Mini 1080p wifi camera from Aliexpress, how to use without app (FtyCamPro)?
Wuppiduppi 75135 206
How can I use this AliExpress mini Wi‑Fi camera without the FtyCamPro app?
Open the case, identify the chip, and replace the vendor firmware with an open build; for TXW817-810 cameras the thread settled on OpenTXW81X, flashed with a C-SKY/CK-Link style programmer via an STM32F103 “blue pill,” after first making a backup of the original flash. [#20946151] [#20946175] [#20946214] After flashing, the camera creates its own AP (typically 192.168.4.1); connect to it in the browser, set your Wi‑Fi settings, and start the stream with `startdriver TXWCAM`. [#21645812] [#21645938] The live feed is then available as RTSP at `rtsp://{ip}:7070/webcam`, and at least one user confirmed the camera sensor worked with the open firmware. [#21695014] [#21645946] If your board turns out to be the BK7252UQN48 variant instead, there is a separate open firmware project for that chip. [#20946175] [#20946214]
  • Camera exposes Wi-Fi but no open ports
    #1 20946131
    Wuppiduppi
    Hi there,
    I found this tiny 1080p wifi camera on Aliexpress for less than 3€ (https://www.aliexpress.com/item/1005005938598467.html). It comes with an integrated rechargeable battery, the USB port does not seem to do anything else than charging (no data connection).
    Unfortunately, they want you to download and install a fishy app called "FtyCamPro". I would love to use this little cam freely, did anybody already look into it? Considering its price, this is a very interesting piece of hardware, but I do not have the knowledge and experience to remove the bloatware. When you start the cam, it provides a wifi network that you can connect to. It also assigns an IPv4 address, but a portscan did not show anything on the camera. Did anybody already play around with this device?
    Small black Wi-Fi camera on a stand, placed on a desk, with a keyboard in the background. Black, small Wi-Fi 1080p camera on a desk with a keyboard in the background. Small black Wi-Fi camera on a wooden desk.
  • #2 20946151
    Rate: 12938
    We've managed to free one cam from the cloud with @DeDaMrAz , but it required opening the case. Is it possible to open the case of this camera without breaking it, and if yes, what kind of chip is inside?
  • Beken BK7252UQN48 chip identified inside camera
    #3 20946175
    Wuppiduppi
    Yes, I managed to open it without destroying anything. The chip is labeled with "Beken BK7252UQN48 AU3437XB". Close-up of an open electronic circuit with visible Beken BK7252UQN48 AU3437XB chip. Close-up of a circuit board with a Beken BK7252UQN48 AU3437XB chip. Close-up of the interior of an electronic device featuring a circuit board with a chip and a camera.
    Rate: 12938
    Sure, there is one firmware for this chip, it seems:
    https://github.com/daniel-dona/beken7252-opencam
    But you need to identify the flashing pins and first do a firmware read (backup) and then write.
  • #5 20946266
    Wuppiduppi
    Perfect, thanks a lot for the link! I'll look into that.
  • TXW817 boot log at 921600 baud
    #6 20946310
    Help: 449
    Rate: 918
    annoyingly some, including mine, are Taixin TXW817s - https://community.home-assistant.io/t/popular...mini-wi-fi-camera-the-ha-challenge/230108/336
    just seen a reply to my post though https://community.home-assistant.io/t/popular...mini-wi-fi-camera-the-ha-challenge/230108/337
    Close-up of a circuit board with TXW817-810 integrated circuit. Image showing a PCB of an electronic device with connected wires.
