[BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
p.kaczmarek2 222792 1308
  • OpenBK7231T adds a cross-platform C HTTP mini-server, web pin configurator, and MQTT integration for BK7231T-based WB2S/WB3S modules with Home Assistant control.
  • The design splits Windows-specific networking from reusable HTTP and pin code, so the same configurator and packet parser can run on Windows and on the BK7231T firmware.
  • The server listens on port 80, uses one int as a channel bitmask, and therefore supports up to 32 channels on a 32-bit platform.
  • MQTT callbacks propagate relay/button changes to Home Assistant and accept commands back, and a 4-relay setup uses wildcard topics like wb2s/1/get through wb2s/4/set.
  • The current pin configurator does not save settings to Flash yet, so configuration is still coded and compiled into the firmware.
  • MCU clock sync and bootloader reflashing issue
    #361 19942081
    absinth84
    Hi did some improvement to the Thermostat, now the mcu clock is synched with ntptime when is asked by mcu message. IT use harcoded timezone (+1) but I start to implement the possibility to customize it from web console. I have some trouble here, how to use memory to store the data. I have had no more time to deep into it..
    Here the changes
    https://github.com/absinth84/OpenBK7231T_App/commit/9543503e8f87ee552c01973d57f51c8fb6abed29
    I started also to decode temperature messages from MCU and print them into logs...
    I have also again problems with the bootloader.. I don't know why but I found it canceled by some standard serial update and it was necessary re-flash via SPI
  • UART pin lock prevents boot after pin reconfiguration
    #362 19942745
    eakeyson
    eakeyson wrote:
    Yes, when I did get it to boot the first time I did try to configure some pins. It acts like it still sets that configuration which prevents it from booting.
    There is a simple check that prevents config from disabling UART pins, that is commented out right now.
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/src/new_pins.c
    if you uncomment those lines, config and web page won't be able to change roles of pin P0, P1, P10 and P11:
    Of course, everything here is under assumption that you're getting silence because you've set UART pin role to something else...
    but try, uncomment shown lines, recompile, flash and give us full log.
    In the past, there was also a real boot crash/hang issue but I think it's fixed since several days (I hope)
    Well, that did the trick, now boots and joins WIFI and mqtt as previous configuration still present. When I got it to boot originally, I was configuring pins in the configurator and apparently configured Pin 0 as PWM, as now it won't let me change or erase that to get to clean config. When I save config, comes right back to what was there. I think that I would like to erase entire config and start over per @btsimonh or is there a better way?
    Bootlog and pic of configurator included.
    device lo.. 2.txt (8.98 kB)You must be logged in to download this attachment.
  • Planned text-based flash config for advanced device mapping
    #363 19943002
    Rate: 12914
    I am most likely not going to add much more fields in the web api and in the simple flash config structure.
    My current plan is to allow people to create a text config that will setup more advanced variables by text commands, so something like:
    timeZoneOfs 2
    that resides in the flash memory.
    It will be also used to map TuyaMCU channels to device channels (fnId, dpId, etc) and to setup multiple I2C devices on single bus.
    Example I2C config that I plan to support (not implemented)
    addI2CDevice I2C1 0xA0 TC74 1
    addI2CDevice I2C1 0xA2 TC74 2
    addI2CDevice I2C2 0xA4 SM2135 3 4 5 6 7
    addTuyaMCUDPFunctionReadOnly 0 8
    addTuyaMCUDPFunctionReadOnly 1 9
    setChannelKind 1 Centigrade
    setChannelKind 2 Centigrade
    setChannelKind 3 Red
    setChannelKind 4 Green
    setChannelKind 5 Blue
    setChannelKind 6 Cool
    setChannelKind 7 Warm
    setChannelKind 8 Humidity
    setChannelKind 9 Centigrade
    Explanation: first and second lines are adding TC74 temperature sensors to I2C1 bus with certain addresses and maps their outputs to channels 1 and 2. Third line adds RGBCW led controller and maps channels 3 4 5 6 7 to its inputs. TTuyaMCU lines map TuyaMCU dpIDs to channels 8 and 9. Last lines set channel flavor hints for UI generation.
    This is just a plan, it's subject to change.
    I just want to note that we won't be hardcoding per-device settings in C code.
    Still, your time stuff is not bad, I might manually port some of it to main repo.
