LCR-T4 electronics components tester ATMega328 - Test and Review
TechEkspert 228534 650
  • #541 18318797
    kkknc
    Help: 1916
    Rate: 6712
    It should be OK. Check how much the tester downloads.
  • #542 18318815
    gumisie
    Help: 1667
    Rate: 2486
    Why check?
    TechEkspert wrote:
    during measurement consumes 12-15mA current, while in sleep mode according to 20nA description (but in practice the current value should be lower,
  • #543 18319079
    DiZMar
    Help: 2892
    Rate: 6656
    WS38 wrote:
    ... 150 mA will this be the right amount?
    Enough.
  • #544 18320161
    WS38
    Rate: 23
    One more question, is it not too high intensity, and therefore, will any of the tester components not heat up ???
    Maybe try to lower them somehow? Can it leave it as it is?
  • #545 18320171
    Rezystor240
    Help: 689
    Rate: 1652
    WS38 wrote:
    therefore, will any of the tester components get hot ???
    Nothing will heat up, this is a stabilized power supply, so as much as it has the original power from a 9V battery. Connect without worries. Just watch out for polarities.
  • #546 18320194
    vodiczka
    Help: 1185
    Rate: 4311
    Hands fall down ;)
    Once again the question appears in the forum such as "whether the 12V 6W bulb (or 0.5A) will not burn when connected to a 12V7Ah battery"
    If the 9V supply voltage is correct, the tester will not consume more current than it needs.
  • #547 18320218
    WS38
    Rate: 23
    Not everyone is Einstein of electronics. But take it easy, I'm just starting out and I'm not offended when someone wants to demonstrate their superiority.
    What for? Still, thank you all for your help and clarifications.
  • #548 18320261
    vodiczka
    Help: 1185
    Rate: 4311
    And it doesn't have to be, but if you get the possession of the tester, the basics should be mastered. I do not demonstrate my superiority, but probably for the third time this month I read a similar question ...
    OKAY. There are no stupid questions, there are stupid answers and the first part of mine was not clever.
  • #549 18320326
    gumisie
    Help: 1667
    Rate: 2486
    And these:
    :cry:
  • #550 18320436
    WS38
    Rate: 23
    if you own the tester, the basics should be mastered.
    I'm working on it.
    But for greater pleasure, I want to combine theory with practical exercises. And for this you need components checked in the tester.
  • #551 18320456
    gumisie
    Help: 1667
    Rate: 2486
    @ WS38 tester calibration, did you do?
  • #552 18320493
    WS38
    Rate: 23
    I have read the calibration procedure:
    - jumper test pins 1,2,3,
    - then a 100uF capacitor. I need to buy a test capacitor with a tolerance of +/- 0.5%.
    I am puzzled, however, by the fact that one person calibrated with a larger capacitor and claims that this is the correct method.
    I have too little knowledge to judge, but it seems to me at least strange, since there is a clear 100uF recommendation.
    I admit that I have already tested some elements to check if the tester works and there are no irregularities.
  • #553 18320498
    gumisie
    Help: 1667
    Rate: 2486
    I confirm, you really have: "little knowledge" .
    Capacitor capacity is: 100nF not 100uF.
  • Repairing a 1982 Unitra Zatra power supply with LCR-T4
    #554 18368438
    WS38
    Rate: 23
    Thanks to this element tester, I was able to repair the power supply, which will eventually become the power supply for the tester.
    Short:
    The faulty historic power supply Unitra Zatra ZS 0.15 / 9/3 (board from December 1982) was dismantled and each part carefully checked. I did not have a schematic, so I intuitively replaced a few elements with other ones obtained from the electric scrap. Ceramic capacitors marked 22 nF (in fact, their capacities were different) I replaced 25 nF ceramic capacitors. The ELWA 470 uF 16 V and 330 uF 10 V electrolytic capacitors were replaced with the NICHICON 1000 uF 10 V and ELITE 470 uF 25 V electrolytic capacitors, respectively. which seems a plus with a small, tight housing. I just wonder if this NICHICON should have more V. (if you need a tip). The rest of the elements have remained unchanged and are original. After the repair, the power supply works, but its parameters have changed - from those given on the housing 9 V and 150 mA, after measurements with a multimeter I get 9.55 V and 283 mA. This last measurement may be inaccurate, because I used only a small light bulb for 6V and 0.5 A (only I found it).
