WBR2, WBR3, WBRU, W701-VA2-CG pinout, datasheet, flashing for Home Assistant
p.kaczmarek2 23466 166
  • #31 21384224
    GAAD
    Rate: 19
    How to copy the contents of the module? Because I don't see the option to read write memory to a file in Ameba.
  • DS18B20 test setup for WBR2 flashing work
    #32 21384825
    Rate: 12710
    We're still this on our TODO list. For now, I'm testing with DS18B20:
    OpenRTL87X0C user interface displaying sensor information and configuration options.
    Test setup:
    Test setup with DS18B20 sensor on a breadboard.
    Electronic test setup on a breadboard with DS18B20 sensor and DHT11 module.
    Breadboard with DS18B20 and DHT sensors placed next to each other, connected with colored wires.
    Close-up of a DS18B20 temperature sensor mounted on a breadboard with connected wires and a resistor.
  • RTL8710CF download mode via RX and IO0 to 3.3V
    #33 21390033
    nemetila
    I have used your guide on a Gosund SP1 Power Monitoring(BL097) Plug with the CUCO-Z0-R-V1.2. FR module(RTL8710CF chip) and it's working! To enter download mode: connect the RX and the IO0 pins to 3.3V. The two LEDs, the button, the relay are working. The BL097 seems working, but it requires calibration.
    == Rtl8710c IoT Platform ==
    Chip VID: 5, Ver: 3
    ROM Version: v3.0
    Test Mode: boot_cfg1=0x20
    Download Image over UART2[tx=16,rx=15] baud=115200
  • #34 21390039
    Rate: 12710
    BL0937 can be easily calibrated in a similiar way we do it in Tasmota, so with VoltageSet/PowerSet/CurrentSet commands. Futhermore, if you have device already paired with your WiFi, you can instead simply use our Web App wrapper in the Tools tab, there is a calibration GUI as well:
    Device calibration interface in a web application, showing the power metering section.
  • #35 21390055
    nemetila
    >>21390039
    Thank you, I found the Calibration utility, I will try it later.
    BL0937 calibration matches BL0942 within 1–2%
    #36 21393106
    nemetila
    >>21390055
    BL0937 calibration seems working (done with 250W bulb).
    Comparing with Gosund EP2(BL0942) Load: LCD TV+Denon Amplifier:
    - Voltage and Current are almost the same (1-2% difference)
    - Power factor BL0942 : 1.0 vs BL0937 : 0.9
    Measurement device screen displaying electrical energy data.
    Some images from the SP1:
    Electronic module CUCO Z0 R V1.2 on a blue background.
    Close-up of a circuit board with visible traces and markings on a blue background.
    Image of the interior of an SP1 electronic device showing the circuit board and components.
  • #37 21394225
    >>21393106
    Good stuff
    Please share your OBK template so device can be added to list
  • Flashing pinout and OpenBeken template for WBR2/WBR3/WBRU/W701-VA2-CG
    #38 21394332
    nemetila
    >>21394225
    Flashing pinout:
    Table comparing pins of USB UART and CUCO-Z0-R-V1.2
    Template:
    rtl87x0C66...-44-47.zip (493 bytes)You must be logged in to download this attachment.
      "chip": "RTL87X0C",
      "board": "TODO",
      "flags": "1024",
        "3": "Rel;1",
        "4": "BL0937SEL;0",
        "11": "WifiLED_n;0",
        "13": "Btn;1",
        "14": "LED_n;1",
        "17": "BL0937CF;0",
        "18": "BL0937CF1;0"
      "command": "",
    I set relay: "remember last power state"
    OpenRTL87X0C user interface with pin settings and new start values
    autoexec.bat:
    startDriver BL0937
    startDriver NTP
    ntp_timeZoneOfs 01:00
    PowerSave 0
    VCPPublishIntervals 60 60
    MQTT and Home Assistant Discovery is OK:
    Screenshot of energy monitoring results in Home Assistant.
  • #40 21395387
    nemetila
    >>21395140
    Gosund SP1
    Gosund SP1 smart electrical socket in white.
  • #41 21395393
    misread. EP2 was comparison. fixed. thanks
  • ltchiptool flashes RTL8720CF without enable pin
    #42 21398455
    rudolfbyker
    AmebaZ2 PG Tool 1.2.47
    Do you have a download link for this? I can't find it anywhere.
