[BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
p.kaczmarek2 178365 1242
  • #121 19876474
    @MustangMatt ermmm the list of commits is here:
    https://github.com/openshwprojects/OpenBK7231T_App/commits/main
    Is this link working for you? I am trying to be descriptive in the commits I make, but I must admit, I haven't been using github much before this project. Only private GIT repos and of course SVN repos as well (sourceforge site, anyone? Old good times!)
    @boozeman I will keep that in mind. I have much more in plans for futher commits, stay tuned
  • #122 19876485
    boozeman
    MustangMatt wrote:
    One more MQTT crash fix pushed to repo now. I am testing in both open access point and client modes.
    Would you mind posting a link to the commit? I'm trying to follow along but I'm not seeing it.
    Thanks!
    I Think it was this: Again; delay MQTT initialization
  • #123 19876564
    MustangMatt
    Perfect. I was looking at the other repo. Thanks!
  • #124 19876607
    I will make organization of repos and readmes more clear soon.
    Also, please note that we have a separate SDK repo for BK7231N version (the App compiles fine with both repos, I will have to rename it....)
    https://github.com/openshwprojects/OpenBK7231N
  • #125 19876784
    boozeman
    Seems like Tuya is like Keepers in Babylon 5. They do not give up easily :D
    My Homeassistant discovers openBK device as Tuya while I was guessing the pin setup. Seems like I cannot connect now to my mqtt broker. Hmm...
    EDIT; My previous build (Build on Feb 9 2022 15:42:00) before todays GiT chages works now OK and I can Save MQTT settings too. I think that my issue is blank mqtt settings when flashing new module at first time and there's nothing on flash memory. Does this sound reasonable?
  • #126 19877080
    First of all, do you know that recent change in unique device name generation (using latter bytes of MAC instead of first four) has invalidated all Home Assistant MQTT configs (because MQTT device names has changed) and thus all configs have to be regenerated? Options->Generate HA Config
    (don't worry, your pins setting are left intact, only device ID changed)
    That is utmost peculiar. I don't know right now how HA searches for devices - anyone?
    Maybe it just recognized the module by MAC address (MAC address have vendor-specific section).
  • #127 19877417
    MustangMatt
    I just bought a 4 pack of these and got the new version.
    https://templates.blakadder.com/feit_electric-BPA800RGBWAG2P.html
    I guess it's time to give the new firmware a go. Any tips for breaking open the bulbs without destroying them? I got the top off but I don't see any easy way to remove the board yet.
    [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant [BK7231T] My HTTP server, configurator, MQTT support from Home Assistant
    Okay, got it with some destruction. That white 8 pin block holds the two boards together.
    I can just barely get to the 5 pins it looks like but I can't get to RST. U1 is serial, U2 is log
    https://developer.tuya.com/en/docs/iot/wb2l-datasheet?id=K9duegc9bualu
  • #128 19877525
    pepesuriano
    Hi! I started playing around with my WB2S, I soldered 3v3 (Red), GND (Orange), RX (Yellow) and TX (Green) and then connected Orange to GND on PL2303, Red to 3v3 on PL2303, Yellow to TX on PL2303 and Green to RX on PL2303.
    Launched screen for serial console but nothing happens, typing does not work and I tried with 115200 and 921600 baud rates, it seems to be a wiring issue...
    I also tried to connect CEN to GND of PL2303 without luck also. All tests were done plugging TX, RX and GND first and then 3v3 to turn on the module, whan can I be doing wrong?
    Also swiped TX and RX as usual confusion with UART, no luck either
    I see the SSID of the module after it boots so it's not fried yet :P
  • #129 19877615
    boozeman
    Try to desolder WB2S module VCC to main board. Use solder sucker or copper strip. Use multimeter continyity mode to check there's no connection. BEWARE! do not overheat the pads. I destroy one of my plugs when soldering pad detached from the pcb.
    After that normal wiring vcc, gnd, rx1 and tx1 and cen. You can use CEN pin opposite of the PWM5 (You do not need to use that pad if that is hard to solder. Look at module pinout above. Your device is easy because test pads are towards.
    RX2 and TX2 gives you some debug with 115200 bps.
    Remember to connect module RX1 to your usb2serial converter TX and TX1 to RX. and VCC only 3.3V I have tested 3 different smart plugs and only RX1/TX1 can be used for programming. In your picture you do just like that. Good. Start beken writer programming (not flash) and connect CND and CEN for a moment (I have push button for that)
    I also figured out that insulating the WB2S-module off the rest of the circuitry helps flashing (no relays klicking or light flickering and then 15 sec init and Failed. No need to desolder whole thing or removing any other components.
