LCR-T4 electronics components tester ATMega328 - Test and Review
TechEkspert 228534 650
  • #511 17469053
    kwok
    Level 40  
    Help: 496
    Rate: 1342
    I coped with the display - I scraped the groove in the housing for protruding glass and ribbon. The possible advantage of this sculpture is that the display may not fall out, aesthetics .... well, the mill did not do it but I think that some veneer will be either painting because I do not like transparent covers. Added after 4 [hours] 53 [minutes]: The tester has one more hidden function - CIK-CIK ? LCR-T4 electronics components tester ATMega328 - Test and Review
  • #512 17472269
    miszczo997
    Help: 134
    Rate: 159
    KMal wrote:
    Unfortunately, in the current batch of testers the display on the side of the tape (connection) is wider, which causes the display glass to protrude beyond the plate.
    And I remember when they blurted me out when I asked for the instruction to fold, because I did not fit the elements :D I managed it this way. It was necessary to detach the display in order to cut off a piece of pcb and additional milling of mounting holes because the button is also slightly moved. LCR-T4 electronics components tester ATMega328 - Test and Review
  • #513 17496603
    diabelski
    Hello, do these testers see the IGBT transistors? Somewhere I saw a photo of someone IGBT was measuring ... or it seemed to me ...
  • #514 17496815
    p.obelix
    Refrigeration equipment specialist
    Help: 215
    Rate: 563
    Only after changing the software. There was something about it in this thread.
  • #516 17505703
    diabelski
    Is it possible to buy a ready device somewhere? i.e. with the changed soft as in the above link.
  • #517 17758633
    kakazx
    Hello, I have a similar miracle Portable HW-308 ESR Meter Transistor Tester Digital 12864 LCD Screen Tester and a problem of this type that does not detect coils ie inductance but only winding resistances. What could be the reason.
  • #518 17758713
    vodiczka
    Help: 1185
    Rate: 4311
    kakazx wrote:
    that it does not detect coils ie inductances but only winding resistances.
    No coils or only those with a relatively high resistance of windings? Mine is like that :cry:
  • #519 17760858
    kakazx
    There are no small capacitors below 100pF, either.
  • #520 17761150
    CMS
    Help: 258
    Rate: 2601
    Mine can measure the capacity of the test leads, these are around 20 Piko.
  • #521 17761215
    KMal
    Help: 340
    Rate: 1434
    LCR-T4 electronics components tester ATMega328 - Test and Review Please note that there are two different testers out there. LCR-T4 electronics components tester ATMega328 - Test and Review LCR-T4 electronics components tester ATMega328 - Test and Review LCR-T4 electronics components tester ATMega328 - Test and Review
  • #522 17761470
    brofran
    Help: 650
    Rate: 1408
    Different testers, but the measured elements also differ. Thus, it is not known which conclusion to make of it? :cry:
  • #523 17761627
    KMal
    Help: 340
    Rate: 1434
    The fact that they are different is of little importance in this case. It was not about comparing them (accuracy).
    ... refers to the above statements. The point is that two different ones measure what others do not work.
  • #524 17849030
    RonyNator
    Hello, I am asking the Society for advice, I am going to buy such a tester on ali, as I am an amateur amateur and I will test rarely and occasionally and I do not intend to improve, reprogram or exchange for a newer model, I want to buy optimally. Unfortunately, so many versions with different software have already come out that I find it difficult to catch up, in effect I chose the following models: LCR-T7 - supposedly with detection of D. Zenner and IGBT https://tiny.pl/tt9tp " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://tiny.pl/tt9tp and for self-assembly (what I'm afraid of), but with the generator and as I see some other functions, 2018 DIY kits ATMEAG328 M328 https://tiny.pl/tt9t2 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > https://tiny.pl/tt9t2 rather, I am leaning towards the other, unfortunately I did not have any in my hands and I do not know what to expect, and do they fundamentally differ in something other than soft and few exits? Greetings.
  • #525 17850062
    kakazx
    On YT you have several tests of such testers even for self-assembly. I bought mine after seeing but unfortunately as I wrote it is not quite ok with it but the zener diode detects those with lower voltage. I have not tried IGBT because I do not currently have one.
  • #526 17920238
    lordwader
    Rate: 37
    Hello, and it has happened, I connected to the LCR-T4 tester, as it turned out not fully discharged electrolyte. The tester died. Is there a chance to revive him or just exchange? Pozdr. K
  • #527 17920422
    AdamC
    Help: 140
    Rate: 246
    lordwader wrote:
    The tester died. Is there a chance to resuscitate him or just exchange? K
    Most likely, the cpu ports were damaged, after replacing the cpu and programming it should live. Check the accompanying elements of the cpu. Well, unless it so flashed that there is nothing to collect ;-)
  • #528 17920489
    lordwader
    Rate: 37
    In other words - replacing the tester .... It is a pity that there is no security there.
