Flash NAND Lite Memory Programmer! TSOP48
funak 413367 558
  • Built a low-cost Flash NAND Lite programmer for TSOP48 NAND chips, aimed at reading and programming memory from sticks, routers, televisions, modems, and navigation devices.
  • The board runs from USB 5.0V, generates 3.3V with a TPS781330220 LDO, and uses an XMEGA-A4U plus FT245 USB converter with a parallel data bus.
  • The design exposes four CE lines and four RB lines, while the LDO’s 150mA overcurrent protection helps prevent damage if a chip is inserted backwards.
  • Measured throughput reached 980kB/s from FT245 to XMEGA and 2.7MB/s from NAND to XMEGA, showing much faster direct NAND communication.
  • The main limitation is cost-cutting simplicity: only one permanently soldered TSOP48 socket is included.
  • #271 18224613
    sryuriy
    Will there be an opportunity to build new programmers on your own?
  • #272 18226506
    funak
    Help: 101
    Rate: 461
    Only version 1.2 will have the option of self-assembly.
    Version 2.0 will be technologically advanced, so self-assembly will be rather difficult.
    I will present everything soon.
    Version 1.2 is still in the fate to change the processor and thus introduce NOR memory support. But then it will be in the TQFP100 housing, so it will be more difficult to mount.
  • #273 18227281
    Reider
    Reading emmc will be arranged in programmer?
  • #274 18227690
    funak
    Help: 101
    Rate: 461
    In version 2.0, it will certainly be possible.
    Version 1.2 I do not have confirmed information yet.
  • #275 18240092
    Reider
    When will the English or Russian version of the software be available? One Polish is inconvenient
  • #276 18250719
    lukasis6
    Help: 25
    Rate: 71
    Will the programmer 2.0 be able to program dice faster? Currently, I program K9GAG08U0E in less than an hour ..
  • Version 2.0 limited to 40 MB/s programming
    #277 18250769
    funak
    Help: 101
    Rate: 461
    Yes, for version 2.0 it will be faster to program bones, basically it will be technically limited to 40MB / s.
    Anyway, version 1.2 should do it faster.
    For K9GAG08U0E we will see after the tests how many will come out :)
    On Monday, I expect a shipment from the USA with samples of the connectors used in the project. I will see what quality they will be and how they will perform in general. A lot depends on them, so after testing the connectors, I will have a complete set of information about what the programmer will look like and what its capabilities will be.
    Lots of work ahead of me, but it's worth thinking about :)
  • #278 18324257
    sryuriy
    I want to ask how is work going?
  • #279 18332026
    funak
    Help: 101
    Rate: 461
    Hello, the work has been temporarily suspended due to health as well as financial reasons, the project will be resumed this year :)
    So please keep your fingers crossed for the success of the entire project.
  • #280 18353182
    funak
    Help: 101
    Rate: 461
    I still have a few ready-made NANDLite v1.0 programmers.
    If anyone is willing before Christmas, please do not hesitate to contact me.
    There will also be an update of the basic application to support the NANDLite programmer, I will try to send a new version before the New Year.
    Kind regards
  • #281 18353305
    1st
    Help: 59
    Rate: 169
    What is the current version of NANDLite? I have 1.1b0123.90L
    And what is the current firmware version for the programmer? I have a NANDLite! _R1.0v1.0b1024a.hex
    Where can you get the current versions?
  • #282 18353353
    funak
    Help: 101
    Rate: 461
    Current online version: 1.0.1014.89.
    Firmware: NANDLite! _R1.0v1.0b1024a.
    There were a lot of fixes for both the interface and the firmware, so I will summarize it, check it, test it and send the update version.
    The current version can be downloaded from the link:
    http://software.progelo.pl/NANDLite/publish.htm
    It will also be possible to create an Offline version on your own from the current Online version.
    Certainly, this option will be useful on a website where, for example, there is no Internet.
  • #283 18353385
    1st
    Help: 59
    Rate: 169
    Well, I can't install this version, Windows10.
  • #284 18353450
    fachura
    Help: 11
    Rate: 111
    Run the program as administrator.