    Added after 53 [minutes]:
    uart boot. 921600 baud
    [0]00 00 17 00 57 0a 12 a0
    [0]28 6e 00 00 00 00 00 00
    [0]00 00 00 00 00 00 00 00
    [0]08 19 75 05 38 66 89 a6
    [0]4a a5 88 77 8e 67 00 00
    [0]80 00 b7 ca a2 96 00 00
    [0]00 16 00 00 0b 0a 00 00
    [0]00 00 00 00 01 60 07 00
    [0]00 00 00 40 00 04 40 00
    [0]04 40 00 04 40 40 04 f1
    [0]00 4c a0 14 4a 51 3c 85
    [0]53 3c c5 03 cf 03 00 01
    [0]00 02 fe 03 0f ae 04 0a
    [0]02 00 fc 04 00 1f 00 1d
    [0]00 03 48 00 00 00 00 0a
    [0]00 00 00 00 00 10 e4 00
    [0]f0 3c 0f
    [0]validity: 1678e00d
    ** hgSDK-v2.5.1.7-26745, app-0, build time:Jan 18 2024 21:55:13 **
    **   libcore v2.5.1.7-26745, build time:Dec 18 2023 11:05:53
    **   libnetutils v2.5.1.7-26745, build time:Dec 18 2023 11:06:10
    **   libcommon v2.5.1.7-26745, build time:Dec 18 2023 11:05:58
    **   libosal v2.5.1.7-26745, build time:Dec 18 2023 11:05:52
    **   libatcmd v2.5.1.7-26745, build time:Dec 18 2023 11:05:59
    **   liblmac v2.5.1.7-26745, build time:Dec 18 2023 11:06:29
    **   libwifi v2.5.1.7-26745, build time:Dec 18 2023 11:06:42
    [0] ------- system restart fault -----------
    [0][soft_reset]
    [0] ------- lvd fault -----------
    [0] ---------------------------------------
    [1]freemem:181032
    [1]custom_mem_init:2000cdb0
    [2]custom mem sram:53248
    [2]skbpool init, total:27436 (0x2003d4d4~0x20044000), max per:80%
    [initStaticParam][ 292]use serverseq=1,svr=d32983:43237`57:g6bb8b322:53
    [4]syscfg_read OK!
    [4]0[540] flashCfg params(103).ssid=FTYC535866GRDBZ,T a O V    ۙ p\e\   s ) O  d#12345678,2,1
    [VerStr2Int][ 834]cVersion=62_1_2_15
    [IpcCfgItemGet][1099]VerStr2Int=62_1_2_15:1040253455
    get flash addr:fd000 size:4096,
    [8]col_flag:1
    [8]get_parse_cloud_id:204
    [8]selfId:FTYC535866GRDBZ:15
    [9]col_flag:1
    [9]col_flag:2
    [9]get_parse_cloud_id:204
    [9]parId:LXKJIG:6
    [IpcCfgInit][ 448]1:616-->get from  ezConfig FTYC535866GRDBZ:ZZZZZ:
    [IpcCfgInit][ 462]0-->get from  ezConfig FTYC535866GRDBZ:ZZZZZ:
    [parseEz2Sch][ 885]NULL==pVal || NULL==pSysSchext || strlen(0)<24
    [12]IpcCfgInit:505  add w0 interface!  2  FTYC535866GRDBZ:12345678
    [12]IpcCfgInit:507  add w0 interface!  2  FTYC535866GRDBZ:12345678
    [IpcGpioInit][ 641]SDD_PIN_INPUT=1
    [IpcGpioInit][ 650]PWR_PIN_INPUT=1
    [IpcGpioInit][ 670]PIN_IN_KEY=1
    [IpcGpioInit][ 687]PIN_IN_USB=0
    [16]main:1007  add w0 interface!  2  FTYC535866GRDBZ:12345678
    [18]lmac rx info size:36
    [18]GAP0 : 200390d4
    [18]GAP1 : 2003d4cc
    [18]lmac rx buff:200390dc, size:17392, hw rx buff size:11256, ampdu:7, max subfrm:3
    [19]lmac priv: 2001ba0c
    [20]lmac tx  : 2001be18
    [20]lmac rx  : 2001cfe4
    [20]lmac ble rx: 00000000
    [20]pack:10, bios_id:3
    [21]use AMPM DPD!
    [21]verf:0x6, ibpt:0xa, ibct:0xa, iref:0x9
    [22]verfvco_trim:0x4, verfcp_trim:0x2, verfdiv_trim:0x5
    [22]verfdsm_trim:0x4, verfvcc25_trim:0x1
    [23]da cap:5, da gain:2
    [25]txdcoc from:1, i:11, q:10
    [26]tx imb from:1, pm:118, gm:1
    [26]rx dcoc from:1
    [26]g:0, ana:64, i:-3, q:1
    [27]g:1, ana:64, i:-5, q:5
    [27]g:2, ana:64, i:-5, q:5
    [27]g:3, ana:64, i:-10, q:15
    [28]g:4, ana:64, i:-10, q:14
    [28]g:5, ana:64, i:-10, q:15
    [28]g:6, ana:64, i:-10, q:15
    [29]g:7, ana:68, i:-15, q:0
    [29]rx imb from:1
    [29]g:0, 8114, 4050
    [29]g:1, 8120, 4047
    [30]g:2, 8112, 4048
    [30]g:3, 8110, 4047
    [30]g:4, 8106, 4049
    [30]g:5, 8114, 4045
    [31]g:6, 8110, 4050
    [31]g:7, 8110, 4047
    [31]time offset:0, 29
    [32]lmac test: 2001d78c
    [33]set_bss_bw: 20M
    [33]lmac_bgn_lo_freq_set: 2432
    [34]set rts_threshold =2304
    [35]lmac set mac0 addr:08:19:75:05:38:98
    [35]ADKEY baud:239
    [35]*** open ADC success!
