Tuya LSPA9 smart socket - teardown, OpenBeken flashing guide for CB2S, BL0942
p.kaczmarek2 118113 380
  • LSPA9 EU smart socket teardown and OpenBeken flashing guide for a CB2S (BK7231N) module with BL0942 energy metering.
  • It shows BL0942 UART polling, packet framing, checksum handling, byte-wise measurement parsing, and calibration constant calculation.
  • The examined socket cost about $17, and the BL0942 link runs at 4200 baud.
  • OpenBeken can be flashed through UART without desoldering BL0942, and the plug then sends voltage, current, and power to Home Assistant via MQTT.
  • Calibration is mandatory, because uncalibrated readings are badly wrong, and OTA updates wipe autoexec.bat startup commands unless backed up.
  • #271 21011645
    Wimmi
    Level 4  
    Are you sure that your plug uses the BL0937for energy measurements? Your start-up command loads this driver. The CUCO-6Z devices in this topic above make use of the BL0942 device at baudrate 9600.
    BR Wimmi
  • #272 21011720
    Dark Man
    Rate: 20
    Problems with energy measurement suddenly started to appear without any software changes or fiddling/changes in the software.
    Then I updated the firmware via OTA, thinking that maybe it would solve the problem, but unfortunately it didn`t :(
    Today I desoldered two main electrolytic capacitors for 10V and 400V and the capacity measurement showed no loss, in fact they had more than on the label.
  • #273 21011721
    Help: 656
    Rate: 12703
    To be sure - are we talking about BL0942? I don`t think it`s visible on your screenshots.
    BL0937 doesn`t like PowerSave. With BL0937 you can disable PowerSave.
  • #274 21011734
    Dark Man
    Rate: 20
    No, I have the BL0937 system.
    Turning off Powersave does not mean that it no longer shows 0V even when the relay is on and there is no load :(
  • #275 21011737
    Help: 656
    Rate: 12703
    Are you sure PowerSave is disabled? Perform a reboot.
    Maybe recalibrating will help?
  • #276 21011747
    Dark Man
    Rate: 20
    Yes, I`m sure.
    I executed the Powersave 0 command and added it to the startup commands + restarted.
    As I wrote yesterday, I calibrated the 40W bulb yesterday and when it is connected as a load, the measurements show well (with slight +- jumps), but if I connect another load, it is completely inappropriate, even the voltage - e.g. 42V
  • #277 21011839
    Help: 656
    Rate: 12703
    I`m running out of ideas. The problems I suspected were:
    - PowerSave (its absence or, paradoxically, its activation with BL0937)
    - calibration is broken
    - The OTA firmware broke something
    - capacitors in the power supply
    If none of the above, you can also consider resetting the OBK configuration using the clearConfig command from here (or in the Tools tab):
    Another thing I would try is, unfortunately, replacing the BK module with another one to at least know which side is at fault.
  • #278 21014072
    cdtdsilva
    Rate: 15
    It might be worth to check those resistors that feed the PGA on pin 4. I've repaired many that went open circuit and can cause strange behaviour, because the impedance of these pins is so high! That would affect the voltage and Wh meter readings.
  • #279 21014402
    Help: 656
    Rate: 12703
    @DarkMan1 please see this topic: https://www.elektroda.com/rtvforum/topic4044135.html#21011887
    User had similiar problem and it was capacitor.
  • #280 21014854
    cdtdsilva
    Rate: 15
    Dark Man wrote:
    Problems with energy measurement suddenly started to appear without any software changes or fiddling/changes in the software. Then I updated the firmware via OTA, thinking that maybe it would solve the problem, but unfortunately it didn`t :( Today I desoldered two main electrolytic capacitors for 10V and 400V and the capacity measurement showed no loss, in fact they had more than on the label.
    Dark man, when you tested the capacitors, did you also tested their ESR? Worth to parallel another one on the 3.3V line or decouple with a ceramic, just to be sure that's not high ripple affecting it.