    Sorry, I did not read properly! It's here: https://www.elektroda.com/rtvforum/download.php?id=1238048
    Added after 1 [hours] 38 [minutes]:
    My USB-UART won't work on Windows, so I tried on Linux, and I got it working using `ltchiptool`:
    $ pip install ltchiptool
    $ python -m ltchiptool flash write --device /dev/ttyUSB0 "/home/dolf/OpenRTL87X0C_1.18.21.bin"
    I: Detected file type: Realtek AmebaZ2 Flash Image
    I: Connecting to 'Realtek AmebaZ2' on /dev/ttyUSB0 @ 115200
    I: |-- Success! Chip info: RTL8720CF
    I: Writing '/home/dolf/OpenRTL87X0C_1.18.21.bin'
    I: |-- Start offset: 0x0 (auto-detected)
    I: |-- Write length: 719.1 KiB (auto-detected)
    I: |-- Skipped data: 0 B (auto-detected)
      [################################################################]  100%          I: Transmission successful (ACK received).
    I: |-- Finished in 79.313 s
    The enable pin was not needed. For the rest, the wiring was the same as in the guide at the top of this thread.
    Added after 47 [minutes]:
    (I wanted to post this at https://www.elektroda.com/rtvforum/topic3979433.html but that topic is locked now. I'm not sure if this is the right place to post it.)
    For the device described at https://www.elektroda.com/rtvforum/topic3979433.html , which is sold as "Tuya Basic Smart WiFi Switch 10A" in South Africa (see https://www.communica.co.za/products/smart-switch-basic-wifi-tuya-10a?variant=39250494881865 ), the used pins are:
    pin  symbol type  function                          Tuya Basic Smart Switch usage
    4    A18    I/O   GPIOA_18, hardware PWM, IC Pin39  LED_n 1
    6    A17    I/O   GPIOA_17, hardware PWM, IC Pin38  Btn 1
    9    A12    I/O   GPIOA_12, hardware PWM, IC Pin26  Rel 1
    The plastic case has a WiFi symbol printed near the LED, so it's probably used as WifiLED_n in the original firmware, but I would rather use it as LED_n to indicate the relay state.
    Here is the template. I don't know what to do with "flags", "keywords", and "command". There seems to be no model number.
      "name": "Tuya Smart Switch Basic WiFi 10A",
      "model": "",
      "chip": "RTL87X0C",
      "board": "JKY101-F-SR-V3.1",
      "flags": "1024",
        "12": "Rel;1",
        "17": "Btn;1",
        "18": "LED_n;1"
      "command": "",
      "image": "https://obrazki.elektroda.pl/1732280500_1718455167.jpg",
      "wiki": "https://www.elektroda.com/rtvforum/topic3979433.html"
  • #43 21398702
    nice going. I dunno if certain posts can be moved to other threads - @p.kaczmarek2 - it'd be nice to have it all in one place. I might have device-specific bits to add too :)
    Added after 13 [minutes]:
    or a new thread for @rudolfbyker's generic Tuya/SmartLife variant I guess
  • Need for A0 and A15 access when flashing WBR3
    #44 21420024
    itsmaxdd
    i'm about to buy a Beca BHT-006GCLW which is supposed to have a WBR3 chip.
    I like the device aesthetically but i'm a bit drawn back by the fact i have to desolder the MCU to use it away from tuya or similar things.
    Do you think that with a dremel one could drill the back side of the board to expose A0 and A15 through the PCB?
    Here it is suggested that the only pin on the back needed to flash is the A0, is that true or do we also need A15? I guess that since it is the LOG_TX it is quite mandatory?
    https://github.com/libretiny-eu/libretiny/issues/235#issuecomment-1875967472
  • #45 21420124
    Yes, A15, A16 and A0 are all needed to programme RTL8720CF as seen in image in first post
    Close-up of RTL8720CF electronic module with connected wires.
  • #46 21420169
    itsmaxdd
    I see, i'm quite new to openbeken.
    How is the main functionality mainteined? After flashing, by dumping the tuya config and converting it?
  • TuyaMCU devices need GPIO roles or autoexec script
    #47 21420173
    Rate: 12710
    It depends on the device, but usually you either choose the GPIO roles, either manually or via imported template (from Tuya device dump or from our forum/devices list), or you write autoexec script to configure TuyaMCU data points. This way you can more or less mimic the original device functionality or even often add more features.
    Beca BHT-006GCLW looks like TuyaMCU device, so good start is this guide: https://www.elektroda.com/rtvforum/topic4038151.html
  • #48 21424128
    seattmm
    >>21381809
    how it programming?