    [36]*** add success: ADC channel cnt = 1, name:257
    [36]*** add success: ADC channel cnt = 2, name:258
    [37]lmac_bgn_lo_freq_set: 2412
    [39]lmac_bgn_lo_freq_set: 2412
    [40]set rts_threshold =1600
    [40]set ac= 0 aifs= 2 cw_min= 15 cwmax= 1023 txop= 79
    [41]set ac= 1 aifs= 6 cw_min= 15 cwmax= 1023 txop= 79
    [42]set ac= 2 aifs= 1 cw_min= 7 cwmax= 15 txop= 128
    [42]set ac= 3 aifs= 1 cw_min= 3 cwmax= 7 txop= 65
    [43]set ac= 0 aifs= 2 cw_min= 15 cwmax= 1023 txop= 79
    [43]set ac= 1 aifs= 6 cw_min= 15 cwmax= 1023 txop= 79
    [44]set ac= 2 aifs= 1 cw_min= 7 cwmax= 15 txop= 128
    [45]set ac= 3 aifs= 1 cw_min= 3 cwmax= 7 txop= 65
    [45]lmac set mac0 addr:ce:f7:82:c9:70:74
    [46]lmac_bgn_lo_freq_set: 2447
    [47]lmac set mac0 addr:ce:f7:82:c9:70:74
    [48]lmac_bgn_lo_freq_set: 2447
    [49]ieee80211_ap_ioctl:164::set channel 8
    [50]set ac= 0 aifs= 1 cw_min= 1 cwmax= 3 txop= 0
    [50]set ac= 1 aifs= 1 cw_min= 1 cwmax= 3 txop= 0
    [51]set ac= 2 aifs= 1 cw_min= 1 cwmax= 3 txop= 0
    [51]set ac= 3 aifs= 1 cw_min= 1 cwmax= 3 txop= 0
    [52]main:1009  add w0 interface!  2  FTYC535866GRDBZ:12345678
    [53]sys_network_init:463  add w0 interface!  2  FTYC535866GRDBZ:12345678
    [54]sys_network_init:465  add w0 interface!  2  FTYC535866GRDBZ:12345678
    JPG start
    [55]csi_test start,iic init
    [55]iic init finish,sensor reset & set sensor clk into 6M
    hgdvp_set_baudrate:clock:480000000
    [59]set sensor finish ,Auto Check sensor id
    1--rsn--->6
    2--rsn--->6
    [359]to check id =4 num:0
    [359]sensorCheckId:1050 preset :0
    [360]SID: ff, 4, 78, 79,f0
    1--rsn--->6
    2--rsn--->6
    [660]to check id =9b num:1
    [660]sensorCheckId:1050 preset :0
    [661]SID: 1, 9b, 42, 43,0
    1--rsn--->6
    2--rsn--->6
    [961]to check id =a0 num:2
    [961]sensorCheckId:1050 preset :0
    [962]SID: 1, a0, 42, 43,0
    1--rsn--->6
    2--rsn--->6
    [1262]to check id =a3 num:3
    [1262]sensorCheckId:1050 preset :0
    [1263]SID: 96, a3, 42, 43,f0
    1--rsn--->6
    2--rsn--->6
    [1563]to check id =bb num:4
    [1563]sensorCheckId:1050 preset :0
    [1564]SID: ff, bb, 66, 67,f0
    1--rsn--->6
    2--rsn--->6
    [1864]to check id =10 num:5
    [1864]sensorCheckId:1050 preset :0
    [1865]SID: 0, 10, 42, 43,f1
    1--rsn--->6
    2--rsn--->6
    [2165]to check id =9d num:6
    [2165]sensorCheckId:1050 preset :0
    [2166]SID: 96, 9d, 42, 43,f0
    1--rsn--->6
    2--rsn--->6
    [2466]to check id =c0 num:7
    [2466]sensorCheckId:1050 preset :403105600
    [2467]preset table num:2
    [2467]SID: ff, c0, 62, 63,0
    1--rsn--->6
    2--rsn--->6
    [2768]to check id =21 num:8
    [2768]sensorCheckId:1050 preset :0
    [2769]SID: ff, 21, 78, 79,f0
    1--rsn--->6
    2--rsn--->6
    [3069]to check id =77 num:9
    [3069]sensorCheckId:1050 preset :0
    [3070]SID: 20, 77, 42, 43,a
    1--rsn--->6
    2--rsn--->6
    [3370]to check id =26 num:10
    [3370]sensorCheckId:1050 preset :0
    [3371]SID: ff, 26, c0, c1,a
    1--rsn--->6
    2--rsn--->6
