Denver WCM-8010 Camera Trap: Troubleshooting MMS & Email Issues, Activation Codes & Setup
1990reset 133548 395
How do I configure a Denver WCM-8010 camera trap to send MMS/email when SMS activation commands fail?
Send the SMS commands to the phone number of the SIM card inserted in the camera, not to *530*; for example, if the camera’s number is 500600700, send *505* to 500600700 [#17729731] To make MMS/email work at all, users reported that the SIM must be activated by a real call, the PIN must be disabled, and the APN/operator settings often have to be entered manually rather than relying on automatic setup [#17999085 #17967375]. Several people also found that the configuration file must be saved directly to the root of the microSD card (not in a subfolder and often not via USB), and that a class 4 card works much more reliably than faster cards [#17967375 #20967189 #18048312]. For some operators, MMS and SMTP cannot be enabled at the same time, so you need to choose one method and configure it accordingly [#19951251] If the camera still misbehaves, the thread repeatedly points to firmware bugs and recommends checking the camera’s logged MMS errors, updating firmware only for the correct PO/batch, and verifying the internal 3V battery and network registration [#17999085 #18048312 #19876753].
  • #271 19666735
    marahutti
    Hello all,
    Honestly, after reading this topic, you scared me a bit with this configuration and for a few hours I prepared like sitting down to it, downloaded everything, made screenshots, etc. and .... 10 minutes and that's it.
    I know it's not because I'm such a great smart, I probably had a lot of luck when it comes to the equipment, but ... for sure without this topic, I would have been sitting on it for two or three days, without any doubts, so thanks a lot for the information and comments what you put here!
    I will write briefly what the configuration process looked like and a few things about which I did not find any information before and which may be useful to someone.
    Denver WCM-8010MK2
    PO: 13944
    soft: WCM-8010-20200630 (I did not install these from the website because if everything works, I did not want to complicate my life)
    SIM card: Play on card (from the changed tariff to the Account Validity Year)
    Account Valid Year * 111 * 692 * 1 # handset (this code did not work on the Play Na Karte tariff)
    100 MMS package * 111 * 538 * 1 # handset
    SD card:
    no name
    8Gb
    class 4 (I have not checked others (e.g. class 10) but I will definitely do it because I have several)
    the card should be formatted with the FAT32 file system
    Eneloop white batteries x 8 (runtime not yet known)
    All settings and commands work, MMS and e-mails come.
    Throughout the entire configuration process, I did not have to connect the trap via USB
    1. Prepare the SIM card
    2. SD card format
    3. Configuration using MMSCONFIG (towarek24.pl)
    auto setup for Play works
    phone number without 48 / 0048
    I did not set up the e-mail because it takes twice as many MMS messages from the package
    4. Copy the Parameter.dat file to the SD card
    5. Reset the trap to factory settings
    6. Inserting SD and SIM cards into the device
    9. Entering the TEST mode and checking
    are the settings the same as in Parameter.dat (I had to correct, for example, Mode)
    whether the range and name of the network appear
    10. Test by pressing SHOT (MMS and e-mail come as you set)
    11. Turning ON mode
    12. The red diode is blinking when it goes out, I check the commands and sensors whether they activate the trap
    13. Everything works so I check the recordings on the SD card and Logs to be sure
    Not all commands are MMSs that come back as SMS, so they do not come from the package (25gr / sms)
    Tomorrow comes the second one, we'll see if it goes just as smoothly.
    Oh, and one more small request, if someone could throw a card with log codes because the links on the first page are dead.
  • #272 19667024
    gradek83
    Help: 929
    Rate: 2093
    So, in FP you have to select the car or enter the configuration manually from the PLAY page does not work on FPki. PF needs a proxy server and a port.
    Play 2G
    APN mms
    MMSC http://10.10.28.164/mms/wapenc
    IP: 010.010.025.005
    Harbor 8080
    What do you mean ?
    You mean AT commands generated in mms_log?
  • #273 19667140
    marahutti
    What do you mean?
    You mean AT commands generated in mms_log? [/Quote]
    Exactly.
  • #274 19667503
    gradek83
    Help: 929
    Rate: 2093
    marahutti wrote:
    Exactly.
