SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters
---Ryba--- 512310 1722
How reliable are Sofar inverters for an around-8 kW PV installation, and what problems or failures do users report?
Users report mostly acceptable results: one 6.6KTL-X had no problems for over a year, and another 8.8KTL-X owner said a firmware update to v2.20 removed the old clipping around 8 kW and let the inverter reach full peak power [#18112697] [#18662870] [#19158337] The most common problems in the thread were not outright inverter defects but installation/configuration mistakes: too many panels in one string or the wrong input mode caused DC overvoltage errors such as PvOVP, BusOPV or permanent fault, and the cure was to wire the strings correctly and keep each MPPT within its limits [#18322870] [#18323108] [#18359020] [#18360610] [#18699492] Another recurring issue was grid overvoltage: users saw ID01/Grid OVP shutdowns when mains voltage rose to about 253 V, and one case reached 280 V at the customer side; the inverter was behaving as designed in those cases [#18624602] [#18665849] A few users also mentioned Wi‑Fi/software quirks and awkward warranty handling, with the installer, seller, distributor and Sofar service bouncing responsibility between each other [#18306997] [#18322870] [#18323064] [#18331261] [#18772451] There was at least one real hardware failure report, where an 8.8KTL-X tripped AC overcurrent after about a month and then would not restart, so the unit had to go through warranty [#18771167]
  • PvConnectError points to inverter-side MPPT failure
    #1711 21909146
    zybinek
    Rate: 11
    SOFAR 4.4 KTLX G3 - PvConnectError at 555 V / (0.0 A), has anyone encountered this problem?
    Servus, after upgrading my 2023 home installation I have moved the installation from the house to the allotment and am having a problem with the SOFAR 4.4 KTLX G3 inverter and am looking for the opinion of someone more experienced before I report the equipment for service.
    Symptoms - On the display all the time: PvConnectError, PV1: 555 V - 0.0 A
    I attach a photo of the display with the message.
    That is:
    -the voltage from the panels is (~555 V)
    -inverter sees string
    but is not drawing current (0.0 A)
    What I have already checked:
    Polarity correct (+ meter to red, - to black → +555 V)
    String working (with load flows >8 A)
    MC4 plugs correctly made (+ red / - black, markings match)
    AC voltages OK; L1: 240 V, L2: 239 V and L3: 239 V
    No other errors on display (only PvConnectError)
    Installation without grounded poles (floating)
    I carried out an additional test.
    I connected directly to the inverter (from a neighbour), an independent string of ~344 V DC: separately to PV1 and separately to PV2. Identical result: after initialising the inverter, the following reappears: PvConnectError, PV1: 344 V 0.0 A (i.e. only the voltage changes)
    What is strange. Inverter: sees PV voltage (both 555 V and 344 V), does not draw any current (0 A), on both MPPTs (PV1 and PV2) behaves identically. It looks as if: the MPPT is not switched on at all!
    Questions:
    1. Has anyone encountered this symptom with the SOFAR G3?
    2. Can the message "PvConnectError" with correct voltage mean:
    -pV / MPPT input failure?
    -a problem with the DC relay?
    -a software / start-up lockout?
    3. Is there anything else worth checking before service?
    Summary:
    - two different strings → same effect
    - two MPPT → same effect
    - correct AC and DC voltages
    - no current on PV side
    It all looks like a problem on the inverter side, but I prefer to verify before reporting.
    I would appreciate any concrete suggestion!
    • Sofar PV1.jpg (430.44 KB) You must be logged in to download this attachment.
  • #1712 21909160
    ja_pizgam
    @zybinek you can still check the + and - to PE to see if it exceeds 30 VDC, although it would be best to measure the insulation resistance with a special meter, but if it comes out measuring OK then something is wrong with the inverter.
  • #1713 21909224
    Janusz_kk
    Help: 229
    Rate: 1482
    And what does the manual say? AI ask, maybe he has already encountered such an error.
  • PV voltage present but inverter draws no current
    #1714 21909259
    zybinek
    Rate: 11
    As suggested, I asked AI - Copilot 365.
    Below is his response:
    "I have checked the topic more extensively and it looks quite clear:
    the inverter sees the PV voltage (344-555 V),
    but does not draw any current (0.0 A),
    both MPPTs behave identically,
    second, independent string - exactly the same effect.
    That is, in practice, the PV installation falls off.
    The PvConnectError in this situation looks like a failure to switch on the DC path - the inverter "sees" the string, but the MPPT does not start.
