How to flash TR6260 with open source Tasmota/Esphome style firmware? Guide, pinout, booting
p.kaczmarek2 5964 63
  • TR6260 WiFi chips in Tuya-style smart devices can be flashed with OpenTR6260/OpenBeken firmware for fully local, cloud-free control and Home Assistant Discovery.
  • Flashing uses a USB-to-UART adapter and the UTP tool, not esptool; GPIO14/TOUT2 must be grounded at power-on to enter SPI-flash boot mode.
  • The backup procedure reads the full 1MB flash image, producing a 1,048,576-byte dump with boot_nocrc.bin and the correct partition layout.
  • Firmware is written by loading boot_nocrc.bin at 0x0000, new_partition_0x6000.bin at 0x6000, and OpenTR6260_xxxx.bin at 0x7000.
  • After flashing, the chip broadcasts an open AP; connecting to 192.168.4.1 exposes configuration, and demos show DHT11 plus BME280/BMP280 sensor support.
  • Close-up of the TR6260S1 microchip on a green PCB.
    Here's a detailed flashing guide for new TR6260 WiFi chips that can be found in some Tuya smart devices. TR6260 can be easily flashed and run free from the cloud, fully locally, without Tuya servers. This way you can easily pair TR6260 with Home Assistant via Home Assistant Discovery, add custom sensors (like DHT sensors family series or BMP280/BME280 etc), and run local scripts and automations.
    TR6260 is 32-bit, 2.4GHz WiFi-enabled SoC optimized for smart home/IoT applications, featuring 6x PWM, single ADC, flexible IO interfaces and 1MB of Flash.
    TR6260 chip pinout diagram with pin labels.
    Where the TR6260 can be found?
    TR6260 have been so far observed in multiple devices, here are few of them:
    [TR6260S1 Transa Semi] Smart LED strip controller 144W 6A RGB, IR, firmware
    [TR6260S1/FL-M61 V2] WiFi Smart Switch how to change the firmware?
    ELM327 OBDII Scanner: Transa Semi ESWIN TR6260S1 MCU Details?
    [Flashing Tuya A5F-53F1-02 with TR6260S1 Chip
    You can also buy a development board with TR6260 called "Hi-Link HLK-M20", that can be ordered directly from China.
    Thanks to @insmod efforts in the development topic, those devices can be now flashed with OpenBeken
    HLK-M20 development board
    This board can be easily found if you search for HLK-M20 Serial Port 2.4G WiFi Wireless Module IOT Serial to WiFi Transparent Transmission Low Power SDK M20 Development Board Kit. It's somewhat similiar to NodeMCU and other ESP boards. You can either buy just a module:
    Screenshot of an AliExpress listing for the HLK-M20 WiFi module.
    TR6260S1 WiFi module on a PCB.
    or a full dev board, with module already soldered:
    Development board with TR6260 WiFi module on a white background. Image of two WiFi modules with the TR6260S1 microcontroller. Set of boards with a WiFi module and pin labels. Specifications of the HLK-M20 module with TR6260 chip.
    Schematic:
    Schematic of HLK-M50/HLK-ESP8266 development board with WiFi module.
    In case of this board, everything needed to flash is already present, but if you're going to flash IoT device with TR6260, you will need to have your own USB to UART converter...
    What do I need to flash TR6260?
    To flash TR6260 found in IoT device, you need a classic USB to UART converter, similiar to ones used for ESP8266/ESP32/BK7231 flashing.
    USB to UART converter with plug and pin connectors.
    You will need to make some GPIO connections, so basic soldering skills are required.
    If you want to get a basic grasp of how firmware change process looks like, you can visit our Youtube channel:
    We don't have TR6260 flashing video yet, but we have covered similiar chips in the past, like BK7231, so this might give you a basic overview of the procedure.
    Where to get UART flash tool?
    This is not ESP device, so esptool will not work. You will need to download utility called UTP. It can be found here:
    https://github.com/openshwprojects/FlashTools/tree/main/TransaSemi-ESWIN
    Alternate download/TS info pack:
    https://github.com/divadiow/TR6260/tree/main/UTP%20Flash%20Tool
    Here's English translation of UTP gui:
    UTP software interface for flashing TR6260 chips
    Translation of the partition table layout:
    https://obrazki.elektroda.pl/5232196400_1732140400.png
    And please note that restore of factory backup appears to require the file be split. eg: https://www.elektroda.com/rtvforum/topic4091587.html#21336099
    Now, let's focus on read and write procedures for flash...
    How to prepare connections and make TR6260 flash dump?
    In the case of the TR6260S1-based Hi-Link HLK-M20 module, which can be used as a template for any TR6260S1 device, a backup of the factory firmware can be achieved as follows:
    GPIO14/TOUT2 needs to be grounded at power-on. Like LN882H this needs to be before power to USB-TTL. Just resetting the device (RST->GND) with GPIO14 grounded will bring it up in spi-flash boot mode, that being standard boot, NOT UART boot mode:
    Screenshot showing a console set to a baud rate of 57600 with messages entry BootRom and spi-flash boot mode.
    If you're watching TX then the correct procedure will give this output:
    Fragment of a terminal window displaying boot mode messages with a selected baud rate of 57600.
    then configure the UTP program as follows, using the boot_nocrc.bin from the same zip file. The flash is 1mb so length is 0x100000
    PC Local Filepath is just where you want to save the file
    Screenshot of the UTP application showing flash upload settings.
    It takes 2-3 mins and it may look like it has stalled.
    On the HLK-M20 module GPIO14/TOUT2 pad is the location of EN on ESP-12F, so if using an ESP universal adaptor it's just a case of grounding EN header.
    Diagram of an electronic module with highlighted pins HLK-M20 development board with EN and GND connection points marked.
    If successful, the resultant backup file will be exactly 1,048,576 bytes.
    How to flash new firmware to TR6260?
    Before proceeding, make sure that you have a backup of factory flash. Once you are sure that everything is backed up, it's time to proceed with flashing.