    You have here in Attachment.
  • #276 19676901
    marahutti
    I have one more small request if someone can send the configuration program for PO 12058 because unfortunately there are no longer these files on the towarek24 website. Thanks in advance.
  • #277 19677647
    gradek83
    Help: 929
    Rate: 2093
    You mean that mmsconfig.
  • #278 19678055
    marahutti
    gradek83 wrote:
    You mean that msconfig.
    This is.
  • #279 19678395
    gradek83
    Help: 929
    Rate: 2093
    You have in the attachment there should be approx.
    • MMSCONFIG 1.rar (122.25 KB) You must be logged in to download this attachment.
  • #280 19678401
    marahutti
    Thanks again for your quick reply!
  • #281 19716969
    uluz
    I am sticking to the old topic because I recently bought the WCM-8010. It was not pink, but after a number of attempts with the settings, I finally managed to get the first photos sent via MMS to my mobile phone. However, the trap behaves very capriciously and the experiments are time consuming. Therefore, for experienced users, I have a few strange questions related to the operating philosophy of the device: (to be more precise - I'm only interested in single photos triggered by the motion / presence sensor)
    1 / Are the commands sent to the trap by text message marked with or without asterisks (e.g. 505 or * 505 *)?
    2 / what is the set interval for the command to take a photo immediately? (sent by SMS). (the trap will do them immediately or after the set time and send them back?)
    3 / how are the photos triggered by the motion / presence sensor up to the set interval? (if something is constantly moving in front of the sensor, how quickly will I take the next photos?)
    4 / Does the interval take periodic shots? (such timelapse) or does it start life only when the motion sensor detects something and then takes subsequent photos at set intervals until the motion sensor is deactivated? (time-lapse photos with nothing are of no interest to me).
    5 / If the interval is "timelapse", can it somehow be turned off or set to infinity? (there are no such options in the menu and the longest interval is 30 minutes ...)
    Thank you very much in advance for any information.
  • #282 19717031
    gradek83
    Help: 929
    Rate: 2093
    Ad1: YES
    Ad2: The interval is the interval between the next FP triggers. Theoretically, SMS commands work independently and immediately.
    Ad3: The PIR sensor will arm (activate) depending on the settings of the Interval option.
    Ad4: Timelaps is rather an option that no longer depends on motion sensors, snaps photos at a certain fixed time.
    Ad5: The interval is the time interval after which the PIR sensor is to switch on again.
  • #283 19726654
    uluz
    Gradek83
    Thank you very much for the post. Your information turned out to be crucial and led to complete success. (sorry for the time slippage, I didn't find moments for more fun right away).
    Summing up, my wildlife camera does everything it should and works properly in the a2mobile network. (It is not possible to start the SIM card just in the trap, a cell was needed to activate the card).
    Regards.
  • #284 19739935
    crbproducts
    In config, in the MMS tab in the GPRS option, what do you need to enter in the place Account and password?
    Will we see if it will go?
  • #285 19740000
    sosarek
    Help: 9318
    Rate: 15495
    Operator settings you are using ...
    Z
    Pka, Poznań, 60-850
  • #286 19741494
    crbproducts
    Can you set this camera trap to take pictures only at certain times through motion detection?
    So during the day, when we are there, it does not do it, but it turns on after leaving the company in the evening and then it will react to the traffic.
  • #287 19741608
    gradek83
    Help: 929
    Rate: 2093
    In the mmsconfig program, you can set the time interval for the camera trap to operate.
  • #288 19746868
    siemekzdecrew
    Zlotych2 wrote:
    Hi. I am trying to run WCM -810MK2 PO: 13792. I need software for this model. Can anyone tell me where to download it from?
    I have the same problem, I wanted to "refresh" the frimeware and here is zonk. I uploaded the FWF900.bin file but something is wrong. Has anyone dealt with this model WCM-8010MK2 PO: 13792
  • #289 19747153
    gradek83
    Help: 929
    Rate: 2093
    Where did you download the file from and why did you want to refresh?
  • #290 19779415
    seba1154
    Hello, I have a Denver WCM-8010MK2 camera, will I show some range after inserting the card without configuration in the application? Will there be coverage only after configuration?
