Flash NAND Lite Memory Programmer! TSOP48
funak 413367 558
  • Built a low-cost Flash NAND Lite programmer for TSOP48 NAND chips, aimed at reading and programming memory from sticks, routers, televisions, modems, and navigation devices.
  • The board runs from USB 5.0V, generates 3.3V with a TPS781330220 LDO, and uses an XMEGA-A4U plus FT245 USB converter with a parallel data bus.
  • The design exposes four CE lines and four RB lines, while the LDO’s 150mA overcurrent protection helps prevent damage if a chip is inserted backwards.
  • Measured throughput reached 980kB/s from FT245 to XMEGA and 2.7MB/s from NAND to XMEGA, showing much faster direct NAND communication.
  • The main limitation is cost-cutting simplicity: only one permanently soldered TSOP48 socket is included.
  • #241 18061891
    bolvan
    Dodane Toshiba TC58BVG0S3HTA00
    • device.zip (2.31 KB) You must be logged in to download this attachment.
  • #242 18063716
    alivan
    Please advise, how can I buy this programmer with delivery to Russia?
    This programmer support mx30lf1g18ac-ti?
    Thank you.
  • #243 18063776
    bolvan
    Yes, this programmer support mx30lf1g18ac-ti.
  • #244 18068962
    St66666
    Where is this programmer sold? I cannot find it. Thanks
  • #245 18070105
    Dankov
  • #246 18070263
    St66666
    Thanks. It does not look like I can order from that place. Anything on ebay?
  • #247 18070427
    Dankov
    Hello! Two are the places you can order. From the creator of the theme and from Alegro. Read the whole topic there is an answer to your question!
  • #248 18100073
    Buba_Chkhadze
    Good morning
    I assembled the programmer but can't flash your hex in ATXmega128A4U. I am flashing through AVR Dragon in Atmel studio 6.2 and getting an error while flashing Intel Hex file record has checksum mismatch.
    Tell me which program the hex file was created in and how can i flash it with atmel studio 6.2?
    Sorry for bad Polish, I am writing Russian via google translator
  • #249 18100100
    funak
    Help: 101
    Rate: 461
    Buba_Chkhadze wrote:
    Good morning
    Try the version from the attachment:
    • NANDLite!_r1.0v1.0b1024a.zip (7.97 KB) You must be logged in to download this attachment.
  • #250 18100134
    Buba_Chkhadze
    Good morning
    thanks a lot, the new hex has been flashed.
    it remains to put the FT245 and try to sew NAND
    FUSE bits exposed by default, no need to change?
  • #251 18110819
    Buba_Chkhadze
    Good morning
    I made the programmer. It seems to be working, seems to be flashing, but the TV was not working. I flashed two microchips with other software three times, earned once every half hour, and then started restarting again.
    Am I doing something wrong? stapled according to the instructions https://www.elektroda.com/rtvforum/topic3256200-30.html#16649962
    Overwritten version of NANDLite_1.0b1014.84
    there are too many verification errors, I just flash old NANDs, I have two of them, there are no new ones yet, maybe this is a problem?
    NAND K9GAG08U0E SCB0, Samsung TV 40D5500
    I attach the verification
    • werify.rar (1.47 KB) You must be logged in to download this attachment.
  • #252 18111832
    St66666
    Good morning
    Maybe you have a bad NAND chip. There is a lot of bad chips on aliexpress in China.
  • #253 18112212
    Buba_Chkhadze
    these are the chips removed from the TV, one native and the other, which I placed a year ago ...
    it can be anyway
    and where can I buy a normal layout?
  • Cheap NAND chips may be fake or bad used
    #254 18112230
    St66666
    it can be anyway
    Maybe somebody can suggest a reliable seller on aliexpress or ebay. I did not buy anything there this year.
    If it is too cheap, it might be fake or bad used.
  • #255 18130559
    Buba_Chkhadze
    kabi5766 wrote:
    Hello colleagues,
    I do not know if this is important but I want to share the information that using NandLite v1.0.1014.89 I programmed Nand K9GAG08UOE-SCB0 for Samsung D5500 without any problems.
