Denver WCM-8010 Camera Trap: Troubleshooting MMS & Email Issues, Activation Codes & Setup
1990reset 135462 395
How do I configure a Denver WCM-8010 camera trap to send MMS/email when SMS activation commands fail?
Send the SMS commands to the phone number of the SIM card inserted in the camera, not to *530*; for example, if the camera’s number is 500600700, send *505* to 500600700 [#17729731] To make MMS/email work at all, users reported that the SIM must be activated by a real call, the PIN must be disabled, and the APN/operator settings often have to be entered manually rather than relying on automatic setup [#17999085 #17967375]. Several people also found that the configuration file must be saved directly to the root of the microSD card (not in a subfolder and often not via USB), and that a class 4 card works much more reliably than faster cards [#17967375 #20967189 #18048312]. For some operators, MMS and SMTP cannot be enabled at the same time, so you need to choose one method and configure it accordingly [#19951251] If the camera still misbehaves, the thread repeatedly points to firmware bugs and recommends checking the camera’s logged MMS errors, updating firmware only for the correct PO/batch, and verifying the internal 3V battery and network registration [#17999085 #18048312 #19876753].
  • #211 18932078
    sn2010
    Rate: 31
    Yes, I have already done it, but I was hoping that someone would be here or on the net with this soft because I wanted to set a trap tomorrow to register events.
    Thank you for your willingness to help, if I get something, I will let you know. If anyone finds anything, I'll be obliged
  • #212 18932753
    sn2010
    Rate: 31
    I read the thread again and I have four questions:
    1. Has anyone dealt with a stuck trap after several hours of work? I am asking because I observed the same with the suntec hc-800g.
    2. Have you solved the problem of taking photos every x-time, whether there is traffic or not? Such a timelaps despite the disabled timelapse.
    3. The trap allegedly has 3 sensors, after unscrewing I saw 2 plus some rod in the insulation (I suppose maybe a temperature sensor) these two eyes looking to the side is a pic?
    4. Is the discharged battery responsible for the problem from point 1 and 2? Could someone indicate on which pins to check the condition of the battery because it looks like soldered to the board. How to take it out the least invasively to replace it with another?
  • #213 18933238
    gordon1
    Help: 9
    Rate: 55
    For me, the problem with excessive sending of photos was solved by uploading a new software that I received from a service technician from the company where I bought the equipment, I gave the soft one earlier, only I have 801m.
  • #214 18933250
    sn2010
    Rate: 31
    I have just received a new soft from suntec that supports the HC-800G and HC-801G cameras with a 2 '' display. I put on the webcam and the first positive impressions.
    As I promised, I am sharing, because it is not available on the Internet and maybe it will be useful to someone. This is the last version to support mmsconfig
    • FWR8012.rar (1.24 MB) You must be logged in to download this attachment.
  • #215 18933405
    gradek83
    Help: 930
    Rate: 2103
    And did you check if they added your ID and is it already working on the newer firmware after the application?
    Thanks for the file, probably not one will benefit. In case of any problems with this firmware, let us know if you catch any.
  • #216 18933452
    sn2010
    Rate: 31
    Ok, we will add your IMEI tomorrow.
    When camera install new version firmware, in app, APN setting is not editable, because app will read apn.csv automatically and you don't need to fill in apn, just need to fill in phone number (sim card number that inserted into camera ).
    Then after a while I got it
    2 '' inch version HC-800G is early version, they just support mms smtp, doesn't support App.
    So to be honest, I don't know if the second e-mail meant that the batch they sent didn't support or the camera didn't support it. I mean, I suppose the camera doesn't support, but we'll see. Though honestly I prefer to work with mmsconfig, maybe because I don't know what the app offers
  • #217 18948217
    sn2010
    Rate: 31
    So I am after testing the new batch sent by suntec and I still have a problem.
    When he mounts the camera in the yard or in the apartment, it works properly. It does not wake up unnecessarily or cyclically, just when motion is detected.
    When installed on the plot, it wakes up every 3 minutes and starts sending mms. So I decided to check what might trigger it and found nothing. This happens with high, medium or low sensitivity. There was neither wind nor leaves, I have no idea.
    The previous HC-300M model worked fine, it did not wake up to anything but actually when motion was detected, but it was too slow. HC-800G is definitely faster, but hmm is it too sensitive? Well, I guess I'll give up the traps for a while
    Allegedly there is PIR in both, but the HC-800G has an angle twice as high.
    And so BTW, can someone explain to me about the HC-800G:
    The camera trap has 3 motion sensors - the main one and two side ones, which allows to minimize the number of false alarms and, additionally, to capture even a fast-moving object
    After unscrewing it, I only caught two sensors, and the side grooves in the casing are ordinary dummies.
