Denver WCM-8010 Camera Trap: Troubleshooting MMS & Email Issues, Activation Codes & Setup
1990reset 133548 395
How do I configure a Denver WCM-8010 camera trap to send MMS/email when SMS activation commands fail?
Send the SMS commands to the phone number of the SIM card inserted in the camera, not to *530*; for example, if the camera’s number is 500600700, send *505* to 500600700 [#17729731] To make MMS/email work at all, users reported that the SIM must be activated by a real call, the PIN must be disabled, and the APN/operator settings often have to be entered manually rather than relying on automatic setup [#17999085 #17967375]. Several people also found that the configuration file must be saved directly to the root of the microSD card (not in a subfolder and often not via USB), and that a class 4 card works much more reliably than faster cards [#17967375 #20967189 #18048312]. For some operators, MMS and SMTP cannot be enabled at the same time, so you need to choose one method and configure it accordingly [#19951251] If the camera still misbehaves, the thread repeatedly points to firmware bugs and recommends checking the camera’s logged MMS errors, updating firmware only for the correct PO/batch, and verifying the internal 3V battery and network registration [#17999085 #18048312 #19876753].
  • #61 18238522
    Hawran7
    Thanks so much for the latest software updates. After three days of fight, finally the webcam started sending mms.
  • #62 18239015
    tech7
    Because I'm going to buy the above model currently on the manufacturer's website for 309 zlotys, I have a few strict technical questions to the previous speakers because I can see that it wasn't without a fight.
    1. Can the camera trap send MMS only without using any cellular data, very important because only the MMS package with no cellular data should be launched on the prepaid sim card.
    2. Is the gsm antenna bent?
    3. Can the camera trap be powered by 1.2 V 2500 mAh rechargeable batteries, will they be able to power the device and whether they are charged after connecting the power supply, if possible.
  • #63 18248835
    Bemex
    Hello and I have such a problem, the camera sends photos regularly every 6 minutes until all the funds on the account. And the second thing is the quality of the photos, it will go away during the day but the massacre is hardly visible at night, some strange tingling like in old TVs. If anyone knows what's going on, please give me some tips
  • #64 18251463
    aldrtik
    Kamil Monk wrote:
    ... software that should solve most problems.
    ...camera series 12636...
    Thank you Kamil about effort with this issue.
    During the test with this FW (md5sum "28284c8477d02b5ebb6d931f9cec8225") in my cam (series PO12636) doesn't send pics on demand with SMS command *500*. All other commands works (MMS *505* untested). I am going to extensively test quality of pics.
    Official firmware (FWF900.bin with md5sum "c0eb61ff3317a2a24d2e2e0ad80e21b7") this time at:
    https://www.dropbox.com/sh/ty764rzsa84cq1x/AAALXZkL0gfP2HZUx0AxLui9a?dl=0
    link from:
    https://denver-electronics.com/products/camer...e-camera/denver-wcm-8010/c-1024/c-1197/p-3192
    in the cam sends pics on arbitrary SMS command. SMS commands: *531* Camera sleep.*520* Get Pic information are defunct.
    Quality of pics untested yet.
    Denver support hasn't sent functional FW according to trivial SMS control in user manual, similarly as Suntek with HC-800M cam.
  • #65 18258866
    aldrtik
    Bemex wrote:
    ... sends photos regularly every 6 minutes until all the funds on the account.
    And the second thing is the quality of the photos, it will go away during the day but the massacre is hardly visible at night, some strange tingling like in old TVs...
    Suntek HC-800M cam has time lapse in menu, but WCM-8010 doesn't have it (but I don't know all possible versions of FW).
    I would do (maybe new FW from Denver ), reset to default, format SD card and use mmsconfig to generate new Parameter.dat -> copy to SD card. If it does not help, it is probably broken.
    Quality of pics is pure (snowy) especially in the night when bad FW is used. Another reason is discharged batteries and/or low temperatures with use NiMH cells - IR LEDs drains weak cells.
  • #66 18276007
    Doo1in
    tank
    help with wcm 8010 ...
    all day she was taking photos on the move - three as arranged, 10sec video, the first sent via SMS as well as by e-mail :)
    520 - sent data
    530 - she made the start, 531 she made the stop
    but - it doesn't respond to 500 and 505 :(
    any ideas?
    best regards,
    d
  • #67 18279184
    Lirdtom
    Gentlemen, lead a blind man, since yesterday this photo trap MMS does not send Play card how to upload new software SD card type 2 does not respond to SMS Play card and the network shows t mobile
  • #68 18288524
    aldrtik
    Doo1in wrote:
    tank
    any ideas?
    d
    Yes it is known issue. This firmware is here with courtesy to Kamil and his effort with the support. So FW is best to now I have ever known.
