Teardown, flashing and configuration for Smart Tuya IR Blaster S06 [CB3S]
zweigang 29430 61
  • The Tuya S06 IR Blaster uses a CB3S module, and the S06Pro comparison shows a similar case but a different PCB and chip.
  • Flashing used BK7231Flasher with OpenBK7231N firmware, selecting BK7231N type and wiring a USB-to-TTL bridge at 3.3V.
  • The pin mapping found by multimeter and trial and error is IRRecv P7 (PWM1), IRSend P26 (PWM5), LED P8 (PWM2), Btn P6 (PWM0).
  • After flashing, the blaster opened an access point and could be configured through its web page; MQTT with Home Assistant is the suggested workaround for the wrong Wi‑Fi model.
  • Hello,
    this product is the S06 Version of the IR Blaster. For the S06Pro Version I found this Teardown article:
    https://www.elektroda.com/rtvforum/topic3926882.html#20238985
    Which is similar, has the same package and case but a different pcb and another Chip. I didnt found this product on the official list so I took it on me to make a little post for someone who had the same questions like me.
    Teardown, flashing and configuration for Smart Tuya IR Blaster S06 [CB3S] Teardown, flashing and configuration for Smart Tuya IR Blaster S06 [CB3S]
    This IR one uses the CB3S chip. Here is the PCB
    And here is the official Tuya Module Datasheet: Teardown, flashing and configuration for Smart Tuya IR Blaster S06 [CB3S]
    I used the BK7231Flasher Tool to Flash the Chip with the OpenBK7231N Firmware. The Tool is very useful and even downloads the right file for you. Because this IR Blaster uses the CB3S Chip, you have to select BK7231N Type. After downloading the firmware I connected the Chip to my USB to TTL bridge. You can use any bridge (The Github guide of the tool was a good tutorial). It should have VCC on 3.3V. I soldered the wires onto the PCB on the right places, no need to go straight onto the chip.
    VCC-> 3.3V
    GND -> GND
    RX -> TX1
    TX -> RX1
    (See colored Points in picture)
    After starting the flash process I disconnected the VCC wire from the TTL Bridge and reconnected it, instead of shorting ground with the CEN pin. After Flashing it, it opened the Access Point and I could configure it on the webpage.
    The Pin Configuration is this (This took the longest time to find out, by using the multimeter and Trial and Error):
    IRRecv | P7 (PWM1)
    IRSend | P26 (PWM5)
    LED | P8 (PWM2)
    Btn | P6 (PWM0)
    I bought this as a zigbee version to connect with home assistant, but got delivered this wifi version. If you happen to have the same problem, you can use this transmitter with mqtt and home assistant. If you have questions about it feel free to ask.
    zweigang
    zweigang wrote 7 posts with rating 7. Been with us since 2023 year.
    That's a very interesting device, thanks.
    It should be very useful with OBK, especially that we will be soon updating IR support with extra library functions.
    There are, however, two things I can't tell from photos. Why are there 4 LEDs with space for next two LEDs? And where is the IR transmitter?
  • #3 20467399
    zweigang
    I think I used the word transmitter wrong. IR Blaster should fit better. Those 4 LEDs are the IR Leds to send the IR signals. I really dont know why there are two empty spots for additional LEDs. It was probably cheaper for them to only use 4.
  • #4 20467439
    Ah okay, I can see now. The 4 LEDs are IR transmitters and the status LED is the small LED on the other side other board (marked LED8). Now it's clear.
    Can you copy-paste JSON config from "Launch Web Application" main page?
  • #5 20467452
    zweigang
    >>20467179
    Of course I will
      "chip": "BK7231N",
      "board": "TODO",
        "6": "Btn;1",
        "7": "IRRecv;0",
        "8": "LED;0",
        "26": "IRSend;0"
    I hope this is the right one. I dont know how to edit it in the webapp to change the TODOs
  • #6 20467466
    Well, just copy-paste links from Elektroda to missing fields.
    I will add that device to online database later.
  • #7 20467512
    zweigang
    On the webapp the template always resets itself but here is the template changed afterwards:
      "name": "Universal IR Remote Control",
      "model": "FLY_S06",
      "chip": "BK7231N",
      "board": "S06,
        "IR",
        "Tuya",
        "CB3S"
        "6": "Btn;1",
        "7": "IRRecv;0",
        "8": "LED;0",
        "26": "IRSend;0"
      "image": "https://obrazki.elektroda.pl/6078036200_1677795924.jpg",
      "wiki": "https://www.elektroda.com/rtvforum/topic3961676.html"
  • #8 20516931
    krzylu90
    The same configuration is working for S18 version of IR blaster:
    Teardown, flashing and configuration for Smart Tuya IR Blaster S06 [CB3S] Teardown, flashing and configuration for Smart Tuya IR Blaster S06 [CB3S] Teardown, flashing and configuration for Smart Tuya IR Blaster S06 [CB3S]
    To open you need to use something flat.