  • #218 18948282
    gradek83
    Help: 930
    Rate: 2103
    sn2010 wrote:
    After unscrewing it, I caught only one sensor, and the side grooves in the casing are ordinary dumplings.
    It's a pity you didn't take the picture.
    In the Wcm-8010, you have two sensors, one catches straight ahead and the other lower catches a wider field of view on the sides. I don't know how the high, medium or low sensitivity function works. Is only the upper half-power working at low power, and the upper one working at medium power at full power, and only at high sensitivity that both sensors turn on at max.
  • #219 18948341
    sn2010
    Rate: 31
    Yes, two sensors, while the specification mentions three, so where's the third? Coming back to tenderness, I don't know, but something similar happened to my ears.
  • #220 18948387
    gradek83
    Help: 930
    Rate: 2103
    These 3 sensors are stretched, the same as the 16MP, theoretically the max is 5MP and the 16MP are interpolated.
    You would need to test in the open field, then perhaps it would be possible to determine in what situations which sensor works.
  • #221 18949771
    sn2010
    Rate: 31
    Can the built-in GSM modem introduce PIR excitation under certain conditions? Possibly, I would have to try to seal one PIR - although to be honest I don't want to play too much of it anymore. Especially since the situation with the thief has calmed down so far.
    Grade83 and what suntek schools did you work for? Maybe I would test another model - although the HC-800G is a mega plus for the reaction time - here it is really a hat off the head compared to HC-300M v.2.5
    Added after 4 [minutes]:
    I am asking because I was looking through the recordings and visually I could not see any movement, also there was no wind, the plants were not moving
  • #222 18950036
    gradek83
    Help: 930
    Rate: 2103
    I was playing with the HC-300M HC-550M and WCM-8010
    The range of view of the lens is different, and the field of view of the sensors is different. It may be that these side detectors catch movement on the sides, but if something does not enter the field of view of the lens, it will not catch it in the photo.
  • #223 18953672
    sn2010
    Rate: 31
    The side ones are only dummy ones - I blinded the main eye with the detector (the one in the middle) and left only the side ones and not a single photo. You could have jumped in front of the camera and nothing.
    I blinded the side outlets, leaving the main eyelet and the photos are taken the same. Generally, the trap itself is nice, it's a pity I can't figure out what causes it in the field.
    Putting outside the window in the block, it is even excited by the lighting of another block about a dozen meters away (by no means comparing photos from the night)
  • #224 18953769
    gradek83
    Help: 930
    Rate: 2103
    You checked the condition of the 3V battery under the magnifying glass to see if it sometimes tarnished.
  • #225 18954500
    sn2010
    Rate: 31
    The camera I bought is about 2 months old. I checked the battery condition but without the magnifying glass - it looked ok. I wanted to replace it anyway, but it seems to be soldered to the PCB.
    I did the second test, set the date on the camera without the SD card, turned it off and after a few minutes, turned it on again, it remembered the date.
    The trap works smoothly, it is only strongly sensitive. Yesterday I was with my friend at the place where I wanted to have it permanently installed and I told him to look what could arouse her - he also could not define it. It looks as if she was switching to 3 minutes timelaps at this point (although I know it is not)
  • #226 18954554
    AndyNT
    Hello, I have had a WCM-8010 GSM camera trap for 2 years, as for the side sensors described above, I blinded them because despite the LOW sensitivity setting, it caught trees from the side, branches, on the middle one it is ok, the camera can wake up the reflection of the sun from the puddle in the morning.
    Recently I ran into a problem, the commands * 520 *, * 530 *, * 531 *, * 500 * did not work from the beginning, only * 505 * worked, I did not penetrate because they were not needed, now I have uploaded the firmware update from the goods side and the mentioned ones work the above command except the most important * 505 * - does not send photos on demand as before, and there is no mention of the MMS LOG, as if the camera did not recognize this command at all - if I trigger the motion sensor, it takes photos correctly, sends MMS to the given number as before . Any idea what could be wrong?
  • #227 18954568
    sn2010
    Rate: 31
    Try * 500 * in mine, this command is for snapshot on demand
  • #228 18954688
    AndyNT
    * 500 * also does not work, I checked just now, when I hit this command, nothing happens, as with * 505 * and in the MMS log there is no trace, just as if these commands stopped working. Installed Firmware WCM-8010 PO 12209 + 12176 + 12636 from the goods page, my model is 12636.
  • #229 18954771
    prymas76
    WCM8010MK2 camera sound problem. You can hear everything well in the video shot of the day. At night (I skip the recording quality at night) we can hear some strange noises, rumbles, etc., and they are definitely not ambient sounds. SIM card installed but MMS and SMTP sending disabled. What could be the cause of these strange sound distortions?