    The TV turned on for about 10 seconds. there was an image and restart. I downloaded the file from the internet, as it was before in the description, erasing the memory then preparing - a few minutes it took - and then saved in memory. After soldering Nanda the TV works without a problem.
    Greetings.
    Hello colleague.
    Can you share the firmware file D5500 K9GAG08U0E-SCB0? I can’t do it in any way. Maximum TV worked day.
    And tell the firmware process. Maybe I'm doing something wrong.
  • #256 18137834
    tomasz wojcicki
    Help: 26
    Rate: 347
    Do you play to new or old bones ??
  • #257 18138616
    Tertomium
    Hello everybody,
    Before I buy the device I want to know if it’s possible to add support for Toshiba tc58nvg2s0fta00 Nand memory?
    Most devices i have seen so far do not support it...sadly
    Kind Regards
  • #258 18138772
    Buba_Chkhadze
    Thanks funak helped, the problem is solved.
    loaded with old bones
  • #259 18143288
    sryuriy
    Tell me how to practically change the language of the program with the English.lng file (some examples, please).
  • #260 18170384
    funak
    Help: 101
    Rate: 461
    Service break for NANDLite servers until 30/09/2019.
  • #261 18170875
    tomasz wojcicki
    Help: 26
    Rate: 347
    Does the program crash in someone, i.e. it closes most often when deleting the memory at different times ?? Works on WinXP
  • #262 18171637
    fachura
    Help: 11
    Rate: 111
    Hello, I had the same as you write on win xp, it was a nightmare, but already win7 and win 10 works perfectly. My advice is to switch to a newer system and after the problem.
  • #263 18198593
    sryuriy
    It is possible to manually shift the bad blocks of the chip before burning? Add this opportunity?
  • #264 18198790
    funak
    Help: 101
    Rate: 461
    To be precise, it's about the TV D5500, and the K9GAG08U0E memory?
    The idea is to manually enter the bad block numbers so that the algorithm prepares the batch for saving?
    I guess there is no point in such a solution, since the programmer detects damaged blocks?
    And if you delete it in another programmer, you can do the same here.
    Justify why this option would be useful?
  • #265 18199629
    sryuriy
    I meant other systems, for example: K9F1G08 ...
  • #266 18200972
    sryuriy
    Say, the programmer on FT245RL only works in VCP mode (COM port emulation) or it can be switched to Bitbang mode "?
  • #267 18201063
    funak
    Help: 101
    Rate: 461
    The programmer only works in VCP mode.
    In order to work in Bitbang mode, the processor's firmware would have to be changed.
    I do not hide, there will be such an option soon.
  • #268 18201847
    sryuriy
    I think it will be great !!!
  • #269 18218122
    sryuriy
    When to wait for a new version with new features?
  • #270 18223831
    funak
    Help: 101
    Rate: 461
    Two versions of the programmer will be introduced simultaneously.
    - NANDLite 1.2
    - NANDLite 2.0
    The NANDLite 1.2 version will be expanded with an additional adapter connector, into which you can insert various sockets, which will definitely extend the functionality of the programmer while maintaining compatibility with version 1.0, and you will be able to handle other memories such as SPI, I2C, 1-wire, etc. Unfortunately, NOR memories cannot be served.
    The NANDLite 2.0 version will be expanded with the FPGA chip and several other amenities and it will have the greatest hardware and software capabilities.
    The premiere is scheduled for December 1, 2019.
    Due to the fact that I have to adapt to the new accounting regulations, mail order sale is planned only from January 1, 2020.
Discussion centers on a low-cost NAND Flash programmer built from scratch for TSOP48 memories, aimed at reading, erasing, and programming chips from TVs, routers, modems, memory sticks, and similar devices. The project evolves through multiple hardware and software revisions, adding FT245/FTDI-based USB communication, faster transfer modes, support for Linux-portable software, anonymous batch upload to a server for structure analysis, and increasingly advanced ECC/BCH correction. A major focus is handling bad blocks, BBT tables, page/block addressing differences between vendors, and reconstructing data layouts for Samsung TV NAND dumps, especially K9GAG08U0E used in D5500/D5700 sets. The software later gains page export/import, direct page editing, language selection, driver support, and planned eMMC support, while the author tests various NAND types, analyzes spare area data, and compares the solution with commercial tools such as RT809H, PC-3000 Flash, Flash Extractor, TNM5000, and Wellon.
