=6
    8th channel,vco_idac_cw=6
    9th channel,vco_idac_cw=6
    10th channel,vco_idac_cw=5
    11th channel,vco_idac_cw=5
    12th channel,vco_idac_cw=5
    13th channel,vco_idac_cw=5
    14th channel,vco_idac_cw=5
    15th channel,vco_idac_cw=6
    16th channel,vco_idac_cw=5
    17th channel,vco_idac_cw=5
    18th channel,vco_idac_cw=5
    19th channel,vco_idac_cw=5
    20th channel,vco_idac_cw=5
    LO locked 9 144
    rosdac_i_gc3=27
    rosdac_i_gc2=27
    rosdac_i_gc1=27
    rosdac_i_gc0=27
    rosdac_q_gc3=33
    rosdac_q_gc2=33
    rosdac_q_gc1=33
    rosdac_q_gc0=33
    rbb_cap1_fc_i=30,rbb_cap2_fc_i=30,rbb_cap1_fc_q=30,rbb_cap2_fc_q=30
    new rbb_cap1_fc_i=54,rbb_cap2_fc_i=54,rbb_cap1_fc_q=54,rbb_cap2_fc_q=54
    LO locked 9 144
    amp=128,step=32,adc_mean_i=85
    amp=160,step=16,adc_mean_i=111
    tmx_cs=0, tmxcs_pwr_avg=50712, tmxcs_pwr_avg>>10=49
    tmx_cs=1, tmxcs_pwr_avg=57332, tmxcs_pwr_avg>>10=55
    tmx_cs=2, tmxcs_pwr_avg=66924, tmxcs_pwr_avg>>10=65
    tmx_cs=3, tmxcs_pwr_avg=81456, tmxcs_pwr_avg>>10=79
    tmx_cs=4, tmxcs_pwr_avg=98581, tmxcs_pwr_avg>>10=96
    tmx_cs=5, tmxcs_pwr_avg=112166, tmxcs_pwr_avg>>10=109
    tmx_cs=6, tmxcs_pwr_avg=110187, tmxcs_pwr_avg>>10=107
    tmx_cs=7, tmxcs_pwr_avg=95296, tmxcs_pwr_avg>>10=93
    tmx_cs_max=5, tmxcs_pwr_max=112166, tmxcs_pwr_max>>10=109
    amp=256,step=64,adc_mean_i=112
    amp=320,step=32,adc_mean_i=228
    tosdac_i=30,tosdac_q=44,tx_iq_gain_comp=1054,tx_iq_phase_comp=1
    tosdac_i=28,tosdac_q=42,tx_iq_gain_comp=1042,tx_iq_phase_comp=5
    tosdac_i=28,tosdac_q=44,tx_iq_gain_comp=1029,tx_iq_phase_comp=4
    tosdac_i=31,tosdac_q=47,tx_iq_gain_comp=1040,tx_iq_phase_comp=2
    tosdac_i=31,tosdac_q=47,tx_iq_gain_comp=1040,tx_iq_phase_comp=7
    tosdac_i=29,tosdac_q=47,tx_iq_gain_comp=1032,tx_iq_phase_comp=2
    tosdac_i=27,tosdac_q=48,tx_iq_gain_comp=1040,tx_iq_phase_comp=0
    tosdac_i=27,tosdac_q=46,tx_iq_gain_comp=1042,tx_iq_phase_comp=-3
    [WF] [KEY] [CFG] nVAP is 2, endidx 12, startidx 8
    td_init
    td_reset idx=0
    td_reset idx=1
    Start Wi-Fi fw is Done @169ms
    [APP] [EVT] INIT DONE 118
    [BL] Initi Wi-Fi with MAC #### 7C:3E:82:C1:6F:17 ####
    hostname: OpenBL602_82c16f17
    [WF] country code CN used, num of channel 13
    [IPC] [TX] Low level size 204, driver size 100, total size 304
    Enable BMX IRQ
    td_init
    td_reset idx=0
    td_reset idx=1
    [version] lmac 5.4.0.0
    [version] version_machw_1 000055FB
    [version] version_machw_2 000001B3
    [version] version_phy_1 00822111
    [version] version_phy_2 00000000
    [version] features 001089DF
    [ME] HT supp 1, VHT supp 0
    [WF][SM] reload tsen
    [WF][SM] Exiting ifaceDown state
    [WF][SM] State Action ###ifaceDown### --->>> ###idle###
    [WF][SM] Entering idle state
    [APP] [EVT] MGMR DONE 130, now 182ms
    [19:49:32.017] - Entering initLog()...