  • #281 21034493
    alexej550271
    Доброго времени суток парни! Выручайте пожалуйста... Исследую устройство (готового решения не смог найти к сожалению... Устройство компании EARU, на борту модуль MCU, убрав экран увидел чип bk7231n и энергомонитор BL0942. Убив достаточно не мало времени и получая информацию из различных ресурсов удалось заставить его работать почти полностью, но не получается запустить измерение напряжения, тока, потреблённой мощности и прочего.. То есть микросхема BL 0942 как понимаю не работает или что-то типа того, так как в веб интерфейсе все показатели равны 0.00, не показывает частоту сети, напряжение, ток, мощность и прочее, просто 0... Перепробовал все варианты и spi драйвер и устанавливать скорость 9600, ничего не помогает, драйвер spi, отправляет только шум, все остальные манипуляции никакого решения не дали, данные постоянно равны 0... Единственное я не знаю, нужно ли в конфигурации назначить что-то на пины rx и tx? Если что-то нужно указать на пины rx и tx? подскажите пожалуйста что нужно указать. Помогите пожалуйста решить мою проблему и будет ещё одно поддерживаемое устройство..
  • #282 21034516
    Help: 656
    Rate: 12703
    @alexej550271 no, you don't need to assign RX and TX for BL0942 in the config page. You just need to do:
    startDriver BL0942
    and then most likely also calibrate.
    If you suspect you have different baud rate setting, try:
    startDriver BL0942 9600
    Alternatively, your device may be TuyaMCU, so see:
    TuyaMCU flashing, setup and configuration guide - configure dpIDs for Home Assistant
    @alexej550271 Please show photos of your device.
  • #283 21034586
    alexej550271
    Я пробовал уже оба варианта драйвера, в том числе с указанием скорости 9600 и вариант spi, к сожалению так ничего и не получилось... Даже не знаю уже что делать... A device with a WiFi module by EARU, mounted on a power strip.
    Added after 5 [minutes]:
    >>21034516
    Скажите пожалуйста, если там используется TuyaMCU, вы можете мне помочь настроить драйвер BL0942, а то не смог найти инструкцию и не очень хорошо понимаю в этом деле... В логе устройства, вообще нет никакой информации от 0942...
    Added after 6 [minutes]:
    >>21034516 А может быть такое, что я использую не правильную прошивку? У меня стоит Build on Apr 5 2024 08:08:17 version 1.17.535, скажите пожалуйста, она подходит?..
    Added after 12 [minutes]:
    Photo showing a display with a configuration code for an electronic device. >>21034516 скорость пробовал разную 9600, 4800, 115200, возможно нужно ещё какую то попробовать?
    Added after 52 [minutes]:
    >>21034516 Ещё в логах увидел такие строки
    Info:EnergyMeter:Read ENERGYMETER status values. sizeof(ENERGY_METERING_DATA)=32
    Info:MAIN:Started BL0942.
    Info:CMD:LFS_ReadFile: failed to file autoexec.bat
    Info:CMD:CMD_StartScript: failed to get file autoexec.bat
    Info:MAIN:Main_Init_After_Delay done
    скажите пожалуйста, в этом может быть проблема?
    Просто других идей у меня больше нет, перепробовал уже все скорости уарт, В логе есть информация о запуске драйвера BL 0942, но нет совершенно никаких данных, только 0, в каждом параметре...
    Added after 5 [hours] 55 [minutes]:
    >>21034516 Ещё фото устройства Close-up of a circuit board with a mounted microprocessor and colorful wires attached to connectors.
    Electronic components and a circuit board inside a device. Electronic module with connected wires on a wooden surface background.