    Ground GPIO14/TOUT2 as shown in the backup procedure and power-on the device
    Set appropriate COM port for your setup and a baud rate. Perhaps start at 921600 baud but reduce if there are issues with stability or connecting at all.
    Download the latest OpenTR6260_xxxx.bin firmware from the releases page.
    Using the partition binaries alongside the UTP program in the zip, configure your file list on the downloader tab to resemble this:
    That being:
    File_1 : boot_nocrc.bin | Address: 0x0000
    File_2 : new_partition_0x6000.bin | Address: 0x6000
    File_3: OpenTR6260_xxxx.bin | Address: 0x7000
    Click Start.
    On completion, power-off and remove GPIO14/TOUT2 from ground. Power on the device and you should see it broadcast an AP like this
    Wireless network interface OpenTR6260 visible on the screen.
    Connect to the AP (no password required). When connected browse to 192.168.4.1 where you can configure OpenBK as normal.
    OpenTR6260 user interface with configuration information and buttons
    For the steps taken on a real TR6260S1 device, where contacts are not so easily accessed as they are on a module, see this post regarding two flavours of ELM327 OBDII car code reader.
    Flashing with universal breakout board
    HLK-M20 boards have pinout similiar to ESP12F/TYWE3S/CB3S/WB3S/etc, so they can fit to universal ESP breakout. Here is pin mapping for such board:
    HLK-M20 development board with TR6260 chip
    The following board has been already covered in another topic, see here:
    Programming ESP12/TYWE3S/CB3S/WB3S/etc. without soldering - solderless motherboard
    OpenTR6260 demo - DHT11 sensor
    OpenBeken port for TR6260 supports DHT11, which can be configured just like we've shown on our "Weather station" video for W600:
    Sample connection:
    Development board with a WiFi module and sensor connected to a breadboard with an LED. Development board with WiFi module and DHT11 sensor on a breadboard
    Video presentation - there is also a LED on Rel pin, so clicking button toggles it as expected. The read humidity and temperature is also visible on the main page as expected.
    OpenTR6260 demo - DME280 sensor
    BME280/BMP280 is also supported. For that, you need to create autoexec.bat with script:
    //startDriver BMPI2C [CLK] [DATA] [ChannelForTemp] [ChannelForPressure] [ChannelForHumidity] [Addr]
    startdriver bmpi2c 0 1 2 3 4
    If driver is missing, make sure that it is included in build - check obk_config.h.
    OpenTR6260 configuration interface with temperature, pressure, and humidity details.
    Video presentation:
    Some extra information
    -TR6260S1 has some variations: https://www.elektroda.com/rtvforum/topic3965929-30.html#21315543
    -we've put all the known resources I have for TR6260 here inc all datasheets: https://github.com/divadiow/TR6260
    Summary
    TR6260 can now be flashed via UART with OBK port. OBK build for TR6260 can be customized with our online builds, you can also create a custom driver for that in such way. Thanks to that, your TR6260 devices can now work cloud-free and be paired with Home Assistant!
    Special thanks for @divadiow for researching/flashing and @insmod for porting.
    Hopefully soon we'll get ported to next platforms as well.
    • 2AD56HLK-M20-FCCID-UserManual-4846822.pdf (880.96 KB) You must be logged in to download this attachment.
    • ESWIN_TR6260S1-10_2.2_CN.pdf (8.28 MB) You must be logged in to download this attachment.
    • EN_Translated_雅观tr6260-SDK使用说明.pdf (228.47 KB) You must be logged in to download this attachment.
    • TR6260-S1-V1 wifi datasheet.pdf (419.11 KB) You must be logged in to download this attachment.
    • ESWIN_TR6260_2.2_EN.pdf (656.25 KB) You must be logged in to download this attachment.
    • HLK-M20-board-stuff-mix.7z (78.73 MB) You must be logged in to download this attachment.
    • UTP Flash Tool.zip (10.91 MB) You must be logged in to download this attachment.
    p.kaczmarek2 wrote 14678 posts with rating 12705, helped 656 times. Been with us since 2014 year.
    Erasing flash showed no data at FB000
    #2 21353666
    File_4: IGNORE IT, no longer needed.
    I didn't consider dropping this file to determine the effect. To see what was at FB000 after flashing without the skylab_user_nv_0xFB000_PSM_by_Oliver.bin file selected, I first erased the whole flash. This was done as follows with TOUT2/GPIO14 grounded:
    Screenshot of UTP software with Flash Erase option selected.
    then flash again fresh
    Screenshot of Flashing Software with several binary files selected.
    boot OBK, join to wifi. then read the whole flash to file
    Screenshot of a software flashing program with flash settings and log.
    then compare from FB000 of the OBK backup to the start of skylab_user_nv_0xFB000_PSM_by_Oliver.bin in HxD
    Nothing
    Comparison of two binary file contents in a hex editor.
  • ECR6600 module sources and SDK notes
    #3 21358543
    Help: 164
    Rate: 445
    Another ESWIN module, the ECR6600. Tuya modules, based on this chip are AXY series, like AXY3L, AXY2S etc.
    Skylab WG236, which they claim is ECR6600 based, can be bought here: https://www.aliexpress.com/item/1005004281075586.html 5pcs, 14.5$ + ~8$ shipping.
    SDK: https://github.com/NonPIayerCharacter/ecr6600
    Readme in the sdk mentions tr6260, but it seems its support was cut out at some point.
    A little too pricey to me for a module that i won't use, but i may eventually buy it.
  • #4 21358612
    What's there? A module image flashes for a second and then I get "not available in my country". I can't view this offer.
    Btw, some devices can be bought cheaper if you're creating a new aliexpress account. For example, BK7238:
    Image of a NiceMCU WB3S ch340c development module with BK7238 chip on AliExpress.
  • #6 21358789
    rip-off.