    Commands registered!
    initLog() done!
    na
    [19:49:32.017] - me PSM
    id 0
    xip_addr 0x231d8000
    [19:49:32.050] - [       651][WARN  : bl_mtd.c: 205] addr@0x230a4d1c is xip flash, size 8
    [19:49:32.150] - [MTD] >>>>>> Hanlde info Dump >>>>>>
    name media
    id 0
    offset 0x001a2000(1712128)
    xip_ad
    [19:49:32.167] - dr 0x23191000
    Main_Init_Before_Delay done
    Main_Init_Delay
    Main_Init_Delay done
    Warn:CFG:CFG_InitAndLoad: Correct config has been loaded with 2 changes count.
    Error:CMD:lfs is absent
    Info:MAIN:Main_Init_Delay
    Info:MAIN:Using SSID []
    Info:MAIN:Using Pass []
    Error:HTTP:Created HTTP SV thread with (stack=2048)
    Info:MQTT:MQTT_RegisterCallback called for bT obl82C16F17/ subT obl82C16F17/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT bl602s/ subT bl602s/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/obl82C16F17/ subT cmnd/obl82C16F17/+
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/bl602s/ subT cmnd/bl602s/+
    Info:MQTT:MQTT_RegisterCallback called for bT obl82C16F17/ subT obl82C16F17/+/get
    Info:CMD:CMD_StartScript: started @startup at the beginning
    Error:CMD:LFS_ReadFile: lfs is absent
    Info:CMD:CMD_StartScript: failed to get file autoexec.bat
    [19:49:33.051] - Info:MAIN:Time 1, idle 0/s, free 112736, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:34.005] - Info:MAIN:Time 2, idle 0/s, free 112736, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:34.975] - Info:MAIN:Time 3, idle 0/s, free 112736, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:35.928] - Info:MAIN:Time 4, idle 0/s, free 112736, MQTT 0(0), bWifi 0, secondsWithNoPing
    [19:49:35.928] -  -1, socks 2/21
    [19:49:36.900] - [lwip] netif status callback
    IP: 192.168.11.1
    MK: 255.255.255.0
    GW: 0.0.0.0
    [WF] MM_ADD_IF_REQ Sending: AP
    td_start idx=0
    [W
    [19:49:36.900] - F] MM_ADD_IF_REQ Done
    [WF] vif_index from LAMC is 0
    IP: 192.168.169.1
    MK: 255.255.255.0
    GW: 0.0.0.0
    [DHCP] ip_start: [192.168.169.2]
    [DHCP] ip_start: [192.168.169.254]
    [WF][SM] start AP with ssid OpenBL602_82C16F17;
    [WF][SM]               pwd  ;
    [WF][SM]               channel  1;
    [WF] APM_START_REQ Sending with vif_index 0
    [WF] received APM Start apm_start_req_handler:74
    [WF] return with other handler
    [WF] APM_START_REQ Done
    [WF] status is 00
    [WF] vif_idx is 00
    [WF] ch_idx is 00
    [WF] bcmc_idx is 05
    [WF][SM] stateGlobalGuard_AP: AP iface has started!