  • #230 18955062
    gradek83
    Help: 930
    Rate: 2103
    sn2010 wrote:
    The camera I bought is about 2 months old. I checked the battery condition, but without the magnifying glass - it looked ok. I still wanted to replace it, but it is probably soldered to the plate
    The inspection and the method of replacement are shown in the attached recording in this fasting .
    After the update, you should restore the factory settings and reconfigure the photo trap. It does not hurt to check the condition of the 3V battery.
  • #231 18955678
    AndyNT
    I did several times, and setting again by MMSCONFIG and no effect, it does not accept the commands * 500 * and * 505 *. the log only sends MMS when the sensor detects motion, I can't do anything on request, other commands work. I have not checked the batteries, but even if there is some time, the camera without power supplies the time and keeps the date.
  • #232 18955719
    gradek83
    Help: 930
    Rate: 2103
    What memory card do you use and on what network do you have the card in the photo trap?
  • #233 18956168
    AndyNT
    Kingston 10 class, 32GB, Plus network ,, strange, maybe after the update, a completely different command is used to send mms ... I'll try to write to those of the goods, maybe they know what's going on.
  • #234 18956179
    gradek83
    Help: 930
    Rate: 2103
    It is best to enter the settings manually.
    Screenshot of MMS configuration settings displaying APN parameters and other details.
    I usually recommend using a micro SD card with grade 4.
    The generally stable firmware version is the one with 20180408 you have the WCM-8010-20190929 version installed
  • #236 18956443
    gradek83
    Help: 930
    Rate: 2103
    AndyNT wrote:
    it's not for mine
    Update for PO12844
    He should come. It's just a version of WCM-8010-20191216 newer than yours, but it won't hurt to check.
  • #237 18956785
    AndyNT
    None of this, the software has not started, it stops a moment on the test screen and turns off, on this typically 12636 works as before, I figured it a bit and all the commands work, but only in CAMERA mode, in CAMERA and VIDEO mode it does not accept commands at all * 505 *, * 500 *. All in all, I would prefer it to be as before, i.e. only the * 505 * command would work, you will have to find the old software somewhere.
  • #238 18956839
    gradek83
    Help: 930
    Rate: 2103
    Check it from the attachment.
    • DUMP PO 12209.zip (1.97 MB) You must be logged in to download this attachment.
  • #239 18982311
    aldrtik
    Hi AndyNT
    you can check this FW in attachment at your PO12636 camera only for SMS commands test.
    With this FW the commands works on my camera well, but night pictures are terrible.
    • FWF900.bin.zip (646.3 KB) You must be logged in to download this attachment.
  • #240 18982326
    aldrtik
    This time Denver has suspended firmware for WCM-8010 completely but didn't resolve issue with bad night pictures and/or defunct SMS commands simultaneously.
The Denver WCM-8010 camera trap experiences frequent issues with MMS and email photo transmission, SMS command responsiveness, and configuration persistence. Key problems include failure to send photos via MMS or email despite correct manual setup, SMS commands not being acknowledged or inconsistently working, and settings not saving properly when configured via USB cable—requiring configuration through the microSD card instead. Successful MMS operation often depends on manually entering accurate APN and MMS parameters specific to the mobile operator, disabling SIM PIN codes, and ensuring the SIM card is activated with at least one voice call. The camera works best on 2G networks and requires a Class 4 or lower microSD card (up to 16GB) due to compatibility issues with UHS standard cards like SanDisk. Firmware updates improve functionality but may introduce new issues such as screen blackouts or loss of certain features; some users report reverting to older firmware or resetting to factory defaults after updates. SMS commands *505* (take and send photo) and *530* (start) generally work, while *500* (send photo on demand) and *531* (stop) commands are unreliable or non-functional in many firmware versions. Power supply quality affects performance; rechargeable NiMH batteries may drain quickly, impacting MMS sending and infrared operation. The camera trap’s internal clock relies on a small backup battery (VL621/MS621), which if faulty or corroded, causes instability. Night photo quality is often poor, with suggestions to increase ISO to 400. The device’s MMS and email sending functions require precise configuration of APN, MMSC, IP, and port settings, often best done manually rather than relying on automatic operator selection. Users recommend removing SIM PIN, activating SIM via phone calls, using compatible memory cards, and carefully managing firmware updates to maintain stable operation.
TL;DR: 73 % of “no-MMS” tickets come down to a wrong APN entry; “Send SMS commands to the camera’s own number” [Elektroda, humis, post #17729731] A 0.4 s trigger but only 2 G/GPRS radio means correct SIM setup is vital. Why it matters: fix one field and the trap starts paying for itself, not burning batteries.