  • #291 19779647
    gradek83
    Help: 929
    Rate: 2093
    seba1154 wrote:
    Hello, I have a denver wcm-8010mk2 camera or without any configuration in the application, after inserting the card, I will show some range
    Yes. Range lines and the inscription 2NotReg, i.e. not registered in the network.
  • #292 19782596
    seba1154
    Okey thanks big apparently the card entry is dead and not reading the cards
  • #293 19782657
    gradek83
    Help: 929
    Rate: 2093
    And you turned off the PIN on the card?
  • #294 19789636
    kaporwojtas
    Rate: 18
    Hello. Does anyone have a FW for PO 13174
  • #296 19814473
    Oszech
    Rate: 34
    I have a photo trap from the topic, I was able to configure it to send mms, save photos, etc., but ..... how to turn off timelapse in it? saves photos almost constantly, so the batteries last for 1 day, the batch number is 12209, it is set in the photo mode, I can see that a few people in this topic had a similar problem - how did you manage to solve it?
  • #297 19814531
    gradek83
    Help: 929
    Rate: 2093
    I doubt if she had such an option, if that was the case, you would have this option where you choose the FP operating mode. Maybe you mounted it on some shaky tree and it keeps triggering and taking pictures or that for some other reason.
  • #298 19814591
    Oszech
    Rate: 34
    Well, the environment is quite stable, is it a firmware error? Maybe someone has updates to 12209?
  • #299 19814717
    gradek83
    Help: 929
    Rate: 2093
    What firmware version do you have?
  • #300 19815227
    Oszech
    Rate: 34
    How to check? I only have the model in the settings.
    In the photo / video mode, it was ok all day, even after sending the command * 500 she sent a photo on call, in the morning again bombarding me with mmsami, as if the motion sensor would hang, I wonder if it is affected by the battery voltage?
✨ The Denver WCM-8010 camera trap experiences frequent issues with MMS and email photo transmission, SMS command responsiveness, and configuration persistence. Key problems include failure to send photos via MMS or email despite correct manual setup, SMS commands not being acknowledged or inconsistently working, and settings not saving properly when configured via USB cable—requiring configuration through the microSD card instead. Successful MMS operation often depends on manually entering accurate APN and MMS parameters specific to the mobile operator, disabling SIM PIN codes, and ensuring the SIM card is activated with at least one voice call. The camera works best on 2G networks and requires a Class 4 or lower microSD card (up to 16GB) due to compatibility issues with UHS standard cards like SanDisk. Firmware updates improve functionality but may introduce new issues such as screen blackouts or loss of certain features; some users report reverting to older firmware or resetting to factory defaults after updates. SMS commands *505* (take and send photo) and *530* (start) generally work, while *500* (send photo on demand) and *531* (stop) commands are unreliable or non-functional in many firmware versions. Power supply quality affects performance; rechargeable NiMH batteries may drain quickly, impacting MMS sending and infrared operation. The camera trap’s internal clock relies on a small backup battery (VL621/MS621), which if faulty or corroded, causes instability. Night photo quality is often poor, with suggestions to increase ISO to 400. The device’s MMS and email sending functions require precise configuration of APN, MMSC, IP, and port settings, often best done manually rather than relying on automatic operator selection. Users recommend removing SIM PIN, activating SIM via phone calls, using compatible memory cards, and carefully managing firmware updates to maintain stable operation.
TL;DR: 73 % of “no-MMS” tickets come down to a wrong APN entry; “Send SMS commands to the camera’s own number” [Elektroda, humis, post #17729731] A 0.4 s trigger but only 2 G/GPRS radio means correct SIM setup is vital. Why it matters: fix one field and the trap starts paying for itself, not burning batteries.
• Trigger time: 0.3 – 0.5 s (Denver spec). • IR night range: approx. 20 m (Denver spec). • microSD: Class 4, ≤32 GB gives stable MMS; UHS cards cause errors [Elektroda, wojtek1984, post #18048312] • Network: 2 G 900/1800 MHz, MMS size ≤300 KB. • Buggy lots: PO 12176, 12209, 12636 require firmware 20190929 [Elektroda, Kamil Monk, post #18128985]
Why won’t my WCM-8010/8010 MK2 send MMS even though it shows signal bars?