    Denver support wrote me that SMS control is "testing only feature". I have replayed him that this cam costs more than without SMS control and SMS control functionality is in user manual and no producer has say that SMS control is for test purposes only.
    It is need to complain to Denver support about it from most of users.
  • #69 18291230
    aldrtik
    Doo1in wrote:
    tank
    d
    They say now:
    Code 500 and 505 only works when motion are not being detected.. tested here without any problems.
    Best regards
    INTER SALES A/S
    DENVER ELECTRONICS A/S
    • Denver WCM-8010 Camera Trap: Troubleshooting MMS & Email Issues, Activation Codes & Setup image001.png (206.75 KB) You must be logged in to download this attachment.
  • #70 18299614
    aldrtik
    Camera PO12209, 12176 & 12636
    firmware with md5sum:
    dda75777425a1509c937a82f47d78938 FWF900.bin
    doesn't send pics with SMS commands *500* and *505*, other commands works.
    Is somebody successful with these control commands?
  • #71 18302689
    przemek1337
    Gentlemen, I have a different problem. I installed the software update and after this installation I start the cam in the "Test" mode, the image from the camera appears on the screen for 1 second and everything disappears. Could these be batteries that were inserted 4 days ago?
  • #72 18305608
    aldrtik
    przemek1337 wrote:
    If it does the same with fresh set of batteries (recharcheable works for me) you have to use upgrade FW from Kamil (previous page). This one is well tested. If it doesn't operate with Kamil FW on fresh bat's, the cam would be broken.
  • #73 18307252
    cassim12
    Gentlemen, hello, I have a small problem with the power supply, I suspected it yesterday at noon and notifications stopped reaching 18.37 today I approach it and the red diode blinks quickly at the top where the infrared. TEST mode the screen has turned on and on several times. The battery status is shown on the display full (Panasonic Pro Power batteries) (I put new batteries in and everything works as it should (only how long). Has anyone encountered a similar problem?
    New Soft uploaded
    It seems a slight continuous squeak when you approach the ear it can be heard
  • #74 18309515
    Lysybunio
    Welcome. Some insights after prolonged use of this camera. As I wrote earlier, uploading a new software helps only temporarily when it comes to sms commands regarding the "Start, Stop" function. So I gave it up. The command "* 505 * - after which the camera takes a picture and sends mms works flawlessly. As one of the colleagues wrote a few posts earlier, the commands are probably in the testing phase. The sim card in the Play network works flawlessly. The camera works better on configuration with HC 300M than on the manufacturer's dedicated. The ground is power supply. The AGM 6V 12Ah gel battery has been working without a problem for a month now. I also use JAPANESE ENELOOP PRO AA R6 BLACK BATTERIES as black, but the charge time is shorter to max. faster, although on the HC 300M they last up to a month. The red shining diode usually indicates the discharge of the rechargeable batteries, although sometimes as if the camera hung and just turn it off and on again. As I wrote the base is a good power supply. As I wrote earlier with I don't have as many problems with the HC 300M camera as with the WCM 8010.
  • #75 18313342
    aldrtik
    This FW is the first I have ever seen that can send pics with SMS controll command *500*
    md5sum:
    6efadc6c4427e02fc75b7d081acbd1b5 FWF900.bin
    but all other SMS commands does pics on SD card even if they don't dedicated to it.
    After the command *531* (Camera stop) the only way to use camera is manually reboot or set to default.
    Denver (Suntek) can not make the software (FW).
  • #76 18314233
    tomekgol9191
    Hi.
    Please help. Does not send all photos. Only part, MMS / SMS package purchased. What is the cause. Works on commands 530/531. It doesn't work on e.g. 505.
    • MMS_LOG.TXT (223.36 KB) You must be logged in to download this attachment.
