  • DIY-A586 v1.9 is a revised FPGA board built around a Spartan6 XC6SLX9, with hardware changes accumulated over several years.
  • It removes joystick multiplexing, supports two floppy drives without extra circuits, and adds an 18.432MHz generator plus USB-C pull-downs.
  • The board uses 32MB 16bit SDRAM, 16MB flash, and stores up to 30 FPGA configurations in flash.
  • Mikan core runs with 8MB CHIP and 23.5MB FAST, and the 8MB DMA CHIP unexpectedly worked.
  • Diagram, Gerberas, and commercial-use restrictions are included in the appendix.
📢 Listen (AI voice):
  • #151 21014665
    xangel
    Level 19  
    Rate: 147
    Thanks a lot!
    However, I will start with the Amiga then :)
    And what if I want to play with the PC?
  • #152 21014686
    piotr_go
    DIY electronics designer
    Help: 94
    Rate: 3350
    Wgrywasz "Next186_SoC.d19" i "BIOS_Next186.ROM".
  • Mouse cursor works but buttons do not
    #153 21033092
    woks11
    Piotr, the project is brilliant, and I even made it. However, I can`t cope with the mouse. I`ve tried many roms and most of them respond to Boot Menu. Could it be the mouse`s fault or did I mess something up on the board? I will add that the mouse cursor works, but the buttons do not work. When the cursor is set, I can only confirm by pressing the "windows" button and the left alt button on the keyboard at the same time.
  • #154 21033110
    piotr_go
    Help: 94
    Rate: 3350
    Maybe a short circuit on the joystick inputs? Take a look at the FPGA pins going to 74xx245.
    Are you sure the mouse is working?
    Does it also enter the Boot Menu without a mouse connected?
  • #155 21037201
    woks11
    And one more thing, if I connect the ttl-usb to the z4, it will generate any logs that will help. There are no short circuits on legs 119-124. Joy pins hanging in the air can`t be the reason?. (I soldered the second board and it`s the same). This is what happens without a mouse.
    • DIY-A586 v1.9 by piotr_go 1712298800937.jpg (534.28 KB) You must be logged in to download this attachment.
  • #156 21037290
    piotr_go
    Help: 94
    Rate: 3350
    woks11 wrote:
    Will I get any logs by connecting TTL-USB to Z4?
    There is no login.
    Not PS/2, check the JOY pins.
    Meaning? 74lvc245 and 10k pull-ups must be fitted.
  • #157 21037656
    woks11
    Yes, that`s right, pull-up was the reason for the failures. Thanks lovely. Let me ask you shyly what you think about this.
    • DIY-A586 v1.9 by piotr_go po resecie.jpg (958.77 KB) You must be logged in to download this attachment.
    • DIY-A586 v1.9 by piotr_go risc.jpg (1.26 MB) You must be logged in to download this attachment.
  • #158 21037695
    piotr_go
    Help: 94
    Rate: 3350
    You must place the doom.wad file in the /doom directory
  • #159 21038112
    woks11
    I have a question why all roms above 2 work, and dozens of tested 1.3 do not want to work.
  • #160 21038203
    piotr_go
    Help: 94
    Rate: 3350
    Working 1.3 MD5 sum: 82a21c1890cae844b3df741f2762d48d
    Unless you load the rom from SD instead of flash, only 512kB roms work from SD
  • #161 21039356
    woks11
    Thanks Piotr, you are great. And tell me if the preparation for starting SD with workbench is described anywhere.
  • V-RISC core shows black screen on DOOM and MP3
    #164 21048875
    xangel
    Level 19  
    Rate: 147
    Well - I finally put everything together.
    Amiga works - I can start Kickstarters 1.3 and 3.1
    I don`t know where to get 3.1 + SD and 3.2.2.1 + SD?
    If I insert a diskette with the system and try to install the system on the card, will it format it? I`m asking because I don`t want to lose data from the card, so in this case I will simply insert a second card.