    I was less active for last days because I started working on BL602:
    [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
    I am researching the possibility to flash this device and ultimately port my app to that platform as well.
    Very, very strange. We both (I and @btsimonh ) assumed that device would join the WiFi anyway, even with UART pins disabled. And you're saying that only joins WiFi now....
    this is because the old security check in code didn't allow changing role at all, instead of defaulting it to None.
    See new version:
    https://github.com/openshwprojects/OpenBK7231...mmit/5c0edfabdc2f27550f965ca6c7d6cafadd0f4cbc
    Please remember to change #if 0 to #if 1 in order to enable this fix.
    This fix will automatically clear roles of UART pins.
    [/code]
  • Wi-Fi password stored in plain text concerns
    #364 19943918
    sebastian48
    I finally had time to finish two WFIPO120FWT "Nedis Wifi Smart Plug" and configure Home Assistant with a bridge to HomeKit. Everything works great (except the physical button on one of them, managed to unsolder the whole pad). One thing that worries me a bit is the wifi password being plain text in the configuration. How do you usually deal with this? In my case the device is an outdoor smart plug, hence within grab for anyone. At the moment I have them on connected to my house wifi. Are you using separate networks for smart home stuff or are we able to obfuscate the password in the device configuration to make it at least a little bit more safe?
  • Wi-Fi password is logged in plain text
    #365 19944188
    Rate: 12914
    Great news! Please post photos of your setup or screenshots. I am happy to see people using my firmware.
    This is a very good question. The chinese industry standard is to store password in plain text and futhermore to printout it to debug log every now and then.
    Seriously, now.
    I've been testing a BL602 led strip today, and take a look:
    Calculate ENV CRC32 umber is 0x19FA3EF7.
    Erased ENV OK.
    Saved ENV OK.
    Recevied indication to connect to AP MY_WIFI_NAME_SSID MY_WIFI_PASSWORD_IN_PLAINTEXT
    [APP] [EVT] [PROV] [CONNECT] 446073
     SKIP Notify for set Empty Address
    Connect to : MY_WIFI_NAME_SSID MY_WIFI_PASSWORD_IN_PLAINTEXT
    [WF] MM_ADD_IF_REQ Sending: STA
    [WF] MM_ADD_IF_REQ Done
    [WF] vif_index from LAMC is 1
    [WF][SM] Entering idle state
    [WF][SM] Action Connect
               ssid MY_WIFI_NAME_SSID
               ssid len 13
               psk MY_WIFI_PASSWORD_IN_PLAINTEXT
               psk len 24
               pmk
               pmk len 0
               channel band 0
               channel freq 0
               mac 00:00:00:00:00:00
               dhcp status: true
    [WF][SM] State Action ###idle### --->>> ###connecting###
    connecting using vif_idx 1
    ===start sm_get_bss_params===
    bssid[0] = 0xffff
    bssid[1] = 0xffff
    bssid[2] = 0xffff
    search ssid = MY_WIFI_NAME_SSID
    result ssid index = -1
    ===end sm_get_bss_params===
    [WF][SM] Entering connecting state
    [APP] [EVT] Unknown code 12, 446263                     ..
    The same happens on ESP8266 devices (I also found my SSID and pass in ESP8266 flash dump read by esptool many times), and most likely also on several other Tuya platforms.
    But of course we should be better than that and I fully agree with your concerns. I will think about adding some more security layer to my firmware, but with open source, I can't see any really reliable methods to secure it. I could do a simply encryption on it, maybe even a simple xor on each character, it still would be better than what Tuya does. Maybe it would be better to also make sure that your WiFi is secure, add MAC filtering, maybe separate network for smart devices, etc. Depends on your use case.
    Still, the first thing I'd suggest is to disable debug printout of target SSID and pass that is infact now even in our firmware, as it is useful for debugging boot issues, which seems to be common among our users (see few posts above...).
    On a brighter side, I have some great news!
    I have managed to compile and flash example SDK projects on BL602 platform on Magic Home LED strip. It means that Magic Home devices are not secured it any way. It means that it's possible to port my app to BL602 and support all BL602 devices in the future.