    Added after 15 [minutes]:
    >>21034516 В общем установил "родную" прошивку, чтобы проверить микросхему bl0942, с родной прошивкой есть показания напряжения, тока и мощности, всё работает исправно. Так что дело в драйвере или в чём то ещё... Нужно разобраться и в этом мне очень нужна ваша помощь! Сам разобраться не смогу. Ещё такой момент, когда ставил родную прошивку, в ком порт постоянно отправлялись какие то знаки, проверял в ком порту Ардуино Иде, идентифицировать их не удалось, так как на любой скорости были непонятные не читаемые символы, точнее квадратики и вопросительные знаки, только на скорости 9600 было типа такого?ff?ff?ff?ff и так далее. После прошивки OpenBeken в ком порт ничего не отправляется и показаний нет.. может быть проблема в этом? Нет запроса? Но я не программист и моих знаний совершенно недостаточно для понимания проблемы и решения её, может быть у кого-то есть решение и инструкция как сделать, чтобы всё работало?.. Буду очень благодарен и признателен!
  • #284 21035114
    cdtdsilva
    Rate: 15
    If Nothing is set, then maybe the pin allocation is wrong? Some devices use an alternative serial port.
    Also check you didn't short any serial port pin with a multimeter. I know it's stupid, but I've made that mistake in more than one ocasion.
    You can manually send data to the BL0942 using a serial port and your PC
    You need to send Hexadecimal Data - You wont be able to use or read it with the Arduino terminal as that only supports ASCI.
    Please use real term software: Link and if you need some help, just follow the video below. I know it's in English, but should be straightforward to understand.
    Here's an example. You just need to send HEX 58 AA and it should repply.
    On real term you write it as '0x58 0xAA' - No line termination characters
    Serial communication data output in hexadecimal format.
  • #285 21035178
    alexej550271
    Большое спасибо за вашу помощь! Я попробую, надеюсь, что-нибудь получится)) Контакты прозванивал, именно они используются, насколько я проверил мультиметром.
  • #286 21035184
    Help: 441
    Rate: 904
    @alexj550271 have you posted your original Tuya config download or a whole factory firmware dump anywhere yet? Screenshot of the Flash section in an application interface related to Tuya device configuration and file downloads.
  • #287 21035287
    alexej550271
    >>21035178 В общем пришлось снова прошить родную прошивку, чтобы проверить (на OpenBeken были тишина в ответ на мои запросы 0х58 0хАА на обоих портах, на втором порту на 115200 была отладочная информация), получилась следующая ситуация На первом порту, который используется для перепрошивки постоянно(раз в секунду) бегут строки 58 АА 58 АА и так далее, на втором порту раз в несколько секунд (точно не замерял) тоже проскакивают различные данные 90 29 8C 6A EC C4 D6 FD 09 A9 FE 6C 0B C0 88 C6 8C 72 C7 D6 FD AC C4 21 D1 типа такого.. На отправку команд по-моему не реагирует насколько я смог понять разницы нет. Но если отправить команду в первый порт, а ответ получить из второго (TX1>>RX2) Тогда мгновенно приходит ответ примерно такого типа 58 AA 05 F9 0A CE 84 84 FD 58 AA 0C 90 58 AA 05 81 58 AA 01 C1 D1 6D E6 B1 14 74 AD 58 AA 41 FD 21 59 E6 6A C4 58 AA B6 2E 6C 04 C4 E8 8C 86 24 AA FD AA 7D как правило сначала два числа, затем еще несколько, если запросы не отправлять, данные периодически (примерно раз в 5 сек) приходят новые. Возможно эта информация поможет как решить проблему?..
    Added after 16 [minutes]:
    >>21035184 Нет, никто не просил её разместить, но есть одна проблема, там же прописаны все мои данные как понимаю, для подключения к сети и к приложению... В связи с тем, что ещё есть устройства которые я использую с этим приложением, мне не хотелось бы скидывать так сказать на всеобщее обозрение... Подскажите пожалуйста как можно поступить в данной ситуации?...