    I have sacrificed 3 devices for the science so far and one of them are now permanently dead. So keep in mind the few casualties in this process. Hope this somewhat unclear instructions help you a bit.
  • #130 19878131
    pepesuriano
    Apologies, but I got confused, you mean to desolder only VCC from WB2S from the mainboard (keeping all the rest soldered like GND, TX, RX, etc)? Or do you mean to remove the whole WB2S module from the mainboard and flash it?
    Yeah once I heard the relay clicking over and over, I thought I lost it, but for the moment there are 0 casutalties :P
    What about CEN, is GND of the PL2303 good to connect it or I need to connect it in another place? I saw that you typed CND, was it a typo and it was supposed to say GND right?
    Thanks so much for your help
    Cheers
  • #131 19878254
    boozeman
    Yep, try to desolder only VCC pin so your usb2serial converter do not power rest of the plug's circuit. This is the only way I have successfully do for first flash. After then you can solder it back. No relay or light flickering for the next flashes with OpenBK firmware.
    You can connect CEN to PL2303 GND or do some jump wire to sort CEN pad and thar circuilar big copper area from the right side of WB2s module. I have GND wire with CEN wire and push button. I recon it is safer than sorting CEN and GND directly at the board. you know "Uups! s***t the manufacturing smoke is gone now!" :)
    My GND wire. with push button operated CEN/I00 wire.
  • #132 19878267
    btsimonh
    Even with this, the power from 3.3v of USB to Serial is probably not *normally* good enough to power the MCU, so if you have failure to start flashing.... (it's designed more as a 3.3v signal than a supply?)
    Based on ESP, you might expect it to need >500mA from the 3.3v
    On my mains powered device, I used the 3.3v from a breadboard supply (with the mains disconnected!!!), and it was fine.
    For my 12v LED strip controller, I powered it via the 12v (not scared of killing myself with a 12v wall-wart....)
  • #133 19878423
    MustangMatt
    tjclement wrote:
    Hi all, for those interested in running custom firmware on devices that can't be opened without breaking them: a buddy and I have made a wireless jailbreak for BK7231-based devices from Tuya that has so far worked on all devices (lights) we tried it on. It makes use of a bug that is currently in Tuya's SDK and has been since 2019.
    We'll be able to publish it after coordinated disclosure with Tuya. More info (I'm not allowed to post links yet on here): twitter dot com /Tom_Clement/status/1490796204862627853
    PS: to those who were interested in looking at the bootloader but couldn't get it dumped (it's protected against dumping via the bootloader's own UART protocol, but still possible), you can also find a copy in the SDK -> github dot com /tuya/tuya-iotos-embeded-sdk-wifi-ble-bk7231t/blob/master/platforms/bk7231t/bk7231t_os/tools/generate/bootloader.bin
    Hey Tom, What sort of timeframe are you thinking? I'd love to be able to flash bulbs without destroying them!
  • #134 19878578
    boozeman
    I can't save mqtt settings with bin file compiled against up-to-date git repository.
    When I hit that confirm, I get only below in log
    [19:00:09.029] Debug:HTTP:TCP Client ip.address.here.censored:36560 connected, fd: 2
  • #135 19878629
    EDIT: now I see what you meant, fixed now.
    It wasn't "not saving", it was "not connecting", I'd say
  • #136 19878861
    boozeman
    And it works now! I will publish tomorrow some data for about Nedis WiFIP130FWT 10A SmartPlug without power metering.
    - How to open
    - What must be do before flashing, etc.
    Just flashed it with last build and configure settings. This is nicely done smart plug. No flux remains on board, no oxidized solderings.
    Settings
  • #137 19878918
    tjclement
    We're finishing up the coordinated disclosure report any day now, and will then send it over to the Tuya security team. Once they've patched it or a reasonable amount of time has passed (whichever comes first), we'll publish our write-up on the bug and our tooling for reflashing affected devices. The exact timeline will become clear when we've submitted the report.
  • #138 19878956
    MustangMatt
    Great. One more question, does it require physical access to the device to exploit I assume?
  • #139 19878967
    tjclement
    It requires being in the vicinity of the light, but the exploit is completely wireless so you don't need to take anything apart or solder anything. That's why it's nice: you can use it to flash devices that don't have the UART port accessible, such as most light bulbs.
