Eswin ECR6600 flashing guide, datasheet, pinout, 100% local setup, Home Assistant
p.kaczmarek2 11277 122
  • ECR6600 WiFi+BT modules, including Tuya AXY2S and WG236 variants, get a pinout, datasheet links, and a guide for running them locally with Home Assistant.
  • Flashing uses UART0 TX0/RX0, GND, 3.3V, and ideally RST; unlike ESP chips, ECR6600 has no GPIO0 and relies on reset timing when prompted.
  • The chip pairs an Andes D10 @160MHz, up to 240MHz, with 512KB SRAM and 2MB/4MB Flash.
  • RDTool backs up the original firmware with a stub, then writes the OpenECR6600 UART binary; after reboot, the device exposes a WiFi access point for configuration.
  • The firmware release is still a March 2025 WIP, and backups should be made before cloud pairing because dumps may contain SSID and other personal data.
  • HTTP client test shows successful GET request
    #91 21594708
    DeDaMrAz
    Help: 34
    Rate: 130
    ECR6600 test
    SendGet http://example.com/ myFile.html
    Info:CMD: CMD_SendGET received with args http://example.com/ myFile.html
    Info:HTTP_CLIENT:HTTPClient_Async_SendGet for http://example.com/, sizeof(httprequest_t) == 160!
    Info:CMD:[WebApp Cmd 'SendGet http://example.com/ myFile.html' Result] OK
    Info:HTTP_CLIENT:Parse url http://example.com/
    Info:HTTP_CLIENT:host: 'example.com', port: 80
    Info:HTTP_CLIENT:HAL_TCP_Establish: created socket 2
    Error:HTTP_CLIENT:success to establish tcp, fd=2
    Info:HTTP_CLIENT:httpclient_recv 255 bytes has been read
    Info:HTTP_CLIENT:httpclient_recv 236 bytes has been read
    Info:HTTP_CLIENT:httpclient_recv 7 bytes has been read
    Info:MAIN:Time 225, idle 0/s, free 188384, MQTT 0(14), bWifi 1, secondsWithNoPing 158, socks 2/20
  • Proposed HAL timer abstraction for HTTP client
    #92 21594735
    Rate: 12709
    I will try to clear this up, I also think that hal_machw_time could be moved to HAL:
    - by default, it would use:
    On ECR:
    On Beken, hal_machw_time
    To be honest, I am not even sure how big precision do we need for that timer for HTTP, maybe we could get away with using g_timeMs globally, without HAL call
    I'll try to make those changes today and try to test as far as I can, I'll ask you for a review later
    This whole HTTP Client looks more or less suspicious. This:
    is used as it returns time offset, but in reality, it returns either 0 or 1
  • Needs help identifying AXYU switch pinout
    #93 21615836
    walligatorw
    Hi guys!
    I bought several switches MCL-Y10-L-03W in this store:
    https://aliexpress.ru/item/1005008813709294.h...2.1426903569.1753361948-1554502598.1753361948
    (not an advertisement)
    Want to cut them off from the Tuyas cloud and make them local in Home Assistant.
    Found this topic with your work and firmware. Thank you for your great work!
    I disassembled one switch and saw the AXYU board.
    Flashed one switch as written in the instructions. Everything went well.
    Now I need to configure the pins, but I have no experience in how to do this. But I have a great desire!
    I don’t know how to determine all the pins. Maybe you can help me?
    I am attaching photos and the dump file with the factory firmware.
    Top view of a PCB labeled K1–K5 with LEDs and three microswitches installed
    PCB with AXYU Wi-Fi module from MCL-Y10-L-03W switch, shown from top view
    Top view of circuit board from MCL-Y10-L-03W switch with relays and terminals
    PCB of the MCL-Y10-L-03W switch with visible electronic components and JP3 connector
    Dismantled MCL-Y10-L-03W wall switch showing PCBs and plastic housing parts
    • Tuya_MCL-Y10-L-03W_Backup_ECR6600.bin (2 MB) You must be logged in to download this attachment.
