SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 512298 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • #151 18666833
    theo33
    Help: 78
    Rate: 322
    Wbm wrote:
    theo33 wrote:
    Where did you download the files from? could you share.
    I got the firmware from the installer and he from the distributor, and my colleague is sometimes not an installer? ;-) I could draw such an erroneous conclusion from my colleague's statements so far ... very professional by the way.
    Wbm.
    Are you an installer? that's a bit too much said, I launched several installations in the neighborhood and for children and mine in 2016, I wrote to the website about this update, but the answer is as if they did not know about something like that, the distributor where I bought sofars also does not know anything now, and I read here, so if I could have these files I would be grateful.
  • #152 18692975
    MariuszKs
    Question for more experienced colleagues.
    Does the energy company control meticulously compliance with the documentation, diagram and correctness with art?
    I am asking because on YouTube you can see many installation connections by "amateurs" (of course, the papers were raised by someone with permissions) that the energy company connected and work, and in the comments under such a video there is always a flood of "professionals / experts" and picking on dozens of things.
  • #153 18693338
    marcinbbb
    Help: 44
    Rate: 178
    They used to go around and check everything, they even made photographic documentation, but it was 2015 when I plugged in the first installation. Now they will mount the meter and they are gone.
  • #154 18693476
    Leon444
    Help: 48
    Rate: 355
    I have not heard in my region that they check anything, The meter is coming and assembled by guests from the energy service in most cases, they do not even ask about the installation if it really is (a year ago it was so with my parents)
    In 2014, as I assumed at home, they came as the first in the region with PV in three of them, but they also did not watch the installation, but struggled with the meter and modem, antenna and when they did, they went :)
  • #155 18693817
    noja102
    Help: 38
    Rate: 246
    In 2 cases, they replaced the meters, as even the material for PV at the investor has not yet been, no one asks for anything today, he has an order to replace it, and if the meter in front of the property, they do not even bother to inform about the exchange
  • #156 18693824
    Cytro12
    Help: 47
    Rate: 304
    And I'm supposed to be scared, one grandfather drives before retirement, which apparently knows and exchanges these meters because the rest probably can't mount the SIM card to the meter. They are not interested in the PV installation because it is on your side of the property, just as they are not interested in your electrical installation in the house, if so, the one who signed up corresponds. Anyway, so much is being installed now that if they wanted to document everything, they would have to build a new office building.
    It is a pity that Sofar is so poor with these software updates.
  • #157 18693940
    Wbm
    What do you mean? The inverter had v2.01, it already has v2.20, the datalogger has LSW3_14_FFFF_1.0.18, it already has 1.0.30. Everything within 2 months.
    Wbm.
  • #158 18694208
    djstanley
    Sure, no one checks the installation, when they changed it recently, they only asked "Ladies and these panels when they will be ..." hehe. Which does not change the fact that it should be made in accordance with art.
  • #159 18694423
    Cytro12
    Help: 47
    Rate: 304
    Wbm.
    And where can you download this soft?
  • #161 18699492
    gotycki1
    Rate: 8
    Hello, I have a problem with Sofar Solar 8.8 KTL-X. After starting, it works normally for some time, then the PvConfigSetWrong message appears and restarts by itself. Several times until the message Permanent fault (PERMANENT) appears and stops working. Maybe someone knows what could be the reason for this. I also don't know how to factory reset this inverter.
  • #162 18699920
    theo33
    Help: 78
    Rate: 322
    Something with the configuration of the inputs involved, probably the id11 error, did you change the settings or was it like that from the beginning?
    how many modules in strings? tell me how it connected on the DC side
  • #163 18700068
    gotycki1
    Rate: 8
    I actually entered the input settings without checking what it was originally and set the parallel ones. I have two strings each with 16 320W panels positioned the same on a ground structure to the south.
  • #164 18700093
    theo33
    Help: 78
    Rate: 322
    Change it to independent and it will be ok.
    and more than 10kW south on inverter 8 is a little too much and will cut a lot
  • #165 18700162
    gotycki1
    Rate: 8
    I'll change to independent and see. This power of inverters was advised by the seller because only a few days a year the panels will give 100% power. Do you know what the setting of the mppt scanner should be and how to restore the factory settings?