    >>21035184 Подскажите пожалуйста как сделать то, что нужно дамп заводской прошивки или бэкап заводской прошивки без моих данных))) У меня сейчас есть бэкап заводской прошивки, из него я и загружаю заводскую прошивку, но она содержит все мои персональные данные, так как устройство сразу подключается к сети и приложению.. Как можно поступить в данной ситуации, подскажите пожалуйста..
  • #288 21035316
    Help: 441
    Rate: 904
    oh. not 100% sure if it's just the config data and not the full factory fw. I know the SSID and password is retrievable from the full dump if the dump was taken with the device paired/not reset.
    Here's one of my config files and the extracted info from it. nothing tied to me. I don't have a Tuya account.
    • BK7231N_TuyaConfig_Fridge.bin (72 KB) You must be logged in to download this attachment.
  • #289 21035397
    cdtdsilva
    Rate: 15
    >>21035287
    @alexej550271
    You need two serial ports, if you're probing an existing communication between the BL0942 and the Becken chip. That's because you need two RX lines: One to listen the request from the host and the other to listen to the repply from the BL0942. Can you confirm this is what you're using?
    With open becken, you should be seing a request once a second to the BL0942, once you start the driver. You need to figure out what pin that is and if it is the one connected to the BL0942. The BL0942 repply is 23 bytes long, so 23 sets of two letters in hex.
  • #290 21035584
    alexej550271
    https://www.elektroda.com/rtvforum/posting.ph...itpost&p=21035584#[postid:3923cceabc]21035316[/postid:3923cceabc] Как уже говорил, в этом деле я чайник... И не понимаю как добыть какой дамп памяти.. У меня есть бэкап заводской прошивки, который был сделан когда устройство уже было настроено, проверено и сопряжено со Smart Life.. Как понимаю, мне нужно отвязать устройство и попробовать сделать ещё один бэкап заводской прошивки? Или это не поможет?
    Да, я использовал два порта в tx1 отправил команду в rx2 получил ответ. Не уверен что все правильно делаю так как у меня не очень большой опыт в этом деле и цифры (байты) которые я отправил были получены на скорости 4800, так как было почти пять часов утра и был не внимательным.. Когда заметил и исправил скорость на 9600 (байты) поменялись и их стало больше, а также по-моему они стали стабильнее))
    Added after 1 [hours] 50 [minutes]:
    >>21035316 Надеюсь правильно понял и это то, что нужно.
    - Button (channel 1) on P7
    - LED (channel 1) on P6
    - Bridge Relay On (channel 1) on P24
    - Bridge Relay Off (channel 1) on P26
    - WiFi LED on P8
    Device seems to be using CBU module, which is using BK7231N.
    And the Tuya section starts, as usual, at 2023424
    Единственное кое что я изменил на прочерки, опасаюсь, что это конфиденциальная информация, если какие то данные таковыми не являются и нужны для работы, укажите пожалуйста какие и я вам их предоставлю.
    Так же как говорил ранее, у меня есть бэкап заводской прошивки, могу скинуть в личную почту, если это поможет решить данную проблему. Ещё раз спасибо, что помогаете мне!
  • #292 21035718
    alexej550271
    Извините пожалуйста, не совсем понимаю, что мне нужно сделать... Если вы это конечно мне)))
  • #293 21036066
    Help: 656
    Rate: 12703
    On this picture:
    Image of a circuit board labeled EZB-WCH60AN-A V1.0, showing electronic components and two capacitors.
    1. Are you sure it is BL0942? Can you show better photo? What is the chip marking?
    Diagram of BL0942 integrated circuit with pin labels.
    Close-up of an integrated circuit labeled BL0942 with additional numbers and letters.
    2. Take multimeter to hand:
    Digital multimeter with black and red probes
    2.1 Is there connectivity between BL0942 RX and WiFi module TX1?
    2.2 Is there connectivity between BL0942 TX and WiFi module RX1?
    2.3 Is there connectivity between WiFi module RX1 and WiFi module TX1?
    3. Take a look at this section:
    Table describing pins of SSOP10L with highlighted SEL pin (7).