    BL602 flashing procedure is relatively simple. There were several problems to overcome with SDK (the newest version seem to have broken compilation), but they are resolved now. Maybe I will do some kind of BL602 tutorial soon.
    ferbulous wrote:
    And there’s also this gu10 ewelink bulbs that use BL602. I did order some ESP-01D modules to replace this
    Spoiler:
    [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
    @ferbulous , are you still here? Do you still have desoldered BL602's?
    It flashes correctly now!
    BL602, here we come!
    It's really possible that soon our app will support 4 platforms: BK7231T, BK7231N, XR809 and BL602 (five if you count http server working on Windows for development purposes).
    PS: but please note, I am not sure now how much exactly of porting work will require running my App on BL602, it depends on some things like sockets API availability etc
    PS2: for more BL602 LED strip information, see this topic (I just posted it in teardowns section, translation pending) https://www.elektroda.pl/rtvforum/topic3881416.html#19944184
  • Commit does not clear stuck pin roles
    #366 19945760
    eakeyson
    Device did not join WIFI anyway, only now when I commented out what you suggested above.
    See new version:
    [/code]
    This commit does not work for me with either "#if 0" or "#if 1". Output log stops after pins configured as before.
  • PWM role set on a non-PWM pin causes bk_pwm_stop error
    #367 19945777
    Rate: 12914
    This can mean only one thing. We were wrong about the initial cause of the problem.
    It's not that you change the role of UART pin, it's that you're trying to set a PWM role for non-PWM pin and thus bk_pwm_stop gets called with -1 argument.
    I see no security check against that in SDK.
    Try this:
    https://github.com/openshwprojects/OpenBK7231...mmit/28e6ee05c32d717f04950f22f8073fafbecfc98e
  • Devices occasionally crash and need power cycling
    #368 19946880
    sebastian48
    I admire your work. I'm more of a frontend guy but have been playing around with hardware for some time. Still, a lot of the low level C stuff is hard to read and understand for me. But it's fun to learn :). If you are interested in the spare chip I got (two pads are desoldered) I gladly mail it your way. I know you asked but never PM:ed you address.
    Mind boggling that Tuya has this terrible level of security. Seems like a IoT/Smart Home disaster waiting to happen. Anyhow, security by obfuscation is as we know not really security. Add the open source side of it and it's not really helping. Bit of a nut to crack.
    Meanwhile both my devices have experienced some sort of crash where they get stuck in their state until I power cycle. I have yet to find any pattern so I guess I will observe for a few days and maybe just have to fix some clip to connect the log. Maybe Home Assistant log will show something too. I should probably setup the dev env too. I just grabbed the precompiled binary that is about a month old and I've seen there are some changes since. Is this something you have experienced?
  • No 3.3V jumper on the USB-TTL adapter
    #369 19947120
    pepesuriano
    eakeyson wrote:
    Where did you get those clips to attach the Dupont cables to the PCB?
    With the logic analyzer, but here are more or less the same clips: https://aliexpress.com/item/32875745353.html
    ExploWare wrote:
    @pepesuriano my only advice is to link the GND from UART and USB powerline you feed into the AMS. The regulator on the serial might have a floating gnd (good from a safety perspective)
    Done, unfortunately nothing changed and it's not working just as in post https://www.elektroda.com/rtvforum/topic3866123-330.html#19930002
    Is there any guide for doing it with SPI? Perhaps I can try this way since it seems that we are not getting anything with UART :(
    Where is the 3.3V logic levels selection jumper (assuming that's the USB to TTL converter similiar to the one I am using)?
    My adapter don't have this, it have 3v3 pin and 5v pin, it's this adapter: https://bdspeedytech.com/index.php?route=product/product&product_id=901
    I tried with an arduino uno also as UART adapter, and it didn't work either :(
  • Suggesting Arduino-based SPI flashing alternative
    #371 19947759
    absinth84
    Which SPI interface do you have? No way to use an RPi?
    An alternative can be modify this project to have an Arduino as SPI interface
    https://github.com/nfd/spi-flash-programmer
    The connections to the flasher are specified here
    https://github.com/OpenBekenIOT/hid_download_py/blob/master/SPIFlash.md
  • SPI flashing via Arduino or RT809h
    #372 19949972
    pepesuriano
    I have a RT809h programmer also, if you know the offsets I can burn directly the binary of openbk to the SPI, do you have the memory address map?
  • LittleFS can store data and host the webapp
    #373 19951537
    btsimonh
    Rate: 14
    look in bkcdriverflash.c for the partition table.
    app starts at 0x11000, boot loader before that.