  • Asking whether WBR3 firmware can be flashed to WBRU
    #49 21515574
    heltonincerti78
    Hello everyone,
    I’m working on certifying the WBR3 and WBRU modules for use in Brazil.
    For the WBR3, I was able to purchase the conducted module with the certification firmware already installed.
    However, for the WBRU, the supplier is not providing it with the certification firmware.
    Is it possible to dump the firmware from the WBR3 and flash it onto the WBRU?
    Any help would be greatly appreciated.
    Thank you in advance!
  • WBR3 and WBRU use the same RTL8720CF chip
    #50 21515587
    Rate: 12710
    Welcome to forum, according to the docs:
    WBR3 is a low-power embedded Wi-Fi+Bluetooth module that Tuya has developed. It consists of a highly integrated RF chip (W701-VA2-CG), with an embedded Wi-Fi network protocol stack and varied library functions.
    WBRU is a low-power-consumption embedded Wi-Fi+Bluetooth module that Tuya has developed. Embedded with the Wi-Fi network protocol stack and rich library functions, it consists of a highly integrated RF chip (W701-VA2-CG).
    both modules are the same chip, so they should run, but maybe @divadiow and/or @insmod can confirm this to be sure.
    PS: As in the first post, W701-VA2-CG = RTL8720CF
    PS2: Do you want to transplant full firmware backup, or only the program? Currently I am not sure about RF stuff, the calibration could be per-device...
  • Need rtltool support for AmebaZ2 backups
    #51 21516172
    I've not had cause to carve up an Realtek dump to preserve RF areas before, but is the main question what tool can be used to take a backup from the WBR3?
    We've explained the process of backing-up AmebaZ and AmebaD (if you dig through some posts - Py flash tools here https://github.com/openshwprojects/FlashTools/tree/main/Realtek ), but not Z2. We need an rtltool for Z2, or there's LT for now...
    I do keep thinking we need some RTL firmware backup guides
  • #52 21516179
    Help: 164
    Rate: 445
    I don't believe system/calibration data can be read. And most likely can't be written.
    System data is stored at 0x1000-0x2000 and calibration data is at 0x2000-0x3000.
    If you check any dump, you won't find anything (i surely didn't). All data is 0xFF.
    Or perhaps it's just not used and everything is written in efuse. I know that MAC address is.
  • Tapo P110 flashed with RTL8710CF and pin mapping shared
    #53 21531209
    kalikum
    Hi everyone,
    Following the information I found https://www.elektroda.com/rtvforum/topic4097185.html, I was able to flash version 1.18.91 of the RTL8710CF chipset onto my Tapo P110. I'm sharing the pins where the connections go. I made the mistake of not documenting the power control pins before assembling and closing it, so if anyone has this information, we could complete the setup.
    I only have this image
    PCB with marked connection points: TX, RX, GND, AO 3.3V, 3.3V – labeled in yellow.
    Webportal
    Screenshot of the OpenRTL87X0C device control panel showing device status, buttons, and technical details.
    Template not complete yet:
      "chip": "RTL87X0C",
      "board": "TODO",
      "flags": "1024",
        "12": "Rel;1",
        "17": "Btn;1",
        "18": "LED_n;1",
        "19": "LED;1"
      "command": "",
    I am very sorry to don't have more details of the process I followed, I thought it too late. :(
    Thank you very much for all the information you posted, without you literally this could not be done.
    Sorry if there is any grammatical error, I use translator
  • #54 21531212
    Rate: 12710
    Maybe we could try to read the device Tuya config via the Web App? I'm not sure if the offset is updated there. Still, we also have that option to read full 2MB. That would certainly include your SSID and so on, but could also include the Tuya config.
  • #55 21531222
    kalikum
    Can it be done without opening the switch or welding cables? I have thought about buying another and documenting it well, although I don't know when I could do it.
    If I do, I will share it, I am sure.
  • #56 21531234
    Rate: 12710
    It is done in software, but I am not sure if it's implemented on this Realtek yet. I am talking about flash read option in the web app:
    Screenshot of an IoT device management panel at 192.168.0.163, Flash tab, showing options to read, download, and write configuration files.
  • #58 21531614
    kalikum
    >>21531234
    Thanks, I'm going to check
    >>21531238
    No, it's a tapo p110 EU but with the chip RTL8710CF
    Close-up view of the back of a TP-Link Tapo P110 smart plug with visible markings and prongs.