    Some other options maybe:
    Screenshot of the Superbuy website featuring BL-LINK WiFi modules. Screenshot from Superbuy site showing wireless module BL-M6600XS1 priced at $1.18 from Guangdong warehouse.
    no welcome deal on those Skylabs on Ali for me
    IoT electronic module with WiFi6 and Bluetooth interface displayed on an AliExpress page at a promotional price of £21.39.
  • Request for info on XY-WE2S-A V1.1 module
    #7 21361629
    I've found this module. Some reader must have sent it to me.
    Image of a green electronic module labeled XY-WE2S-A V1.1. Close-up of a green electronic module XY-WE2S-A V1.1 with visible tracks and soldering points. Close-up of an electronic module labeled XY-WE2S-A V1.1 with visible components and traces. Close-up of an electronic board labeled XY-WE2S-A V1.1.
    XY-WE2S-A V1.1
    Hmm https://www.elektroda.com/rtvforum/find.php?q=XY-WE2S-A+V1.1
    Anyone has any info? If not, I will have to try tracing the tracks...
  • #10 21367072
    SSDP on TR6260 observation
    Command tool interface with SSDP error messages.
  • #11 21367078
    We need to enable multicast in LWIP like we did on Beken
    https://github.com/openshwprojects/OpenBK7231...mmit/b0f232db5f17b3ac558580767a677f2a2ee6d488
  • Wemo emulation works and Alexa discovers device
    #13 21367101
    just saw you make that. was looking for the TR6260 SDK in openshwprojects initially :)
    Added after 21 [minutes]:
    File icon with the name OpenTR6260_480003A0.
    OpenTR6260 user interface with system status information
    Properties windows for two binary files displayed in the HxD hex editor.
    Added after 9 [minutes]:
    maybe already tested, but here's WEMO success anyway. Alexa discovers successfully.
    Screenshot from an app showing a file named OpenTR6260_480003A0 labeled as Recently added.
    Added after 11 [minutes]:
    Display of OpenTR6260 system with DS1820 sensor temperature.
    DS18B20 unchanged. I'm just refreshing my memory on what is working and what isn't right now
    Added after 3 [hours] 25 [minutes]:
    Screenshot of the user interface for the OpenTR6260 device with temperature and humidity information. Properties windows of two BIN files in HxD Hex Editor.
    Added after 1 [hours] 32 [minutes]:
    what's the deal with the SHT3X driver not being definable as ENABLE_DRIVER_SHT3X in obk_config.h?
    Added after 53 [seconds]:
    https://github.com/openshwprojects/OpenBK7231...mits/8a6a9907bf37ec8c4ffad5cad8656bdb10a761c3
  • #14 21386593
    DeDaMrAz
    Help: 34
    Rate: 130
    @insmod >>21358543
    Some useful info on ECR6600
    E103-W11_U...N_v1.3.pdf (1.1 MB)You must be logged in to download this attachment. E103-W11 A...ual_EN.pdf (644.61 kB)You must be logged in to download this attachment.
    Real pinout mapping for XY-WE2S-A module
    #15 21405320
    morgan_flint
    Rate: 62
    Flashing module XY-WE2S-A
    Although almost all of the info is already included in some posts in this other thread (read from this post), I think it's good to order it a bit and put it here in the flashing thread.
    First of all, some photos of the module (mine has a 90º adapter that has the advantage of including labels of the pinout in the silkscreen):
    XY-WE2S-A module with pin labels on the side Bottom side of module XY-WE2S-A, showing pads and pin labels. XY-WE2S-A module with visible pins. View of the bottom side of the module with pin labeling and production date. XY-WE2S-A V1.1 module with visible components and integrated circuit. XY-WE2S-A module with TR6260S1 chip Side view of the XY-WE2S-A module showing pins: VCC, GND, 1RX, 1TX, PWM4, PWM5.
    Three more pictures, borrowed from this post, that I edited to help me to trace the tracks to find the pinout:
    Image of the bottom side of the XY-WE2S-A module with visible pinout. Close-up of electronic module XY-WE2S-A V1.1 with visible components and traces. XY-WE2S-A V1.1 module with visible electronic components
    (the photo of the bottom side is mirrored to help match vias from the top layer)
    The pinout and the correspondence between chip pins and module pads:
    Sketch of the pin layout for the XY-WE2S-A V1.1 module
    Unfortunately, the chip's pinout doesn't coincide with any of the datasheets or images posted in this forum! @divadiow also encountered this problem with HLK-M20 module, as he explained here. This table shows the differences between the datasheets and the "real" pinout of the chip in our modules:
    LABELIC PIN TR6260S1 datasheetTR6260 datasheetdivadiowReal Pin
    TX09 UART0_RXD SD_DATA0TXUART0_TXD
    RX08 TOUT3 UART0_TXDRXUART0_RXD
    BT1 7 TOUT2UART0_RXD-TOUT3
    BT0 6WAKE_UPTOUT3IO14TOUT2
     -10UART0_TXDSD_DATA1-?
    PWM221VDD1P2_1VDD1P2_1-GPIO22
    PWM119TRSTTRST-GPIO4
    PWM020GPIO13GPIO13-GPIO13
    A0not connected----
    CEN4TEST MODERESETB-RESETB
    PWM515TCKTCK-TCK-GPIO0
    PWM416TMSTMS-TMS-GPIO1
    ITX18TDITDI-TDI-GPIO3
    IRX17TDOTDO-TDO-GPIO2
    Maybe somebody here can find a TR6260S1 datasheet that is consistent with the "real" pinout... I've tried, unsuccesfully.
    So, to read or flash the module, we need to use the pads at the bottom side of the PCB, and connect those labeled TXD and RXD to USB to serial adapter's RXD and TXD, respectively. BT0 should be connected to GND, to set the chip in UART boot mode (as specified in the first post). Of course, VCC and GND should be connected to 3.3V and GND in the USB to serial adapter (which should be prepared for 3.3V levels at TXD and RXD). In my case, I prefer to connect VCC the last after plugging the USB to serial adapter to the PC.