    From the suggestions of colleagues I will still check:
    +/- voltages relative to PE (whether there is an isolation problem)
    On the other hand, with these symptoms it looks most like:
    → damage to the PV input / MPPT section of the inverter."
    I wonder how this problem is seen by practicing installers?
  • #1715 21909268
    Janusz_kk
    Help: 229
    Rate: 1482
    Check also this PE what your colleague here suggested >>21909160
    Because if there is an error here, the inverter won't start either.
  • Measured string-to-PE voltage drops to about 92 V DC
    #1716 21909447
    zybinek
    Rate: 11
    As suggested by ja_pizgam I checked with a METEX 6030 meter on the 600 v DC range the "+" and "-" voltages relative to PE, with the "-" of the meter caught behind PE.
    At first, relative to the "-" string (black lead) a voltage above -500V appeared and started to drop rapidly to about -92V and stabilised at this level and when I moved the meter's plus lead to the "+" string (red lead) a voltage above +500V DC appeared briefly and after a while started to drop to about + 91V.
    What should I do in this situation to reduce it by at least 3 times?
  • #1717 21909453
    ja_pizgam
    Well then, either you have damaged wire insulation somewhere, or there is a strong induction of voltage in these wires. All you have to do now is measure the insulation resistance with a special meter.
  • #1718 21909461
    DJ MHz
    Help: 40
    Rate: 255
    In my hyd it was throwing a similar PV error, the software has bolted despite upgrading to different versions. Currently there is one string and it goes in "parallel" mode even though it should be independent :D
  • Check MC4 connectors and possible PE leakage
    #1719 21909480
    Janusz_kk
    Help: 229
    Rate: 1482
    Look through the mc4 connectors to see if any are lying in the water, check the wires.
    Is it PE you have sure? maybe it is not contacting and something is induced from the phases in PE? maybe one of the panels has leakage?
    Something must be on the connections since it was running and after moving it stopped.
    Where do you have it installed anyway? city, region.
  • Possible inverter settings issue with parallel string mode
    #1720 21909544
    zybinek
    Rate: 11
    Thank you for all the hints!
    The String 555V consists of 2 tables of 250 Wp panels. One table has 9 panels and the other has 8 panels.
    The installation with these panels was commissioned in 2016 near Legionowo. So the panels and cables have at least 10 years of use behind them, while the SOFAR 4.4 KTLX-G3 inverter has a warranty term as shown in the picture. I got it for a small amount from my brother, who was upgrading his installation and had to replace the inverter with a hybrid one. The tables are 10-15 m from the inverter and the power cables are buried 50-60 cm underground.
    DJ MHz wrote - " Actually there is one string and it goes in 'parallel' mode even though it should be independent " maybe there is actually something wrong in the settings?
    Or does anyone, based on this information, have any more ideas on what to do about this faff?
    • SOFAR 8kW PV Installation: Opinions, Durability, Failures & Experiences with Inverters SOFAR KTLX-G3_Data z gwarancji.jpg (126.88 KB) You must be logged in to download this attachment.
  • Incorrect PV input mode caused PvConnectError
    #1721 21911581
    zybinek
    Rate: 11
    Problem solved.
    The cause of the error PvConnectError was an incorrectly set PV input mode on the inverter.
    Parallel mode was set and the installation was not symmetrical (one string connected to one MPPT.
    After changing the setting in the menu:
    Settings -> Input modes -> password 0001 -> mode "independent" the inverter started to work correctly and draw current from the panels.
    The installation of the panels was operational and the problem lay solely in the inverter configuration.
    Thank you for all the hints that helped me solve the problem!
  • #1722 21911843
    DJ MHz
    Help: 40
    Rate: 255
    Under 0715 you also have various interesting settings
  • Parallel mode change required inverter reset
    #1723 21930043
    maniakalny
    I was in standalone mode with the units connected independently – I physically switched them to parallel mode to split the currents, changed the setting to parallel (but didn’t reset the inverter), which meant the settings didn’t take effect.
    I can’t remember what the error was, but the result was that output didn’t exceed 200–300 W (even though it should have been running at 8 kW at the time) – the string voltages were a bit odd too.