    All in all, it's fun and gaining experience, because considering the amount of time spent, buying a new power supply is more economical. Especially that on this plate there were no copper paths printed, only made of tin, which in several places peeled off or cracked, it can even be seen that already in the factory they were reinforced with wire inserts.
    Thanks for all the tips and patience.
  • Poor-quality PCB traces peeled off easily
    #555 18368491
    Janusz_kk
    Help: 228
    Rate: 1478
    It is not, you worked in your free time, if you did nothing t this time you would lose forever, and so you have a power supply, i.e. you earned :)
    You can't make tin paths :) there they are copper only additionally tinned, and that then the paper laminates were exceptionally
    of poor quality, and these paths detached themselves from just looking :) not to mention the soldering iron.
  • Factory PCB traces are copper with tin plating
    #556 18368558
    WS38
    Rate: 23
    In fact, there is something that looks like a thin silver foil then thickly tinned, but in a few places there was no trace of it, although there were etches or ironing marks, so I was making connections again. It seems that the factory has not everywhere ironed and adhered, because in a few places there are very shallow marks, but there is no film.
  • No-load voltage is misleading under bulb load
    #557 18368896
    vodiczka
    Help: 1185
    Rate: 4311
    WS38 wrote:
    After the repair, the power supply works, but its parameters have changed - from those given on the housing 9 V and 150 mA, after measurements with a multimeter I get 9.55 V and 283 mA. This last measurement may be inaccurate, because I only used it as a load small bulb for 6V and 0.5 A (only that I could find).
    Dude, Ohm's law bows. ;)
    If the bulb at 6V draws approx. 0.5A (500mA) then when powered from 9V it should draw approx. 750mA.
    Since it only consumes 283mA it means that you overloaded the power supply and the voltage on his output settled after loading the light bulb.
    Measure what voltage you have with the bulb connected because these 9.55V is no-load voltage.
    After loading 150mA, the voltage should be around 9V.
  • #558 18368933
    Janusz_kk
    Help: 228
    Rate: 1478
    It just means that it measured the current with a light bulb and a SERIAL ammeter which added its resistance here.
  • #559 18368959
    vodiczka
    Help: 1185
    Rate: 4311
    You must be kidding, voltage drop on ammeter above 3V with current below 300mA :?: :D
    This would mean an ammeter resistance greater than 10?.
  • #560 18368973
    stasiek70
    Rate: 8
    And the bulb is not a linear element. So the current does not increase proportionally to the voltage.
  • Nonlinear bulb load makes ammeter resistance unclear
    #561 18368995
    Janusz_kk
    Help: 228
    Rate: 1478
    Not necessarily, the bulb is non-linear and as for the meter
    Read the thread about fuse, e.g. this post:
    https://www.elektroda.pl/rtvforum/topic3525704.html#18351285
    see for yourself, and we don't know what the author measured and to what extent.
  • Incandescent bulb current still follows Ohm’s law
    #562 18369003
    vodiczka
    Help: 1185
    Rate: 4311
    What's one got to do with another? I wrote that the current should be "about 750mA" and not exactly that. The difference in resistance between cold fiber and filament at nominal voltage is much greater than when the supply voltage differs by +/- 50% from the nominal.
    In addition, it is not possible for a bulb with a voltage higher than the nominal voltage to flow at a lower current than the nominal voltage. Ohm's law also applies to light bulbs ;)
    • LCR-T4 electronics components tester ATMega328 - Test and Review Zależność mocy żarówki od napięcia zasilania.gif (16.99 KB) You must be logged in to download this attachment.
  • Questioning whether to uprate 10 V Nichicon capacitor to 16 V
    #563 18369049
    WS38
    Rate: 23
    Let me explain:
    I measured the voltage with a multimeter directly at the ends of the cables coming out of the power supply (without a light bulb attached).
    Then I connected the bulb exactly 6V 0.3 A and multimeter measured the intensity. Initially, I gave a 0.5 A light bulb because I could not read its markings and I had two almost identical bulbs with this marking, but under the influence of the discussion I grabbed the magnifying glass and read 0.3 A with difficulty. I apologize for the mistake. Once again I have seen how important accuracy and precision are in electronics.