    I tried SPI via ESP32 first, and was unsuccessful. RPi worked after some coaxing...
    Theoretically, you should only need SPI if the bootloader is broken - in your case the serial flashing is not working, correct?
    So if your serial connections are ok, you could try first putting the std bootloader in from 0x0 - 0x11000, and then retry serial flashing.
    I had to SPI because I overwrote the bootloader whilst developing the OTA flashing :).
    If you do get SPI working, be sure to read all 2Mbyte as a backup first!!!
    And don't overwrite the RF partition... I don't think we have calibration yet.
    yes, it's better to have unsecure devices that you are in control of than devices which get their firmware from China.
    Tuya claims 300M devices in the field. Each of these could be updated over the air at any moment under the control of a single organisation.
    If that organisation was Russian, we would be being told to turn all of our 'smart' lights off at this moment...
    If I was a govmnt sponsored hacker, I'd be hacking the tuya infrastructure. Far more opportunity than MicroTik routers....
    It should be noted that OpenBeken is just as secure as TAS - i.e. not.
    we have LittleFS (at least on BK7231). It occupies the OTA flash area (not used unless flashing!!).
    If you use the Webapp for OTA flashing, then there are options to backup the LittleFS, flash the device, then restore the LittleFS.
    Or, you can simply drag and drop your file back into the FS after flash... this will format the LittleFS area on first file write.
    Also, there is a 'bootfile' from which initialisation commands are run. (autoexec.bat?).
    You can also 'host' the webapp in the LittleFS, and edit files from the webApp...
    Using the FS for constant configuration seems a fairly natural thing to do.
  • Multi-arch i386 support fixes BK7231N build on Debian
    #374 19951572
    theosoft
    I try to compile the firmware for the BK7231N.
    I followed the instructions. I am using a Debian VirtualBox VM (32bit and 64bit) on win11.
    I found, that the crosscompiler package (gcc) is for i386 and the package_tool (i.e: encrypt) is for X86_64.
    path in SDK: "OpenBK7231N/platforms/bk7231n/toolchain/gcc-arm-none-eabi-4_9-2015q1/bin/"
    path in SDK: "OpenBK7231N/platforms/bk7231n/bk7231n_os/tools/generate/package_tool/linux/"
    The build process doesn't work, because of the different architectures.
    Am i right??
    regards
    Theosoft
    EDIT: Found a solution. I installed Multi-arch and added i386. So needed libc and libncurses could be installed also for :i386. Compiled succesfully :-)
  • Suggesting OTA flashing via Tuya CloudCutter
    #375 19953966
    ferbulous
    Help: 8
    Rate: 56
    @p.kaczmarek2
    Sorry, I havem't been receiving any notification from this thread
    Great work on this, I still do have the desoldered modules and will try flashing them soon
    Been trying out tasmota group feature which was a really neat feature to group multiple led bulbs without HA
    I wonder if similar feature could be implemented?
    Now that tuya cloudcutter tools is public, (thanks! @tjclement )
    https://github.com/khalednassar/tuya-cloudcutter
    Could we now utilize this to flash the bin file with ota method?
    Just noticed flashing custom firmware steps is in progress, will be waiting for this
  • Question about two MQTT switches dropping Home Assistant connection
    #376 19954281
    sebastian48
    As I mentioned I have two switches running the latest pre-compiled release. I have noticed that one of them stops responding through Home Assistant after the second one has been activated. Not immediately but after some time, usually hours. They both work individually which makes this even more strange. And they do work with the physical on/off toggle. It seems to be the last one connected that will survive and somehow force the other to lose connection. The one that will continue to run will be rock solid until I reset the other one, then roles will switch.
    This is the setup in Home Assistant:
    switch:
      - platform: mqtt
        state_topic: "obk70897666/0/get"
        command_topic: "obk70897666/0/set"
        qos: 1
        payload_on: 1
        payload_off: 0
        retain: true
      - platform: mqtt
        state_topic: "obk10D5618E/1/get"
        command_topic: "obk10D5618E/1/set"
        qos: 1
        payload_on: 1
        payload_off: 0
        retain: true
    Am I doing this wrong? The devices are assigned unique IP and have different MAC. Any ideas?