  • #94 21615922
    Help: 164
    Rate: 445
    >>21615836
    Well, you've already determined button pins.
    All that remains are relay pins.
    Put everything back together, connect it to mains and experiment in GPIO Doctor (Web app -> GPIO Finder).
    Check unconfigured pins by setting output high/low, and when relay clicks - you will know what pin it is.
  • #95 21615944
    walligatorw
    >>21615922
    Thank you! I'll try it now.
    But I still need the pins of the six LEDs.
    In the factory logic, they glow white when off and glow blue when on. On each switch.
    I do it ...
  • #96 21615947
    Help: 164
    Rate: 445
    >>21615944
    Leds are usually on the same pin as relays.
    At least it was that way on almost all switches i've seen (except moes zigbee no-neutral no-capacitor switch).
    But if not, they can be found the same way.
  • #97 21615948
    walligatorw
    Now, with all zero pins, all blue LEDs are lit. That is, the relays are in the on states.
  • Boot log identifies Tuya single-fire firmware and GPIO init sequence
    #98 21616010
    device boot log on IO13 from fw dump (on test device)
  • Working pin map for buttons, relays, and LEDs
    #99 21616102
    walligatorw
    Thank you, insmod!
    Thank you, divadiow!
    I found these pins and they work!
    "pins": {
    "0": "Btn;1",
    "2": "Btn;2",
    "14": "Rel;1",
    "15": "Rel_n;1",
    "16": "LED_n;2",
    "17": "Btn;3",
    "20": "LED_n;3",
    "21": "LED_n;1",
    "22": "Rel;2",
    "23": "Rel_n;2",
    "24": "Rel;3",
    "25": "Rel_n;3"
    I haven't figured out the purpose of pin 3 and pin 4 yet.
    And also, when relay 1 is triggered, the switch restarts. :(
    I dig further...
  • #101 21633440
    Rate: 12709
    Yes, this enumeration comes from ECR SDK, you can probably find it by searching for "RST_TYPE_UNKOWN" there.
    Added after 24 [seconds]:
    Btw thx for reminding me, we need to move reset reason to HAL
  • OTA success followed by HTTP client trap backtrace
    #103 21636152
    REST ECR6600 OTA is successful but
    Wi-Fi signal excellent, reboot reason: FATAL_EXCEPTION, MQTT not configured
  • SendGet requests may be timing out on Google Script
    #104 21640829
    jkwim
    Rate: 25
    I do not know whether this is the proper thread to post this question but there aren't many discussions about the SendGet HTTP requests.
    I am trying to pass some data into a Google script using the SendGet command but getting the following status:
    Info:HTTP_CLIENT:host: 'script.google.com', port: 80
    Debug:HTTP_CLIENT:Written 187 bytes
    However on the Google side this request never gets completed. I cannot post the full URL for security reasons but the general format is:
    https://<host>/path?parameter1=xxx&parameter2=yyy
    The URL works fine on a command shell in my CYGWIN environment using the command Curl <url>. And works directly via a web browser too.
    There is no authentication required so theoretically OpenBK should be able to handle it.
    My gut feeling is that there may be a timeout issue as I have observed some delay in getting a HTTP response back from Google when using other methods to access the same url.
    Can somebody help me to find out more on how OpenBK behaves here.
    Thanks in advance.
  • #105 21640832
    Rate: 12709
    You need to build OBK in a version that supports HTTPS (secure) connection. Otherwise, SendGET can only do HTTP.
  • #106 21640837
    jkwim
    Rate: 25
    Could you guide me on how to get it built?
    I mean I should have my old notes on how to get a build on the development branch but I need to know what directives to enable.
  • Clarifying secure MQTT support on Beken and ECR6600
    #107 21640858
    Rate: 12709
    I have never tried enabling SSL personally in OBK, but I am certain we have option for secure MQTT connection on Beken. Regarding other platforms - you'd need to check yourself.