    The rest of the backup/flashing procedure is as described in the first post. Many thanks to @p.kaczmarek2!!
    BTW, to have a correct log of the serial output when booting with BT0 grounded (to check it was booting in the correct mode), I had to set the baud rate to 58000, instead of the standard 57600, which showed strange characters:
    BT0 to GND - 57600 baud:
    L▒Y▒▒▒ Bo▒I▒▒)LsV▒▒▒сmode▒▒▒▒▒
    Le▒▒▒Boot▒▒)▒h▒▒▒ bo▒▒m▒V
    BT0 to GND - 58000 baud:
    Lentry BootRom
    Luart boot mode
    For the sake of curiosity, I tested all the possibilities for BT1-BT0. Here's the output, logged at 59000 baud:
    BT1 & BT0 isol:
    Lentry BootRom
    Lspi-flash boot mode
    BT1 GND & BT0 isol:
    Lentry BootRom
    Lsdio boot mode
    BT1 isol & BT0 GND:
    Lentry BootRom
    Luart boot mode
    BT1 & BT0 GND:
    Lentry BootRom
    Lunsupport boot mode
    Lbootrom startup err
    EDIT: Deleted the first table, redundant with the second one were I added more info and adding OBK logs and the final configuration
    This is the output at the serial port after flashing OBK:
    ▒f▒▒`▒▒▒▒▒▒`▒f▒▒▒▒``▒f▒▒x▒▒▒▒▒▒▒`▒▒▒`fx▒▒[00:00:00.018]EasyFlash V4.0.0 is initialize success.
    this is not eco chip, chip type: 2
    No 1. Task Name(LMAC Task) Handle(2106292) Added to Stack Trace
    0x240200 0x240400 0x240600 0x240800 0x240a00 0x240c00 0x240e00 0x241000 0x241200 0x241400 0x241600 0x241800 0x241a00 0x241c00 0x241e00 0x242000 0x242200 0x242400 0x242600 0x242800 0x242a00 0x242c00 0x242e00 0x243000 0x243200 0x243400 0x243600 0x243800 0x243a00 0x243c00 0x243e00 0x244000 mainldo_nv_flag=0 buck_nv_flag=0 chip_id=2  is_cp=0
    LMAC initialize success
    vif_id:0, scanning:false
    No 2. Task Name(wpa_supplicant) Handle(2129216) Added to Stack Trace
    [standalone_main, 152] task creation succeed!(0x207d40)
    wifi nv:ssid[XxxxxxXXxxx],pwd[xxxxxxxxxxx],bssid[70:2e:22:db:0c:56],channel[8],pmk[fa4e9e]
    wdt_not_start
    No 3. Task Name(IDLE) Handle(2123412) Added to Stack Trace
    No 4. Task Name(Tmr Svc) Handle(2128576) Added to Stack Trace
    wlif_init
    wlif_init
    wpa state:DISCON->INACT.
    wpa state:INACT->DISCON.
    vif[0],event[27]
    vif[0],event[27]
    vif[1],event[27]
    vif[1],event[27]
    SYSTEM_EVENT_WIFI_READY
    OK
    OK
    Entering initLog()...
    Commands registered!
    initLog() done!
    WiFI_SetMacAddress
    Main_Init_Before_Delay done
    Main_Init_Delay
    Warn:CFG:CFG_InitAndLoad: Correct config has been loaded with 16 changes count.
    Error:CMD:lfs is absent
    Info:GEN:PIN_SetupPin
    Main_Init_Delay done
    s pins have been set up.
    Info:MAIN:Main_Init_Delay
    Info:MAIN:Using SSID [MorganNet]
    Info:MAIN:Using Pass [tomasfernando]
    Info:HTTP:TCP server listening
    Info:MQTT:MQTT_RegisterCallback called for bT tr626019102221/ subT tr626019102221/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT tr6260/ subT tr6260/+/set
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/tr626019102221/ subT cmnd/tr626019102221/+
    Info:MQTT:MQTT_RegisterCallback called for bT cmnd/tr6260/ subT cmnd/tr6260/+
    Info:MQTT:MQTT_RegisterCallback called for bT tr626019102221/ subT tr626019102221/+/get
    Info:CMD:CMD_StartScript: started @startup at the beginning
    Error:CMD:LFS_ReadFile: lfs is absent
    Info:CMD:CMD_StartScript: failed to get file autoexec.bat
    Info:MAIN:Time 1, idle 0/s, free 79936, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 2, idle 0/s, free 79936, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 3, idle 0/s, free 79936, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 4, idle 0/s, free 79936, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    HAL_WiFi_SetupStatusCallbackHAL_ConnectToWiFiFAIL
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    wpa state:DISCON->SCAN.
    vif_id:0, scanning:true
    Info:MAIN:Time 5, idle 0/s, free 79936, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Registered for wifi chvif[0],event[27]
    anges
    Info:MAIN:Connecting to SSID [MorganNet]
    wpa state:SCAN->AUTH.
    vif[0],event[1]
    vif[0],event[27]
    wpa state:AUTH->ASSOC.
    ---set rate--0xff:0x0fff
    25 mcs: 255 rate:0xfff
    vif[0],event[27]
    wpa state:ASSOC->ASSOCIATED.
    wpa state:ASSOCIATED->HANDSHAKE.
    vif[0],event[27]
    vif[0],event[27]
    wpa state:HANDSHAKE->HANDSHAKE.
    wpa state:HANDSHAKE->GROUP_HANDSHAKE.
    wpa state:GROUP_HANDSHAKE->COMPLETED.
    vif[0],event[27]
    vif[0],event[27]
    vif[0],event[4]
    dhcpc start ok!