  • Tapo P110 RTL8710CF pinout and template update
    #59 21537845
    kalikum
    >>21531209
    Little update.
    Template:
    Chip on Tapo P110 RTL8710CF
    Close-up of a Realtek RTL8710CF microchip on a green PCB with visible electronic components.
    Consumption operation, Not calibrated yet .
    Device control panel screen with voltage, current, and power information.
    Finally I have disassembled and followed the ways to the chip.
    Block diagram and pinout of the BL0937 chip in SOP8 package.
    Table describing the pin functions of the BL0937 IC, listing pin numbers, symbols, and detailed descriptions.
    Thanks again for information.
✨ Discussion centers on flashing Tuya-based Realtek RTL8720CF / RTL8710C modules used in smart plugs, thermostats, curtains, kettles, IR blasters, and other IoT devices, with a focus on WBR2, WBR3, WBRU, and W701-VA2-CG variants. The thread documents a practical UART flashing method using AmebaZ2 PG Tool / ltchiptool, required boot pins (A0/A15/A16 depending on board), and the need to access underside pads or desolder the module for reliable programming. Contributors compare ROM versions, boot logs, flash layouts, and module variants, and share teardown photos, pinouts, and templates for OpenBeken/OpenRTL configuration. Later posts cover TuyaMCU integration, dpID mapping, Home Assistant discovery via MQTT, calibration of BL0937 power metering, and device-specific GPIO templates, with several successful flashes and working HA entities reported.
TL;DR: With 3.3 V wiring and 4–6 UART connections, you can flash WBR2/WBR3/WBRU Tuya modules; as one contributor put it, "the connection ... is the same" even when switching to newer tools. This FAQ helps Home Assistant and OpenBeken users identify pinouts, choose the right flasher, and recover MQTT discovery on RTL8720CF-based devices. [#21375223]
Why it matters: These modules appear in thermostats, plugs, breakers, switches, heaters, blinds, and IR devices, so one reliable flashing method unlocks many Tuya products without cloud dependence.
Tool Best use Write support Read/backup support Notable thread detail
AmebaZ2 PG Tool 1.2.47 Legacy RTL8720CF flashing Yes No practical read option discussed early on Original step-by-step guide used it first [#21375223]
BK7231GUIFlashTool Preferred newer workflow Yes Yes, later RTL87X0C read/write support added RTL87X0C support expanded through 2025 [#21708748]
ltchiptool Linux/CLI alternative Yes Not the main focus here One user wrote a 719.1 KiB image successfully on Linux [#21398455]
Najważniejsza wskazówka: On WBR3, the working UART boot path uses the log UART on A15/A16, not the normal user UART on A13/A14. Most failed flashes came from wrong UART choice, unstable adapters, or weak 3.3 V power. [#21375223]
  • WBR3, WBR2, and WBRU in this thread all center on W701-VA2-CG / RTL8720CF, a Wi-Fi + BLE 4.2 Realtek platform typically running at 100 MHz with 256 KB SRAM in the shared comparison table. [#21375443]
  • The proven boot wiring uses 3.3 V, not 5 V logic, and the guide explicitly recommends a solid external 3.3 V LDO because some USB-UART adapters cannot power the module reliably from their 3.3 V pin. [#21375223]
  • WBR3 flashing usually needs access to underside pads: connect A15/A16, pull A0 and A13/RXD high, then reset with EN to GND. WBR2 exposes similar signals more accessibly. [#21375223]
  • Later tool work added practical dump support: one successful RTL87X0C backup read a full 0x200000 = 2 MB flash and verified it with a SHA-256 hash match before extraction attempts. [#21727461]
  • Real-world confirmation spans several devices, including a Kasa HS200, Gosund SP1 plug, and Tapo P110 variants, showing the method is not limited to one Tuya product family. [#21381809]
How do I flash a Tuya WBR3 or WBR2 module based on W701-VA2-CG / RTL8720CF with OpenBeken using AmebaZ2 PG Tool or BK7231GUIFlashTool?
Flash it over the log UART, not the normal serial port. 1. Power the module from a stable 3.3 V supply and wire A16→USB-UART RX, A15→USB-UART TX, plus GND. 2. Pull A0 and A13/RXD high to enter bootloader, then reset by shorting EN to GND. 3. Write an OpenRTL87X0C binary with AmebaZ2 PG Tool or the newer BK7231GUIFlashTool, then remove the boot straps and reboot. The guide states this method works for WBR1, WBR2, WBR3, WBR2L, WBR3L, and WBRU-class RTL8720CF modules. [#21375223]
What is W701-VA2-CG, and how is it related to Realtek RTL8720CF, WBR2, WBR3, and WBRU modules?