    Info:MAIN:Time 5, idle 0/s, free 112736, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [APP] [EVT] Unknown code 11, 5706
    [19:49:37.878] - [      6710][WARN  : bl_mtd.c: 205] addr@0x230a4d1c is xip flash, size 8
    Info:MAIN:Time 6, idle 0/s, free 112424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:38.816] - In
    [19:49:38.832] - fo:MAIN:Time 7, idle 0/s, free 112424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:39.801] - Info:MAIN:Time 8, idle 0/s, free 112424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:40.754] - Info:MAIN:Time 9, idle 0/s, free 112424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:41.722] - Info:MAIN:Time 10, idle 0/s, free 112424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:42.682] - Info:MAIN:Time 11, idle 0/s, free 112424, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/21
    [19:49:43.096] - Close COM5 Success
    Any hint or suggestions? Maybe the OpenBL602_1.18.123.bin is corrupt?
  • #86 21586581
    Rate: 12954
    Your log ends at:
    What happens later? Does it continue to run?
  • #87 21586660
    kellerto
    In this Test3, I was using the firmware options together with OpenBL602_1.18.123.bin firmware.
    log continues like this.
    Since the IP address is not mine it will not reach my mqtt server nor my network.
    It also does not open an AP access point.
    I kept sweeping wifi but no AP like with original firmware ☹️
    IP: 192.168.169.1
    MK: 255.255.255.0
    GW: 0.0.0.0
  • Confirm whether latest OpenBL602.bin works on Magic Home RGB controllers
    #88 21589678
    kellerto
    >>21586157 thank you for checking,
    Backup will bring the device back to original state.
    And then I installed latest OpenBL602.bin
    But then device is not starting AP anymore and UART log is silent (no log)
    I tried on a second new MagicHome controller but it behaves exactly the same.
    Can someone confirm that lstest OpenBL602 bin works?
    Or even confirm that it works on a Magic Home RGB Controller?
    DeDaMrAz
    Help: 34
    Rate: 130
    Latest build is working on BL602 devices, see picture.
    Can you change the partition table .toml file and use the attached one and report back? DTS and Boot2 remain the same.
    • partition_cfg_2M_FIX.rar (334 Bytes) You must be logged in to download this attachment.
  • AP starts in log but no SSID visible
    #90 21592996
    kellerto
    >>21590554
    Hi I'm back and thank you for the partition_cfg_2M_FIX file. Just reflashed the device us suggested.
    There is still no "OpenBL602_82C12029 "AP starting.
    Monitoring the log I observed some sections which caught my eyes. But not sure if this is the place to look.
    1. According UART log, Wifi seems to start with country code "CN" --> Is this a probem?
    2. Event Log says AP started and I keep scaning my Wifi but no such AP to see :-(
    [16:02:47.930] - [lwip] netif status callback
    IP: 192.168.11.1
    MK: 255.255.255.0
    GW: 0.0.0.0
    td_start idx=0
    [WF] MM_ADD_IF_REQ Done
    IP: 192.168.169.1
    MK: 255.255.255.0
    GW: 0.0.0.0
    [DHCP] i
    [16:02:47.946] - p_start: [192.168.169.2]
    [WF][SM] start AP with ssid OpenBL602_82C12029;
    [WF][SM]               pwd  ;
    [WF][SM]               channel  1;
    [WF] status is 00
    [WF] vif_idx is 00
    [WF] ch_idx is 00
    [WF] bcmc_idx is 05
    3. searching logfile for lines with keyword error in it:
    [        41][ERROR : bl_romfs.c: 158] romfs magic is NOT correct
    4. searching for warning message
    [16:41:54.353] - [      6763][WARN  : bl_mtd.c: 205] addr@0x230a4d1c is xip flash, size 8
    Complete logfile see txt file logfile_pa...2M_FIX.txt (26.03 kB)You must be logged in to download this attachment.
    I don't want to give up, so I'm hope you can give me some hints to fix this.