    [3671]to check id =37 num:11
    [3671]sensorCheckId:1050 preset :0
    [3672]SID: ff, 37, dc, dd,fc
    1--rsn--->6
    2--rsn--->6
    [3972]to check id =3a num:12
    [3972]sensorCheckId:1050 preset :0
    [3973]SID: ff, 3a, dc, dd,fc
    1--rsn--->6
    2--rsn--->6
    [4273]to check id =36 num:13
    [4273]sensorCheckId:1050 preset :0
    [4274]SID: ff, 36, dc, dd,fc
    1--rsn--->6
    2--rsn--->6
    [4574]to check id =3 num:14
    [4574]sensorCheckId:1050 preset :0
    [4575]SID: ff, 3, dc, dd,fd
    1--rsn--->6
    2--rsn--->6
    [4875]to check id =20 num:15
    [4875]sensorCheckId:1050 preset :0
    [4876]SID: ff, 20, dc, dd,fd
    1--rsn--->6
    2--rsn--->6
    [5001]main_wkq run work 0x2000cd7c (func:0x1803a308) use 5000 ticks
    local:ce:f7:82:c9:70:74
        bios:3, pack:10
        pwr idx: 0
        chip-temperature: 30
        freq:2447, bg_rssi:-85
        cca: -70, -60, -62
        tx: txq:0, ps:0, tx_stat_q:0,
            tx dma:0, total tx:0, retry:0, tx lost:0, tx err:0
        rx: frms:209, data:0
        throughput: tx: 0 bps, rx: 0 bps
        max gain:7
    [5176]to check id =96 num:16
    [5176]sensorCheckId:1050 preset :0
    [5177]SID: ff, 96, 60, 61,4
    1--rsn--->6
    2--rsn--->6
    [5477]to check id =71 num:17
    [5477]sensorCheckId:1050 preset :0
    [5478]SID: a6, 71, 42, 43,2
    1--rsn--->6
    2--rsn--->6
    [5778]to check id =a6 num:18
    [5778]sensorCheckId:1050 preset :0
    [5779]SID: a6, a6, 42, 43,2
    [5779]checked ok id =a6 num:18
    [5779]Auto Check sensor id finish
    [5780]mclk:24000000MHz
    [5780]init:1806ec60 u8Addrbytnum:1,u8Databytnum:1
    [5781]SENSER....init
    [5850]init table num:542
    [5851]SENSR ident ok:640*480
    [5851]csi init start  --
    [5851]csi set size ====>640*480
    [5851]csi dvp_size_set
    [5852]csi IRQ init
    [5852]dvpirq_register:1 18028d58  18028d58
    [5853]dvpirq_register:0 18028d44  18028d44
    [5853]vppirq_register:0 18028b40  18028b40
    [5853]vppirq_register:1 18028b44  18028b44
    [5854]vppirq_register:2 18028b3c  18028b3c
    [5854]vppirq_register:3 18028d14  18028d14
    [5855]vppirq_register:4 18028d28  18028d28
    [5855]vppirq_register:5 18028b1c  18028b1c
    [5856]vppirq_register:6 18028b0c  18028b0c
    [5856]vppirq_register:7 18028afc  18028afc
    [5857]csi IRQ init finish,start get data
    [5857]enable sdio irq[5858]clk:400000 width:1 power:UP
    [5868]clk:400000 width:1 power:ON
    [5878]read timeout pending set or rsp err:1 0
    [5879]open_stream_available name:adc_audio
    [5883]auadc power on
    [5883]is CONFIG_UMAC4 2:2  FTYC535866GRDBZ:12345678
    [5884]is CONFIG_UMAC4 2:2  FTYC535866GRDBZ:12345678:8
    [5884]lmac_bgn_lo_freq_set: 2447
    [5886]ieee80211_ap_ioctl:164::set channel 8
    [5887]vif2 state WPA_DISCONNECTED -> WPA_COMPLETED
    @eloop_init:287::start
    user_[6057]dns sock :2
    port:7070	fd:3
    [6058]set_video_track:364
    [6058]set_video_track source->track[t]:0	rtp:20027ED4
    [6059]live audio_ex:20027E84
    [6059]set_video_track:364