  • #285 18353467
    funak
    Help: 101
    Rate: 461
    In addition to running as administrator, there may be restrictions on the system regarding SmartScreen, which is generally a blockage from installing unsigned applications. Perhaps that is why 1st cannot install the NANDLite app !.
    The certificate costs PLN 1500 net / year, there is a chance that next year I will have such a certificate for signing the application, so the installation problems will be solved automatically.
  • #286 18356308
    1st
    Help: 59
    Rate: 169
    Can I get around this somehow?
  • #287 18359665
    funak
    Help: 101
    Rate: 461
    If while installing the NANDLite app from the link:
    the following picture appears:
    press More Info, then the Run anyway button will appear:
    then you can install the app normally:
    In this way, you can install an application that does not have a special certificate.
    Added after 17 [minutes]:
    Taking advantage of the Christmas time, I would like to remind you that I have NANDLite version 1.0 programmers assembled and ready for shipment. If anyone would be willing or unable to make up their mind yet, please do not hesitate to contact me. If it is necessary to issue a VAT invoice, it will of course be possible, but only after January 1, 2020. Unfortunately, the change in regulations introduced on September 1, 2019 prevented me from selling programmers in the current formal form.
    Of course, as always, I provide substantive, technical and warranty support. After all, a development product, therefore open to news, requests and suggestions of users.
  • #288 18362279
    1st
    Help: 59
    Rate: 169
    Well, unfortunately, my window:
    And I'm an administrator, and I run "as" administrator ...
  • #289 18362283
    fachura
    Help: 11
    Rate: 111
    And I forgot to write to turn off the Windows Defender firewall because it is blocking you.
  • #290 18380046
    m0lnaR
    Good afternoon.
    Where can I buy this device?
    The topic also read that there will be a new version after the new year ?
    Spoiler:
    mmmm...... sorry but I can't change my avatar O. 0
  • #291 18391077
    root42
    Hi, newbie here from Germany. I would love to buy a programmer. Are there still some available? How much does it cost? Feel free to send me a private message.
    Love the project!
  • #292 18393621
    funak
    Help: 101
    Rate: 461
    China celebrates until January 31, 2020, so I'm planning v2.0 for the second half of February.
  • #293 18393912
    tomasz wojcicki
    Help: 26
    Rate: 347
    I also sign up :)
  • #294 18394431
    kiko80
    Help: 67
    Rate: 163
    I am waiting for the final version of v2 and maybe I will be tempted
  • #295 18399851
    root42
    Yeah, I think I'll also wait for 2.0. I actually only need to flash one device so far, so if I spend a significant amount of money on this, I'd like the best version there is. :)
  • #296 18399928
    tomasz wojcicki
    Help: 26
    Rate: 347
    Hello, I have such a problem with the memory TC58NVG3S0HTAI0 cannot be deleted or saved, here's what inf spits out the program after any attempt:
    Memory erasing
    ID: 98 D3 91 26 76 16 08 00
    Manufacturer: TOSHIBA
    Model: TC58NVG3S0HTAI0
    Configuration:
    Target count: 1
    LUN count: 0
    Block per LUN: 0
    Page per Block: 0
    Page size: 256 + 0
    Total size: 0 bytes
    Error:
    The index is out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
  • #297 18399957
    funak
    Help: 101
    Rate: 461
    After detecting a memory, you should click on the list below and select the memory, even if there is one in the list.
    According to the attached LOG, the geometry of the system is not set, so it does not work.
  • #298 18400102
    tomasz wojcicki
    Help: 26
    Rate: 347
    That's what I do all the time. I have 2 pcs of the case, they behave correctly in another program.
  • #299 18400138
    funak
    Help: 101
    Rate: 461
    Please use the layout definition: TC58NVG3S0FTAI0
    In fact, there are no parameters for this memory in the database.
    I will fix it in the next update.