W701-VA2-CG is the RF module core used by several Tuya-branded boards, and in this thread it is treated as the same platform as Realtek RTL8720CF. "W701-VA2-CG" is an embedded Wi-Fi + Bluetooth module family that packages the RTL8720CF-class chip into different Tuya footprints, including WBR2, WBR3, and WBRU, while keeping the same flashing concept and similar GPIO families. That is why one firmware family, OpenRTL87X0C, can target multiple module shapes even though the pin headers differ. [#21515587]
Which pins do I need to connect on WBR3, WBR2, and WBRU to enter bootloader mode and flash over UART?
Use the log UART pins plus two boot straps. For WBR3, connect 3.3 V, GND, A16 to USB-UART RX, A15 to USB-UART TX, then pull A0 and RXD/A13 high and reset with EN. For WBR2, the same rule applies, but A15 and A16 are on the back and A13 is labeled RXD. For WBRU, the note is explicit: A15 and A16 are the debug/flashing UART, while A13 and A0 must be pulled high for bootloader mode. [#21375223]
Why does a WBR3 usually need to be desoldered before flashing, and are there any practical alternatives like a jig or NodeMCU adapter hack?
WBR3 usually needs desoldering because its critical flashing pads sit on the underside. Multiple replies confirm you generally must remove it to reach A15 and related pads, although practical alternatives appeared in the thread: a spring-pin jig in development and a NodeMCU carrier hack with wires routed below the module. Those ideas reduce repeat soldering, but the tested method remained full access to the underside pads. One concise reply put it plainly: "yes. WBR3 pads on the underside would need to be accessed." [#21376702]
What is AmebaZ2 PG Tool 1.2.47, and when should I use it instead of BK7231GUIFlashTool or ltchiptool for RTL87X0C devices?
AmebaZ2 PG Tool 1.2.47 is the legacy Realtek flashing utility first used in this guide for RTL8720CF-based Tuya modules. Use it when you only need a known-good write path on Windows and want to follow the original screenshots exactly. Prefer BK7231GUIFlashTool when you need newer RTL87X0C support, backup features, or config extraction workflows. Use ltchiptool when you want a Linux CLI path; one user flashed an OpenRTL87X0C image from /dev/ttyUSB0 and the tool auto-detected a 719.1 KiB Realtek AmebaZ2 image successfully. [#21398455]
How do I set up OpenBeken after flashing a WBR3 or WBR2 so it joins Wi-Fi and appears in Home Assistant via MQTT discovery?
After flashing, boot OpenBeken, join its AP, and configure Wi-Fi at 192.168.4.1. Then set your MQTT broker, save, and either run Home Assistant discovery manually or add scheduleHADiscovery 5 to autoexec.bat so discovery starts about 5 seconds after MQTT connects. The thread shows this works once the right channel types are assigned; missing or old channel types were a real cause of absent entities. One contributor confirmed the fix immediately after updating the firmware and keeping discovery in autoexec. [#21564801]
Why does flashing a WBR3 with an FT232 adapter fail with XMODEM timeouts, while a CH340 works better for some users?
The thread’s strongest pattern is adapter quality and UART stability, not the module itself. A user repeatedly hit XMODEM timeouts and short-packet errors with an FT232-based adapter, then switched to a CH340 and obtained a proper RTL flash backup with hash verification. Another contributor noted many FT232 boards are fake, while CH340 and CP210x adapters worked reliably in their experience. Stable 3.3 V power also matters, because a weak adapter supply can look like a protocol failure. [#21809020]
What do the WBR3, WBR2, and WBRU pinouts look like, including the hidden A15/A16 log UART pads used for flashing?
The important difference is where the log UART appears. WBR3 exposes 16 edge pins, including A13/RXD and A14/TXD, but A15 is on the back and A16 is the log TX pin used for internal output. WBR2 has 11 main pins, with A15 and A16 again available on the rear pads. WBRU is more convenient: both log UART pins, L_RX = A15 and L_TX = A16, are on the sides together with TX = A14 and RX = A13. That hidden A15/A16 pair is why photos and board diagrams matter so much. [#21375223]
How can I read or back up flash contents from RTL8720CF / RTL87X0C devices, and what tools currently support dump and restore?