    The station is supposed to be Amiga based on what was previously mentioned in this thread?
    Turns on the NES - I launched Contra
    Launches Spectrum - I have a white Sinclair sign and I can write. How can I use this EXODOS?
    It boots PC Core 186 - says "No boot device" I assume I can insert the system disk and install the system to the SD card. I will test it in my free time.
    PC station? Jumper on D1 as in PC or on D0 as in Amiga? Interlaced or non-interlaced tape?
    However, the V-RISC core does not start. When I run DOOM, I have a black screen. No subtitles or anything.
    And when I play MP3, I only have a mouse cursor and a black screen.
    The memory I use is the W9825G6KH-7 model because I didn`t have any other.
  • W9825G6KH-7 memory may cause core issues
    #165 21048995
    piotr_go
    Help: 94
    Rate: 3350
    Regular kick 3.1, 3.2....
    SD is loaded from a separate file.
    You need to create partitions in HDtoolbox. Preferably on a separate tab.
    Amiga
    F11
    xangel wrote:
    PC core 186
    There is currently no station service. I don`t know when or if I will add it.
    Can the cursor be moved?
    There may be problems with it (core PC and risc-v). Unfortunately, I have no way to test it.
  • W9825G6KH-7 memory used as substitute
    #166 21049135
    xangel
    Level 19  
    Rate: 147
    Ok, I put it (earlier) on the 3.1 card and thanks to this it also starts 3.1 + SD. Somehow I didn`t check this before.
    So something is being done there on the fly? Added SD support on the fly?
    I had 3.2.2 on my disk, I named it KICK3221.ROM and it runs (to the floppy disk logo). Is this correct? Is 3221 a different version than 322? Sorry, I`m not an Amiga guy, hence the stupid questions. The Internet is silent about 3.2.2.1
    Ok, so I know to use another card so as not to lose files from the previous fight.
    piotr_go wrote:
    Amiga
    Thanks, I`ll test it soon and let you know.
    piotr_go wrote:
    F11
    I`ll check this F11 soon, because for now I`ve uploaded the Spectrum ROM from post 147:
    https://www.elektroda.pl/rtvforum/topic3891155-120.html#21005077
    And now it asks for the files 128-0.ROM and 128-1.ROM.
    What is this about?
    piotr_go wrote:
    xangel wrote:
    PC core 186
    So at the moment it only turns on the BIOS welcome screen and nothing else? Neither FDD drive nor SD card? Can SD work? I mean, is this a proof-of-concept or something more?
    You can move the cursor
    Unfortunately, I only had access to these. I will order the right ones (through a friend) so they will arrive when they arrive - it`s a matter of months rather than days, because it`s related to an order.
    Sorry for your inquisitiveness, but maybe this will create a small compendium for laymen (like me) in the subject of FPGA, how to run it quickly and efficiently, and everything will be in one place.
  • SD support works with FAT32 cards
    #167 21049163
    piotr_go
    Help: 94
    Rate: 3350
    2 roms are mounted.
    You can call any 512kB that. It should not be a problem.
    https://www.hyperion-entertainment.com/
    What is this about?
    Roms for spectrum.
    Get core from github. It`s newer.
    xangel wrote:
    Can SD work?
    Works.
    I think I posted an image of a dos card in thread 1.6. Look for.
    Hmmm, the code seems to work.
    Fat32 card?
  • FAT32 SD card support confirmed on 16 GB media
    #168 21049201
    xangel
    Level 19  
    Rate: 147
    piotr_go wrote:
    2 roms are mounted.
    What I mean is, what is the difference between KICK 1.3 and KICK 1.3 + SD? Because they both probably use one KICK13.ROM file
    The Amiga starts nicely, I ran Swords of Valdgir II and Giana from the floppy disk.
    I will soon insert another SD card and try to install the system.
    I see this article on Hyperion, I created an account, but unfortunately I cannot download the hotfix.