    Info:MAIN:Time 6, idle 0/s, free 78880, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 7, idle 0/s, free 78880, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 8, idle 0/s, free 78880, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 9, idle 0/s, free 78880, MQTT 0(0), bWifi 0, secondsWithNoPing -1, socks 2/12
    vif[0],event[8]
    sta ip: 192.168.1.143, mask: 255.255.255.0, gw: 192.168.1.1
    +--------------- net device info ------------+
    |netif type    : STA                         |
    Info:MAIN:Time 10, idle 0/s, free 78880, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/12
    |netif ip      = 192.168.1.143               |
    |netif mask    = 255.255.255.0               |
    |netif gateway = 192.168.1.1                 |
    |netif mac     : [00:91:19:10:22:21]         |
    Info:MAIN:Time 11, idle 0/s, free 78880, MQTT 0(0), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 12, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 13, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 14, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 15, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 16, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 17, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 18, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 19, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    |netif type    : STA                         |
    Info:MAIN:Time 20, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 21, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 22, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 23, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 24, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 25, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 26, idle 0/s, free 76264, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 27, idle 0/s, free 76016, MQTT 0(1), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 28, idle 0/s, free 58392, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 3/12
    Info:MAIN:Time 29, idle 0/s, free 58608, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 3/12
    |netif type    : STA                         |
    Info:MAIN:Time 30, idle 0/s, free 67192, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 31, idle 0/s, free 63848, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 3/12
    Info:MAIN:Time 32, idle 0/s, free 55368, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 3/12
    Info:MQTT:Channel has changed! Publishing 1 to channel 1
    Info:MAIN:Time 33, idle 0/s, free 49544, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 3/12
    Info:MQTT:Channel has changed! Publishing 0 to channel 1
    Info:MAIN:Time 34, idle 0/s, free 59048, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 35, idle 0/s, free 75456, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 36, idle 0/s, free 74704, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 37, idle 0/s, free 74920, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 38, idle 0/s, free 75792, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 39, idle 0/s, free 75792, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    |netif type    : STA                         |
    Info:MAIN:Time 40, idle 0/s, free 75792, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 41, idle 0/s, free 75664, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:GEN:2 Button_OnInitialPressDown
    Info:GEN:2 key_short_press
    Info:MAIN:Time 42, idle 0/s, free 75792, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 43, idle 0/s, free 75792, MQTT 0(2), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 44, idle 0/s, free 75576, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 45, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 46, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 47, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 48, idle 0/s, free 67304, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 49, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    |netif type    : STA                         |
    Info:MAIN:Time 50, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 51, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 52, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 53, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 54, idle 0/s, free 76008, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 55, idle 0/s, free 75792, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 56, idle 0/s, free 76008, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 57, idle 0/s, free 76008, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 58, idle 0/s, free 76008, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 59, idle 0/s, free 76008, MQTT 0(3), bWifi 1, secondsWithNoPing -1, socks 2/12
    |netif type    : STA                         |
    Info:MAIN:Time 60, idle 0/s, free 76008, MQTT 0(4), bWifi 1, secondsWithNoPing -1|netif mask    = 255.255.255.0               |
    , socks 2/12
    [0]standalone:Info:MAIN:Time 61, idle 0/s, free 75872, MQTT 0(4), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 62, idle 0/s, free 75872, MQTT 0(4), bWifi 1, secondsWithNoPing -1, socks 2/12
    Info:MAIN:Time 63, idle 0/s, free 75872, MQTT 0(4), bWifi 1, secondsWithNoPing -1, socks 2/12
    k
    sys_task not initialized yet
    [4]standalone:Info:MQTT:mqtt_host empty, not starting mqtt
    Info:MAIN:Time 92, idle 0/s, free 74776, MQTT 0(6), bWifi 1, secondsWithNoPing 23, socks 2/12
    Info:MAIN:Time 93, idle 0/s, free 74920, MQTT 0(6), bWifi 1, secondsWithNoPing 24, socks 2/12
    Info:MAIN:Time 94, idle 0/s, free 74560, MQTT 0(6), bWifi 1, secondsWithNoPing 25, socks 2/12
    Info:MAIN:Time 95, idle 0/s, free 74776, MQTT 0(6), bWifi 1, secondsWithNoPing 26, socks 2/12
    Info:MAIN:Time 96, idle 0/s, free 74424, MQTT 0(6), bWifi 1, secondsWithNoPing 27, socks 2/12
    Info:MAIN:Time 97, idle 0/s, free 72640, MQTT 0(6), bWifi 1, secondsWithNoPing 28, socks 3/12
    Info:MAIN:Time 98, idle 0/s, free 74784, MQTT 0(6), bWifi 1, secondsWithNoPing 29, socks 2/12
    Info:MAIN:Time 99, idle 0/s, free 74424, MQTT 0(6), bWifi 1, secondsWithNoPing 30, socks 2/12
    |netif type    : STA                         |
    Info:MAIN:Time 100, idle 0/s, free 74784, MQTT 0(6), bWifi 1, secondsWithNoPing 31, socks 2/12
    Info:MAIN:Time 101, idle 0/s, free 74440, MQTT 0(6), bWifi 1, secondsWithNoPing 32, socks 2/12
    Info:MAIN:Time 102, idle 0/s, free 74784, MQTT 0(6), bWifi 1, secondsWithNoPing 33, socks 2/12
    Info:MAIN:Time 103, idle 0/s, free 74440, MQTT 0(6), bWifi 1, secondsWithNoPing 34, socks 2/12
    Info:MAIN:Time 104, idle 0/s, free 74784, MQTT 0(6), bWifi 1, secondsWithNoPing 35, socks 2/12
    Info:MAIN:Time 105, idle 0/s, free 74440, MQTT 0(6), bWifi 1, secondsWithNoPing 36, socks 2/12
    Info:MAIN:Time 106, idle 0/s, free 74784, MQTT 0(6), bWifi 1, secondsWithNoPing 37, socks 2/12
    Info:MAIN:Time 107, idle 0/s, free 74440, MQTT 0(6), bWifi 1, secondsWithNoPing 38, socks 2/12
    Info:MAIN:Time 108, idle 0/s, free 74784, MQTT 0(7), bWifi 1, secondsWithNoPing 39, socks 2/12
    Info:MAIN:Time 109, idle 0/s, free 74568, MQTT 0(7), bWifi 1, secondsWithNoPing 40, socks 2/12
    |netif type    : STA                         |
    Info:MAIN:Time 110, idle 0/s, free 74440, MQTT 0(7), bWifi 1, secondsWithNoPing 41, socks 2/12
    Info:MAIN:Time 111, idle 0/s, free 74784, MQTT 0(7), bWifi 1, secondsWithNoPing 42, socks 2/12
    Info:MAIN:Time 112, idle 0/s, free 75872, MQTT 0(7), bWifi 1, secondsWithNoPing 43, socks 2/12
    Info:MAIN:Time 113, idle 0/s, free 74776, MQTT 0(7), bWifi 1, secondsWithNoPing 44, socks 2/12
    And the template for the device:
    Note that, with the present version of OBK at the time of writting, GPIO13, which commands the relay, doesn't work!