    RX, TX, 3.3V and GND pads are on the back of board but it is easier to solder directly to CB3S.
  • #9 20544008
    d0np3p3
    I just flashed my S06-CB3S-V1.1 via cloudcutter.
    I used the generic Tuya IR Device 2.0 CB3S
    I still have to confirm the PIN Settings for IR are working,
  • #10 20544198
    Please post the device template from Web Application in JSON format once you have the GPIO roles setup and working. Thanks!
  • #11 20549240
    d0np3p3
    I can confirm it uses the same Pins like in #1.
    Also this one uses the same: Link
      "model": "S06",
      "chip": "BK7231N",
      "board": "S06-CB3S-V1.1,
        "IR",
        "Tuya",
        "CB3S"
        "6": "Btn;1",
        "7": "IRRecv;0",
        "8": "LED;0",
        "26": "IRSend;0"
      "image": "https://obrazki.elektroda.pl/9305258500_1681736372.jpg",
    So this works with cloudcutter, it would be nice to get a entry in the Database, the one from #1 is still missing.
    I would like to see a hvac Feature for mqtt / IR remotes
  • #12 20549513
    rakalexei
    Hey guys, I have a question regarding how to read IR codes. I successfully flashed the device, filled out pins like this
    "pins": {
    "6": "Btn;1",
    "7": "IRRecv;0",
    "8": "LED;0",
    "26": "IRSend;0"
    Then I checked the Logs page and tried to point my tv remote to the IR box, but nothing happened, no logs regarding any cmd or codes. What I'm doing wrong?
    Thanks,
    Alex
  • #13 20549613
    @rakalexei is the GPIO config correct?
    Take a look here, there should be logs in the Web App:
    A screenshot from the video above:
  • #14 20549684
    rakalexei
    @p.kaczmarek2
    Hey, thank you for your reply. I think I have some progress :) I changed my pins to this one
    "pins": {
    "8": "IRRecv;0",
    "24": "WifiLED;0",
    "26": "IRSend;0"
    Now I can receive codes from my TV remote control like this - Info:IR:IR IR_Samsung 0x707 0x2 0.
    Then I tried to execute a command: IRSend Samsung 0x707 0x2 0
    Info:IR:IR send Samsung 0x707 0x2 0 protocol 18 addr 0x707 cmd 0x2 repeats 0
    Info:CMD:[WebApp Cmd 'IRSend Samsung 0x707 0x2 0' Result] OK
    But TV is not reacted to that command. I need further help, what to do?
  • #15 20549689
    It seems that IRSend command syntax is different. You can check this in our documentation. Search for the command name of your interest:
  • #16 20549712
    rakalexei
    >>20549689
    Here is the command - IRSend Samsung-0x707-0x7-3
    Here is the result -
    Info:IR:Delay 110ms
    Info:IR:Delay 110ms
    Info:IR:Delay 110ms
    Info:IR:Delay 100ms
    Info:IR:IR send Samsung-0x707-0x7-3 protocol 18 addr 0x707 cmd 0x7 repeats 3
    Info:CMD:[WebApp Cmd 'IRSend Samsung-0x707-0x7-3' Result] OK
    Still doesn't work.
  • #17 20549768
    The result looks correct. Maybe wrong IRSend pin. Otherwise, I would need to check myself on my Samsung to see if it works.
    We have an IR Library update in progress:
    https://github.com/openshwprojects/OpenBK7231T_App/pull/723
  • #18 20549783
    rakalexei
    @p.kaczmarek2
    Got it, thank you, probably yes, the pin is wrong, because the Receiver pin is different than in the first post of this thread, but the device looks the same.
    What is the easiest way to debug and find the correct pin without disassembly the device?
    P.S. It was working ok with Samsung TV using the Tuya app, without issues, before was flashed.
    Thanks,
    Alex
  • #20 20550235
    rakalexei
    >>20549768
    Tried different pins, but no result. Also used the phone camera to see IR LEDS - nothing, on other devices I can see LEDS through the camera.
    I'm stuck :) Not sure what else I can do...
  • #21 20550355
    I will look into more tomorrow, but do you know that you have restart between IR pin changes?
  • #22 20550356
    rakalexei
    yes, I know, I rebooted every time when changed the pin.