  • #377 19954344
    ExploWare
    @sebastian48 it seemsfarly identical to my issue. I have 3 relays and one smart plug. Only one relay and the smartlplug connected, will try with all 4 soon
  • #378 19954355
    sebastian48
    I will continue observe. To me it feels like a Home Assistant issue but not sure. As far as I can tell both web servers are still running even when one of them has stopped responding to MQTT.
  • Proposed Wi-Fi reconnect handler for Beken SDK
    #379 19954693
    Rate: 12914
    Sorry for my absence. I've been unable to contribute due to a minor health issue. I am recovering now and I will renew my development activity soon.
    The plan does not change, my next planned step is to look into that BL602 platform.
    Now I will try to answer the questions.
    If somebody is willing to test, then I could insert a reconnect condition pretty easily. It seems that Beken SDK is not reconnecting automatically. Just catch an event here:
    Code: C / C++
    and schedule a reconnect.
    Anyone willing to help with testing? The modified code in block above should force reconnect if something goes wrong.
    One could theoretically test it by connecting openbk to wifi and then evicting it from wifi from router (and see if callback is called).
    But please clarify - it only disconnects from WiFI but button and logs still works, right? It's not a total device freeze?
    sharathbk1912 wrote:
    found this
    https://github.com/openshwprojects/OpenBK7231.../apps/bk7231t_bl0937_1_plug_demo/src/bl0937.c
    is there support for bl0937 in OpenBK7231T_app for now ?
    This is Tuya code, not mine. The SDK had already BL0937 support. It's just not integrated into OpenBK. I am still waiting for BL0937 device from eBay to arrive. About a month passed so far...
  • Webserver crash suspected as disconnect cause
    #380 19955250
    sebastian48
    First of all I wish you a speedy recovery.
    Secondly, I'd gladly help out! That said I've just did a complete wipe of my computer and have not setup my developer environment yet so it might take a while until I find the time unless someone is willing to send me a precompiled binary. I also don't have the possibility to log at the moment, I'm still waiting for my head to get a good idea how to access the pads/pins without needing to desolder it completely.
    What is interesting to me is WHY it disconnects? As I said, the other device will run rock solid without any hickups at all. There is definitely a pattern, I'm just trying to figure it out. I am leaning towards Home Assistant still.
    I can confirm that the physical button still works BUT I just now see that the webserver is not responding on the one that is down. So it seems to have crashed.
  • Proposed Wi-Fi reconnect handler for BK7231T
    #381 19956249
    ExploWare
    I wish you health and strength.
    Code: C / C++
    Sure! I've installed the two which are not yet in function, upgraded one of them, the other untouched. Both are NOT IN home assistant, to exclude that factor
    I also updated one of my other ones which are in home assistant.
    I did pull the latest _App code from github. In there I needed to comment out all I2C lines in the new_pins.c, and added your code above to usr_main.c (replacing the existing block.
    I'll try building a ping-script script or so, maybe even better try to telnet into port 80... lets see what happens
  • #382 19958480
    sebastian48
    I just noticed that the one functioning device also seems to have "crashed" not responding to commands. Still responding with physical button though. Probably needs to be hooked to log over time to understand what is going on. Unfortunately I am unable to do this atm.
  • BK7231N OTA header error and scan support patch
    #383 19960185
    theosoft
    Edit: I modified my build setup. Now the images are build as dev_XXXX.
    I noticed, that the images are flashed over OTA correctly. But the error message in the log still remains... IGNORING now :-)
    I am trying do use OTA on BK7231N devices. No success...
    I am using the RBL files from release 1.0.4 or compiled by me.
    The log shows, that the download is started and ended ok, but the bootloader message is:
    "Get 'App' partition firmware header failed! This partition will be forced to upgrade."
    1. RBL encryption wrong?? Is the header part of the compressed, encrypted segment? passcodes ok?
    2. Bootloader expects the downloaded file at a different location? OTA partition should be at 0x12A000.
    Is anybody else playing around with the N version? :-)
    regards
    For wifi scanning in http_fns.c
    Code: C / C++
  • Remote flashing merged into tuya-cloudcutter
    #384 19961349
    kmhn
    Hi folks, @tjclement and I finally cleaned up and merged the remote flashing code into https://github.com/khalednassar/tuya-cloudcutter
    Instructions to follow but it should be pretty self explanatory. Add the custom firmware UG image in custom-firmware then run run_flash.sh
    Of course that's assuming you have a device profile for the exploit to work. You can check out the example device profiles and the writeup if you'd like to make one for a device you have, or create an issue and tag it with exploit-needed along with a firmware dump link on cloudcutter's repository. Can't promise that we'll get to it quickly but I'll try when I have the time.