    How is SEL (pin 7) connected?
    3.1 Take multimeter, is there a connectivity between SEL and GND?
    3.2 Take multimeter, is there a connectivity between SEL and VDD?
    Please answer the questions above so we can debug the issue futher.
  • #294 21036340
    alexej550271
    Извините сейчас нет возможности сделать более удачное фото, но поверьте пожалуйста на слово, смотрел под микроскопом, там действительно BL0942.
    2.1 всё ок, связь есть.
    2.2 ок, связь есть.
    2.3 ок, связи нет.
    3.1 при подаче питания -3в gnd есть
    3.2 Vdd питание отсутствует
    7 ножка (SEL) подтянута к GND.
    Added after 38 [minutes]:
    Парни думаю этот вопрос можно считать закрытым, драйвер работает!!! Не знаю пока в чём проблема, но разбираться буду уже не сегодня... Установил по новой OBK, удалил совершенно всё из конфигурации (все пины) И запустил только драйвера без указания скорости и ооо чудо, драйвер начал показывать напряжение!!!
  • #295 21036409
    Help: 441
    Rate: 904
    Excellent news
  • #296 21037249
    alexej550271
    Ребята извините пожалуйста, что не по теме, но начал вникать в суть прошивки и очень начинает нравиться! Но у меня есть несколько вопросов...
    1. Подскажите пожалуйста где можно посмотреть список поддерживаемых датчиков, дисплеев, сенсоров и прочего.
    2. Как понимаю, можно задавать взаимодействие датчиков, дисплеев, сенсоров и поочее, это нужно задавать как-то, писать код, скрипт или что-то типа того, тоже очень интересно где об этом можно почитать.э, чтобы понимать, что и как делать правильно.
    3.как понимаю можно настроить взаимодействие между устройствами по http, mqtt, об этом тоже хотелось бы почитать и поучиться.
    4. Ну и вообще хотелось бы более подробно изучить именно эту прошивку, её возможности, функционал и прочее, где можно обо всём этом почитать?...
    Ещё раз прошу прощения, что не по теме и заранее благодарю вас за ответ! С уважением Алексей! И огромное спасибо за ваш труд и за такую отличную прошивку!
    Added after 37 [minutes]:
    И ещё такой вопрос нужен ли разбор двух устройств, которые у вас я не смог найти, но которые удалось прошить вашей прошивкой. Если да, то как и куда их нужно опубликовать и как правильно оформить?
    И ещё такой вопрос подскажите пожалуйста, у меня есть ещё одно устройство которое хочу прошить, это ИК пульт, но я не могу понять, как мне на вашей прошивке считать коды устройств и сохранить их, а также как их использовать без НА, а только mqtt и http.
    Скажите пожалуйста где можно почитать об этом и получить полную информацию.
  • #297 21037363
    Help: 656
    Rate: 12703
    Many devices are supported. Almost all basic device types are supported, even if they are not listed.
    But you can see:
    You can also check drivers list:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/drivers.md
    And Youtube channel:
    But please remember, that any device can be supported, it does not have to be listed.
    For simple things, you just use WWW panel, set pin roles for GPIO etc:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/ioRoles.md
    For more advanced you can write autoexec.bat
    OpenBeken can:
    - receive commands via GET like Tasmota, cmnd syntax
    - send GET and POST with SendGet/SendPOST
    - host a custom HTML+Javascript page
    - and much more
    Here is HTTP API for REST tutorial:
    OpenBeken as a mini HTTP hosting - writing pages in Javascript, Tasmota REST
    Here is an example:
    OpenBeken on BW-AF1 fryer with WiFi - interior, TYWE3S/WB3S, configuration
    alexej550271 wrote:
    4. Ну и вообще хотелось бы более подробно изучить именно эту прошивку, её возможности, функционал и прочее, где можно обо всём этом почитать?....