    Additional question: Is there a way, I can preset my Wifi parameter prior flashing?
    greatings from Black Forrest
The discussion explains how to flash Magic Home BL602-based devices over Wi‑Fi without soldering by abusing the manufacturer OTA mechanism. The working procedure involves resetting the controller into AP mode, hosting an OpenBeken BL602 OTA image on a local HTTP server, then sending an AT+UPURL command to the device over its wireless control interface so it downloads and installs the firmware. Participants later reverse-engineer the CozyLife/Magic Home JSON protocol, identify the relevant UDP/TCP ports, and test OTA triggers on different firmware versions and device families. Results show that some BL602 Zengge/Magic Home firmwares accept the exploit and boot OpenBeken, while newer versions may return OTA errors or appear patched. The thread also covers restoring factory firmware, partition table issues, flash size differences, and later mhflasher updates adding BL602 and LN882H OTA support.
TL;DR: With 0 solder joints and "back ok" as the key success reply, this method lets Magic Home BL602 owners push an OpenBeken OTA file over the device’s own AP using UDP port 48899 and a local HTTP server. It suits users who want a faster no-solder path, but only on firmware that still accepts the vendor OTA trigger. [#21056057]
Why it matters: This gives BL602 Magic Home owners a real no-solder upgrade path, while also showing exactly where newer Zengge firmware blocks it.
Method Hardware access Main transport Typical result in thread Recovery path
Magic Home OTA exploit No UDP 48899 + local HTTP Works on some BL602 firmwares Restore dump or solder later
mhflasher on Android No Automates same OTA path Works on vulnerable devices Same limits as OTA exploit
UART / BLDevCube flashing Yes Serial flashing Most reliable overall Full dump restore possible
Factory dump restore Yes Serial flashing Confirmed working on 2 MB dumps Returns device to stock
Key insight: The no-solder path is real, but it is firmware-dependent. Older Magic Home BL602 builds can fetch and install an OTA image from your own server, while newer builds such as 33_227_20231220_ZG-BL return OTA errors and appear patched. [#21418610]
  • Magic Home BL602 AP mode in the thread uses device IP 10.10.123.3, client IP 10.10.123.4, and listens for AT commands on UDP port 48899. [#21056057]
  • The Linux example serves the OTA file on HTTP port 1111, then triggers download with AT+UPURL=http://10.10.123.4:1111/...; users reported success after about 1 minute. [#21056057]
  • A confirmed vulnerable OTA session wrote about 427,676 bytes and then rebooted into OpenBeken; the UART log showed ota download is done! before reset. [#21063222]
  • Factory BL602 dumps discussed here are typically 2 MB, while some dev boards use 4 MB flash; that mismatch matters for restore tests and partition handling. [#21063112]
  • BL602 UART logs in the thread used 2,000,000 baud, and weak power from a USB-to-UART adapter was called out as a cause of missing AP behavior after flashing. [#21586157]
How do you flash a Magic Home BL602 controller to OpenBeken over WiFi without soldering using the manufacturer's OTA mechanism?
You reset the controller, join its AP, host the OTA file locally, and trigger the vendor OTA URL over UDP. 1. Power-cycle the device 4 times to factory reset, then connect to the LEDnetXXXXXXXXX AP. 2. Serve OpenBL602_...OTA.bin.xz.ota on a local HTTP server, often on port 1111. 3. Send AT+UPURL=http://10.10.123.4:1111/update?... to 10.10.123.3:48899. A working device replies back ok, then usually reboots after about 1 minute and appears as OpenBL602_XXXXXXXX. [#21056057]
Which OpenBeken file should I download for a BL602 WiFi-only flash, and why does it need to be the .ota build instead of the regular binary?
Download the BL602 OTA package, for example OpenBL602_1.17.553_OTA.bin.xz.ota, not the plain .bin. The OTA method calls the manufacturer’s updater, so it expects an OTA-formatted image rather than a raw UART-flash binary. The thread explicitly says to choose the version for the BL602 chip and OTA. A regular OpenBL602_...bin is used for wired flashing through tools like BLDevCube, not for the WiFi-only exploit path. [#21056057]
What do the BL602 Magic Home AT commands AT+LVER and AT+UPURL do, and how are they used during the WiFi flashing process?
