Flash NAND Lite Memory Programmer! TSOP48
funak 413394 558
  • Built a low-cost Flash NAND Lite programmer for TSOP48 NAND chips, aimed at reading and programming memory from sticks, routers, televisions, modems, and navigation devices.
  • The board runs from USB 5.0V, generates 3.3V with a TPS781330220 LDO, and uses an XMEGA-A4U plus FT245 USB converter with a parallel data bus.
  • The design exposes four CE lines and four RB lines, while the LDO’s 150mA overcurrent protection helps prevent damage if a chip is inserted backwards.
  • Measured throughput reached 980kB/s from FT245 to XMEGA and 2.7MB/s from NAND to XMEGA, showing much faster direct NAND communication.
  • The main limitation is cost-cutting simplicity: only one permanently soldered TSOP48 socket is included.
  • #331 18674433
    funak
    Help: 101
    Rate: 461
    You can use it, theoretically it should work.
  • #332 18677018
    Tertomium
    Okay, because the device fails when I try to start / update smart hub. I have tried all dumps I have found around in the web.
  • #333 18680338
    lukasis6
    Help: 25
    Rate: 71
    Tertomium wrote:
    does the D5700 have the same Bad-Block support as the D5500, so you can use nandlite for correction?
    These are the same NAND dice and the same dunk can be used.
  • #334 18683734
    Tertomium
    Thanks for answering.
    Do you know why the tv breaks when i try to use smart hub?
    Maybe the nand itself or are there known bugs within nandlite which are not Resolved yet?
  • #335 18705670
    Wazier
    Where can I buy the nand lite and shipped to the Netherlands?
    Thank you
  • #336 18708522
    funak
    Help: 101
    Rate: 461
    Yes, you can buy it at https://allegro.pl by typing in the search engine: NANDLite
  • #337 18777543
    kiko80
    Help: 67
    Rate: 163
    How are you progressing with the V2 ??
  • #338 18814067
    Reider
    emmc won't read soon?
  • #339 18851717
    SERGEY4273
    Hello! I can't flash atxmega128a4u, here's a picture Flash NAND Lite Memory Programmer! TSOP48 DO I FLASH all the elements on the board with a ready-made programmer, or do I need to flash atxmega without installing it on the board? Or so it should be stitched but I can't, tell me how to fix it? Thank you!
  • #340 18868229
    funak
    Help: 101
    Rate: 461
    The NANDLite server is currently down, so it is not possible to send batches, and the signatures of the systems can, they will be queued for analysis. The planned server activation is scheduled for August 20, 2020.
    We have a lot of work ahead of us on NANDLite v2.0 in September, please wait for some positive news.
  • #341 18887607
    funak
    Help: 101
    Rate: 461
    Good morning,
    Recently, I noticed a certain incorrectness in the use of the programmer, so I would like to remind you of some basic rules when working with NAND memories:
    - NAND memory is divided into blocks and pages
    - pages are contiguous data spaces contained in a data block, for example a block contains 64 pages, and a page contains 2112 bytes
    - the factory NAND memory may have damaged data blocks (and this is normal), i.e. those to which data cannot be written, an attempt to write data to such a block fails, it does not "spoil" the memory
    - each memory page is divided into two logical data spaces, the so-called: MainArea, where the size is defined as powers of two, i.e. 2048 bytes, and the so-called: SpareArea of different sizes, in which ECC correction data is stored. This division is basically contractual and provided by the manufacturer in the documentation. Physically, both of these areas are equally qualitatively efficient.
    - a page in the NAND memory consists of bytes, and individual bytes - of bits, and individual bits may have a lower capacity to store data, as a result of which the memory may not be verified correctly after the recording, i.e. random bit errors may occur, they may also occur after the device memory has been used for an extended period of time. The manufacturer knows about it, that's why he introduced an additional SpareArea space, where you can place the result of special mathematical operations that allow you to locate a specific distorted bit and recreate it, usually it is already implemented by the device in which it is installed.
    - the manufacturer suggests what correction ability must have an algorithm of special mathematical operations (so-called ECC), i.e. how many bits may be distorted during reading,
    - more than 1 bit can be stored in a particular NAND memory cell, therefore the type designations have been introduced: SLC, MLC, TLC, etc.
    - SLC is the best quality memory, 1 bit of memory is stored in one NAND memory cell, therefore this type of memory can be repeatedly erased and programmed and their number reaches up to 100,000 times, the disadvantage is unfortunately the low capacity
    - MLC - the next generation of NAND memory, on the same silicon surface in one NAND memory cell can fit 2 bits of data. Unfortunately at the cost of something for something. The number of writes decreased to about 5,000 times, while the greater number of unstable bits increased, so the SpareArea area had to be enlarged to include more information for the bit correction system (ECC). The algorithm itself is more complicated, but it can correct 4-8 bits of distorted bits
    - TLC, the next generation of NAND, the manufacturer said that if you could fit two bits, why not three? And yes, it also happened, 3 bits in the memory cell is a capacitive jump in the same volume of silicon, hence the memory of 16.32Gbit. Unfortunately, practically every page has corrupted bits here, the ECC system has something to do here. Subscriptions dropped to around 500!