    [6060]set_video_track source->track[t]:0	rtp:20028554
    [6060]add w0 interface!  2:2  FTYC535866GRDBZ:12345678
    [IpcSysInit][2203]gStartType=0,gDcOrBattery=0,gSysUpTime=6061
    [normalRun][2089]normalRun--->0,gFctChkOn=0
    [normalRun][2092]sysmode=0,t=6062
    mutex create 0
    [IlnkConnInit][ 137]init max connection--->[]->2
    [IpcSdInit][1592]chk mmc dev, and mount it to sd
    [IpcSdInit][1598]chk mmc dev, and mount it to sd
    [IpcSdInit][1606]get storage status
    [GetStorageInfo][ 186]totalBytes=0 M,freeBytes=0 M,usedBytes=0 M
    [IpcSdInit][1622]create dir for rec&pic 4
    [IpcSdDirCreate][1497]create dir for rec&pic 4
    [IpcSdDirCreate][1501]create dir for rec&pic 4
    [IpcSdDirCreate][1503]create dir for rec&pic 4
    [IpcSdDirCreate][1505]create dir for rec&pic 4
    [IpcSdDirCreate][1507]create SPECIALCAP_FOLDER 12
    failed-create RECORD_FOLDER 12
    [IpcSdInit][1627]IpcIlnkIdxInit=0
    [IpcIlnkIdxInit][1465]gIdxPicLock created[0]
    [IpcIlnkIdxInit][1467]gIdxRecLock created[0]
    [IpcIlnkIdxInit][1469]gIdxSplLock created[0]
    [IpcSdInit][1629]IpcIlnkIdxInit=0
    [IpcPicIdxChk][1485]TFcard not mounted[0]
    [IpcRecIdxChk][1530]TFcard not mounted[0]
    [IpcSplIdxChk][1508]TFcard not mounted[0]
    [IpcSdInit][1638]ok[0]--IpcSdInit[gSdInitFlag=1]
    [recInit][ 677]IpcSdInit=0
    [recInit][ 685]IpcRecMgrInit=0
    [IpcP2pStart][ 559]p2p starte,bP2pStarted=[0] 3;4d449b8b;5c722d77;9a3f3ea2
    [IpcP2pStart][ 596]p=558c9c:4b633e66:8`2g2d`32:5e,len=28,ret=1,d32983:43237`57:g6bb8b322:53
    ifPsram=0 		sNmb=1
     		cNmb=2
     		cBuf=12
    		svr0=1122121874
     		svr1=1379035718
     		svr2=4157381667
    [IpcP2pStart][ 640]Success[0]--IlnkModP2pStart
    [IpcP2pStart][ 646]IpcP2pStart=0
    [normalRun][2124]normalRun--->4,gFctChkOn=0
    [6082]p_sensor_cmd->id=0:a6
    [6082]spaFlip=0
    [6082]setPtzRun 0,-1,-1
    [6083]ble_ll: set adv data, len=28
    [6083]ble_ll: set scan_resp data, len=31
    [6084]ble_ll: set adv en:1
    [6084]ble_ll: set coexist en:1, decrease duty cycle:0
    t_socket=4 strerror: Success
    network interface: pt (Default)
    MTU: 8486
    MAC: 07 18 40 06 ce f7 82 c9 70 74 06 3f 77 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 00 00 00 01 00 00 00 34 f1 01 20 00 00 00 00 00 00 00 00 b8 00 60 00 00 00 00 00 94 b2 00 20 ac 54 00 20 2c 00 1c 00 80 00 00 00 00 00 ff ff ff ff ff ff ce f7 82 c9 70 74 08 06 45 00 00 2c 00 00 00 00 ff 11 bd be 7f 00 00 01 7f 00 00 01 c0 36 c0 36 00 18 bb bf 0c 01 74 00 01 00 00 00 00 00 00 00
    FLAGS: UP LINK_DOWN ETHARP
    ip address: 192.168.1.1
    gw address: 192.168.1.1
    net mask  : 255.255.255.0
    network interface: $[framememt_video_thread][ 443]bOK=0,gfps=0,gBps=1719,tm=6
    $[6379]enable sdio irq[6379]clk:400000 width:1 power:UP
    [6389]clk:400000 width:1 power:ON
    [6399]read timeout pending set or rsp err:1 0
    $$$$$$$[_mon100chk][1653]!gBatteryValue 1--->(2827):3200----->IpcShutdown
    [6691]erase flash, 1 sectors ...
    [6693]write flash, 540 bytes ...