  • #529 17920514
    AdamC
    Help: 140
    Rate: 246
    lordwader wrote:
    In other words - replacing the tester ... It is a pity that there is no security there.
    I have not seen capacitors of this type in capacitor meters. The only security is the inscription: BEFORE MEASURING, UNLOAD THE CONDENSER! And from the company practice, there will always be someone who will connect a charged capacitor, damaging the meter.
  • #530 17920573
    lordwader
    Rate: 37
    Well ... Is the programmed atmel unreachable? ...
  • #531 17920602
    AdamC
    Help: 140
    Rate: 246
    There is still an option that someone in your area will program the processor you have purchased. Probably also in another place will be a helpful person.
  • SRV05-4 protection diode and zener test hazard
    #532 17920645
    Stanley_P
    Help: 62
    Rate: 294
    A colleague did not meet much ;-) In my tester Fri T7, which perfectly matches the TC1 tester diagram, which in turn can be viewed in this topic: https://www.elektroda.pl/rtvforum/topic3402823.html there is a security element titled. SRV05-4 (there are application notes on the net). I was saved by a processor in one of these testers, although it was "short-circuited" by myself. But after removing the element, the meter came to life, However, in another copy of the tester, unfortunately, the item failed and ended in processor damage. I would like to add as a curiosity that this first tester was damaged by ... the same tester. Namely, the T7 tester (also TC1) enables measurement of Zener diodes. On the terminals K and A (in the above-mentioned thread are pictures), a voltage of approx. 40V appears. I accidentally put a capacitor in it, and when I realized it, I translated it into the right terminals without thinking. Without unloading ... ;-) or rather :-( That is why K and A are currently covered with a piece of adhesive tape, which I remove only during measurements of Zener diodes, which take place quite rarely.
    The only security is the inscription: BEFORE MEASURING, UNPLUG THE CONDENSER !!! And from the company practice, there will always be someone who will connect a charged capacitor, damaging the meter.
    Of course, I agree with the above. Nevertheless, a colleague who has been damaged by the tester may look at the tape to see if there is a security element in his device, similar to the one I mentioned above. Greetings.
  • #533 17920721
    lordwader
    Rate: 37
    Unfortunately, there is no SRV5-04 on the board :(
  • Recommend TC1 or T7 instead of repair
    #534 17920762
    Stanley_P
    Help: 62
    Rate: 294
    In that case, he took a slingshot ... The question is whether to play in resuscitation? I took one look at the eyed-eyed ones - Ali's TC1 or T7 testers are now 15-20 $ circa, maybe you can shoot cheaper (less than 2 years ago about 30 $). Maybe it is worth going in this direction? You will have a "ready", i.e. with a ready casing, a rechargeable battery (charging by a standard microUSB), even with the Zener diode measurement up to 30V (you only need to be careful ;-) ). And with some sort of security, but a guarantee that it will always be protected. Well, but always a bigger chance than not at all ;-)
  • #536 17926089
    AdamC
    Help: 140
    Rate: 246
    lordwader wrote:
    but yes to the sport if someone programmed this atmela I would like to change ;) .
    Then you have to specify what software you want to program and what software version you have.
  • #537 17930904
  • #538 18318483
    WS38
    Rate: 23
    Gentlemen, I bought this tester (without a housing) and found that for greater safety in use and easier movement it is better to put the battery with the tester in one housing. At the first measurements, I dug out a box with old elements and, by the way, found a power supply that once fed my mother's calculator in deep PRL. I thought that since I want to put the tester in the housing, it can use this power supply?
    UNITRA ZATRA power supply model ZS 0.15 / 9/3
    220 V; 50 Hz; 5.5 VA
    9 V; 150 mA
    Same as shown in this thread:
    https://www.elektroda.pl/rtvforum/topic2512531.html
    My question, could I use this power supply to power this tester ???
    Possibly, what changes I would have to make.
    As you probably figured out, I'm just starting to play with electronics.
    I will be grateful for your help.
  • #539 18318546
    kkknc
    Help: 1916
    Rate: 6712
    The link is different. The one you have will do.
  • #540 18318716
    WS38
    Rate: 23
    Oh sorry, I've already corrected the correct link.
    I mean exactly this parameter on the output: 150 mA will it be the right intensity?