    P.S. If anyone has 3.3, 4.4, 5.5 or 6.6 models for sale or exchange (I have 11ktlx and 20ktlx g3), please email ;)
Discussion about Sofar PV inverters for an ~8 kW installation focuses on reliability, long-term experience, and common faults. Several users report generally stable operation of Sofar units such as 6.6KTL-X and 5.5KTL-X, but also mention issues with Wi‑Fi connectivity, missing service support, and occasional inverter shutdowns under certain weather conditions. The main technical problem analyzed is DC input overvoltage: a 1-phase Sofar inverter with a 600 V maximum input was connected to a string of 15 Q.CELLS 305 W modules, causing PvOVP / BusOPV errors and shutdowns when string voltage exceeded the limit, especially in cold, sunny conditions. The proposed fix was to split the array into two strings and connect them to separate MPPT inputs, or redesign the inverter choice and string sizing. The thread also covers MPPT limits, string voltage calculations, current limits, Sunspec/RS485 compatibility, Polish menu/software availability, and comparisons with SMA and Fronius as higher-priced alternatives.
TL;DR: Field owners report 0–20 % daily energy loss when Sofar inverters trip on 253 V grid peaks; “set Country Code 12 for Poland and the problem goes away” [Elektroda, 3301, post #18624621] Why it matters: one menu setting often fixes most unexpected shutdowns without replacing hardware.
• Max. DC input voltage 1000 V & MPPT window 240-850 V (Sofar 8.8KTL-X manual [Uri, #18921613]) • Recommended DC/AC oversize ratio ≤ 1.2 : 1 for KTL-X models [Elektroda, BikeBarian, post #18360391] • Country Code list: PL = 12, DE = 07, NL = 05 [Elektroda, Defence & 3301, post #18851696] • Typical firmware: V2.30 (increases AC limit from 4.0 kW to 4.4 kW on 4.4KTL-X) [Elektroda, prose, post #19034268] • Service e-mail: service.pl@sofarsolar.com; hotline +48 22 123 98 58 [Elektroda, AT PRO, post #18772451]
How reliable are Sofar inverters in everyday use?
Most 6–9 kW owners report trouble-free work for 1–3 years [Elektroda, iborkim, #18112697; Elekt...
Which menu code should I select for Polish grid parameters?
Use Country Code 12 (PL). It lifts the over-voltage trip to 253 V/10 min and 264 V/1 s, matching Polish NC-RFG limits [Elektroda, 3301, post #18851696] Selecting 07 (DE) raises the limit to 264 V but violates declaration of conformity.
My inverter shows ID01 ‘GridOFP’ and stops at noon—what now?
Measure L-N voltage; if it rises above 253 V, ask the DSO to lower tap settings or move PV to another phase. Until then, temporarily change Country Code to DE (07) or install a 230 → 220 V autotransformer [Elektroda, MariuszFEG, post #18623709]
What causes PvOVP / BusOPV errors on 4KTLM-G2 units?
Voc exceeds 600 V in cold sun. Split the 15-panel string into two of 8 + 7 or use a 3-phase inverter that accepts 1000 V DC [Elektroda, noja102, post #18323557]
Is the MPPT Scan function worth enabling?
Enable only when partial shading occurs; it rescans the IV curve at user-set intervals. Service says it "improves harvest under shade" but reduces output 1–2 % on clean arrays [Elektroda, 3301, post #18622124]
How do I update Sofar firmware myself?
  1. Copy the /firmware folder to the SD card.
  2. Insert card, choose Menu → 5.Software Update, enter password 0715.
  3. Wait until ‘Update DSP1 OK’, ‘DSP2 OK’, ‘FUSE OK’, then reboot [Elektroda, Grucha383, post #19029218]
The display boots for one second at dawn—is that harmful?
No. The capacitors charge when DC rises above 180 V, then discharge if current is < 20 mA; this soft-start repeats without affecting lifespan [Elektroda, rydzyk673, post #19035241]
Why does Solarman show 0.9 A per phase even at 0 W?
Firmware ≤ V2.30 reports reactive standby current as active. Real clamp-meter reading is ~0.2 A; ignore the dash-board figure until a patch arrives [Elektroda, wilk125, post #19038447]
Edge case: can the inverter fail after a breaker trip?
Yes—one 8.8KTL-X died after a 16 A AC breaker opened; display stayed dark despite correct DC voltage, requiring warranty swap [Elektroda, gotycki1, post #18771167]
How to auto-run a 1.5 kW boiler only on surplus PV?
Install a PR-energised relay with the inverter’s CT loop; set closure above 4.5 kW export so the heater engages only in excess production [Elektroda, 3301, post #19053070]