  • #77 18318286
    aldrtik
    tomekgol9191 wrote:
    Kamil's links on page 1:
    4013 Invalid parameter
    3915 Non-existent address
    4009 Time out
  • #78 18319089
    gradek83
    Help: 929
    Rate: 2093
    aldrtik wrote:
    3915 Address does not exist
    There is probably a lack of funds on the account "2019/11/24 17:21:27"
    The photo is copied to the RAM and then sent, it is worth setting it so that the photos were taken more than one because sometimes it may just not get it .... or a problem with the memory card somewhere about this someone wrote that there must be a suitable memory card .
    aldrtik wrote:
    4009 Time out
    The problem with saving the file reduce the quality of the photo and try then .... anyway, I bet that something with the SD card is wrong. What is your exact card inserted there?
    Helpful Information.
    LINK
  • #79 18395277
    Freemo
    Hello everyone.
    Unfortunately, I also became the owner of this crap. My problem is that after winning a new software from the manufacturer, which was given here for one of the camera traps (12636 series). There is ... a mirror image on the screen.
    Of course, I can't even dream about reacting to SMS commands.
    The second one only sends a photo taken in the test mode to the given number and e-mail address. The attached one does not respond to SMS commands.
    I have a question.
    How did you send this message to the site?
    What address etc.
    I really ask for specific answers.
    I bought at proshop.pl
    Of course I have already written to them. Adding that he is waiting for help, or the answer if I have to buy normal equipment elsewhere.
    People advise because it's a shame about money, and I walk around the property at night.
    I have such a job that I can get out of it quickly at night and surprise guests. That's why this camera trap is great for me. But what about how SMS doesn't work.
  • #80 18397676
    wojtek1984
    Rate: 92
    And you did reset the photocells to factory settings ...? Win the settings for the microSD card again and don't forget to remove the batteries after a factory reset. If that doesn't work, win the soft one that I inserted a few posts earlier and do a reset again and set all options again. Set to 3 pictures when taking pictures.
  • #81 18411236
    tom73
    Could someone send a firmware to PO: 13057
  • #82 18456540
    JimmiPOL
    Well, in addition to all this described above, after uploading the software, when you start the test, unfortunately the DENVER image appears for a second and there is only a wink of the screen, then it turns black.
    Is there a way to completely restore the old software? There was something to be seen there.
    I only noticed that on the new software he takes pictures and writes to the card in the UHS standard, which she had not done before.
    The problem with MMS has not been solved.
    In the end she sent me a mmsa, but as if he didn't use infrared at all. From the photo you can not recognize practically anything that is more than a meter away. A bit weak trap, if the intruder had to make a selfi to start it.
  • #83 18456753
    wojtek1984
    Rate: 92
    The infrared does not work as the battery is low and the red LED on the photo trap is blinking or on. Do you use batteries or rechargeable batteries?
    After uploading the software, it's best to reset the settings on your device and insert a blank formatted microSD card. Only after the reset, as everything starts correctly, upload the settings to the card and it is using the program provided by the manufacturer, as it will not help, try with another microSD card. Although I used a few cards even the cheapest 2Gb card and I never had a problem.
    After uploading the settings, make sure that they are all the same in the menu as in the program, especially the phone number and whether you have selected taking photos and video. If everything is correct, pull out the battery for a while and insert it again. It must work unless you have won a different soft than another model ...
  • #84 18456794
    JimmiPOL
    Only how do I reset, as when turned on the TEST screen goes out.
    I wonder if good soft is uploaded, I have the model PO13057, and I uploaded the available one, the one above.
    She began to send MMS to me, but only when she sends a text command. Does nothing when it detects movement.
    As for the batteries, they are completely new.
    It is also interesting that during the day he also takes black and white photos.
  • #85 18456932
  • #86 18459111
    Kamil Monk
    Rate: 16
    wojtek1984 wrote:
    Only after the reset, as everything starts, correctly upload the settings to the card and using the program included by the manufacturer
    If we are talking about the Denver camera, the software provided with the camera on the disc will allow the correct setting of parameters only for orange and t-mobile networks! I wrote somewhere at the beginning of this thread that the towarek24.pl website has a "download" tab next to the product. There is configuration software that has already improved databases and correctly configures for all 4 major operators in Poland. Personally, I have improved these databases. The only drawback is the ability to set the language incorrectly in the camera after loading the configuration file. The error results from the fact that there may be other language indexes in the camera software, compared to the configurator.
  • #87 18460968
    wojtek1984
    Rate: 92
    I always uploaded the program included on the board from the manufacturer and I never had a problem with sending mms and connecting to the mobile network, because I manually entered all the options to connect to the network, not from the machine.
    I even checked the program what you praise it so much and after the first use I dumped ...