    I'm only worried about this Nichicon electrolytic capacitor for 10 V. Should I not replace it with at least 16 V for example ???
  • Requesting voltage and meter range under load
    #564 18369069
    vodiczka
    Help: 1185
    Rate: 4311
    WS38 wrote:
    Sorry for the mistake. Once again I have seen how important accuracy and precision are in electronics.
    OKAY. Half of the riddle is cleared.
    WS38 wrote:
    I measured the voltage with a multimeter directly at the ends of the cables coming out of the power supply ( without a light bulb attached ).
    Measure the voltage with the bulb attached, give the result and we will solve the puzzle to the end.
    Also write what ammeter you measured this 283 mA, if the multimeter is what current range was it set to?
    Added after 8 [minutes]:
    We will write this, we will find out, but the range must have been greater than 200mA since he measured 283mA, so guessing about the high resistance of the fuse in the meter ;)
  • LCR-T4 draws 360 mA and drops to 2 V
    #565 18369237
    WS38
    Rate: 23
    Measurement:
    The bulb is this time a new KRYPTON 4.8 V 0.5 A. Measurements made with the light bulb on:
    360 mA stable current. (The first measurements - described earlier for safety I made with a multimeter probe connected to the socket 10A max. Now I changed to mA and uA socket). Measuring range set to mA (Auto Range).
    Voltage dropping with continuous measurement from 2.6 V - to 2 V. At 2 V, the measurement was interrupted.
    Multimeter with which I took measurements: VOLTCRAFT VC175
    Power transformer very warm.
  • #566 18369339
    vodiczka
    Help: 1185
    Rate: 4311
    WS38 wrote:
    Voltage drop with continuous measurement from 2.6 V to 2 V.
    Mystery solved :|
    Both the voltage value and the heating transformer indicate a strong overload of the power supply.
    Connect both bulbs in series (those with 0.5A power consumption) and you should get a load close to the nominal. If it is still significantly above 150mA then connect both 6V (0.5A and 0.3A) in series
    Each capacitor should withstand a higher voltage than its nominal, at least 20% higher. Since you have 9.55V DC without load, that's OK. Old (Elwa) was also on 10V.
  • #567 18369859
    Janusz_kk
    Help: 228
    Rate: 1478
    You forget about the ammeter.
  • #568 18369894
    WS38
    Rate: 23
    Continued measurements:
    Because I did not find a light bulb for about 9 V. (one turned out to be burned out), I connected the old PiKO battery drill with 12 V DC found in the box.
    When the drill was working, the measurements were as follows:
    Direct voltage also 9 V.
    Leakage current from 96 mA to 101 mA. It rose and fell - so all the time.
    Can anyone now tell me responsibly whether this power supply will be suitable for this T4 electronic component tester?
    Because the further into the forest the more trees and I see how much more I have to learn.
  • #569 18369924
    gumisie
    Help: 1667
    Rate: 2486
    Once again: YES.
    Do not mix with these bulbs, because in a moment you will damage it and it will be "sneezing".
  • #570 18369938
    WS38
    Rate: 23
    I'm not combining anymore. Thanks a lot!
    Can anyone explain to me in a nutshell what this leaping intensity is all about? What is this phenomenon? I read the rest myself, because I was curious.
The discussion reviews the LCR-T4 / M328 transistor and component tester based on the ATmega328, focusing on its practical usefulness for amateur electronics and workshop diagnostics. Users report that the tester automatically identifies discrete components and pinout, measures resistance, capacitance, inductance, diode forward voltage, transistor type and hFE, and can also test some thyristors and MOSFETs, though not always perfectly. The device is considered sufficiently accurate for hobby use, but several limitations are noted: poor inductance resolution, no reliable measurement below about 20 pF, sensitivity to battery voltage, occasional misidentification of semiconductors, and lack of protection against charged capacitors. Calibration by shorting all three test leads is emphasized, and some users install alternative firmware with more extensive calibration options. Mechanical issues dominate the review: the ZIF socket is fragile, the display ribbon and LCD can be damaged or pop out during shipping, and many recommend adding a protective enclosure or reinforcing the display. The thread also compares variants such as T4, T7, TC1, and color-display versions, and discusses availability, pricing, and sourcing from Elektroda shop, Allegro, eBay, AliExpress, and Banggood.