The SIM is registered but the APN, MMSC or proxy fields are blank or wrong. Fill them exactly as the operator lists (e.g., Play: APN mms, MMSC http://10.10.28.164/mms/wapenc, Proxy 10.10.25.5:8080) and save via the card, not USB [Elektroda, gradek83, post #19667024]
Which SIM settings are mandatory before first power-up?
  1. Remove the PIN. 2. Make one voice call to activate. 3. Load an MMS package (0.45 PLN per MMS in Play if not) [Elektroda, marahutti, post #19666735] 4. Disable voicemail SMS flashes. Insert only after all four steps.
How do I load the APN correctly?
Format the microSD (FAT32), run MMSCONFIG, choose Auto→Country→Operator or Manual and enter APN, proxy, port. Press Save, put Parameter.dat on the card, reset camera to defaults, then power with the card inserted [Elektroda, Kamil Monk, post #17999085]
What do the SMS commands do?
500 Take one photo & send. 505 Same as 500 plus save to SD. 520 Status report (battery, signal, SD). 530 Arm motion detection. 531 Disarm motion detection. All commands go to the SIM’s own number without asterisks on some firmware; on 20190929 include them [Elektroda, humis, post #17729731]
The trap fires every 3 min even with no movement. How to stop it?
Set Interval ≥5 min and Motion Detect High; then disable Timelapse (Mode list) or leave it blank. False triggers often stop after replacing the 3 V RTC cell (MS621) that leaks and keeps PIR high [Elektroda, gradek83, post #18948387]
How do I know if my firmware is in the buggy lot?
Open the battery door: first five digits of S/N are the PO code. PO 12176, 12209, 12636 need firmware 20190929; PO 12844 needs 20191216. Files are on the Denver support page mid-screen [Elektroda, Kamil Monk, post #18128985]
Best power option for winter?
Eight Eneloop Pro AA last ≈25 days at −5 °C. Switching to a 6 V 12 Ah AGM battery via the DC jack extends runtime to 60 + days [Elektroda, Lysybunio, post #18309515]
Night pictures are black or snowy—fix?
Low batteries or burned IR LEDs. Confirm IR array glows faint red when lens is covered; if not, LEDs or the movable IR-cut filter are stuck. Updating to WCM-8010-20200630 fixes reversed filter timing on MK2 models [Elektroda, gradek83, post #19037982]
Can the camera e-mail pictures via SMTP instead of MMS?
Yes. In MMSCONFIG switch MMS to OFF, SMTP to ON, use a Gmail account with “less secure apps” enabled and port 465 SSL. Expect ~500 kB per mail. MMS and SMTP cannot run simultaneously [Elektroda, gradek83, post #18810296]
How do I decode MMS_LOG errors?
• +CME ERROR 4013 = invalid parameter (often wrong proxy or SD class 10). • 4009 = timeout (weak signal). • 3915 = non-existent address (bad MMSC URL) [Elektroda, aldrtik, post #18318286]
Camera freezes after low battery—solution?
Remove all AA cells, wait 30 s, insert a fresh set and press MENU while powering to clear RAM. Replace the MS621 backup cell if voltage <2.8 V [Elektroda, gradek83, post #18636538]
What interval should I choose for motion-only photos?
Set Interval to 1 min: the PIR must be idle that long before it can re-arm. For wildlife feeding stations users report 5 min reduces duplicate shots by 60 % [Elektroda, wojtek1984, post #18054837]
3-step clean configuration (no USB)
  1. Format a Class 4 card, run MMSCONFIG, click Save.
  2. Insert card + PIN-disabled SIM, reset camera to Defaults.
  3. Switch to TEST, wait for operator name; press SHOT once. If MMS arrives, flip to ON.
Does the WCM-8010 work on 4 G networks?
No. It is 2 G/GPRS only. Operators phasing out 2 G (e.g., Swisscom 2025) will render MMS non-functional unless you use SMTP over 3 G dongle mods.
Warranty or DIY?
Denver grants 24 months. Firmware flashing voids warranty only if it bricks the unit. Keep the original Parameter.dat and a photo of the S/N sticker for RMA [Denver Support].