    [6696]verify flash ... OK
    [6697]switch syscfg partition ... OK
    [6698]syscfg_write OK! (addr:ff000, crc=f84d, size:540, last_addr:fe000)
    [IpcRecSwitch][ 809]bOnOff=0 && pParam==NULL
    $$[_mon500chk][1707]1--Mode=1,wlan=0:1,IDR=0,sd=0,conn=0,keep=0:-1:0,[0:1]wlan=2,run=0,rec=0,t=6182
    $$[6900]enable sdio irq[6900]clk:400000 width:1 power:UP
    [6911]clk:400000 width:1 power:ON
    [6921]read timeout pending set or rsp err:1 0
  • #7 20947320
    Rate: 12938
    hgSDK? That's something new. Still, please consider creating a separate topic for that, maybe we can find SDK for that one as well
  • #8 20985373
    Help: 449
    Rate: 918
    Not that I know what to do with it, but there is this SDK for download
    Screenshot of a table listing development materials, including documents and software with versions and update dates.
  • #9 20990128
    Rate: 12938
    That's a good find! Is there a flash tool? Can you check whether it's possible to read and write the flash of this chip?
    That "programmer" tool looks like a flash tool.
  • No UART flash options in burner tool
    #10 20990159
    Help: 449
    Rate: 918
    yes. I had a look, but could see no obvious uart flash options. none of the drop-downs in the app reveal any com port settings, Burner PDF in english attached
    Screenshot of software with chip selection TXW81X and file download issue.
    • taixinprog_eng.pdf (4.79 MB) You must be logged in to download this attachment.
  • #11 20990165
    Rate: 12938
    Can you find a pinout of that microcontroller?
    Maybe it has some UART or USB port.
  • #12 20990208
    Help: 449
    Rate: 918
    yes.
    • TXW817_datasheet_chinese.pdf (2.85 MB) You must be logged in to download this attachment.
    • TXW817_datasheet_english.pdf (3.39 MB) You must be logged in to download this attachment.
  • #13 21035231
    mickeymouse
    A little more information about cameras with TXW817 chipset: https://github.com/DavidVentura/cam-reverse
    After configuring with YsxLite app it can be blocked on firewall from the Internet access and accessible on LAN with the app from GitHub.
  • #14 21235702
    Help: 449
    Rate: 918
    TX81x documents, SDK and programmer for the library
    • TXW81x_SoftwareDesignDoc_V2.0.2_20240417110526.zip (24.42 MB) You must be logged in to download this attachment.
    • TXW817_HardwareDesignDoc_V1.0.0_20231225162731.zip (238.96 KB) You must be logged in to download this attachment.
    • TXW81x_IOT-v2.5.2.6-27783_20240511174750.zip (10.19 MB) You must be logged in to download this attachment.
    • TXW817 数据手册 V1.5_20240511131349.pdf (2.99 MB) You must be logged in to download this attachment.
    • TXW81x_FPV-v2.5.3.7-29936_20240806101839.zip (17.05 MB) You must be logged in to download this attachment.
    • TXW81x_FPV-v2.5.2.7-29594_20240706183334.zip (16.92 MB) You must be logged in to download this attachment.
    • TXProgrammer_V2.1.37.sfx_20230323113051.exe (21.43 MB) You must be logged in to download this attachment.
    • TXW81x_FPV-v2.5.0.7-27315_20240511174606.zip (14 MB) You must be logged in to download this attachment.
    • TXW81x_EVB_Doc_V1.0.0_20240417110415.zip (2.25 MB) You must be logged in to download this attachment.
  • QSPI flash wiring attempt on TXW817-810 A9 failed
    #15 21239764
    Help: 449
    Rate: 918
    Regarding the TXW817-810 based A9, I have attempted to use these pads to connect using QSPI/SPI to the internal flash memory
    CS (Pin 1 on CH341A) → PA7 (OSPI_NSS0)
    CLK (Pin 5 on CH341A) → PA8 (QSPI_CLK)
    MOSI (Pin 3 on CH341A) → PA10 (QSPI_IO1)
    MISO (Pin 2 on CH341A) → PA9 (QSPI_IO2)
    Close-up of a printed circuit board with visible traces and electronic components.
    PA7 doesn't seem to be exposed to a test pad. I couldn't find where it traced to, so I very delicately soldered a twisted copper wire (taken from several strands of a de-soldering braid) to the PA7 pin on the IC.
    Image of TXW817-810 chip with a soldered copper wire.
    Sadly no joy with NeoProgrammer. Looking through the Taixin docs there's only mention use of their TX-Link programmer device to write to these chips.
    Help: 449
    Rate: 918
    Comparative table of different SDK versions with features and main applications.
    • TXW81x_FPV-v2.5.4.7-33915_20250414095601.zip (23.54 MB) You must be logged in to download this attachment.
    • TXW81x_IOT-v2.5.2.6-31320_20241106091716.zip (10.08 MB) You must be logged in to download this attachment.
    • TXW81x_FPV-v2.5.3.7-33908_20250414095532.zip (23.75 MB) You must be logged in to download this attachment.