    Ok, there actually is "Updated last week" - my oversight.
    After pressing F11 on the screen with the word Sinclair, nothing happens.
    piotr_go wrote:
    xangel wrote:
    Can SD work?
    Works.
    THX for the info, I`ll check it out soon. It can even be combined - a bootable PC card and the files I am using now.
    Fat32 card?
    FAT32 card size 16GB.
    I don`t think we`ll compete here - probably timing. We`ll see how the memories come - I`ll definitely let you know.
  • ESXDOS required for F11 Sinclair menu
    #169 21049232
    piotr_go
    Help: 94
    Rate: 3350
    1 ROM vs 2 ROMs
    A second one is added to "+SD" (there used to be one, but patched).
    Roms/system are paid.
    Put esxdos on the card.
    http://www.esxdos.org/
  • Wolfenstein works; Doom limited by weak CPU
    #170 21049259
    xangel
    Level 19  
    Rate: 147
    Ah, ok, now I understand that I need KICK.ROM and SD.ROM :)
    The PC works, I launched Wolfenstein. Dooms don`t work because the processor is too weak.
    The mouse works with the mouse.com driver
    Dos Navigator works, Volkov Commander too.
    The sound from Wolfenstein is there (as I selected in the PC Speaker menu).
    Spectrum works, TAP and Z80 files are supported. I don`t know why, but after entering the ESXDOS Menu, a noise appears in the speakers and then does not disappear.
    I`m going to fight the Amiga soon.
    Overall this card image is amazing! Thanks to it, it will probably be possible to manage everything on one card.
  • Spectrum audio noise bug and FAT32 partition suggestion
    #171 21049279
    piotr_go
    Help: 94
    Rate: 3350
    There is a bug, but I don`t know spectrum so I probably won`t fix it.
    View core from the "test" directory.
    It`s quite old, I suspect it may require re-creating the Amiga partitions.
    You can also add a FAT32 partition there as a third partition (for NES and updates).
  • Amiga boots straight to Kickstart without core menu
    #172 21049306
    xangel
    Level 19  
    Rate: 147
    Okay, the Spectrum test ROM doesn`t make any noise.
    I was already happy with this card, but the NES actually shouts that there is a FAT32 card error
    Are you saying to create a third partition - at the beginning, at the end? Is he playing a role?
    I have a problem with Amiga - I run KICK3.1 + SD, a screen appears asking me for a Workbench 3.0 or 3.1 floppy disk.
    I insert the floppy disk, it tries to copy the files and activate Workbench and it fails - it gets the error: System has a write error from disk block 26764.
    I tried on two SD cards - 4GB and 8GB.
    And now something`s completely screwed up - when I turn on the power, I don`t have a screen with the CORE selection, but the Amiga starts up immediately - how can I fix it? And can I do it without desoldering Flash?
  • Hold reset at power-on to reach core selection
    #173 21049337
    piotr_go
    Help: 94
    Rate: 3350
    At the end. I didn`t add anything in the image so that everyone could add one that would fit on the card.
    Probably the fault of the old painting.
    Initialize the disk and create partitions again in HDtoolbox, but it`s best to experiment on a different card first.
    Maybe the Fire in the Joystick is blocked? Hold reset at power on.
  • #174 21049373
    xangel
    Level 19  
    Rate: 147
    Ok, I`ll create a FAT32 partition for the NES at the end and see what happens.
    I don`t worry about the card - I keep bringing it back from the image because I break something.
    Of course you were right about the Fire button :)
    I will still struggle with the Amiga - I need to remember how to install the system. There will be some combination to run Workbench and HDToolBox from one station.
  • FAT32 partition works; Amiga hangs on slow memory
    #175 21050835
    xangel
    Level 19  
    Rate: 147
    Sorry for the double post. I played around with this hardware a bit more, added a FAT32 partition at the end and the NES takes data from it without any problems.
    And now this: My Amiga hangs, even on the desktop.