  • #166 18700530
    AT PRO
    Help: 63
    Rate: 191
    It advised you badly. I have one 3.6 on the 3.3 inverter and I regret it because it cuts, I could give 4.4 kW.
    Set the scanner to off. For me, the inclusion worsened the yield.
  • #167 18700980
    Cytro12
    Help: 47
    Rate: 304
    That's why you calculate it and don't buy it cheap, it depends a lot on the temperature coefficient and you are experiencing it now.
    The MPPT scanner is used in certain cases, normally it should be turned off because it interferes with the algorithm.
  • #168 18701179
    AT PRO
    Help: 63
    Rate: 191
    Cytro12 wrote:
    That is why it is calculated and not bought cheaply,
    I do not know in what sense you write that cheap is wrong. It can be cheap and good. I suggested, like everyone else, to oversize the panels in relation to the inverter, but now I am a supporter of not oversizing. Let the panels produce as much as they can at the moment.
  • #169 18701186
    Cytro12
    Help: 47
    Rate: 304
    Cheap and good? I did not know that such views are still alive today. The rest of the post shows that there is not much to talk about :)
  • #170 18703091
    Mirek_Gab
    Rate: 115
    What is the difference when it comes to a soft datalogger?
    Wbm.
  • #171 18707924
    Grucha383
    Rate: 19
    Hello, is there any instructions on how to upload new firmware to Sofar? The Chinese sent me. And to the datalogger, not because they wrote that it is not necessary?
  • #172 18707928
    Wbm
    Yes, you copy the received files to the firmware folder on the microSD card. Then select update from the inverter menu.
    Wbm.
    Added after 6 [minutes]:
    Of course you can ;-)
    Wbm.
  • #173 18708397
    macgaw
    Rate: 13
    Is the SD card in Sofar inverters only for updating or can you save measurements on it?
  • #174 18708738
    Wbm
    The inverter itself saves the measurements on it, an example of the folder structure on the card:
    Code: Bash
    in each folder / directory there are .csv files that contain various information such as the amount of energy produced for each hour, daily, monthly and yearly, events, errors, etc.
    Wbm.
  • #175 18708964
    AT PRO
    Help: 63
    Rate: 191
    The cards are pre-installed or do you need to add them because I haven't visited my home?
    What type of inverter do you have?
  • #176 18710592
    wowo-slu
    I have a question. Has anyone used the TIGO TS4 optimizers in an installation with a SofarSolar 5.5KTL-X or similar inverter?
    Will it work at all and how effective is it in the case of periodic shading of 4 panels?
  • #177 18744777
    tmarcel
    Good morning,
    Mama Sofar 3300TL-G3 (new model Sofara series G3 single-phase). I am looking for information on how the Reflux Power Setting parameter (Disabled or Enabled) should be set in point 17 of the menu - in a situation where I do not have any additional equipment connected to the inverter monitoring the power returned to the network.
    With the Enabled option, I see that you can enter the power value and set the limit of the power returned to the network.
    Maybe someone has experience or knows what the default setting for this point is.
    Can he know what is the current software version for this inverter? I have V1.9 on the sticker
    Best regards,
  • #178 18744881
    AT PRO
    Help: 63
    Rate: 191
    You don't have the Polish language version there?
    As for the power output limiter, leave it off or set it to 100% power on.
  • #179 18744918
    tmarcel
    There is no Polish version. Then I leave Reflux Power disabled.
    Do you know what the current firmware version is for Sofar 3300TL-G3. I have v1.9 on the sticker. I have not found any information about the current firmware versions for Sofar inverters on the manufacturer's website.
    Best regards,
  • #180 18747829
    tmarcel
    By the way, I will share in the attachment the instructions received from the manufacturer on how to control the power delivered to the grid in Sofar Solar inverters.
    • reflux power setting.pdf (395.11 KB) You must be logged in to download this attachment.
Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