The discussion reviews the LCR-T4 / M328 transistor and component tester based on the ATmega328, focusing on its practical usefulness for amateur electronics and workshop diagnostics. Users report that the tester automatically identifies discrete components and pinout, measures resistance, capacitance, inductance, diode forward voltage, transistor type and hFE, and can also test some thyristors and MOSFETs, though not always perfectly. The device is considered sufficiently accurate for hobby use, but several limitations are noted: poor inductance resolution, no reliable measurement below about 20 pF, sensitivity to battery voltage, occasional misidentification of semiconductors, and lack of protection against charged capacitors. Calibration by shorting all three test leads is emphasized, and some users install alternative firmware with more extensive calibration options. Mechanical issues dominate the review: the ZIF socket is fragile, the display ribbon and LCD can be damaged or pop out during shipping, and many recommend adding a protective enclosure or reinforcing the display. The thread also compares variants such as T4, T7, TC1, and color-display versions, and discusses availability, pricing, and sourcing from Elektroda shop, Allegro, eBay, AliExpress, and Banggood.
TL;DR: LCR-T4 auto-tests 14 part types, draws only 12-15 mA per measurement, and “will be useful in every workshop” [Elektroda, TechEkspert, post #16556695] Accuracy stays within ±2 % for most resistors. Firmware flashing adds live-scan mode and Zener tests. Why it matters: you get multimeter-level insight from a €10 gadget.
• Supply: 9 V battery; 12-15 mA active, 20 nA sleep [Elektroda, 16556695] • R range: 0.1 Ω – 50 MΩ, C range: 25 pF – 100 000 µF, L range: 0.01 mH – 20 H [Elektroda, 16556695] • Typical accuracy: ±1 % R, ±3 % C, ±5 % L (user tests) [Elektroda, 16556695] • ESR read-out for electrolytics ≥1 µF [Elektroda, post #16556695] • Open-source firmware: AVR-based, 40 V boost for Zener mode [Elektroda, 16666684]
1. Which components does the LCR-T4 recognise?
It auto-detects resistors, capacitors, inductors, diodes (single & dual), LEDs, Zener diodes (≤30 V with updated firmware), BJTs, MOSFETs, JFETs, IGBTs (basic), thyristors, triacs, and voltage regulators [Elektroda, #16556695; #16666684].
2. How accurate are its measurements versus a quality multimeter?
User comparison showed 9.97 kΩ read as 10.18 kΩ (2 % high) and 100 µF read as 99.6 µF (0.4 % low) [Elektroda, 16556695] Inductance errors rise above 5 % near the 0.01 mH limit.
3. How do I calibrate the tester?
  1. Short pins 1-2-3 with low-resistance wire.
  2. Hold the single button until “Self-Test” appears.
  3. At 38 % remove jumper; at 82 % connect a >100 nF capacitor between 1-3 [Elektroda, 16556695]
4. What battery life can I expect?
A 550 mAh alkaline 6F22 supports roughly 30 000 tests (≈15 mA × 2 s each); users reported >2 years on one cell [Elektroda, bestler, post #16671201]
5. Why does my inductor show "resistor"?
The MCU flags coils below 0.01 mH or above 20 H as resistive. Bifilar wound or high-resistance windings can also be misread [Elektroda, 16708279]
6. Triac appears as NPN—faulty?
Not necessarily. High-gate-current triacs (e.g., KT207) may be detected as NPN when pin order flips. Confirm by testing both 180° rotations [Elektroda, 16585086]
7. What gains do I get from flashing new firmware?
Newest Git build adds: live-scan (continuous R/C/L), PWM & frequency generator, Zener/IR-LED test to 30 V, Polish UI, and logo support [Elektroda, 16666684]
8. How do I flash the AVR safely?
Use an ISP programmer, set fuses: LOW 0xE2, HIGH 0xD9, EXT 0xFC. Backup the factory hex first; then write the compiled .hex, verify, and power-cycle. Full guide in forum post #16666684.
9. Can I measure ESR in-circuit?
Yes for electrolytics ≥1 µF. Testers showed identical ESR values before and after desoldering PC-motherboard caps [Elektroda, Dydelmax, post #16669734]
10. What’s an edge-case the tester fails?
Charged capacitors can kill the input; one user cracked the LCD after a 50 V part was connected [Elektroda, 16579821] Always short large caps first.
11. How do I protect the ribbon display?
Stick 1 mm foam tape under the LCD and avoid flexing the gold ribbon. A clear acrylic case with 10 mm standoffs prevents pressure on the button [Elektroda, 16674114]
12. How do I assemble the acrylic enclosure?
Follow this 3-step: 1. Sandwich PCB between 10 mm spacers; 2. Insert LCD through front panel, secure with nuts; 3. Add rear plate and eight M3 screws [Elektroda, 16658664]
13. Why does the tester mis-show varicaps?
It measures junction capacitance at one bias only, so it logs them as ordinary diodes. A manual curve-tracer is needed for full C-V plots [Elektroda, 16689532]
14. Where can I buy or what’s the typical cost?
Ready-made LCR-T4 kits ship from AliExpress or eBay for €8–12; Polish stock adds ~40 % markup [Elektroda, 16567602] Shipping weight fits <2 cm letter rate.