    I wrote earlier that RISC does not matter.
    It occurred to me that maybe it`s possible to write a "core" with a memtest that would test all available memory? This would be a pretty cool and useful tool.
    Anyway, I suspect that my memory is too slow.
    I have another question: how to access this Amiga partition?
    I inserted this card into the A500 with an IDE controller and fast, but it does not see it.
    Maybe somehow under an emulator? I would like to reinstall the system on the Amiga partition without destroying the rest of the card.
  • Memtest recommended for desktop hangs and partition access
    #176 21050910
    piotr_go
    Help: 94
    Rate: 3350
    Run memtest in "Advanced Amiga Analyzer". Have him check it a few times. Probably a memory problem.
    It won`t work, the errors are core speed dependent.
    As for the DOS card image, create an image of the second partition and save it to another card (as a card image). Alternatively, use with FS-UAE.
  • #177 21059907
    leonecomdir
    Hello Peter, very good project, I read the topic as a FAQ, so that I don't ask again about problems if there are any. Tomorrow I have to finish assembling my A-586, I put it together for a long time, not much free time at work and even less at home) anyway thanks for such a cool comp, I was looking for an FPGA version of the Amiga and here is such a great Combine, all my favourite platforms on one device)
  • Asking which bus and clock the SD card uses
    #178 21062782
    woks11
    Peter, another question. With what clock is the sd card running , on sd2 , sd3 , or spi bus ?.I was thinking of using something like MKDN032GCL-AA.I have constant problems with write , read and checksum errors at completely random times. I practically tested a dozen cards with different capacitances , I removed all components at the card (capacitors and pullups), measured the next ones, mounted new ones and nothing :( I add that installation of workbench to ramu from goteka goes without any problems. The card prepared in UAE goes but during the installation of several programs it crashes. Few times I managed to install wb :) )
  • #179 21063152
    piotr_go
    Help: 94
    Rate: 3350
    SPI 25MHz
    There was a bug in the SD driver related to threads, but I corrected it in SD_v0.10.ROM.
    Which WB version is causing the problem?
    Which disk and partition size?
    Which file system?
    Which ROM?
    Which card?
    I remember that in the Amiga one used to set "MaxTransfer" and "Mask" because there were similar errors.
  • Tested WB versions, partition sizes, and FFS settings
    #180 21063344
    woks11
    I have SD_v0.10.ROM. WB I practically tested 2.04 , 2.05 , 3 . 3.1. partition created in uae and floppies also , mostly 3.5 Gb , but I also tried up to 1 Gb. FFS interiational files , I also tried with PFS. Max transfer I set to 0x1fe00. The rest of the information on the photos. Several microSD cards and Samsung adapters lying on an electronic device. Amiga system boot screen with 3.1 ROM logo and floppy disk graphic. Amiga system screen with information about Kickstart and Workbench versions, showing a 3.1 ROM dialog box. System error message indicating a checksum error on disk block. Screenshot of the Workbench system on an Amiga computer with the SYSTEM partition open. .
✨ Discussion of the DIY-A586 v1.9 FPGA-based Amiga-compatible board by piotr_go, built around a Spartan-6 XC6SLX9 with 32 MB SDRAM, 16 MB flash, HDMI, analog audio, SD, RS232, joystick, PS/2, floppy and A500 keyboard interfaces. The thread covers core architecture (own core with TG68 CPU), compatibility, FPGA resource usage, synthesis constraints, and comparisons with Minimig/MiSTer. A large part of the discussion focuses on assembly and bring-up: flash programming, ROM loading, SD card formatting, Kickstart patches, floppy-drive conversion, Gotek compatibility, SDRAM timing, oscillator choice, and soldering order. Later posts report fixes and updates for Amiga core, SD support, PS/2 reset, floppy reading, audio, and bitplane handling, plus questions about parts sourcing, connector footprints, and possible future ports or expansions such as AGA, C64, Spectrum, and alternative FPGA platforms.