  • #385 19961687
    Dobie01
    I have tested the openbk7231T Firmware on some WB2S modules i had lying around.
    Setting an I/O port via MQTT works, but changing the status of a port (by button) does not trigger a mqtt response.
    Am i missing something or is that simply not implemented yet?
    So i could switch a light on but i want to add a motion sensor that sends me a message when it detects movement.
  • Ping and port 80 tests show Wi-Fi fix did not help
    #386 19964464
    ExploWare
    Dank je wel! Ik zal snel mn lampjes testen en loggen! :)
    ExploWare wrote:
    If somebody is willing to test...
    Polling all four devices once a minute by ping and by connecting to port 80, they all once in a while failed,
    I have had it running for 90 hours; quick conclusion is the Home Assistant issue seems legit, of course it could still be the MQTT connection part.
    With my test setup, I have been pinging the IP and trying to connect to port 80 once a minute.
    ~$ for i in 19 22 23 24; do  grep \.$i ping-openbk.log|head -n1; grep \.$i ping-openbk.log|grep ping|wc; grep \.$i ping-openbk.log|grep port|wc; done
    192.168.2.19 = plug, version with Wifi Reconnect, HomeAssistant
       2482  #ping fails
       4620  #port fails
    192.168.2.22 = relay, version with WiFi Reconnect, no HomeAssistant/MQTT connection
       8339  #ping fails
       9315  #port fails
    192.168.2.23 = relay, version 17feb, no HomeAssistant/MQTT connection
        495  #ping fails
        463  #port fails
    192.168.2.24 = relay, version 28feb, HomeAssistant
       4632  #ping fails
       4652  #port fails
    My four devices, one of the four was very steady, it was an older version,not connected to the MQTT. The wifi fix did not solve the connectivity, if anything, it worsened it according to this one way of testing.
  • Intermittent flash erase failures on WB2S module
    #387 19965155
    mike2k
    I too have a nedis power measure thiny, the WIFIP120FT.
    I've tried al kinds of methods to flash the firmware but I'm getting intermittent errors. I power it from my lab supply and I can see it pulling around 0.02 amps @ 3.3V
    The uartdownloader constantly fails at writing the firmware. The beken writer constantly fails at erasing flash, somewhere between 0x00011000 and 0x00018000
    Did I destroy it ? And is it possible to get any of the shelve WB2S and just solder it in place ?
  • Remove R33 to stop RX1 interference during flashing
    #388 19965710
    boozeman
    Desolder carefully 0R resistor R33 and try then flash the device. The RX1 pin is used on the circuit and causes relay flickering and lights flashin while try to flash it. I can not flash this witout removing that resistor (It was easier to desolder) After Flashing and testing, you can solder it back and use OTA method for firmware updates.
  • Removing R33 to isolate RX1 for flashing
    #389 19966337
    mike2k
    Thanks for your answer. I even went so far as to desolder the module.
  • Brennenstuhl LED light flashed with OpenBK7231T pins mapped
    #390 19966342
    rupertst
    Hi
    another working device:
    Brennenstuhl LED light:
    It is based on WB3S chip, and it's connecting to "brennenstul connect" which is fork of Tuya.
    Successfully flashed device with OpenBK7231T_App_UA_1.0.0.
    Pins are:
    P8 - set to PWM (brightness) or set to rely (on/off)
    P9 - set to PWM (colour of light - warm/cold)
    P1(?) - may be button, but I'm not sure - haven't tested yet
    Web APP work ok.
    It connects to MQTT broker (Mosquitto), however I have some problems with configuring it on Domoticz (I'm not using Home Assistant). I know it can be done by shell script, by publishing in lamp's topic (which is "obk060D1E8D"), but I wold like to do it in more elegant way.
    Domoticz has some plugins for MQTT. The standard one force it to publish in topic with prefix (eg. domoticz/out) and publish in json style. I don't know if the OpenBK7231T_App_UA_1.0.0. would "understand" it.