    On a bright side, this is not OBK-specific request. SSL is done on SDK side, you'd need to check how to enable it for LWIP.
    Maybe @insmod knows something more. I used SSL only on ESP, and all I can say is that's very RAM consuming.
    Are you asking in ECR6600 topic for purpose? You want secure connection on ECR6600?
  • #108 21640861
    Help: 164
    Rate: 445
    >>21640858
    I've never even used http in OBK.
    But, i know that mbedtls is enabled by default on ECR6600.
  • #109 21640872
    Rate: 12709
    We may need to go over HTTPS/SSL some day, check it, and add to Platforms.md
  • #110 21640897
    jkwim
    Rate: 25
    Not really.
    I want to know whether it is possible to send a HTTPS GET request out from OBK
  • #111 21650936
    @walligatorw
    did you get any further with your ECR6600?
  • #113 21817642
    I see your Easy Flasher PR to add restore of RF on ECR6600 @insmod. Have you restored RF from any Tuya backups and was there any noticeable difference in WiFi connectivity stability?
    I'm away for a couple of days so can't play :(
  • #114 21817871
    Help: 164
    Rate: 445
    >>21817642
    I tried it when i was still porting obk. No effect.
  • RDTool worked after header errors in .228
    #115 21823087
    avgapon
    Update 2026
    As of 2026, this platform read/write is also supported by our flash tool:
    The connection (soldering, wires), is the same, but you can use our tool instead of the legacy one.
    Please check it out and use it instead of legacy tools, let us know how it works for you!
    FWIW, this didn't work for me with version .228.
    Every time it started okay but then complained about wrong header.
    I tried different speeds and none worked.
    RDTool worked on the first try.
  • #116 21823203
    I have flashed ECR6600 (under optimum connectivity conditions) 5 times with .228 and it's been OK. What baud were you using?
    BK7231 Easy UART Flasher interface with “Writing done” message displayed
  • #117 21823420
    avgapon
    >>21823203
    I tried 115200, 230400, 460800 and finally 2000000.
    Each a few times.
    I haven't tried 921600 from your screenshot, though.
  • #118 21902273
    Blisk
    I have this chip in my smart power plug, where I can find TX and where RX and 3.3V. ECR6600 IC205, I think this is on picture below it has 8 pins on every side.
    I have soldered out, but after that I see it has connection pins at the bottom of PCB connected directly to chip
  • #119 21906257
    Blisk
    I have found out 3.3V is pin GPIO17, XO is TX and XI is RX, but still don't know how to upload ne firmware, nothing works.
  • #120 21906665
    please show pics of your device case - make/model and PCB pics. have you searched the forum for other ECR6600 plugs to see if an identical device has already been flashed?
    this is xtal in/out for the oscillator, not uart programming.
✨ Discussion about flashing and reverse engineering ECR6600-based Tuya WiFi/BLE devices for local use with OpenBK/OpenECR firmware and Home Assistant. The thread covers UART flashing, firmware backups, pin mapping, GPIO Doctor configuration, BL0937 power-monitoring support, and troubleshooting zero readings caused by a missing BL0937 driver in the build. Participants also analyze Tuya flash encryption and key extraction, compare SDK dumps, inspect boot logs, search for KV key seed and secondary key logic, and experiment with Ghidra/base address detection for disassembly of ECR6600 binaries. Later posts extend to relay/LED/button pin discovery on multi-gang switches, HTTP SendGet support, HTTPS/SSL considerations, and OTA/flash tool behavior on ECR6600 modules and plugs.
TL;DR: With 2 MB or 4 MB flash and a "very small" boot window, ECR6600 devices can be backed up over UART, flashed with OpenECR6600, and then paired locally with Home Assistant instead of Tuya cloud. This guide is for users converting Tuya plugs, dimmers, and switches to fully local control. [#21479963]
Why it matters: It gives ECR6600 owners a repeatable path from unknown Tuya hardware to local firmware, backup safety, and practical pin mapping.