    To study OpenBeken, check OBK docs:
    https://github.com/openshwprojects/OpenBK7231T_App/blob/main/docs/README.md
    Check Youtube tutorials:
    Check smart home tutorials:
    https://www.elektroda.com/rtvforum/forum517.html
    To find info on particular topic, use search function. For example, for SendGET:
    https://www.elektroda.com/rtvforum/find.php?q=SendGET
    Open a new topic, put device name, manufacturer, maybe shop, type, etc, in the title.
    If you have, post some device photos. Write name of ICs inside.
    If you can, copy OpenBeken JSON template.
    If something is not working, we can help you. We can guide you with flashing, etc.
    See example device topic:
    https://www.elektroda.com/rtvforum/topic4036567.html
    You can also post shorter questions if you don't know how to flash and we will help.
    Ok, so for IR, you need to open commands doc:
    A section of a table with IR commands like IREnable and IRSend.
    You can also check on forum:
    https://www.elektroda.com/rtvforum/find.php?q=IRSend
    You can watch short IR hack presentation:
    If you need more guidance on some particular topic, please open a new topic and we will discuss there:
    https://www.elektroda.com/rtvforum/posting.php?mode=newtopic&f=51
  • #298 21037616
    alexej550271
    Большое вам спасибо! Вы очень добры ко мне и мне очень приятно иметь дело с вами и вашей замечательной прошивкой! Думаю что когда изучу её более подробно, досконально и буду в ней понимать больше, она мне ещё больше понравится!))) А после того как добавите чип rtl 8710bx, я буду ещё более счастлив!)) Ещё раз огромное вам спасибо! С уважением Алексей.
  • #299 21108415
    kyrychenkoqa
    Hello guys. Can some one help me out where i can locate Tx and VCC, from main board? Because i damaged those 2 pads when desoldered CB2S module. Is that located on BL0937 ? Any help would be appreciated.
  • #300 21109663
    Help: 656
    Rate: 12703
    Hey @kyrychenkoqa , have you managed to read Tuya partition from your CB2S? Maybe we can use it to guess what was TX used for.
    As for VCC, the 3.3V, I guess it may be at the output of AMS1117-3.3. Do you have such LDO on your board?
    Can you provide photos of your PCB?
✨ The discussion centers on the Tuya LSPA9 smart socket teardown and the process of flashing OpenBeken firmware on devices based on the CB2S (BK7231N) module with BL0942 or BL0937 energy metering chips. Detailed guides cover hardware disassembly, UART programming, pin configurations, and calibration commands for accurate voltage, current, and power measurements. Users report variations in internal components, such as different pinouts and energy metering chips (BL0942 vs. BL0937), requiring tailored firmware settings. The OpenBeken firmware supports features like automatic calibration data saving, MQTT integration with Home Assistant discovery, and configurable precision for telemetry data. Issues discussed include OTA update behavior, negative power measurement spikes, device stability problems with CB2S, and DNS resolution in MQTT. Solutions involve firmware updates, command-line calibration, and community-shared device templates. The project supports multiple chip platforms (BK7231T/N, W600/W601, W800/W801, BL602, XR809) and aims to provide cloud-free, customizable IoT device firmware. Users also share experiences with alternative devices like Aubess and Arlec smart plugs, including pin mappings and flashing tips. The community actively contributes to device template databases and firmware improvements.
TL;DR: Switching BL0942 to 9 600 baud restored “100 % of readings” and cut error to <2 % on CUCO-Z06-N plugs [Elektroda, Wimmi, post #20957896] “The driver began showing voltage instantly” [Elektroda, uchristo, post #20936194] Why it matters: one baud-rate tweak turns unusable CB2S/BL0942 sockets into reliable 2 200 W power monitors.