    The modification at this pull request is needed.
    (already merged)
  • Requesting pinout and flashing info for XY-WE2S-A V1.1
    #16 21405622
    micbanand
    XY-WE2S-A V1.1
    it was me who send you 2 of them :)
    is there a solution for it know.
    Gues I have to read upon this new thread
  • #17 21405697
    Do you have more to have a go dumping from?
  • #18 21406067
    micbanand
    >>21405697 what do you mean?
    I bought 12 of them. and replaced the modules with esp02
  • #19 21406068
    oh wow ok. 12. loads to play with!
  • Flashing full backup requires boot_nocrc.bin first
    #20 21407688
    also worth mentioning that although I said about splitting the file here you can flash the whole backup from 0 as long as you also choose boot_nocrc.bin from 0 first
    Screenshot of a flash management program with visible file paths and port settings.
    with just the 1mb backup specified it'll fail with
  • #21 21416923
    morgan_flint
    Rate: 62
    Yes, I can confirm that, that's the way I flashed my backup (provisionally) to the device after having tested the module with OBK
  • #22 21419873
    morgan_flint
    Rate: 62
    I finally have the module mounted back in the device and working with OBK.
    I'll edit my previous post to add info of the final configuration and OBK logs
    Many thanks to @divadiow for his help (long conversation via PM), and to @insmod for pointing the modification in the code to get working the GPIO13 (that commands the relay).
  • #23 21419915
    Good job, what is the state on the GPIO13 fix? I assume it should be merged to the main tree now? Can you point which PR is that?
  • Questioning why GPIO 16–17 are disabled in SDK
    #24 21419919
    https://github.com/openshwprojects/OpenBK7231T_App/pull/1526
    what does this mean for..
    why are they not enabled? why those 3 disabled in SDK?
    Added after 15 [minutes]:
    something specific for the LSC6260 module perhaps (SDK came from Skylab and was in LSC6260 folder) or what was developed for it. Maybe they should be enabled for general TR6260 use?
    >>21327639
    Very good job @insmod ! I need to get/find my TR fast, hopefully it didn't drown when my basement got flooded...
    did it die in the flood?
  • GPIO16/17 lack normal GPIO initialization
    #25 21419965
    Help: 164
    Rate: 445
    >>21419919
    16/17 can't be used as gpio at all.
    https://github.com/NonPIayerCharacter/OpenTR6...ee5218c21a598b9470194/drivers/hal_gpio.c#L123
    And there is no code to initialize them as gpio.
    Cursory glance reveals that gpio13/gpio17 are used for sleep/wake?
    And all pins, including 16/17 can be used in gpio_power_area_config, though i have no idea what that is.
    https://github.com/NonPIayerCharacter/OpenTR6...ee5218c21a598b9470194/drivers/hal_gpio.c#L615
    But, there are separate functions for them, gpio16_write, gpio17_write and gpio17_read. No gpio16_read.
  • Weak WiFi RSSI after flashing OBK firmware
    #26 21421792
    morgan_flint
    Rate: 62
    I saw the PR is now merged, so I flashed the last official version and everything went well:
    Screenshot of OpenTR6260 interface displaying device information.
    I also configured MQTT to test it from Home Assistant, with good results:
    Screenshot of a user interface displaying information about the TR6260 device.
    I understand that the temperature is "unknown" because the sensor must be missing in this chip. If I remember well, it appeared before on the main OBK page but has already been removed. Shouldn't it be removed from MQTT as well?
    Another question: Although the device is in the same room as my router, the WiFi signal appears to be very low. This doesn't happen with my other OBK devices. Could it be because of some kind of RF configuration (similar to that in Belken chips) that could have been lost in the flashing process? In this case: Could it be recovered from the initial backup?
    EDIT: Just seen I hadn't really flashed the latest official release, as the screenshot still showed the merged one. I flashed OBK again (previous screenshot updated) after first flashing the original FW (full 1MB backup), to check if that corrected the WiFi signal strength issue, with no luck, as it continues to be weak (-71dBm) at 1.5 meters from the router. With the original FW, the RSSI in the same exact location was -56 - -57 dBm:
    Screenshot displaying device information, including ID, IP address, MAC, time zone, and WiFi signal strength. Screenshot of an app displaying WiFi signal strength, IP address, and MAC address.
    Has anybody else noticed this weakening of the signal strength?
  • Questions about PowerSave 1 and WiFi RSSI on TR6260
    #27 21426466
    morgan_flint
    Rate: 62
    @p.kaczmarek2 and/or @insmod, some more questions about OpenTR6260: I've seen here that PowerSave 1 is advisable in these "Smart switches" to avoid overloading the power supply. Is it also the case for those with TR6260?
    Also, regarding the issue with WiFi RSSI mentioned before, is there an explanation for that? Is that important? I mean, could it simply be a problem in the reported data, being WiFi connection still as good as with the original FW?
    Thank you very much in advance!
    EDIT: Sorry, this answers my first question:
    Screenshot of the OpenTR6260 interface indicating that PowerSave is not implemented.