    • TXW81x_FPV-v2.5.2.7-31320_20241106091643.zip (16.96 MB) You must be logged in to download this attachment.
    • TXW81x_SoftwareDesignDoc_V2.0.4_20250410113540.zip (24.44 MB) You must be logged in to download this attachment.
    • TXW81x_FPV-v2.5.0.7-31060_20241021174704.zip (14.01 MB) You must be logged in to download this attachment.
  • #17 21540514
    Rate: 12938
    My new guide:
    How to access cheap 1$ A9 camera video stream from LAN page (NodeJS)?
    Help: 449
    Rate: 918
    TXW81x AT demo from IOT SDK - built with CDK
    Screenshot of a folder containing binary and configuration files for the TXW81x AT demo project built with IOT SDK, with the file “txw81x_v2.5.2.6-31320_2025.5.11_IOT_AT.bin” highlighted.
    • txw81x_v2.5.2.6-31320_2025.5.11_IOT_AT.zip (1.81 MB) You must be logged in to download this attachment.
  • #19 21546604
    Rate: 12938
    That's good news, how did you compile it?
  • CDK builds TXW81x SDK projects directly
    #20 21546674
    Help: 449
    Rate: 918
    CDK - C-SKY Development Kit can be downloaded from the same xrvm.cn XuanTie download pages as the CK804/W80x toolchain bits mentioned in the W806 thread starting here https://www.elektroda.com/rtvforum/topic4054074-30.html#21534187
    https://www.xrvm.cn/community/download?id=4397799570420076544
    Website download panel for Jianchi CDK tools, listing available files and download links.
    About window of CSKY Development Kit showing version 2.24.5.
    Like the W806 zip file provided by YourCee, the Taixin TXW81x IoT SDK download contains a .cdkproj file for opening with CDK
    Windows Explorer window showing project files in the TXW81x_IOT software folder.
    Then it just builds through menu Project -> Build Active Project
    Screenshot of an IDE showing a project tree, folder structure, and build log output.
    Help: 449
    Rate: 918
    >>20990159
    TXProgrammer can be put into English by changing the language value in config.cfg under TXProgrammer\dll to "1"
    A fragment of a configuration file with setting parameters in a text editor.
    Screenshot of the TXProgrammer V2.2.7 application showing a bin file selection error message.
    A configuration software window displaying system and microcontroller parameters.
  • CK-Link access and 2 MB flash dump from TXW817-810 camera
    #22 21558806
    Help: 449
    Rate: 918
    I was hoping it's just a CK-Link rebrand device. Maybe it is and I haven't got the process right with CK-Link. I ordered one from Taobao so that should arrive in a couple of weeks.
    This arrived but was not needed for flash read/write in the end.
    CK-Link:
    and a 2mb dump, perhaps the world's first from one these TXW-based cams. This is from the X5 'barrel' type of TXW817-810.
    Black modern car camera in a sleek case on a white background.
    I've not explored it much yet but I attach the dump
    We can already see the cam sensors this has drivers for
    Screenshot of a hex editor showing binary data and decoded text with highlighted phrases.
    • X5_MiniCam_TXW817-810_CK803.bin (2 MB) You must be logged in to download this attachment.
  • LVD fault during TXW817-810 demo boot
    #23 21559929
    Help: 449
    Rate: 918
    >>21546674
    and now that demo running on a TXW817-810
    UART changed to PC6/7 which are exposed as test pads on cam PCB. Previously PA1/PA2
    Screenshot of the project_config.h configuration file with highlighted lines defining UART0 pins as PC_7 and PC_6.
    updated build filename and PC6/7 AT build addition https://github.com/divadiow/FlashDumps/commit/4ba2aba34dbed11194d75a76a4fbc012d9642fbe
    Added after 30 [minutes]:
    Does anyone else have Taixin cams? @p.kaczmarek2 @insmod
  • Clarifying CKLink debugger and UART test pads
    #24 21638405
    sebek2435
    Hey, I'm new here and kinda new to electronics as well but recently I got a couple of these cams and have been reading about them on these forums trying to figure out how to flash some new firmware on them.
    How do you interface with the chip? I noticed in the code you posted it says
    CKLink_Lite_V2
    is that the debugger or are you using something else like a J-link?
    Also you said:
    But I don't see a PA1 pin on the pinout of the chip, did you mean PA0?
    Any help would be greatly appreciated, Thanks!
    EDIT:
    P.S. I have already downloaded CSKY CDK and will be looking into development on it soon.