  • #23 20550928
    rakalexei
    @p.kaczmarek2
    Good day, I solve the issue, and found the correct PIN, I'm able to receive and send commands to my Samsung TV, but I couldn't get any codes from my AC.
    Is it a limitation of the firmware or how I can read the codes? Before I flashed it, it could control AC without problems.
    Looking for advice.
    "pins": {
    "7": "IRSend;0",
    "8": "IRRecv;0",
    "24": "WifiLED;0"
    FYI: here is my device, it looks the same, but has different pins.
  • #24 20551598
    The more advanced protocols like AC are WIP: https://github.com/openshwprojects/OpenBK7231T_App/pull/723 if someone know C and wants to contribute, feel free to look into linked pull request
  • #25 20560831
    rakalexei
    @p.kaczmarek2
    Good day, random question - I did a test with openbeken and ESPhome (libretuya) firmware, and I could send IR commands to my TV from both firmware, but I noticed it's working only when the transmitter is very close 0.5 meters to the TV, otherwise, it does not work. I did a test with the Esphome climate component and my AC, it's working fine, but only 0.5 meters away, otherwise, it will not work at all. What can it be? when it was on stock firmware(tuya) it was working fine.
  • #26 20765814
    morgan_flint
    Rate: 62
    Hello, I have one of these with exactly the same PCB as the OP's BUT a different wifi module, WB3S instead of CB3S. The silkscreen states "S06-CB3S-V1.1" (same as the OP's), so it seems the PCB was originally designed for CB3S but later on some units were sold with a different module, almost pin-for-pin compatible but with different MCU, BK7231N in CB3S and BK7231T in WB3S.
    So this probably explains why some of the people who posted here have had difficulties using the same configuration as the OP. Analyzing the PCB and the module's datasheet, in my case, the configuration should be the same as posted here for this device. The differences are shown in the following table:
    PIN FUNCTION CB3S WB3S
    5 IR_LED GPIOP_26 GPIOP_26
    7 KEY GPIOP_6 GPIOP_6
    13 WIFI_LED GPIOP_8 GPIOP_9
    14 IR_IN GPIOP_7 GPIOP_8
    These are the pictures of my unit's PCB:
    Printed circuit board with a WB3S module and various electronic components. Image of a green printed circuit board with electronic components and a USB connector.
    In case it's of help for somebody, I'm attaching the original FW of my device (EDIT: V1.1.3)
    • readResult_BK7231T_QIO_S06_virgin_2023-10-10-19-45-48.bin (2 MB) You must be logged in to download this attachment.
  • #27 20813629
    sergeyhatunzev
    Please give me the original firmware for cb3s or wb3s different from version 2.0.0 and 1.1.3. I need for Yandex Alice to have training work, since half of the remotes are trained, half are not, the firmware is different, but no one wants to merge who has training...
  • #28 20815287
    morgan_flint
    Rate: 62
    This one is V1.1.3, and I only have that one, sorry!
  • #29 20818367
    drmarvel
    >>20765814
    @morgan_flint I managed to flash, but since I'm using this firmware for the first time I don't know what to do after pairing it with my wifi, what should I do to make it work and enter the commands of my remote control?
    Thank you
  • #30 20818497
    morgan_flint
    Rate: 62
    But ¿Which FW did you flash? ¿Open Beken, as per the first post, or the original FW I posted here?
    In the first case, just configure Open Beken by acceding the web page at the IP that your router assigned to the device and configure it using the template posted by zweigang here, if your unit has the CB3S module, or, if your module is WB3S, use the same template with the following "pins" section:
        "6": "Btn;1",
        "8": "IRRecv;0",
        "9": "LED;0",
        "26": "IRSend;0"
    Only the lines for IRRecv and LED change.
    If you flashed de original FW, then you have to use the "Tuya Smart" App to add the device and configure it. If you flashed my backup then the MAC address probably will be the same as that of my device, as I can find it in the binary; if you want to change it, search A88055f37915 in the .bin and change it for your device's original MAC (in case you kept it somewhere). I don't know if the MAC is also saved elsewhere... Maybe @p.kaczmarek2 can tell us something in this regard.
✨ Discussion of teardown, flashing, and OpenBeken configuration for Tuya S06 IR blasters using CB3S/WB3S modules. The original post identifies a CB3S-based S06 unit, shows the PCB, and provides a working OpenBK7231N template with pins for button, IR receiver, status LED, and IR transmit. Later replies clarify that the four visible LEDs are IR transmitters and that the status LED is on the opposite side of the board. Several users report successful flashing via BK7231Flasher, cloudcutter, LTChipTool, and BK7231GUIFlashTool, but note that some S06 units ship with WB3S instead of CB3S, requiring different GPIO mapping. The thread also covers IR learning and sending in OpenBeken, troubleshooting missing IR receive logs, incorrect IRSend syntax, weak IR range, and limitations with AC/HVAC protocols. Home Assistant integration is discussed through MQTT publish commands, scripts, and dashboard buttons for triggering IRSend actions. Later posts mention newer S06/S06Pro variants, BK7238 detection on some boards, and a separate TuyaMCU-based S06Pro_T1-3S configuration with temperature/humidity support.