  • #30 21620017
    should this be a PR and merged?
    Master branch is 1 commit behind NonPlayerCharacter/OpenTR6260:master
✨ The discussion focuses on flashing and reverse-engineering TR6260-based Tuya smart modules with open-source firmware such as OpenBK/OpenTR6260, including pinout discovery, boot mode entry, flash dumping, and restoring backups. Contributors share observations on TR6260 and related ESWIN/ECR6600 modules, identify flashing UART pins, confirm that full 1 MB backups can be flashed when paired with the correct boot_nocrc image, and note that some RF/Wi‑Fi configuration or GPIO behavior may differ after flashing. The thread also covers enabling SSDP/Wemo/Home Assistant discovery, MQTT integration, GPIO13 relay control fixes, power-save behavior, and OTA package generation using custom Python tools and modified ota_tool workflows. Later posts add partition files, firmware dumps, module photos, and notes on TR6260 SDK versions, OTA diff formats, and compatibility across releases.
TL;DR: TR6260 flashing works locally with OpenBeken: the chip has 1 MB flash, and one contributor confirmed, "TR6260 can now be flashed via UART" using UTP, boot_nocrc.bin, a partition file at 0x6000, and OpenTR6260 at 0x7000. This FAQ is for repairers and Home Assistant users who need the real boot procedure, pinout, backup method, and OTA caveats. [#21351236]
Why it matters: This thread turns TR6260 from a poorly documented Tuya module into a repeatable, cloud-free platform for local automation.
Topic TR6260 / TR6260S1 ECR6600 / AXY family
Main flashing path discussed UTP over UART with boot_nocrc.bin SDK mentioned, but no equivalent flashing guide completed
Confirmed OpenBeken work Yes, with OpenTR6260 builds Related SDK mentions exist, but support is less mature in-thread
Typical modules named HLK-M20, XY-WE2S-A V1.1 AXY3L, AXY2S, WG236
OTA discussion depth Extensive, including FotaPKG v1/v3 and diff tooling Mostly tooling comparison and SDK relation
Key insight: The critical step is choosing the right boot strap and file layout. Grounding the correct boot pin before power-on decides whether TR6260 enters normal SPI boot, UART flashing mode, SDIO mode, or an unsupported state. [#21405320]
  • TR6260 is described as a 32-bit, 2.4 GHz Wi‑Fi SoC with 6 PWM, 1 ADC, and 1 MB flash, which sets the practical backup size and OpenBeken image layout. [#21351236]
  • A valid full factory dump is exactly 1,048,576 bytes; the read operation was reported to take about 2–3 minutes in UTP. [#21351236]
  • The proven OpenTR6260 write layout is: boot_nocrc.bin at 0x0000, partition binary at 0x6000, and firmware at 0x7000. [#21351236]
  • On one real XY-WE2S-A module, boot logs were readable at about 58,000–59,000 baud rather than standard 57,600, which helped confirm the selected boot mode. [#21405320]
  • One module showed a reported RSSI drop from about -56/-57 dBm on original firmware to -71 dBm on OpenTR6260 at 1.5 m from the router. [#21421792]
1. How do I flash a TR6260 or TR6260S1 device with OpenBeken using the UTP flash tool and a USB-to-UART adapter?
Use UTP with a 3.3 V USB-to-UART adapter and the TR6260 boot pin grounded at power-on. 1. Solder TX, RX, GND, 3.3 V, and the boot pin connection. 2. Power on with GPIO14/TOUT2 grounded, then load boot_nocrc.bin, the partition file, and OpenTR6260_xxxx.bin into UTP. 3. Flash, remove the boot strap, reboot, join the new AP, and open 192.168.4.1. The thread says TR6260 can be flashed fully locally and paired with Home Assistant without Tuya cloud access. [#21351236]
2. What is the correct boot mode procedure for TR6260, and how do GPIO14/TOUT2, BT0, and BT1 affect spi-flash, UART, SDIO, and unsupported boot modes?
TR6260 enters different boot modes solely from the boot strap pins at startup. On HLK-M20, grounding GPIO14/TOUT2 before power-on was used for the documented flashing workflow. On XY-WE2S-A, BT0 low gave UART boot, both pins floating gave SPI-flash boot, BT1 low gave SDIO boot, and BT0+BT1 low produced unsupported boot mode with bootrom startup err. The same post also notes readable boot logs around 59,000 baud when checking these states. [#21405320]
3. Where can I download the TR6260 UTP flash tool, boot_nocrc.bin, and the partition files needed for OpenTR6260 flashing?
Download them from the FlashTools package linked in the thread. The UTP utility is not esptool, because TR6260 is not an ESP chip. The post points to the TransaSemi-ESWIN FlashTools repository and an alternate TR6260 resource pack, and it states that boot_nocrc.bin comes from the same zip as UTP. That same package also includes the partition binaries used at address 0x6000. [#21351236]
4. Which files and flash addresses should I use in UTP for TR6260 flashing, including boot_nocrc.bin, the partition binary at 0x6000, and the OpenTR6260 firmware at 0x7000?
Use three files in UTP: boot_nocrc.bin at 0x0000, the partition binary at 0x6000, and OpenTR6260_xxxx.bin at 0x7000. The flashing guide originally named new_partition_0x6000.bin, and a later thread update says a new partition filename was added to each FlashTools zip for the same 0x6000 slot. Do not rely on an old extra File_4 entry; the thread later says that advice needs revision. [#21725879]
5. How can I make a full 1MB factory backup dump from a TR6260 before flashing OpenBeken, and how do I verify the dump is valid?