    UART log routed to PC6/7 pads in Taixin demo
    #25 21638429
    Help: 449
    Rate: 918
    hi. There'll be more context/info regarding the Taixin journey in these threads
    https://www.elektroda.com/rtvforum/topic4129331.html
    https://www.elektroda.com/rtvforum/topic4123724.html
    https://www.elektroda.com/rtvforum/topic4120455.html
    This was me modifying the Taixin demo in CDK so UART log could be captured on pads that were available to me on my cam - PC6/7
    There is no opensource alternative firmware for these Taixin MCUs that I am aware of.
  • FPV SDK configured for RTSP live feed
    #26 21639247
    sebek2435
    I did some digging in the demos you provided in >>21527312
    After looking at the IoT demo yesterday I couldn't find anything camera related (though I could be wrong). So instead I decided today to try looking into the FPV demos and they seem to be a better fit for the board. I went with the FPV-v2.5.0.7 SDK since I don't think most of these chips have Bluetooth (correct me if I'm wrong. I have seen some of these cameras using Bluetooth but I don't know what chip they used.) and these demos support RTSP.
    I think I have correctly or mostly correctly configured it for my board but I'm honestly not 100% sure and cannot yet test since I don't have the debugger for now.
    I will provide the bin file here in case you wanted to test it. The Wi-Fi settings I set were SSID: Wifi_Cam_Test Password: 12345678 and the camera should stream to [camera-ip]/liveFeed or [camera-ip]:7070/liveFeed
    Here is a picture of my board in case you wanted to compare the pinouts:
    HQT6_V2.0 PCB with labeled pins, microSD slot, chip components, and PCB antenna
    If you decide to test it then have fun, I will report on my own findings/testing once I have my debugger.
    • txw81x_fpv_v2.5.0.7-31060_2025.8.19_.bin (396.02 KB) You must be logged in to download this attachment.
  • GC0329 support added to the camera build
    #28 21639665
    sebek2435
    The default was set to gc0308 and ov2640 and I think the code auto detects and selects the camera. I could change that to whatever camera you want and recompile.
    This is the cam I have though I'm not sure what it is exactly. The closest thing in your list seems to be the SP0828.
    Camera module with lens and H23548 marking on flexible ribbon cable
    Added after 24 [minutes]:
    Here's a build with the GC0329 added. My list of supported cameras seems to be shorter than the one you provided probably since it's an older SDK?
    • txw81x_fpv_v2.5.0.7-31060_2025.8.20_.bin (396.02 KB) You must be logged in to download this attachment.
  • TX pin mapping for boot diagnostics and SDK compatibility
    #29 21643763
    Help: 449
    Rate: 918
    thanks. I'm not sure it's booting for me. To which IO is TX set so I can see what it's doing? PC7 would be preferred for the device I'm testing on.
    Or please supply project and I'll adjust/build.
    the list in post 1 here? https://www.elektroda.com/rtvforum/topic4121965.html
    that's from an XF16 firmware dump. I've been using an XF16 A9 cam to identify various 18-pin sensors from all these types of cam. They seem interchangeable
  • Enabled DCDC and removed __NO_BOARD_INIT for booting
    #30 21644074
    sebek2435
    I have already set the TX and RX to PC7, PC6 and baud rate is set to 921600. I just enabled DCDC, might be needed for these boards. I also removed __NO_BOARD_INIT from the compiler in case it was stopping the board from booting.
    Also the LEDs might not work since I don't think they were defined in the SDK. There is some code and I tried writing some basing it on the code around it but it didn't work so I removed it.
    Here's the new build and the project.
    • TXW81x_FPV-v2.5.0.7-31060.zip (39.58 MB) You must be logged in to download this attachment.
    • txw81x_fpv_v2.5.0.7-31060_2025.8.25_.bin (398.52 KB) You must be logged in to download this attachment.
Discussion about a very cheap AliExpress 1080p Wi‑Fi mini camera and how to use it without the vendor app FtyCamPro. The camera can be opened without damage, revealing different chip variants across units, mainly Beken BK7252UQN48 and Taixin TXW817/TXW817-810. The thread evolves into reverse engineering the hardware, identifying UART boot output, locating flashing pads, and testing SDKs and programmer tools for read/write access to flash. For BK7252-based units, an open firmware project is referenced; for TXW81x units, Taixin SDKs, TXProgrammer, CK-Link, and CDK are used to build and flash custom firmware. Later posts show progress toward an RTSP camera firmware and an OpenBK/OpenTXW81X port, including LAN streaming, audio enablement, GPIO/LED handling, NTP, and OTA experiments, though several limitations remain such as unstable flashing, missing deinit support, TCP_PCB exhaustion, and incomplete OTA/web streaming.