AT+LVER reads the installed firmware version, and AT+UPURL tells the device where to fetch an update. In the working example, AT+LVER returned +ok=33_48_20201219_ZG-BL from UDP port 48899. AT+UPURL then pointed the device at a local HTTP URL on 10.10.123.4:1111 so it could download and install OpenBeken. "AT+UPURL is a device OTA trigger that makes the stock firmware fetch a new image from a supplied URL, using the vendor update path rather than UART flashing." [#21056057]
Why does a Magic Home BL602 device reply with +ok=up_ErrType, +ok=up_ErrHttp, or just a blank +ok= when I try the OTA exploit?
Those replies mean the OTA request was accepted syntactically but failed at validation, transport, or reboot stage. +ok=up_ErrType appeared on newer or incompatible Magic Home firmware, including 33_227_20231220_ZG-BL, and on a 35_162_20220801_ZG-BL-BP101 device that did not exploit. +ok=up_ErrHttp points to a fetch or URL issue. A blank +ok= can happen before reboot; one user saw it before disconnect, but the HTTP listener never received a request. Check firmware version, URL reachability, exact query format, and whether that device family still accepts custom OTA payloads. [#21245497]
What is mhflasher, and how does it automate the Magic Home BL602 OTA flashing procedure on Android?
mhflasher is an Android app that automates the same Magic Home BL602 OTA exploit described for Linux. It connects to the device AP, checks whether UDP communication works on port 48899, and sends the OTA trigger without needing manual terminal commands. The source code was shared publicly, and APKs were said to be in the releases folder. Later, an updated build was reported tested with OpenBL602 1.18.230 and confirmed to work on vulnerable Magic Home dumps. [#21787740]
How can I serve the OpenBL602 OTA file from Windows with PowerShell and send the UDP command with Packet Sender instead of using Linux netcat?
Use PowerShell as a one-shot HTTP listener and Packet Sender for the UDP packet. 1. Start an HttpListener on port 1111 and serve OpenBL602_...OTA.bin.xz.ota. 2. Connect your PC to the device AP, usually with the controller at 10.10.123.3 and your PC at 10.10.123.4. 3. In Packet Sender, send AT+UPURL=http://10.10.123.4:1111/update?version=...&beta,pierogi as UDP to port 48899. The thread reports you should see the upload, an OK, then a reboot into OpenBeken. [#21063222]
Why do some newer Zengge or Magic Home BL602 firmware versions like 33_227_20231220_ZG-BL appear patched against the OTA method?
They appear patched because the same OTA trigger that works on older builds fails early on newer ones. A tested device on 33_227_20231220_ZG-BL returned +ok=+ok=up_ErrType, and its UART log showed *system:ota fail after comparing the OpenBeken version string against stock values. Another user also suspected newer versions had been patched against custom firmware via OTA. The thread’s working pattern is clear: exploit success depends on firmware family and date, not just on using a BL602 chip. [#21418610]
What is BLDevCube, and how is it used to dump, restore, or flash factory firmware on BL602 devices?
BLDevCube is Bouffalo Lab’s serial flashing tool for BL602, used here for full-dump backup, factory restore, and wired OpenBeken flashing. Users restored 2 MB factory images, flashed raw OpenBL602 .bin files, and tested full-image writes from address 0x0 or app-region writes from 0x10000. One successful restore to a 4 MB dev board from a 2 MB Magic Home dump booted the stock LED... AP and even paired in the app. That made BLDevCube the main recovery tool when OTA failed. [#21063112]
How does the Magic Home BL602 OTA method compare with soldering and UART flashing in terms of reliability and recovery options?