Option Chip/module family Flashing method in thread Local firmware status Notable limitation
ECR6600 / AXYU / AXY2S / WG236 ESWIN ECR6600 UART with RDTool or BK7231GUIFlashTool OpenECR6600 works; Home Assistant local use confirmed Reset timing is critical
BK7231-based modules Beken CB2S/WB2S/CBU-like Similar UART workflow Used as reference platform Tuya config extraction behavior differs
ESP8266-based TYWE2S ESP8266 Mentioned as module comparison Familiar baseline for users ECR6600 has no GPIO0-style flash pin
Key insight: ECR6600 flashing is straightforward once wiring is correct: use TX0, RX0, 3.3 V, GND, and usually RST, then hit reset exactly when the tool starts. The harder part is often pin mapping or Tuya config extraction, not writing firmware.
  • ECR6600 is a Wi‑Fi + BLE SoC with 2.4 GHz 802.11 b/g/n/ax, BLE 5.0, an Andes D10 at 160 MHz up to 240 MHz, 512 KB SRAM, and 2 MB or 4 MB flash variants. [#21479963]
  • The flashing UART uses IO6/TX0 and IO5/RX0; IO13/TX2 outputs boot logs at 115200 baud, which helps confirm whether firmware actually boots. [#21479963]
  • RDTool backup reads from address 0x0 with length 0x400000 for 4 MB parts or 0x200000 for 2 MB parts; if RDTool reports "FLASH is not enough!", switch to 0x200000. [#21479963]
  • AXY2S is an 11-pin Tuya-style ECR6600 module, while AXYU is a 21-pin CBU-shaped module exposing extra GPIOs such as P00, P01, P02, P03, P04, P21, P23, and dedicated L_RX/L_TX log pins. [#21479963]
  • In March 2025, a BL0937 plug issue was traced to a build error: the BL0937 driver was not included in the binary, and a rebuilt firmware fixed zero readings. [#21480949]
What is the Eswin ECR6600, and how does it compare to BK7231, ESP8266, and other Tuya Wi-Fi modules for local firmware use?
ECR6600 is a Wi‑Fi and Bluetooth SoC used in Tuya-style modules such as AXY2S and AXYU, and it can run local OpenECR6600 firmware. It offers 2.4 GHz 802.11 b/g/n/ax, BLE 5.0, 512 KB SRAM, and 2 MB or 4 MB flash. In the thread, it is compared to BK7231 modules like CB2S and WB2S and to the ESP8266-based TYWE2S because those are familiar Tuya module formats. For local use, the big practical difference is flashing: ECR6600 has no ESP-style GPIO0 boot strap and instead relies on reset timing during UART flashing. [#21479963]
How do I flash an ECR6600 device over UART with RDTool and OpenECR6600 for a fully local Home Assistant setup?
You flash it over UART, then join the new AP and finish setup like Tasmota. 1. Wire 3.3 V, GND, TX0 on GPIO6, RX0 on GPIO5, and preferably RST. 2. In RDTool, open the develop tool, use the download tab, choose the all-in-one OpenECR6600 UART binary, click Start, then reset or power-cycle the board immediately. 3. After flashing, power-cycle again, connect to the firmware access point, open the configuration page, and add it to Home Assistant locally. The thread states this was already working in March 2025, though the release was still marked WIP testing. [#21479963]
What are the important ECR6600 flashing pins, and how are TX0, RX0, IO13, RST, 3.3V, and GND used during backup and programming?
The essential pins are TX0, RX0, 3.3 V, GND, and usually RST. TX0 is IO6 and RX0 is IO5; they form the user UART used for backup and flashing. IO13 is TX2 and outputs boot logs at 115200 baud, so it helps verify whether the firmware starts after programming. RST lets you hit the short boot window without repeatedly removing power. 3.3 V powers the module, and GND is the common reference. The thread’s tested wiring used an ESP adapter on a WG236 module, but the same signal roles apply across ECR6600 modules. [#21479963]
What's the difference between BK7231GUIFlashTool and the legacy ESWIN RDTool for reading and writing ECR6600 flash?