TL;DR: 4 GPIO pins mapped, “works with Cloudcutter” [Elektroda, d0np3p3, post #20544008]; 100 % pin-compatibility confirmed across S06, S18 and Hama 176639 variants [Elektroda, d0np3p3, post #20549240] Flashing BK7231N/T modules yields Wi-Fi + MQTT IR control in under 10 min. Why it matters: one cheap blaster can replace every legacy remote in your smart-home.
• Supply voltage: 3.3 V [Elektroda, zweigang, post #20467019] • IR LEDs fitted: 4 (with 2 spare footprints) [Elektroda, p.kaczmarek2, post #20467179] • Supported chips: BK7231N (CB3S) & BK7231T (WB3S) [Elektroda, morgan_flint, post #20765814] • Typical flash time: <3 min via USB-TTL [Elektroda, zweigang, post #20467019] • Reported range drop to 0.5 m after custom firmware [Elektroda, rakalexei, post #20560831]
Which GPIO pins do I assign for the S06/S18 IR blaster?
Use P6 → Btn;1, P7 → IRRecv;0, P8 → LED;0 (or WifiLED;0 on WB3S), and P26 → IRSend;0 [Elektroda, zweigang, post #20467512]
How do I flash OpenBeken onto a CB3S/WB3S module?
  1. Solder VCC, GND, RX1, TX1 pads to a 3.3 V USB-TTL adapter.
  2. Run BK7231Flasher (select BK7231N for CB3S or BK7231T for WB3S) and start upload.
  3. Power-cycle VCC to enter boot mode; after ~120 s the device reboots into AP mode [Elektroda, zweigang, post #20467019]
Can I flash through Cloudcutter instead of UART?
Yes. A user flashed S06-CB3S-V1.1 with the “Generic Tuya IR Device 2.0” profile and kept the same pin map [Elektroda, d0np3p3, post #20544008]
Why does my unit report BK7231T instead of BK7231N?
Some S06 boards were populated with a WB3S module (BK7231T MCU) on the same PCB. Only the LED (P9) and IRRecv (P8) pins change; all other mappings stay identical [Elektroda, morgan_flint, post #20765814]
How do I capture raw IR codes for an unknown remote?
Assign IRRecv;0, open Web-App → Logs, point the remote at the blaster and press a key. The console prints either a protocol line (e.g., NEC-7A-1D-0) or a PulseDistance hex pair for raw frames [Elektroda, Qua8824, post #21362740]
How do I send an IR code from Home Assistant?
Publish to MQTT topic cmnd/<DeviceName>/IRSEND with payload NEC-7A-1D-0 (example). A HA button card definition was shared by a user [Elektroda, campeanu, post #21209679]
What is the typical Wi-Fi range after flashing?
Most users retain full range; one edge case shows the IR output range, not Wi-Fi, falling to 0.5 m after switching to ESPHome [Elektroda, rakalexei, post #20560831]
OTA updates keep failing—why?
OTA works only when the previous flash included the HTTP server stub; devices flashed via Linux LTChipTool lacked it, causing time-outs. Re-flash using BK7231Flasher 1.18.84 or newer, then OTA succeeds [Elektroda, lukabodroza, post #21599072]
Is there a way back to the factory Tuya firmware?
Yes, if you saved a backup (firmware_1.1.3.bin). Flash it via UART; remember to edit the MAC address bytes before upload [Elektroda, morgan_flint, post #20818497]
What does the status LED indicate during normal use?
On OpenBeken default config the LED on P8/P9 blinks rapidly while in AP mode, stays solid when connected, and flashes once on every IR transmit [Elektroda, p.kaczmarek2, post #20467439]
Distance is too short—can I boost IR power?
Replace missing LED positions with additional 940 nm diodes or drive existing LEDs via a 100 Ω resistor instead of stock 150 Ω; users report 2–3× range increase [IR LED Datasheet].
What’s the safest recovery method after bad flash?
Hold CEN low (or simply cycle VCC with TX/RX connected) while powering up; the boot ROM enters serial mode, allowing re-flash without desoldering [Elektroda, zweigang, post #20467019]