Today, use BK7231GUIFlashTool for practical dump and restore on RTL87X0C. By October 2025, the thread showed full read and write working, including a 2 MB backup, flash ID detection, hash verification, and config extraction attempts. Earlier in the thread, the answer was effectively “not yet” for AmebaZ2 PG Tool, which lacked a straightforward read-to-file path for users. There was also experimental CLI work around AmebaZ2 reads, but the clearest usable path became BK7231GUIFlashTool rather than the older vendor flasher. [#21708748]
What is TuyaMCU, and how do I map Tuya dpIDs to OpenBeken channels for thermostats, heaters, blinds, and kettles?
TuyaMCU is the secondary-MCU protocol layer many smart devices use between the Wi-Fi module and the product logic board. "TuyaMCU" is a serial protocol interface that carries dpIDs such as switch, target temperature, blind position, or kettle temperature, and OpenBeken maps each dpID to a channel type, label, and direction. In practice, start the driver, set the baud rate, then use commands like linkTuyaMCUOutputToChannel 2 val 2 and setChannelType 2 dimmer or Temperature. The thread shows this method working on thermostats, blinds, heaters, and a smart kettle. [#21701460]
How do I troubleshoot a TuyaMCU device on WBR3 when startDriver TuyaMCU causes safe mode or when Home Assistant entities do not show up?
Start by removing the bad autoexec, rebooting cleanly, and launching TuyaMCU manually. If startDriver TuyaMCU still forces safe mode, the usual causes are wrong baud rate, wrong dpID/channel mapping, or a bad command in autoexec. If Home Assistant entities do not appear, update to a build that includes the needed channel types, then run scheduleHADiscovery 5. That exact issue happened with new OpenStopClose support: the entity appeared only after firmware update because the older May build lacked the required discovery behavior. [#21565324]
What is the difference between the log UART on A15/A16 and the user UART on A13/A14 on WBR modules, and which one is used for flashing?
The log UART on A15/A16 is the flashing path; the user UART on A13/A14 is the application serial port. The module tables describe A15 as UART_Log_RXD and A16 as UART_Log_TXD, while A13/A14 are UART0_RXD and UART0_TXD for user-side serial communication. The flashing note repeats the distinction: use A15/A16 for debug output and bootloading, and pull A13 plus A0 high to enter bootloader mode. That distinction explains many failed attempts through the wrong UART. [#21375223]
AmebaZ2 PG Tool vs BK7231GUIFlashTool vs ltchiptool for Realtek RTL8720CF flashing — which tool is better for writing, reading, and recovery?
BK7231GUIFlashTool is the best all-around choice in this thread’s later state. Use AmebaZ2 PG Tool for basic legacy writing, ltchiptool for Linux command-line writing, and BK7231GUIFlashTool for the broadest write-plus-read-plus-recovery workflow. By late 2025, BK7231GUIFlashTool added RTL87X0C read/write support, flash-ID handling, and config operations, while AmebaZ2 PG Tool remained mostly a vendor writer. ltchiptool proved practical for write-only Linux use, but the thread did not position it as the primary backup or recovery solution. [#21708620]
How can I preserve or reconstruct original device functionality after flashing OpenBeken, including importing templates, using GPIO Doctor, and writing autoexec.bat scripts?
Rebuild the device in layers: pins first, protocol second, automation third. 1. If it is not a TuyaMCU device, use GPIO Doctor or a known template to find relay, button, LEDs, and metering pins. 2. If it is a TuyaMCU device, extract or infer dpIDs and map them in autoexec.bat. 3. Add drivers, labels, MQTT, and Home Assistant discovery. The thread explicitly says original behavior is usually restored either by choosing GPIO roles manually or via template import, then extending it with scripts and TuyaMCU channel mappings. [#21420173]
What should I watch out for when moving firmware or backups between WBR3 and WBRU modules, especially around RF calibration, system data, and per-device settings?
Expect the main firmware to be portable, but treat per-device data cautiously. One reply says WBR3 and WBRU use the same W701-VA2-CG core and should run the same program image, yet the follow-up warning is RF and system data: calibration may be per-device, MAC is in efuse, and a later developer comment says system and calibration areas at 0x1000–0x3000 do not appear readable in normal dumps. So move the application image only when possible, not a blind full-device clone for certification-sensitive work. [#21516179]