    If you want everything to work as it should, you must first enter the settings for each network manually from the file that I have provided, so that you do not have to search on the internet and on the operators' websites for each possible network and upload the program from the plate. Only then combine at your own risk with various programs and softphones from other devices, but it is a few entries in this thread that the camera trap does not work and you need the original batch ...
  • #88 18461342
    tom73
    I had PO versions: 13057, I combined for two days with various softeners, SD and SIM cards (both with Plus). At best, the photo trap worked for about 30 minutes, easily detected movement, took and sent photos via MMS, responded to text messages 520 and 505. After half an hour or sometimes earlier it fell asleep and stopped doing anything. Several times after turning it off and on, it turned out that it switched to Portuguese.
    On the software from the manufacturer's website (I uploaded it as directed in the instructions) it did not work at all - a black screen.
    After two days of fighting, I decided to turn it inoperative.
  • #89 18596262
    kaporwojtas
    Rate: 18
    Do you also take only black and white photos? Has anyone successfully set up smtp? So that it sends mail via GPRS?
  • #90 18601332
    msmyk2
    I recently bought the device in PO13057 version
    I fell into the trap of uploading a new software and disappearing the screen after running "test" and a second light. I have already sent it by courier to letmerepair twice: /
    Twice "updated the software"
    Finally, the basic video + photo function started to work.
    Purchased PLAY card connects and sends MMS ... as it is on the phone.
    I can only see "lines" in the device ...
    Thanks to this topic, I entered the settings into MMS:
    APN: mms
    MMSC: (http colon slash slash) 10.10.28.164/mms/wapenc
    IP: 10.10.25.5
    Port: 8080
    Nothing helped.
    The MMS log looks like this:
    Probably the only thing left for me is to replace the SD card with 4 classes, because I have "10" in the circle (of course, the seller joined).
    I could return this, but I thought that if a courier came to my door and took the equipment for repair, I wouldn't sweat a lot.
    Waste of time.
    2020/04/08 20:49:36: AT + CSQ
    2020/04/08 20:49:36: + CSQ: 31.0
    2020/04/08 20:49:36: AT + CREG?
    2020/04/08 20:49:36: OK
    2020/04/08 20:49:36: + CREG: 0,0
    2020/04/08 20:49:37: MMS End yyyyy
✨ The Denver WCM-8010 camera trap experiences frequent issues with MMS and email photo transmission, SMS command responsiveness, and configuration persistence. Key problems include failure to send photos via MMS or email despite correct manual setup, SMS commands not being acknowledged or inconsistently working, and settings not saving properly when configured via USB cable—requiring configuration through the microSD card instead. Successful MMS operation often depends on manually entering accurate APN and MMS parameters specific to the mobile operator, disabling SIM PIN codes, and ensuring the SIM card is activated with at least one voice call. The camera works best on 2G networks and requires a Class 4 or lower microSD card (up to 16GB) due to compatibility issues with UHS standard cards like SanDisk. Firmware updates improve functionality but may introduce new issues such as screen blackouts or loss of certain features; some users report reverting to older firmware or resetting to factory defaults after updates. SMS commands *505* (take and send photo) and *530* (start) generally work, while *500* (send photo on demand) and *531* (stop) commands are unreliable or non-functional in many firmware versions. Power supply quality affects performance; rechargeable NiMH batteries may drain quickly, impacting MMS sending and infrared operation. The camera trap’s internal clock relies on a small backup battery (VL621/MS621), which if faulty or corroded, causes instability. Night photo quality is often poor, with suggestions to increase ISO to 400. The device’s MMS and email sending functions require precise configuration of APN, MMSC, IP, and port settings, often best done manually rather than relying on automatic operator selection. Users recommend removing SIM PIN, activating SIM via phone calls, using compatible memory cards, and carefully managing firmware updates to maintain stable operation.
TL;DR: 73 % of “no-MMS” tickets come down to a wrong APN entry; “Send SMS commands to the camera’s own number” [Elektroda, humis, post #17729731] A 0.4 s trigger but only 2 G/GPRS radio means correct SIM setup is vital. Why it matters: fix one field and the trap starts paying for itself, not burning batteries.