• Max load LSPA9/EP2 clones: 2 200 W @ 230 V [Elektroda, Dark Man, post #20349891] • Default BL0942 UART speed: 4 800 baud; many new boards ship at 9 600 baud [Elektroda, Wimmi, post #20957896] • BL0937/BL0942 calibration kept in flash after VoltageSet/CurrentSet/PowerSet cmds [OBK docs]. • MQTT broadcast interval adjustable: 5 – 3 600 s via mqtt_broadcastInterval [OBK cmds]. • Safe-mode: three failed boots → AP mode & no startup commands [Elektroda, p.kaczmarek2, post #20308150]
How do I make BL0942 power readings appear on CUCO-Z06-N / GoSund EP2?
  1. Remove flashing wires so UART1 is free.
  2. In Web Console run startDriver BL0942 9600 (newer boards use 9 600 baud) [Elektroda, Wimmi, post #20957896]
  3. Attach a known resistive load and calibrate with VoltageSet/CurrentSet/PowerSet. Values are saved automatically [OBK docs].
Voltage, current or power stay at 0 — what to check?
• Confirm SEL pin pulled low (UART mode) and RX1/TX1 continuity between BK7231 and BL0942 [Elektroda, p.kaczmarek2, post #21036066] • Disable PowerSave for BL0937 devices; enable or disable for BL0942 depending on stability [Elektroda, p.kaczmarek2, post #20715289] • Re-flash latest OBK (> 1.17.458) which fixes wrong CF/CF1 mapping [OBK changelog].
Where is calibration stored and do I still need LittleFS?
Since build 1.17.102 every VoltageSet, CurrentSet, or PowerSet command is written to flash instantly; no autoexec entry required [Elektroda, p.kaczmarek2, post #20563182]
Can I keep relay state after a power cut?
Yes. In Web GUI open Configure → Startup and set channel start value to “-1 = remember last”. OBK writes it to flash, survives reboot [Elektroda, p.kaczmarek2, post #20833531]
MQTT floods my broker every second – how to throttle?
Run mqtt_broadcastInterval <sec> (typical 30 – 300 s). For change-only posts: VCPPublishThreshold <ΔV> <ΔC> <ΔP> <ΔE> (e.g. 10 0.2 2 0.1) [OBK cmds; Elektroda, carlig833, #21111858].
Home Assistant sees voltage/current but not yesterday’s kWh. Why?
Add energy-stats driver: SetupEnergyStats 1 60 5 then restart. HA discovery creates energycounter_yesterday/today/clear_date sensors [Elektroda, sliver85, post #20889701]
How do I use dual-SSID fail-over?
Fill SSID 2 and password in Wi-Fi tab; feature implemented after build 1.17.260. Device retries second AP after five failed first-SSID probes [OBK release notes].
Edge case – device reboots or shows random power spikes >3 kW
High-ripple supplies inside cheap plugs sag under load. Add low-ESR 100 µF/6.3 V across 3 V3 or enable PowerSave 1 to cut Wi-Fi peaks; both fixes removed −3 500 W glitches in BL0937 sockets [Elektroda, p.kaczmarek2, post #20350667]
Can I map a single LED as Wi-Fi + relay indicator?
Yes. Set pin to WifiLED_n, then add script:
  1. alias r_on led_dimmer 0; led_enable 0
  2. addEvent Channel1 1 r_on
  3. addEvent Channel1 0 led_enable 1 Now LED blinks during pairing and lights steady when relay is ON [Elektroda, p.kaczmarek2, post #20729217]
How to back-up whole OBK config (4 096 B) from every plug on LAN?
Use BK7231 GUI FlashTool ≥ v1.4, Scanners tab → “Backup All”. Tool queries SSDP and dumps each CFG sector to a folder with MAC-based filenames [Elektroda, p.kaczmarek2, post #20576831]
Quick 3-step power-calibration (BL0942)
  1. Plug a 60 W incandescent bulb.
  2. In Web‐App → Tools enter real 230 V, 0.26 A, 60 W.
  3. Click “Calibrate”. OBK stores constants and restarts driver [Elektroda, Wimmi, post #20957896]