    - at any time we can program any page in the memory in any block
    - with some exceptions (SLC, NOP> 1) we program the memory only once, if we want to re-program even the same content, we must necessarily delete it, otherwise errors will occur during verification
    - before programming any page, it must be previously deleted, i.e. its content is the same logical "1"
    - you cannot delete a single page, we always delete the entire block and this is a significant limitation
    From the point of view of the NANDLite programmer - ALWAYS before writing the memory, ERASE the memory.
  • #342 18900517
    jagdeepdhillon
    Hi funak,
    Today I tried to read hynix nand HY27UCG8T2BTR-BC. It took about 3.5 hours to finish. But read only 00 in every block. Is there any problem with the algorithm.
    Thanks
  • #343 18907112
    ptihka69
    Tell me, is it possible to flash OneNand KFG1GN6W2D-SAMSUNG UE32D5500 with this programmer, if you make some kind of adapter? Or can it be in the programmer version 2.0? And will the second version of the programmer be free like the first, or will it only be paid?
  • #344 18950335
    talkos
    what about version 2, when to wait approximately and what changes there will be
  • #345 18964723
    Marco82tn
    Good evening, I should revive my NR609, I ordered the DSP from china from a seller who have a lot of positive feedback about the d830. I'm afraid that NAND also needs to be reprogrammed, does the NANDlite programmer also send it to Italy? Thank's
  • #346 18964804
    funak
    Help: 101
    Rate: 461
    Yes, shipping in Italy possible. Info in a private message.
    Please enter the NAND symbol. I'll check if it can handle this memory.
  • #347 18964845
    Marco82tn
    Thanks to the creators of this exceptional forum, thanks to everyone I was able to find out how to revive my onkyo NR609 .. I am an electronic technician. I hope to be able to restore the sound to the amplifier
  • #348 18965095
    fachura
    Help: 11
    Rate: 111
    Hello, my friend funak's programmer supports NAND memory, among others, as Onkyo tx-nr 609 is on the memory list.
  • #349 18968589
    Marco82tn
    YES yes, he told me .. since I make the purchase I also try to fix an 8050 of a friend who has a faulty DSP .. after the reflow by a Centre Assistance it went a week and now it is silent ..
  • #350 18970546
    SERGEY4273
    Здравствуйте! Подскажите пожалуйста когда выйдет новая прошивка для NAND Lite ? Спасибо!
    Dzień dobry! Czy możesz mi powiedzieć, kiedy zostanie wydane nowe oprogramowanie dla NAND Lite? Dzięki!
  • #351 18979670
    Marco82tn
    ordered, I just have to wait for the DSP and the programmer and let's try to revive the NR609 there. thank you all!!! I'll let you know
  • #352 18979766
    funak
    Help: 101
    Rate: 461
    SERGEY4273 wrote:
    ????????????! ?????????? ?????????? ????? ?????? ????? ???????? ??? NAND Lite? ???????!
    Good morning! Can you tell me when the new firmware for NAND Lite will be released? Thanks!
    The new software should be available in December. I am waiting for a new internet connection, where there will be a new application server. There will be news :)
    Version 2.0 should also be released in December, but that is yet to be confirmed. We'll see what the end of the month will bring.
  • #353 19061993
    funak
    Help: 101
    Rate: 461
    The batch shipping server will not start until December 1. Please be patient.
  • #354 19063111
    talkos
    może długo oczekiwana aktualizacja pojawi się w grudniu?
  • #355 19069243
    Reider
    emmc will not read, the project died.
  • #356 19093774
    talkos
    let's hope that the author will still revive this wonderful project
  • #357 19095746
    funak
    Help: 101
    Rate: 461
    It will revive and revive the project, please give me a moment more patience :)
  • #358 19113249
    DelphiN1305
    Funak, please help. After NAND firmware K9GAG08U0E SCB0, the TV still starts to reboot after a while.
  • #359 19117986
    funak
    Help: 101
    Rate: 461
    Did you process a batch after erasing memory?
    Provide programming logs.
  • Poor solder joint or high bit errors may cause rebooting
    #360 19118042
    mahcin
    Help: 21
    Rate: 60
    DelphiN1305 wrote:
    Funak, please help. After NAND K9GAG08U0E SCB0 firmware, the TV still reboots after a while.
    I had such a situation, only after the 2nd time I soldered the pins with a soldering iron, it was okay, it did not restart, I did not program the system again, I had the problem in February. Apparently, if something is not in contact, the effect is the same, but this programmer supports K9G ... beautiful, if you have any BB in the system and probably you will always hit 1 - process the file in the program, then save the processed file to the system.
    What's in your log? Because you know ... how many high error bits are, even though you program it, there is no chance for the system to work, without your LOG from programming it's hard to talk about details. Paste the log.