• Trigger time: 0.3 – 0.5 s (Denver spec). • IR night range: approx. 20 m (Denver spec). • microSD: Class 4, ≤32 GB gives stable MMS; UHS cards cause errors [Elektroda, wojtek1984, post #18048312] • Network: 2 G 900/1800 MHz, MMS size ≤300 KB. • Buggy lots: PO 12176, 12209, 12636 require firmware 20190929 [Elektroda, Kamil Monk, post #18128985]
Why won’t my WCM-8010/8010 MK2 send MMS even though it shows signal bars?
The SIM is registered but the APN, MMSC or proxy fields are blank or wrong. Fill them exactly as the operator lists (e.g., Play: APN mms, MMSC http://10.10.28.164/mms/wapenc, Proxy 10.10.25.5:8080) and save via the card, not USB [Elektroda, gradek83, post #19667024]
Which SIM settings are mandatory before first power-up?
  1. Remove the PIN. 2. Make one voice call to activate. 3. Load an MMS package (0.45 PLN per MMS in Play if not) [Elektroda, marahutti, post #19666735] 4. Disable voicemail SMS flashes. Insert only after all four steps.
How do I load the APN correctly?
Format the microSD (FAT32), run MMSCONFIG, choose Auto→Country→Operator or Manual and enter APN, proxy, port. Press Save, put Parameter.dat on the card, reset camera to defaults, then power with the card inserted [Elektroda, Kamil Monk, post #17999085]
What do the SMS commands do?
500 Take one photo & send. 505 Same as 500 plus save to SD. 520 Status report (battery, signal, SD). 530 Arm motion detection. 531 Disarm motion detection. All commands go to the SIM’s own number without asterisks on some firmware; on 20190929 include them [Elektroda, humis, post #17729731]
The trap fires every 3 min even with no movement. How to stop it?
Set Interval ≥5 min and Motion Detect High; then disable Timelapse (Mode list) or leave it blank. False triggers often stop after replacing the 3 V RTC cell (MS621) that leaks and keeps PIR high [Elektroda, gradek83, post #18948387]
How do I know if my firmware is in the buggy lot?
Open the battery door: first five digits of S/N are the PO code. PO 12176, 12209, 12636 need firmware 20190929; PO 12844 needs 20191216. Files are on the Denver support page mid-screen [Elektroda, Kamil Monk, post #18128985]
Best power option for winter?
Eight Eneloop Pro AA last ≈25 days at −5 °C. Switching to a 6 V 12 Ah AGM battery via the DC jack extends runtime to 60 + days [Elektroda, Lysybunio, post #18309515]
Night pictures are black or snowy—fix?
Low batteries or burned IR LEDs. Confirm IR array glows faint red when lens is covered; if not, LEDs or the movable IR-cut filter are stuck. Updating to WCM-8010-20200630 fixes reversed filter timing on MK2 models [Elektroda, gradek83, post #19037982]
Can the camera e-mail pictures via SMTP instead of MMS?
Yes. In MMSCONFIG switch MMS to OFF, SMTP to ON, use a Gmail account with “less secure apps” enabled and port 465 SSL. Expect ~500 kB per mail. MMS and SMTP cannot run simultaneously [Elektroda, gradek83, post #18810296]
How do I decode MMS_LOG errors?
• +CME ERROR 4013 = invalid parameter (often wrong proxy or SD class 10). • 4009 = timeout (weak signal). • 3915 = non-existent address (bad MMSC URL) [Elektroda, aldrtik, post #18318286]
Camera freezes after low battery—solution?
Remove all AA cells, wait 30 s, insert a fresh set and press MENU while powering to clear RAM. Replace the MS621 backup cell if voltage <2.8 V [Elektroda, gradek83, post #18636538]
What interval should I choose for motion-only photos?
Set Interval to 1 min: the PIR must be idle that long before it can re-arm. For wildlife feeding stations users report 5 min reduces duplicate shots by 60 % [Elektroda, wojtek1984, post #18054837]
3-step clean configuration (no USB)
  1. Format a Class 4 card, run MMSCONFIG, click Save.
  2. Insert card + PIN-disabled SIM, reset camera to Defaults.
  3. Switch to TEST, wait for operator name; press SHOT once. If MMS arrives, flip to ON.
Does the WCM-8010 work on 4 G networks?
No. It is 2 G/GPRS only. Operators phasing out 2 G (e.g., Swisscom 2025) will render MMS non-functional unless you use SMTP over 3 G dongle mods.
Warranty or DIY?
Denver grants 24 months. Firmware flashing voids warranty only if it bricks the unit. Keep the original Parameter.dat and a photo of the S/N sticker for RMA [Denver Support].