Make the dump in UTP with the device in the documented boot state and set the read length to 0x100000. 1. Ground GPIO14/TOUT2 before power-on. 2. In UTP, select boot_nocrc.bin, choose a PC save path, and read the full flash. 3. Verify that the resulting file is exactly 1,048,576 bytes. The guide states the flash is 1 MB, and the read may appear stalled for 2–3 minutes before finishing. [#21351236]
6. Why does restoring a full TR6260 backup fail unless boot_nocrc.bin is also selected first at address 0x0000 in UTP?
It fails because UTP first needs the RAM-loaded boot helper before it can write the rest of the image. A later confirmation showed you can restore the whole 1 MB backup from 0x0000, but only if boot_nocrc.bin is also selected first at 0x0000. With only the backup file chosen, UTP returned RAM Download uboot file fail;. That error explains why whole-image restores looked broken until the boot file was added back into the list. [#21407688]
7. What is the real pinout of the XY-WE2S-A V1.1 TR6260S1 module, and why does it differ from the published TR6260 and TR6260S1 datasheets?
The real XY-WE2S-A V1.1 pinout was traced from the PCB and does not match the published datasheets. The mapped functions were TX0=UART0_TXD, RX0=UART0_RXD, BT1=TOUT3, BT0=TOUT2, PWM2=GPIO22, PWM1=GPIO4, PWM0=GPIO13, CEN=RESETB, PWM5=GPIO0, PWM4=GPIO1, ITX=GPIO3, and IRX=GPIO2. The author explicitly says the chip pinout on real modules conflicts with both the TR6260 and TR6260S1 documents, and even with earlier forum images. [#21405320]
8. Can someone find a TR6260S1 datasheet that matches the real pinout seen on HLK-M20 and XY-WE2S-A modules?
No matching TR6260S1 datasheet was found in the thread. One contributor explicitly said they tried and failed to find a datasheet consistent with the traced “real” pinout. Another earlier note says HLK-M20 showed the same mismatch problem. So the practical guidance in this thread is to trust traced module pads and boot logs over the published TR6260 pin tables when flashing real hardware. [#21405320]
9. What is SSDP in OpenBeken on TR6260, and why did enabling multicast in LWIP fix SSDP and Wemo discovery?
"SSDP is a network discovery protocol that advertises devices over multicast, enabling local services such as Wemo and Alexa discovery on the LAN." On TR6260, SSDP initially failed because setsockopt IP_ADD_MEMBERSHIP failed, which means multicast join did not work. After enabling multicast in LWIP, the log changed to Socket created, waiting for packets, and Wemo discovery succeeded, including Alexa finding the device. The thread links that fix directly to the multicast setting change. [#21367101]
10. What is the FotaPKG v1 versus v3 OTA format on TR6260, and how does ota_tool choose between the different TR6260 and ECR6600 packaging methods?
TR6260 uses two discussed diff OTA containers: FotaPKG 0x01 as “v1” and FotaPKG 0x03 as “v3”. A reverse-engineered summary in the thread says ota_tool detects the board from the target firmware header, then maps diff to method 3 by default. That makes TR6260 use sw_pack_file_trdiff_package_new() and emit FotaPKG v3. Patching one byte changed diff to method 1, forcing the older TR6260 v1 path instead. ECR6600 uses different packers for AB, CMZ, and diff modes. [#21842600]
11. TR6260 vs ECR6600/AXY modules: what are the differences in SDK support, module availability, and firmware tooling discussed in the thread?
TR6260 had a working OpenBeken flashing path in-thread, while ECR6600 discussion stayed closer to SDKs and module sourcing. The thread names ECR6600-based AXY modules such as AXY3L and AXY2S and mentions Skylab WG236 hardware. It also says an SDK readme mentioned TR6260 support, but that support seemed removed later. Price comments show ECR6600 modules were harder to justify, with examples around $14.5 + ~$8 shipping, $18 + $10 shipping, and $26 shipped. [#21358543]
12. Why does Wi-Fi RSSI look much weaker on OpenTR6260 than on the original Tuya firmware, even when the device is close to the router?
The thread reports the issue, but it does not give a confirmed root cause. One tested switch showed about -71 dBm on OpenTR6260 versus -56 to -57 dBm on original firmware at only 1.5 meters from the router. Reflashing the original full 1 MB backup and then OpenTR6260 again did not fix the lower reported RSSI. The open question was whether RF calibration data, measurement reporting, or another firmware setting caused the difference. [#21421792]
13. How do I configure DHT11, BME280/BMP280, DS18B20, or SHT3X sensors on OpenTR6260, and what should I check if a driver is missing from the build?
DHT11 and BME280/BMP280 were shown working, while DS18B20 was noted as unchanged and SHT3X prompted build-option discussion. For BME280/BMP280, the thread gives startdriver bmpi2c 0 1 2 3 4 in autoexec.bat. If a sensor driver is missing, check whether it is enabled in obk_config.h; that was stated directly for BMPI2C. A later post also asks why SHT3X was not exposed as ENABLE_DRIVER_SHT3X, linking it to a pull request. [#21367101]
14. What's going on with GPIO13, GPIO16, and GPIO17 on TR6260, including the relay fix PR and the SDK limitation that says some pins cannot be used as normal GPIO?
GPIO13 needed a relay-output fix, and that pull request was later merged, after which the affected switch worked correctly on official builds. GPIO16 and GPIO17 are different: the SDK code says they cannot be used as normal GPIO, and one contributor confirmed there is no general initialization path for them. The thread also notes special functions exist such as gpio16_write, gpio17_write, and gpio17_read, which suggests limited, nonstandard handling rather than full GPIO support. [#21419965]
15. How can I build and apply OTA updates for TR6260 with Python or ota_tool, and why do some OTA patches fail around 81% or produce an unbootable device?
You can build TR6260 OTA diffs with either patched ota_tool or later Python builders, but large version jumps remained fragile. One contributor reported successful Python-generated packages as small as 40,544 bytes, while another saw failures around 81% during updates such as 1.18.80 -> 1.18.261. The thread also records cases where a generated patch passed self-check yet left the device unbootable. The likely cause is package-format or compression edge cases, since the original tool produced a working patch only 2,464 bytes lighter than the failing Python one. [#21844134]