TL;DR: LCR-T4 auto-tests 14 part types, draws only 12-15 mA per measurement, and “will be useful in every workshop” [Elektroda, TechEkspert, post #16556695] Accuracy stays within ±2 % for most resistors. Firmware flashing adds live-scan mode and Zener tests. Why it matters: you get multimeter-level insight from a €10 gadget.
• Supply: 9 V battery; 12-15 mA active, 20 nA sleep [Elektroda, 16556695] • R range: 0.1 Ω – 50 MΩ, C range: 25 pF – 100 000 µF, L range: 0.01 mH – 20 H [Elektroda, 16556695] • Typical accuracy: ±1 % R, ±3 % C, ±5 % L (user tests) [Elektroda, 16556695] • ESR read-out for electrolytics ≥1 µF [Elektroda, post #16556695] • Open-source firmware: AVR-based, 40 V boost for Zener mode [Elektroda, 16666684]
1. Which components does the LCR-T4 recognise?
It auto-detects resistors, capacitors, inductors, diodes (single & dual), LEDs, Zener diodes (≤30 V with updated firmware), BJTs, MOSFETs, JFETs, IGBTs (basic), thyristors, triacs, and voltage regulators [Elektroda, #16556695; #16666684].
2. How accurate are its measurements versus a quality multimeter?
User comparison showed 9.97 kΩ read as 10.18 kΩ (2 % high) and 100 µF read as 99.6 µF (0.4 % low) [Elektroda, 16556695] Inductance errors rise above 5 % near the 0.01 mH limit.
3. How do I calibrate the tester?
  1. Short pins 1-2-3 with low-resistance wire.
  2. Hold the single button until “Self-Test” appears.
  3. At 38 % remove jumper; at 82 % connect a >100 nF capacitor between 1-3 [Elektroda, 16556695]
4. What battery life can I expect?
A 550 mAh alkaline 6F22 supports roughly 30 000 tests (≈15 mA × 2 s each); users reported >2 years on one cell [Elektroda, bestler, post #16671201]
5. Why does my inductor show "resistor"?
The MCU flags coils below 0.01 mH or above 20 H as resistive. Bifilar wound or high-resistance windings can also be misread [Elektroda, 16708279]
6. Triac appears as NPN—faulty?
Not necessarily. High-gate-current triacs (e.g., KT207) may be detected as NPN when pin order flips. Confirm by testing both 180° rotations [Elektroda, 16585086]
7. What gains do I get from flashing new firmware?
Newest Git build adds: live-scan (continuous R/C/L), PWM & frequency generator, Zener/IR-LED test to 30 V, Polish UI, and logo support [Elektroda, 16666684]
8. How do I flash the AVR safely?
Use an ISP programmer, set fuses: LOW 0xE2, HIGH 0xD9, EXT 0xFC. Backup the factory hex first; then write the compiled .hex, verify, and power-cycle. Full guide in forum post #16666684.
9. Can I measure ESR in-circuit?
Yes for electrolytics ≥1 µF. Testers showed identical ESR values before and after desoldering PC-motherboard caps [Elektroda, Dydelmax, post #16669734]
10. What’s an edge-case the tester fails?
Charged capacitors can kill the input; one user cracked the LCD after a 50 V part was connected [Elektroda, 16579821] Always short large caps first.
11. How do I protect the ribbon display?
Stick 1 mm foam tape under the LCD and avoid flexing the gold ribbon. A clear acrylic case with 10 mm standoffs prevents pressure on the button [Elektroda, 16674114]
12. How do I assemble the acrylic enclosure?
Follow this 3-step: 1. Sandwich PCB between 10 mm spacers; 2. Insert LCD through front panel, secure with nuts; 3. Add rear plate and eight M3 screws [Elektroda, 16658664]
13. Why does the tester mis-show varicaps?
It measures junction capacitance at one bias only, so it logs them as ordinary diodes. A manual curve-tracer is needed for full C-V plots [Elektroda, 16689532]
14. Where can I buy or what’s the typical cost?
Ready-made LCR-T4 kits ship from AliExpress or eBay for €8–12; Polish stock adds ~40 % markup [Elektroda, 16567602] Shipping weight fits <2 cm letter rate.