    You also have to be careful not to overheat the circuit next to it, if you are soldering with air.
    Maybe the reset will help? As I remember correctly, shorten the M_HRESET and M_E_SDA pins on the motherboard and connect to the TV power supply and start. It will perform a reset, unless the TV even starts up in this mode, I don't really remember, remove the jumper and turn it on again, it will turn on normally. I guess that's how it went.
Discussion centers on a low-cost NAND Flash programmer built from scratch for TSOP48 memories, aimed at reading, erasing, and programming chips from TVs, routers, modems, memory sticks, and similar devices. The project evolves through multiple hardware and software revisions, adding FT245/FTDI-based USB communication, faster transfer modes, support for Linux-portable software, anonymous batch upload to a server for structure analysis, and increasingly advanced ECC/BCH correction. A major focus is handling bad blocks, BBT tables, page/block addressing differences between vendors, and reconstructing data layouts for Samsung TV NAND dumps, especially K9GAG08U0E used in D5500/D5700 sets. The software later gains page export/import, direct page editing, language selection, driver support, and planned eMMC support, while the author tests various NAND types, analyzes spare area data, and compares the solution with commercial tools such as RT809H, PC-3000 Flash, Flash Extractor, TNM5000, and Wellon.
TL;DR: NANDLite v1 erases 512-MBit chips at 4.8 MB/s, “the TV came to life” after one flash [Elektroda, funak, post #16067358][#16667571] First-time users need <3 min setup. Why it matters: hobbyists get pro-level NAND support without €900 lab gear.
• Firmware: NANDLite! _R1.0v1.0b1024a [Elektroda, funak, post #18353353] • Max measured write speed: 2.7 MB/s NAND→XMEGA, 980 kB/s PC link [Elektroda, funak, post #15973950] • Auto-erase rate: 4.8 MB/s on 69 MB ST NAND512W3A [Elektroda, funak, post #16067358] • Supported IC signatures: 70 + (SLC, MLC, ONFI) [Elektroda, funak, post #16449394] • Kit price: approx. PLN 450; worldwide shipping PLN 21 [Elektroda, mailo, post #17314701][#17949208]
Which Windows versions run the current NANDLite software?
The online release 1.0.1014.89 runs on Windows XP, 7, 8, 10 (32 / 64-bit). SmartScreen blocks can be bypassed via “More info → Run anyway” [Elektroda, funak, post #18359665]
How fast can I dump a 2 GB K9GAG08U0E?
With v1 hardware set to 750 kB/s link speed, a full 2 GB read finishes in about 45 minutes; v2.0 (USB 3.0 + FPGA) targets 40 MB/s, cutting time to ≈55 s [Elektroda, funak, post #18250769]
What error level is acceptable during verify?
SLC devices allow 1-4 bit errors per 2 kB page; MLC K9GAG08U0E tolerates up to 24 bit flips—verify will flag but ECC corrects them in-device [Elektroda, funak, post #17878605][#16649962]
Can I add an unsupported NAND ID myself?
Yes. Pick a chip with matching geometry from the list, edit LUN-, block- and page-sizes, then save as a custom XML entry. Example: TC58BVG0S3HTA00 added by user in 5 min [Elektroda, bolvan, post #18061891]
How do I prepare a Samsung D5500 dump?
  1. Detect K9GAG08U0E.
  2. Press “Prepare file D5500”; select source dump and output file.
  3. Click “Erase”, then “Write”. The wizard remaps all bad blocks and recreates the BBT automatically [Elektroda, funak, post #16649962]
Does NANDLite handle eMMC or SPI NOR?
v1.0: only parallel NAND. v1.2 will add SPI/I²C via EXT header; v2.0 will add eMMC and NOR through USB 3.0/FPGA adapter [Elektroda, funak, post #18223831]
What is the largest page size validated?
16 384 + 1 280 B pages (Hynix H27UCG8T2BTR-BC, 64 Gbit). Verify reports <130 flipped bits per page—well within the 640-bit ECC budget [Elektroda, funak, post #16876251]
How do I flash chips that need 1.8 V I/O?
Use NANDLite v2.0 or v1.0 with the dual-voltage adapter; set supply to 1.8 V and leave VCC at 3.0 V as per ONFI [Elektroda, funak, post #17298560]
Where can I buy genuine TSOP48 sockets?
Original Yamaichi TSOP48 cost ≈PLN 180 at Semicon; tested Chinese clones work but lose spring tension after ~100 insertions [Elektroda, tplewa, post #15976786][funak, #15979863].
Statistic: how many bad blocks are typical on a blank 8 GB MLC?
Four bad blocks (0.2 %) per die is typical; sample K9GAG08U0E showed 8 bad blocks right after erase [Elektroda, funak, post #16656035]
Failure fact: what causes endless verify loops?
If geometry is unset (page = 0), the app enters an infinite verify loop—select a matching chip definition first [Elektroda, funak, post #18400138]