The OTA method is faster and needs no soldering, but UART flashing is more reliable and easier to recover from. OTA works only when the stock firmware still accepts the vendor update trigger on UDP 48899. Wired flashing with BLDevCube can restore a full factory dump, write OpenBL602 directly, and recover devices that no longer expose an AP. If you have only 3 devices and a patched build, one user concluded it was quicker to use a soldering iron than keep spoofing OTA traffic. [#21418610]
What troubleshooting steps help when OpenBL602 flashes successfully but the OpenBL602_XXXXX AP never appears afterward?
Check power, boot wiring, partition layout, and UART logs before assuming the image is bad. The thread suggests using a stable 3.3 V supply instead of powering from a weak USB-to-UART adapter, disconnecting the BOOT pin after flashing, and capturing serial output at 2,000,000 baud. One responder also supplied a fixed 2 MB partition table for BL602 tests. "OpenBL602_XXXXX AP never appears" usually means the app booted incorrectly or the radio config is wrong, not that the flash write itself failed. [#21592996]
Why is the OpenBL602 firmware file much smaller than a full 2 MB factory dump, and what flash regions are intentionally left untouched?
The OpenBL602 file is smaller because it only replaces the application area, not the whole flash chip. A maintainer explained that full-chip overwrites would destroy RF calibration, MAC address data, Tuya GPIO config on supported platforms, and existing OpenBeken settings. That is why a release binary can be under 1 MB while the stock backup is 2 MB. The design is intentional, and it matches the goal of preserving board-specific data outside the main firmware partition. [#21586062]
How can I restore a BL602 device back to its factory firmware from a backup dump if OpenBeken flashing or configuration goes wrong?
Write the saved factory dump back with BLDevCube, then reboot and verify the original AP returns. The thread confirms a full 2 MB backup can restore a Magic Home BL602 to stock behavior, including the factory LEDnet... AP and normal app pairing. One user called this a tested dump-and-restore path for putting BL602 devices back to factory firmware. If OpenBeken config is broken, a full restore is the recommended reset path before trying another flash. [#21063222]
What is the CozyLife local JSON protocol on UDP 6065 and TCP 5555, and how is it different from the Magic Home AT-command method on UDP 48899?
CozyLife uses JSON messages on UDP 6065 and TCP 5555, while Magic Home uses plain-text AT commands on UDP 48899. A working CozyLife query looked like {"cmd":0,"pv":0,"sn":"...","msg":{}} and returned JSON with fields such as did, pid, mac, ip, and res. "CozyLife local JSON protocol is a device-control API that exchanges structured JSON commands and responses, unlike Magic Home’s short AT strings sent to the vendor pairing port." The thread also tied CozyLife cmd:5 to OTA experiments. [#21068684]
What should I try when a flashed Magic Home or OpenBL602 device disappears from both AP mode and my home WiFi after a failed setup?
First restore factory power-cycling, then inspect UART logs, and be ready to reflash from backup. A user who lost both the AP and home WiFi after setup was advised that AP mode may not recover with power cycling alone if the device crashes or stores bad settings. Another thread segment recommends watching serial logs, verifying power from the normal 5–28 V input, and restoring the original dump if needed. If the device stays silent, wired recovery is the practical next step. [#21264185]
How could the Sonoff DIY mode REST API or eWeLink update mechanism be investigated as a no-solder flashing path for BL602 Sonoff plugs and bulbs?
Investigate it by entering Sonoff DIY mode, capturing traffic, and testing whether its REST OTA endpoint accepts a local firmware URL. The thread mentions a BL602 smart plug exposing Sonoff DIY mode after holding the button for 5 seconds, with official documentation describing a RESTful API that includes OTA actions. eWeLink devices were also noted to use different ports and sometimes SSL, so packet capture and version checks are essential. The same no-solder idea may work, but the thread does not yet show a confirmed OpenBeken flash on Sonoff BL602 hardware. [#21188184]