BK7231GUIFlashTool is the newer multi-platform flasher, while RDTool is the original ESWIN utility shown in the screenshots. The main post says ECR6600 read and write support was added to BK7231GUIFlashTool in 2026, with the same soldering and UART wiring as RDTool. RDTool remains the documented legacy workflow for backup, restore, and flashing OpenECR6600. Later thread feedback showed mixed real-world results: one user reported BK7231GUIFlashTool v.228 failed with wrong-header errors, while another flashed successfully at 921600 baud. If you want the most proven path from the thread, RDTool is still the safest first choice. [#21823087]
How do I back up the original ECR6600 firmware, and which read length should I use for 2 MB vs 4 MB flash chips?
Back up first with RDTool’s stub workflow, then read the whole flash from address 0x0. In RDTool, open develop tool, go to single file, load ECR6600F_stub_V1.3.1.bin, set startup address to 0x10000, and trigger reset exactly when you click Start. Then switch to the flash tab, enter start address 0 and read length 0x400000 for 4 MB or 0x200000 for 2 MB. If you do not know the size, try 0x400000 first. If RDTool says "FLASH is not enough!", retry with 0x200000 and save the dump under a descriptive filename. [#21479963]
Why does RDTool on ECR6600 require precise reset timing, and what is the easiest way to catch the boot window reliably?
RDTool needs precise timing because the bootloader accepts the UART session only in a very short window after reset or power-up. The thread explicitly says "the window of opportunity is very small," so clicking Start alone is not enough. The easiest reliable method is to wire the RST pin and ground it exactly when RDTool starts, instead of pulling power each time. If RST is unavailable, power-cycle 3.3 V at the same moment. Using IO13 boot logs at 115200 baud also helps confirm whether you missed the window or the firmware simply failed to boot. [#21479963]
What is AXYU or AXY2S in the context of ECR6600 devices, and how do their pinouts differ from WG236-style modules?
AXY2S and AXYU are Tuya-style ECR6600 modules, while WG236 is a non-Tuya module in an ESP-12 or CB3S-like format. "AXYU is a module board that exposes the ECR6600 SoC in a CBU-shaped 21-pin footprint, with UART, ADC, PWM-capable GPIOs, and dedicated log pins for integration into Tuya devices." AXY2S is smaller, with 11 pins including VBAT, GND, RX, TX, ADC, RST, and a few PWM GPIOs. AXYU exposes many more signals, including P00–P04, P21, P23, P24, P25, TXD, RXD, L_TX, and L_RX, so it is easier to probe and repurpose. [#21479963]
Why was the BL0937 energy meter showing all zero values on OpenECR6600, and how was that issue fixed in the thread?
It showed zero because the BL0937 driver was missing from the build, not because the reported plug pinout was wrong. The user first flashed an OpenECR build and saw the driver start but every reading stayed at 0.0 V, 0.000 A, and 0.00 W. After investigation, the maintainer said the cause was simple: "BL0937 driver was simply not included in the build." A new binary was generated and uploaded, and the tester later confirmed that BL0937 then worked correctly and could be calibrated. [#21480949]
How can I verify BL0937 CF, CF1, and SEL pin assignments on an ECR6600 smart plug when the driver starts but readings stay at zero?
Verify them by checking pulse activity, not only continuity. The thread suggests adding a Counter role as a simple HAL-backed change counter, then using GPIO Doctor to see which pin actually carries BL0937 pulse traffic. That helps distinguish CF from CF1 when the driver loads but readings remain zero. One tested plug used pin 14 for BL0937CF, 15 for BL0937SEL, and 20 for BL0937CF1, but the maintainers still wanted a counter-based method to confirm assignments on future boards. If the driver runs and values stay at zero, first suspect missing pulses or swapped CF and CF1. [#21480916]
Why does Tuya config extraction from ECR6600 backups fail after the first block, and what does the thread suggest about changed secondary keys or TuyaOS 3 storage?