  • #300 18405492
    fachura
    Help: 11
    Rate: 111
    Hello, when is the update to NANDLite 1.0 finally, I can't wait. Best regards
Discussion centers on a low-cost NAND Flash programmer built from scratch for TSOP48 memories, aimed at reading, erasing, and programming chips from TVs, routers, modems, memory sticks, and similar devices. The project evolves through multiple hardware and software revisions, adding FT245/FTDI-based USB communication, faster transfer modes, support for Linux-portable software, anonymous batch upload to a server for structure analysis, and increasingly advanced ECC/BCH correction. A major focus is handling bad blocks, BBT tables, page/block addressing differences between vendors, and reconstructing data layouts for Samsung TV NAND dumps, especially K9GAG08U0E used in D5500/D5700 sets. The software later gains page export/import, direct page editing, language selection, driver support, and planned eMMC support, while the author tests various NAND types, analyzes spare area data, and compares the solution with commercial tools such as RT809H, PC-3000 Flash, Flash Extractor, TNM5000, and Wellon.
TL;DR: NANDLite v1 erases 512-MBit chips at 4.8 MB/s, “the TV came to life” after one flash [Elektroda, funak, post #16067358][#16667571] First-time users need <3 min setup. Why it matters: hobbyists get pro-level NAND support without €900 lab gear.
• Firmware: NANDLite! _R1.0v1.0b1024a [Elektroda, funak, post #18353353] • Max measured write speed: 2.7 MB/s NAND→XMEGA, 980 kB/s PC link [Elektroda, funak, post #15973950] • Auto-erase rate: 4.8 MB/s on 69 MB ST NAND512W3A [Elektroda, funak, post #16067358] • Supported IC signatures: 70 + (SLC, MLC, ONFI) [Elektroda, funak, post #16449394] • Kit price: approx. PLN 450; worldwide shipping PLN 21 [Elektroda, mailo, post #17314701][#17949208]
Which Windows versions run the current NANDLite software?
The online release 1.0.1014.89 runs on Windows XP, 7, 8, 10 (32 / 64-bit). SmartScreen blocks can be bypassed via “More info → Run anyway” [Elektroda, funak, post #18359665]
How fast can I dump a 2 GB K9GAG08U0E?
With v1 hardware set to 750 kB/s link speed, a full 2 GB read finishes in about 45 minutes; v2.0 (USB 3.0 + FPGA) targets 40 MB/s, cutting time to ≈55 s [Elektroda, funak, post #18250769]
What error level is acceptable during verify?
SLC devices allow 1-4 bit errors per 2 kB page; MLC K9GAG08U0E tolerates up to 24 bit flips—verify will flag but ECC corrects them in-device [Elektroda, funak, post #17878605][#16649962]
Can I add an unsupported NAND ID myself?
Yes. Pick a chip with matching geometry from the list, edit LUN-, block- and page-sizes, then save as a custom XML entry. Example: TC58BVG0S3HTA00 added by user in 5 min [Elektroda, bolvan, post #18061891]
How do I prepare a Samsung D5500 dump?
  1. Detect K9GAG08U0E.
  2. Press “Prepare file D5500”; select source dump and output file.
  3. Click “Erase”, then “Write”. The wizard remaps all bad blocks and recreates the BBT automatically [Elektroda, funak, post #16649962]
Does NANDLite handle eMMC or SPI NOR?
v1.0: only parallel NAND. v1.2 will add SPI/I²C via EXT header; v2.0 will add eMMC and NOR through USB 3.0/FPGA adapter [Elektroda, funak, post #18223831]
What is the largest page size validated?
16 384 + 1 280 B pages (Hynix H27UCG8T2BTR-BC, 64 Gbit). Verify reports <130 flipped bits per page—well within the 640-bit ECC budget [Elektroda, funak, post #16876251]
How do I flash chips that need 1.8 V I/O?
Use NANDLite v2.0 or v1.0 with the dual-voltage adapter; set supply to 1.8 V and leave VCC at 3.0 V as per ONFI [Elektroda, funak, post #17298560]
Where can I buy genuine TSOP48 sockets?
Original Yamaichi TSOP48 cost ≈PLN 180 at Semicon; tested Chinese clones work but lose spring tension after ~100 insertions [Elektroda, tplewa, post #15976786][funak, #15979863].
Statistic: how many bad blocks are typical on a blank 8 GB MLC?
Four bad blocks (0.2 %) per die is typical; sample K9GAG08U0E showed 8 bad blocks right after erase [Elektroda, funak, post #16656035]
Failure fact: what causes endless verify loops?
If geometry is unset (page = 0), the app enters an infinite verify loop—select a matching chip definition first [Elektroda, funak, post #18400138]