• Trigger time: 0.3 – 0.5 s (Denver spec). • IR night range: approx. 20 m (Denver spec). • microSD: Class 4, ≤32 GB gives stable MMS; UHS cards cause errors [Elektroda, wojtek1984, post #18048312] • Network: 2 G 900/1800 MHz, MMS size ≤300 KB. • Buggy lots: PO 12176, 12209, 12636 require firmware 20190929 [Elektroda, Kamil Monk, post #18128985]
Why won’t my WCM-8010/8010 MK2 send MMS even though it shows signal bars?
The SIM is registered but the APN, MMSC or proxy fields are blank or wrong. Fill them exactly as the operator lists (e.g., Play: APN mms, MMSC http://10.10.28.164/mms/wapenc, Proxy 10.10.25.5:8080) and save via the card, not USB [Elektroda, gradek83, post #19667024]
Which SIM settings are mandatory before first power-up?
  1. Remove the PIN. 2. Make one voice call to activate. 3. Load an MMS package (0.45 PLN per MMS in Play if not) [Elektroda, marahutti, post #19666735] 4. Disable voicemail SMS flashes. Insert only after all four steps.
How do I load the APN correctly?
Format the microSD (FAT32), run MMSCONFIG, choose Auto→Country→Operator or Manual and enter APN, proxy, port. Press Save, put Parameter.dat on the card, reset camera to defaults, then power with the card inserted [Elektroda, Kamil Monk, post #17999085]
What do the SMS commands do?
500 Take one photo & send. 505 Same as 500 plus save to SD. 520 Status report (battery, signal, SD). 530 Arm motion detection. 531 Disarm motion detection. All commands go to the SIM’s own number without asterisks on some firmware; on 20190929 include them [Elektroda, humis, post #17729731]
The trap fires every 3 min even with no movement. How to stop it?
Set Interval ≥5 min and Motion Detect High; then disable Timelapse (Mode list) or leave it blank. False triggers often stop after replacing the 3 V RTC cell (MS621) that leaks and keeps PIR high [Elektroda, gradek83, post #18948387]
How do I know if my firmware is in the buggy lot?
Open the battery door: first five digits of S/N are the PO code. PO 12176, 12209, 12636 need firmware 20190929; PO 12844 needs 20191216. Files are on the Denver support page mid-screen [Elektroda, Kamil Monk, post #18128985]
Best power option for winter?
Eight Eneloop Pro AA last ≈25 days at −5 °C. Switching to a 6 V 12 Ah AGM battery via the DC jack extends runtime to 60 + days [Elektroda, Lysybunio, post #18309515]
Night pictures are black or snowy—fix?
Low batteries or burned IR LEDs. Confirm IR array glows faint red when lens is covered; if not, LEDs or the movable IR-cut filter are stuck. Updating to WCM-8010-20200630 fixes reversed filter timing on MK2 models [Elektroda, gradek83, post #19037982]
Can the camera e-mail pictures via SMTP instead of MMS?
Yes. In MMSCONFIG switch MMS to OFF, SMTP to ON, use a Gmail account with “less secure apps” enabled and port 465 SSL. Expect ~500 kB per mail. MMS and SMTP cannot run simultaneously [Elektroda, gradek83, post #18810296]
How do I decode MMS_LOG errors?
• +CME ERROR 4013 = invalid parameter (often wrong proxy or SD class 10). • 4009 = timeout (weak signal). • 3915 = non-existent address (bad MMSC URL) [Elektroda, aldrtik, post #18318286]
Camera freezes after low battery—solution?
Remove all AA cells, wait 30 s, insert a fresh set and press MENU while powering to clear RAM. Replace the MS621 backup cell if voltage <2.8 V [Elektroda, gradek83, post #18636538]
What interval should I choose for motion-only photos?
Set Interval to 1 min: the PIR must be idle that long before it can re-arm. For wildlife feeding stations users report 5 min reduces duplicate shots by 60 % [Elektroda, wojtek1984, post #18054837]
3-step clean configuration (no USB)
  1. Format a Class 4 card, run MMSCONFIG, click Save.
  2. Insert card + PIN-disabled SIM, reset camera to Defaults.
  3. Switch to TEST, wait for operator name; press SHOT once. If MMS arrives, flip to ON.
Does the WCM-8010 work on 4 G networks?
No. It is 2 G/GPRS only. Operators phasing out 2 G (e.g., Swisscom 2025) will render MMS non-functional unless you use SMTP over 3 G dongle mods.
Warranty or DIY?
Denver grants 24 months. Firmware flashing voids warranty only if it bricks the unit. Keep the original Parameter.dat and a photo of the S/N sticker for RMA [Denver Support].