  • #140 19878974
    ExploWare
    Tom, is this exploit method closed by your uploaded code or are we all going to flash our friends bulbs as a joke, each time we're at their place/hackerspaces??
  • #141 19878981
    tjclement
    If you flash firmware that either does not use the Tuya SDK or uses the latest version after they've patched it, the exploit is gone.
  • #142 19879126
    So, in practice, how useable do you think your OTA exploit will be? How many our users will be able to benefit from it before it gets patched forever by Tuya?
    Can Tuya remotely patch the exploit in all of the devices that are currectly running at clients houses?
  • #143 19879157
    MustangMatt
    You might be doing them a massive favor in helping them keep their pledge for local only devices!
    In the tuya app you have to opt-in to updating each individual device automatically so it would surprise me if they automatically patched all devices.
  • #144 19879385
    boozeman
    One suggestion for generating Homeassistant cfg.
    Change the beginning of the cfg from switch:
    to switch <device name_1>:
    No more Duplicate key errors
    Or mention that if you have plenty off bk devices, do one named switch like switch beken:
    and put all your devices to that same group like:
    switch Beken:
      - platform: mqtt
      - platform: mqtt
  • #145 19880249
    MustangMatt
    I see references to BKWriter 1.60 but where do I actually download that from?
  • #147 19880275
    @boozeman I will add a mention about it
    @MustangMatt BKWriter 1.60 but is attached here https://www.elektroda.com/rtvforum/topic3850712-30.html#19840309
    I have started working on adding XR809 support, based on my previous work here:
    https://www.elektroda.com/rtvforum/topic3806769.html#19447386
    There is more porting to be done but maybe sometime soon we'll support XR809 devices as well.
  • #148 19880525
    btsimonh
    Note: using the latest updates, you can go to
    http://<ip>/app
    this loads a webapp from
    https://github.com/OpenBekenIOT/webapp
    (check gh-pages branch)
    The webapp now allows you to OTA direct from the browser.
    Also, the device CAN store a filesystem... this occupies the OTA flash area, so if you use it, it is destroyed each time you OTA.
    So... The OTA page of the webapp allows you to backup the FS, and then restore after OTA.
    Still a prototype, but have a go, and PRs welcome in terms of controllers for various devices.
    br,
    btsimonh
  • #149 19880572
    Initial XR809 platform support progress:
    Setup:
    Of course, this is a hello world app, but the OpenBK7231T app also will be running on XR809, so most of the OpenBK7231T will be also available on XRadioTech devices.
    Repo:
    https://github.com/openshwprojects/OpenXR809
  • #150 19880630
    boozeman
    http://<ip>/app
    br,
    btsimonh
    Wow nice one! No need to second uart anymore!
    I tested OTA and got my device reset (seems like that backup process got some hickupp) and the devicename changed to obk8C000000. Is this normal or something new "feature"? ;-)
    It is nice if we have ability to set mqtt topic like Tasmota, ie. You can taylor the mqtt message with device client name and even topic. I am about to close this Nedis WIFIP130FWT with dupoint-header for serial if needed. Ota feature is super nice to have at this point of development.
    Cheers
The discussion centers on the development and testing of an open-source firmware project for the BK7231T microcontroller, focusing on creating a cross-platform mini HTTP server, web-based pin configuration, MQTT integration, and Home Assistant compatibility. The project includes a Visual Studio project for Windows and firmware flashing tools like Beken Writer and a Python-based uartprogram. Users report challenges with flashing devices, including issues with firmware size limits (956KB), UART converter compatibility, and power supply stability during flashing. Solutions include using specific UART adapters (e.g., FT232R, CP2102), resetting devices via the CEN pin instead of power cycling, and trimming firmware binaries. The firmware supports devices with BK7231T and BK7231N chips, with ongoing work to add PWM dimmer support, BLE, TuyaMCU protocol integration, and OTA updates. Various smart devices such as WB2S/WB3S modules, smart plugs, LED bulbs, and switches from brands like MOES, Nedis, Hama, and Calex are tested. Users share detailed hardware teardowns, pinouts, and flashing procedures. MQTT topic naming issues related to MAC address usage were identified and fixed. The project emphasizes community collaboration, with suggestions for a Discord server to enhance real-time communication. Additional tools and SDK improvements, including CMake support and BLE integration, are under development to facilitate firmware building and device support expansion.