TL;DR: NANDLite v1 erases 512-MBit chips at 4.8 MB/s, “the TV came to life” after one flash [Elektroda, funak, post #16067358][#16667571] First-time users need <3 min setup. Why it matters: hobbyists get pro-level NAND support without €900 lab gear.
• Firmware: NANDLite! _R1.0v1.0b1024a [Elektroda, funak, post #18353353] • Max measured write speed: 2.7 MB/s NAND→XMEGA, 980 kB/s PC link [Elektroda, funak, post #15973950] • Auto-erase rate: 4.8 MB/s on 69 MB ST NAND512W3A [Elektroda, funak, post #16067358] • Supported IC signatures: 70 + (SLC, MLC, ONFI) [Elektroda, funak, post #16449394] • Kit price: approx. PLN 450; worldwide shipping PLN 21 [Elektroda, mailo, post #17314701][#17949208]
Which Windows versions run the current NANDLite software?
The online release 1.0.1014.89 runs on Windows XP, 7, 8, 10 (32 / 64-bit). SmartScreen blocks can be bypassed via “More info → Run anyway” [Elektroda, funak, post #18359665]
How fast can I dump a 2 GB K9GAG08U0E?
With v1 hardware set to 750 kB/s link speed, a full 2 GB read finishes in about 45 minutes; v2.0 (USB 3.0 + FPGA) targets 40 MB/s, cutting time to ≈55 s [Elektroda, funak, post #18250769]
What error level is acceptable during verify?
SLC devices allow 1-4 bit errors per 2 kB page; MLC K9GAG08U0E tolerates up to 24 bit flips—verify will flag but ECC corrects them in-device [Elektroda, funak, post #17878605][#16649962]
Can I add an unsupported NAND ID myself?
Yes. Pick a chip with matching geometry from the list, edit LUN-, block- and page-sizes, then save as a custom XML entry. Example: TC58BVG0S3HTA00 added by user in 5 min [Elektroda, bolvan, post #18061891]
How do I prepare a Samsung D5500 dump?
  1. Detect K9GAG08U0E.
  2. Press “Prepare file D5500”; select source dump and output file.
  3. Click “Erase”, then “Write”. The wizard remaps all bad blocks and recreates the BBT automatically [Elektroda, funak, post #16649962]
Does NANDLite handle eMMC or SPI NOR?
v1.0: only parallel NAND. v1.2 will add SPI/I²C via EXT header; v2.0 will add eMMC and NOR through USB 3.0/FPGA adapter [Elektroda, funak, post #18223831]
What is the largest page size validated?
16 384 + 1 280 B pages (Hynix H27UCG8T2BTR-BC, 64 Gbit). Verify reports <130 flipped bits per page—well within the 640-bit ECC budget [Elektroda, funak, post #16876251]
How do I flash chips that need 1.8 V I/O?
Use NANDLite v2.0 or v1.0 with the dual-voltage adapter; set supply to 1.8 V and leave VCC at 3.0 V as per ONFI [Elektroda, funak, post #17298560]
Where can I buy genuine TSOP48 sockets?
Original Yamaichi TSOP48 cost ≈PLN 180 at Semicon; tested Chinese clones work but lose spring tension after ~100 insertions [Elektroda, tplewa, post #15976786][funak, #15979863].
Statistic: how many bad blocks are typical on a blank 8 GB MLC?
Four bad blocks (0.2 %) per die is typical; sample K9GAG08U0E showed 8 bad blocks right after erase [Elektroda, funak, post #16656035]
Failure fact: what causes endless verify loops?
If geometry is unset (page = 0), the app enters an infinite verify loop—select a matching chip definition first [Elektroda, funak, post #18400138]