    There are some other plugins that allows autodiscovery, but its not working properly.
    Maybe I should move to home assistant, but its a lot of work for me :-(
    Maybe adding an option in OpenBK7231T to change publishing topic would solve the problem?
Discussion about developing and testing open firmware for BK7231T-based Tuya devices, including a cross-platform mini HTTP server, web configurator for GPIO/pin mapping, MQTT integration, and Home Assistant control. The thread covers flashing procedures with Beken Writer and a Python UART downloader, backup of original firmware, UART wiring, CEN reset method, power-supply precautions, and troubleshooting of flashing failures, erase limits, baud-rate issues, and boot problems. As development progresses, PWM dimmer support is added, MQTT startup bugs are fixed, Wi‑Fi AP/client mode behavior is improved, network scanning is implemented, and support is extended toward BK7231N and related SDKs. Participants also identify device internals such as BL0937 power metering, AMS1117 regulators, TuyaMCU/UART peripherals, and various smart plugs, switches, bulbs, and dimmers that may be compatible with the firmware.
TL;DR: 100 % flash-success reported on BK7231 T/N modules [Elektroda, p.kaczmarek2, post #19906676]; “OpenBK7231T now boots on three chip families” [Elektroda, p.kaczmarek2, post #19883071] Use QIO image for BK7231N, UA for BK7231T; erase only 0×11000-0×1EF000. Why it matters: a single workflow now replaces vendor firmware on 60 + low-cost IoT boards.
• Supported MCUs: BK7231T, BK7231N, XR809 (Wi-Fi + BLE) [Elektroda, 19883071] • Recommended UART speed: 921 600 bps for write, 115 200 bps for read [Elektroda, 19857664] • Flash sizes: Typical 2 MB on-chip; config area starts @ 0×1EF000 [Elektroda, post #19893493] • OTA format: .rbl (gzip + AES, served by HTTP) [Elektroda, btsimonh, post #19880525] • Typical power: 5 V @ 500 mA to AMS1117 input for safe programming [Elektroda, ExploWare, post #19853546]
3. Writer stops at “Erasing 0×11000” – why?
The chip is protected. For BK7231N add --unprotect when using uartprogram, or choose BK7231N mode in BKWriter; baud 921 600 often succeeds after 115 200 fails [Elektroda, boozeman, post #19857804]
4. Relay clicks during flashing – safe fix?
A pull-up on RX1 ties the push-button to 3 V3, driving the relay. Remove jumper R33 on Nedis WIFIPO120FWT, flash, then solder it back [Elektroda, boozeman, post #19882233]
5. How can I back-up the Tuya stock firmware?
Run python bk7231tools.py read_flash -d COMx --no-verify-checksum -s 0 -c 512 dump.bin for T/N chips (2 MB, 512 × 4 KB) [GitHub bk7231tools].
6. My BK7231N loses settings after power-cycle.
Disable FAST_CONNECT (RL_SUPPORT_FAST_CONNECT) or use latest OpenBK build ≥ f6c3c8f6 that stores config outside NET_PARAM table [Elektroda, p.kaczmarek2, post #19893493]
7. Does OTA work and how do I host updates?
Yes. Serve *.rbl over HTTP (http-here --host 0.0.0.0 8000). In WebApp → OTA tab → enter http://<IP>:8000/firmware.rbl; device backs up filesystem, flashes, restores settings [Elektroda, btsimonh, post #19880525]
9. What are the default GPIO roles for common plugs?
• Nedis WIFIPO120FWT – P6 LED, P10 Button, P26 Relay [Elektroda, 19883937] • QiaChip Smart Switch (WB2S,T) – P24 Relay, P26 Button [Elektroda, 19906692]
10. How do I compile on Linux or Windows?
Clone SDK OpenBK7231T, then OpenBK7231T_App into /apps. Build: ./build_app.sh apps/OpenBK7231T_App OpenBK7231T_App git (Linux) or Cygwin on Windows; ensure build-essential and gcc-arm-none-eabi installed [Elektroda, boozeman, post #19885620]
11. Is there a no-solder exploit?
Yes. CloudCutter abuses 2019 Tuya SDK bug to OTA-flash BK7231 lights wirelessly; code published February 2022 [khalednassar/tuya-cloudcutter]. "It works on every test bulb so far" [Tom Clement, #19890768].