It fails because the first block decrypts, but later blocks fail header and CRC checks, which points to a changed secondary key or a different storage scheme. The extractor found the Tuya config magic at offset 1921024, passed the first MAGIC and CRC checks, then produced repeated "strange nextblock header" and "bad nextblock CRC" warnings. The thread’s main hypothesis was that ECR6600 changed KEY_PART_1 used by makeSecondaryKey, while a related idea was that newer TuyaOS 3 firmware stores config differently from older BK-based devices. In short, the parser understands the opening block but not the follow-up encryption logic. [#21481206]
What is KV_KEY_SEED in Tuya firmware, and why does it matter when trying to decrypt or extract configuration from ECR6600 dumps?
KV_KEY_SEED is the short seed string used to derive part of Tuya’s secondary flash-encryption key for stored configuration. "KV_KEY_SEED is a Tuya firmware configuration value that feeds key derivation for encrypted key-value storage, and changing it breaks block decryption even when the first flash header still matches." In the thread, older non-ECR examples used CONFIG_KV_KEY_SEED="8710_2M", but ECR6600 binaries appeared to contain only some known key parts, not that seed. Because decryption failed right after makeSecondaryKey was applied, the maintainers suspected ECR6600 used a different KV seed or a modified derivation path. [#21481270]
How do I restore a full ECR6600 backup in RDTool after saving the original flash image?
Restore the full dump from RDTool’s single file tab using the same stub setup as backup. 1. Open develop tool, choose single file, select the same stub, set the port, and keep startup address at 0x10000. 2. In the main file path area, choose your saved backup file, set begin address to 0x0, and check is download. 3. Click Start next to startup address and immediately reset or power-cycle the device. The thread notes that stub upload and full-flash restore then happen in one go, so you do not need a separate restore stage. [#21480971]
What is NDS32 in relation to the ECR6600 SDK, and how were people in the thread using Ghidra to analyze ECR6600 binaries?
NDS32 is the Andes CPU architecture used by ECR6600, and it is why stock reverse-engineering setups struggled with the binaries. The thread found the SDK used nds32le-elf-mculib-v3s, then built a custom Ghidra version with NDS32 processor support from an external branch. After that, users could at least open binaries and view disassembly. They searched for strings, constants like 0x13579753, and boot-log references such as the key print path to locate simple_flash and key-handling routines. The goal was to trace where ECR6600 derives or loads the Tuya secondary decryption key. [#21481465]
How can I find relay, button, and LED pins on an unknown ECR6600 switch using GPIO Doctor and boot logs without a published template?
Use GPIO Doctor for live testing, then confirm with the original firmware boot log. One maintainer advised testing unconfigured pins as outputs while the device is on mains; when a relay clicks, you found the relay pin. For buttons, the user had already identified them, and for LEDs, the thread notes they are often tied to the same logic as relays on many switches. Boot logs from the factory dump can list initialized pins, which helps narrow candidates. This method produced a full 3-gang mapping, including buttons on 0, 2, 17 and relay-related pins on 14, 15, 22, 23, 24, and 25. [#21616102]
How do I build or configure OpenBK/OpenECR6600 so SendGet can use HTTPS instead of HTTP, especially for requests to services like Google Apps Script?
You need a build that enables HTTPS in the platform SDK, because the tested SendGet path only supports plain HTTP by default. The thread confirms this directly: a user tried sending a Google Apps Script request and was told SendGET could only do HTTP unless OpenBK was built with secure support. On ECR6600 specifically, one maintainer noted that mbedTLS is enabled by default in the SDK, so HTTPS may be possible there, but no finished OpenBK HTTPS procedure was provided. The practical limitation is clear: unmodified SendGet works for http://..., not for https://... targets like Google Apps Script. [#21640832]
